[U-Boot] [PATCH 1/3] DaVinci DA8xx: tidy up clock ID definition
Tidy up the clock IDs defined for the DA8xx SOCs. With this new structure in place, it is clear how to define new clock IDs, and how these map to the numbers presented in the technical reference manual.
Signed-off-by: Laurence Withers lwithers@guralp.com Cc: Prabhakar Lad prabhakar.csengg@gmail.com --- arch/arm/include/asm/arch-davinci/hardware.h | 53 +++++++++++++++++++------- 1 files changed, 39 insertions(+), 14 deletions(-)
diff --git a/arch/arm/include/asm/arch-davinci/hardware.h b/arch/arm/include/asm/arch-davinci/hardware.h index b145c6e..dac43bb 100644 --- a/arch/arm/include/asm/arch-davinci/hardware.h +++ b/arch/arm/include/asm/arch-davinci/hardware.h @@ -441,21 +441,46 @@ struct davinci_pllc_regs { #define davinci_pllc1_regs ((struct davinci_pllc_regs *)DAVINCI_PLL_CNTRL1_BASE) #define DAVINCI_PLLC_DIV_MASK 0x1f
-#define ASYNC3 get_async3_src() -#define PLL1_SYSCLK2 ((1 << 16) | 0x2) -#define DAVINCI_SPI1_CLKID (cpu_is_da830() ? 2 : ASYNC3) -/* Clock IDs */ +/* + * A clock ID is a 32-bit number where bit 16 represents the PLL controller + * (clear is PLLC0, set is PLLC1) and the low 16 bits represent the divisor, + * counting from 1. Clock IDs may be passed to clk_get(). + */ + +/* flags to select PLL controller */ +#define DAVINCI_PLLC0_FLAG (0) +#define DAVINCI_PLLC1_FLAG (1 << 16) + enum davinci_clk_ids { - DAVINCI_SPI0_CLKID = 2, - DAVINCI_UART2_CLKID = 2, - DAVINCI_MMC_CLKID = 2, - DAVINCI_MDIO_CLKID = 4, - DAVINCI_ARM_CLKID = 6, - DAVINCI_PLLM_CLKID = 0xff, - DAVINCI_PLLC_CLKID = 0x100, - DAVINCI_AUXCLK_CLKID = 0x101 + /* + * Clock IDs for PLL outputs. Each may be switched on/off independently, + * and each may map to one or more peripherals. + */ + DAVINCI_PLL0_SYSCLK2 = DAVINCI_PLLC0_FLAG | 2, + DAVINCI_PLL0_SYSCLK4 = DAVINCI_PLLC0_FLAG | 4, + DAVINCI_PLL0_SYSCLK6 = DAVINCI_PLLC0_FLAG | 6, + DAVINCI_PLL1_SYSCLK2 = DAVINCI_PLLC1_FLAG | 2, + + /* map peripherals to clock IDs */ + DAVINCI_ARM_CLKID = DAVINCI_PLL0_SYSCLK6, + DAVINCI_MDIO_CLKID = DAVINCI_PLL0_SYSCLK4, + DAVINCI_MMC_CLKID = DAVINCI_PLL0_SYSCLK2, + DAVINCI_SPI0_CLKID = DAVINCI_PLL0_SYSCLK2, + DAVINCI_UART2_CLKID = DAVINCI_PLL0_SYSCLK2, + + /* special clock ID - output of PLL multiplier */ + DAVINCI_PLLM_CLKID = 0x0FF, + + /* special clock ID - output of PLL post divisor */ + DAVINCI_PLLC_CLKID = 0x100, + + /* special clock ID - PLL bypass */ + DAVINCI_AUXCLK_CLKID = 0x101, };
+#define DAVINCI_SPI1_CLKID (cpu_is_da830() ? DAVINCI_PLL0_SYSCLK2 \ + : get_async3_src()) + int clk_get(enum davinci_clk_ids id);
/* Boot config */ @@ -570,10 +595,10 @@ static inline int cpu_is_da850(void) return ((part_no == 0xb7d1) ? 1 : 0); }
-static inline int get_async3_src(void) +static inline enum davinci_clk_ids get_async3_src(void) { return (REG(&davinci_syscfg_regs->cfgchip3) & 0x10) ? - PLL1_SYSCLK2 : 2; + DAVINCI_PLL1_SYSCLK2 : DAVINCI_PLL0_SYSCLK2; }
#endif /* CONFIG_SOC_DA8XX */
On the DA830, UART2's clock is derived from PLL controller 0 output 2. On the DA850, it is in the ASYNC3 group, and may be switched between PLL controller 0 or 1. Fix the definition of the ID to match.
