RE: [U-Boot-Users] JFFS2 File System Problem for ST MICRO ELECTRONICS FLASH
Thanks a ton. I am asking bit more but if u have Exact idea where to make the necessary changes it would be a great help.
Regards Vikrant -----Original Message----- From: Rune Torgersen [mailto:runet@innovsys.com] Sent: Thursday, April 21, 2005 7:20 PM To: Vikrant_Basotra Subject: RE: [U-Boot-Users] JFFS2 File System Problem for ST MICRO ELECTRONICS FLASH
Your flash is stuck in command mode....
From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users-admin@lists.sourceforge.net] On Behalf Of Vikrant_Basotra Sent: Thursday, April 21, 2005 06:04
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060000: 0x0020 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060004: 0x22df instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0006000c: 0x0008 instead
DISCLAIMER: This email (including any attachments) is intended for the sole use of the intended recipient/s and may contain material that is CONFIDENTIAL AND PRIVATE COMPANY INFORMATION. Any review or reliance by others or copying or distribution or forwarding of any or all of the contents in this message is STRICTLY PROHIBITED. If you are not the intended recipient, please contact the sender by email and delete all copies; your cooperation in this regard is appreciated.
Vikrant_Basotra
