[U-Boot] CFI flash broken for 8-bit bus
I am running into issues in that the CFI code is broken for flash with an 8- bit bus. The problem is that the CFI code uses the wrong addresses for 8-bits vs 16-bits.
The CFI function flash_map incorrectly calculates the byte offset with Spansion flash.
In our case, we have an 8-bit Spansion S29GL-N MirrorBit flash chip on an 8- bit bus.
According to the data sheet, in 8-bit mode the first unlock address is 0xAAA and the second is 0x555. Basically all of the addresses are approximately double what they are in 16-bit mode.
Most of the addresses in the CFI code are wrong for 8-bit mode.
They should be as follows: unlock1: 0xAAA unlock2: 0x555 CFI Query: 0xAA
Offset Device ID: 0x02, 0x1c, 0x1e Offset Silicon Sector Factory Protect: 0x6 Sector protect verify (sector address) + 4
The problem is that the dectection code detects (incorrectly) that we're an 8- bit device on a 16-bit bus when in fact it's an 8-bit bus.
For 16-bits, it's:
unlock1: 0x555 unlock2: 0x2aa CFI Query: 0x55 Offset Device ID: 0x1, 0x0e, 0x0f
Now, in 16-bit mode these addresses should be effectively doubled so they should look to be the same to software as I understand it.
This is all taken from the datasheet.
Note that the CFI code works fine with the flash hooked up as 16-bit on a 16- bit bus.
If it's an 8-bit flash on a 16-bit bus then the addresses should be doubled.
flash detect cfi fwc addr 1ec00000 cmd f0 f0 8bit x 8 bit fwc addr 1ec00000 cmd ff ff 8bit x 8 bit fwc addr 1ec00055 cmd 98 98 8bit x 8 bit <== should be 0x1ec000AA is= cmd 51(Q) addr 1ec00010 is= 0 51 fwc addr 1ec00000 cmd f0 f0 8bit x 8 bit fwc addr 1ec00000 cmd ff ff 8bit x 8 bit fwc addr 1ec00555 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr 1ec00010 is= 0 51 fwc addr 1ec00000 cmd f0 f0f0 16bit x 8 bit fwc addr 1ec00000 cmd ff ffff 16bit x 8 bit fwc addr 1ec000aa cmd 98 9898 16bit x 8 bit is= cmd 51(Q) addr 1ec00020 is= 5151 5151 is= cmd 52(R) addr 1ec00022 is= 5252 5252 is= cmd 59(Y) addr 1ec00024 is= 5959 5959 device interface is 2 found port 2 chip 1 port 16 bits chip 8 bits 00 : 51 52 59 02 00 40 00 00 00 00 00 27 36 00 00 06 QRY..@.....'6... 10 : 06 09 13 03 05 03 02 18 02 00 06 00 01 7f 00 00 ................ 20 : 02 00 00 00 00 00 00 00 00 00 00 00 00 08 13 e8 ................ fwc addr 1ec00000 cmd f0 f0f0 16bit x 8 bit fwc addr 1ec01554 cmd aa aaaa 16bit x 8 bit fwc addr 1ec00aaa cmd 55 5555 16bit x 8 bit fwc addr 1ec01554 cmd 90 9090 16bit x 8 bit fwc addr 1ec00000 cmd f0 f0f0 16bit x 8 bit fwc addr 1ec000aa cmd 98 9898 16bit x 8 bit manufacturer is 2 manufacturer id is 0x0 device id is 0x3f device id2 is 0x0 cfi version is 0x3133 size_ratio 1 port 16 bits chip 8 bits found 1 erase regions erase region 0: 0x0200007f erase_region_count = 128 erase_region_size = 131072 fwc addr 1ec00000 cmd f0 f0 8bit x 8 bit fwc addr 1fbe0000 cmd 70 70 8bit x 8 bit flash_is_busy: 0 Flash: 16 MiB
-Aaron
For 16-bits, it's:
-Aaron
Hi Aaron,
Does this patch (originally by Stefan Roese) work for you? I also need it for the DNS323 port. FWIW, mine is also a Spansion flash (S29GL064M90TFIR4), although I am not 100% sure of the layout and connectivity.