Signed-off-by: Laurence Withers lwithers@guralp.com Cc: Prabhakar Lad prabhakar.csengg@gmail.com --- arch/arm/include/asm/arch-davinci/hardware.h | 4 +++- 1 files changed, 3 insertions(+), 1 deletions(-)
diff --git a/arch/arm/include/asm/arch-davinci/hardware.h b/arch/arm/include/asm/arch-davinci/hardware.h index dac43bb..0fce940 100644 --- a/arch/arm/include/asm/arch-davinci/hardware.h +++ b/arch/arm/include/asm/arch-davinci/hardware.h @@ -466,7 +466,6 @@ enum davinci_clk_ids { DAVINCI_MDIO_CLKID = DAVINCI_PLL0_SYSCLK4, DAVINCI_MMC_CLKID = DAVINCI_PLL0_SYSCLK2, DAVINCI_SPI0_CLKID = DAVINCI_PLL0_SYSCLK2, - DAVINCI_UART2_CLKID = DAVINCI_PLL0_SYSCLK2,
/* special clock ID - output of PLL multiplier */ DAVINCI_PLLM_CLKID = 0x0FF, @@ -478,6 +477,9 @@ enum davinci_clk_ids { DAVINCI_AUXCLK_CLKID = 0x101, };
+#define DAVINCI_UART2_CLKID (cpu_is_da830() ? DAVINCI_PLL0_SYSCLK2 \ + : get_async3_src()) + #define DAVINCI_SPI1_CLKID (cpu_is_da830() ? DAVINCI_PLL0_SYSCLK2 \ : get_async3_src())
Replace a magic number for the DDR2/mDDR PHY clock ID with a proper definition. In addition, don't request this clock ID on DA830 hardware, which does not have a DDR2/mDDR PHY (or associated PLL controller).
Signed-off-by: Laurence Withers lwithers@guralp.com Cc: Prabhakar Lad prabhakar.csengg@gmail.com --- arch/arm/cpu/arm926ejs/davinci/cpu.c | 3 ++- arch/arm/include/asm/arch-davinci/hardware.h | 2 ++ 2 files changed, 4 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/davinci/cpu.c b/arch/arm/cpu/arm926ejs/davinci/cpu.c index 4bdb08b..b31add8 100644 --- a/arch/arm/cpu/arm926ejs/davinci/cpu.c +++ b/arch/arm/cpu/arm926ejs/davinci/cpu.c @@ -122,7 +122,8 @@ int set_cpu_clk_info(void) { gd->bd->bi_arm_freq = clk_get(DAVINCI_ARM_CLKID) / 1000000; /* DDR PHY uses an x2 input clock */ - gd->bd->bi_ddr_freq = clk_get(0x10001) / 1000000; + gd->bd->bi_ddr_freq = cpu_is_da830() ? 0 : + (clk_get(DAVINCI_DDR_CLKID) / 1000000); gd->bd->bi_dsp_freq = 0; return 0; } diff --git a/arch/arm/include/asm/arch-davinci/hardware.h b/arch/arm/include/asm/arch-davinci/hardware.h index 0fce940..7f3dcc2 100644 --- a/arch/arm/include/asm/arch-davinci/hardware.h +++ b/arch/arm/include/asm/arch-davinci/hardware.h @@ -459,10 +459,12 @@ enum davinci_clk_ids { DAVINCI_PLL0_SYSCLK2 = DAVINCI_PLLC0_FLAG | 2, DAVINCI_PLL0_SYSCLK4 = DAVINCI_PLLC0_FLAG | 4, DAVINCI_PLL0_SYSCLK6 = DAVINCI_PLLC0_FLAG | 6, + DAVINCI_PLL1_SYSCLK1 = DAVINCI_PLLC1_FLAG | 1, DAVINCI_PLL1_SYSCLK2 = DAVINCI_PLLC1_FLAG | 2,
/* map peripherals to clock IDs */ DAVINCI_ARM_CLKID = DAVINCI_PLL0_SYSCLK6, + DAVINCI_DDR_CLKID = DAVINCI_PLL1_SYSCLK1, DAVINCI_MDIO_CLKID = DAVINCI_PLL0_SYSCLK4, DAVINCI_MMC_CLKID = DAVINCI_PLL0_SYSCLK2, DAVINCI_SPI0_CLKID = DAVINCI_PLL0_SYSCLK2,
- gd->bd->bi_ddr_freq = cpu_is_da830() ? 0 :
gd->bd->bi_dsp_freq = 0; return 0;(clk_get(DAVINCI_DDR_CLKID) / 1000000);
-- 1.7.2.5
This patch does depend on my earlier patch to tidy up the definition of set_cpu_clk_info() :
http://lists.denx.de/pipermail/u-boot/2012-July/129205.html
Bye for now,
-- 1.7.2.5
Can you please post everything as a series of 4 patches so that we don't add and then replace the magic value with the enum? Other than that, I'm happy with the series and will apply the updated series on Friday or so, thanks!
Laurence Withers
