[U-Boot] mystery boot code in MPC8247-based device
I am working on a MPC8247-based device that is not booting. I can see that the CPU is properly powered and gets out of reset, but that the software watchdog is timing out every ~1.3 sec and sending the device back into reset again.
The board has a 1Mbit flash EEPROM used for booting, and a larger 32Mbit NAND device that contains the full OS and firmware. I can see that the boot ROM is being accessed, and that the flash is never accessed. Also, the serial port on the board never has any output.
I managed to dump the boot EEPROM using JTAG boundary scan, and so have been poking around inside to see if it has any obvious corruption.
The boot code is indeed based on U-Boot, and inspecting the first few instructions I can see that the reset vector routine (located at 0x100) is pretty much an exact match with the mpc8260/start.S from the U-Boot tree. There is one major exception though - there are 6 dwords, starting from 0x100, that are not found in U-Boot (The U-Boot start.S code actually begins at 0x118). The first dword does not appear to actually be an instruction. See below:
(omitting HRCW)
// what is this first part??? 100: 04 a0 00 01 .long 0x4a00001 104: 60 00 00 00 nop 108: 48 00 00 10 b 0x118 10c: 00 00 00 00 .long 0x0 110: 3a a0 00 02 li r21,2 114: 48 00 00 04 b 0x118
// below matches _start: in mpc8260/start.S
118: 7c a0 00 a6 mfmsr r5 11c: 3c 60 f0 00 lis r3,-4096 // r3 <- 0xf0000000 120: 60 63 00 00 ori r3,r3,0 124: 3c 80 0f 01 lis r4,3841 // r4 <- 0x0f010000 128: 90 64 01 a8 stw r3,424(r4) // MEM(0x0f0101a8) <- 0xf0000000 (load new IMMR base addr)
.... and so on.
(compare to http://git.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git;a=blob;f=arch/powerpc/cpu..., line 137)
Does anybody have any thoughts on what the first "instruction" 0x04a00001 would cause the CPU to do when it is sent to 0x100 on reset? I'm not much of a PPC expert, but that doesn't seem to correspond to a legal instruction.
Seems like it was probably put there for a reason, but I'd be interested to know how its supposed to work.
Thanks, Ben
Ben Gelb