Rogan
--- drivers/mtd/cfi_flash.c | 22 +++++++++++++++++++++- 1 files changed, 21 insertions(+), 1 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index dd394a8..74e9ade 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -291,6 +291,9 @@ static inline uchar flash_read_uchar (flash_info_t * info, uint offset) uchar *cp; uchar retval;
+#if 1 // test-only + offset = offset * 2; +#endif cp = flash_map (info, 0, offset); #if defined(__LITTLE_ENDIAN) || defined(CONFIG_SYS_WRITE_SWAPPED_DATA) retval = flash_read8(cp); @@ -308,6 +311,9 @@ static inline ushort flash_read_word (flash_info_t * info, uint offset) { ushort *addr, retval;
+#if 1 // test-only + offset = offset * 2; +#endif addr = flash_map (info, 0, offset); retval = flash_read16 (addr); flash_unmap (info, 0, offset, addr); @@ -328,6 +334,9 @@ static ulong flash_read_long (flash_info_t * info, flash_sect_t sect, #ifdef DEBUG int x; #endif +#if 1 // test-only + offset = offset * 2; +#endif addr = flash_map (info, sect, offset);
#ifdef DEBUG @@ -363,6 +372,9 @@ void flash_write_cmd (flash_info_t * info, flash_sect_t sect, void *addr; cfiword_t cword;
+#if 1 // test-only + offset = offset * 2; +#endif addr = flash_map (info, sect, offset); flash_make_cmd (info, cmd, &cword); switch (info->portwidth) { @@ -420,6 +432,9 @@ static int flash_isequal (flash_info_t * info, flash_sect_t sect, cfiword_t cword; int retval;
@@ -1762,6 +1777,7 @@ static int __flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) info->addr_unlock1 = 0x555; info->addr_unlock2 = 0x2aa;
+#if 0 // test-only /* * modify the unlock address if we are * in compatibility mode @@ -1776,6 +1792,7 @@ static int __flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) info->addr_unlock1 = 0xaaa; info->addr_unlock2 = 0x555; } +#endif
info->name = "CFI conformant"; return 1; @@ -1942,11 +1959,13 @@ ulong flash_get_size (phys_addr_t base, int banknum) debug ("cfi version is 0x%04x\n", info->cfi_version);
size_ratio = info->portwidth / info->chipwidth; +#if 0 // test-only /* if the chip is x8/x16 reduce the ratio by half */ if ((info->interface == FLASH_CFI_X8X16) && (info->chipwidth == FLASH_CFI_BY8)) { size_ratio >>= 1; } +#endif debug ("size_ratio %d port %d bits chip %d bits\n", size_ratio, info->portwidth << CFI_FLASH_SHIFT_WIDTH, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); @@ -2034,12 +2053,13 @@ ulong flash_get_size (phys_addr_t base, int banknum) /* round up when converting to ms */ info->write_tout = (tmp + 999) / 1000; info->flash_id = FLASH_MAN_CFI; +#if 0 if ((info->interface == FLASH_CFI_X8X16) && (info->chipwidth == FLASH_CFI_BY8)) { /* XXX - Need to test on x8/x16 in parallel. */ info->portwidth >>= 1; } - +#endif flash_write_cmd (info, 0, 0, info->cmd_reset); }
I don't think that will work. Multiplying the offsets by two won't always work (i.e. offset 2AA * 2 != 555). I think this will require a more substantial fix. I started working on something but it may take me a few days, though I have both an 8-bit and a 16-bit board to play with (though no 8-bit chip on a 16-bit bus).
-Aaron
For 16-bits, it's:
-Aaron
Hi Aaron,
Rogan
+#if 1 // test-only
- offset = offset * 2;
+#if 1 // test-only
+#if 1 // test-only
+#if 1 // test-only
I have it working on our 8-bit boards properly now, though I've only done some limited testing.
I basically put in the correct addresses into cfi_flash.h and updated various addresses for 8-bit support. The problem was that the CFI code was written using the 16-bit addresses which don't work for an 8-bit bus.
I added a mask which is used to calculate the correct address for 16 and 32- bit busses. I have only been able to test with 8-bit and 16-bit Spansion devices though.
-Aaron
For 16-bits, it's:
-Aaron
Hi Aaron,
Rogan
+#if 1 // test-only
+#if 1 // test-only
+#if 1 // test-only
+#if 1 // test-only
Hi Aaron,
Good.
Please post the patch on the list. I'll try to test it on some of my systems as well.
Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
-Aaron
Hi Aaron,
I'm happy to test it, when you post the patch.
Regards,
Rogan
I am still doing some testing and just added a fix today so that if a flash chip that supports both 8 and 16-bits is on an 8-bit bus the interface is set to 8-bits. I'll try and get patches out next week.
So far it's working fairly well on all of our boards, most of which have an 8- bit bus but one has a 16-bit bus. I had to change all of the defined addresses for AMD parts and calculate the 16 and 32-bit addresses by applying a mask.
The CFI code *should* work if there's an 8-bit part on a 16-bit bus, but it probably will not support two 8-bit parts in parallel. That should be doable with some work.
-Aaron
-Aaron
Hi Aaron,
Regards,
Rogan
-Aaron
Hi Aaron,
I'm looking forward to seeing your patches. With any luck, they'll also work on my board, and a nasty hack can go away. :-)
Regards,
Rogan
-Aaron
Hi Aaron,
I also would like to see these patches, even in RFC form. Maybe it could fix the way the MX29LV400CB is detected on ED Mini V2 and will allows removing legacy code for this board.
Regards,
Rogan
Amicalement,
I'll post the patches as soon as I figure out how to get git to do it.
The patches are fairly clean and works well for both an 8-bit bus and a 16-bit bus.
My biggest obstical is that I'm not all that familiar with GIT and we use SVN internally.
-Aaron
-Aaron
Hi Aaron,
Regards,
Rogan
Aaron Williams
Albert ARIBAUD
Rogan Dawes
Stefan Roese
