[U-Boot] [RFC] Make U-Boot log great again
Hi guys,
TL;DR This is a suggestion about fixing U-Boot log, which has got worse recently.
Right now U-Boot and SPL logs are cluttered with bogus warnings like these (on X15 board, but I'm pretty sure it should appear on many others):
Loading Environment from FAT... *** Warning - bad CRC, using default environment Failed (-5)
Those are the consequences of next commit:
fb69464eae1e ("env: Allow to build multiple environments in Kconfig")
Because of this commit, I can see following changes in my .config file:
+CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_FAT_INTERFACE="mmc" +CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" +CONFIG_ENV_FAT_FILE="uboot.env"
which led U-Boot to try and load the environment from different sources. I agree that it's good thing to do and can be useful, but the problem is that the code for loading the environment wasn't changed to handle errors properly.
How I suggest to handle that case:
1. If we have two sources for the environment (e.g. FAT partition on SD card and some raw partition on eMMC), we shouldn't print error messages if we were unable to load the environment from one source 2. We should probably print some human-readable information that we didn't find the environment there, let's skip and look for next source (but don't print those warnings/failed messages) 3. And only print the error message in case when U-Boot environment wasn't found at all (on all possible sources).
I don't have enough time to fix this by my own right now. But let's discuss how to approach this issue in a best way possible. And if someone wants to step forward and do that -- would be really nice. If no -- I can look into that later. But let's collect some opinions here, first.
Thanks.
On Fri, Feb 16, 2018 at 1:01 PM, Sam Protsenko semen.protsenko@linaro.org wrote:
Hi guys,
This one seems to cause the most confusion with end users. They like to think it's a real bug, when in reality, "saveenv" and friends was just never run from within u-boot or a separate environment partition wasn't pre-programmed.
It's one of those bugs, users asked 10 years ago when the Beagle first launched, yet users still ask from time to time..
- If we have two sources for the environment (e.g. FAT partition on
I've also found, when you are dealing with multiple sources, it's nice to print "where" you came from.
Otherwise, I've been known to make things way to verbose, but it's easier to debug years later, when your adding a new family, or overhauling when/how "overlays" are handled...
Regards,
On Sat, Feb 17, 2018 at 3:49 AM, Robert Nelson robertcnelson@gmail.com wrote:
Hi guys,
Do we plan to fix this "Failed (-5)" message? It's very confusing. Like previous U-Boot just printing "*** Warning - bad CRC, using default environment" is enough I think.
Regards, Bin
Hello,
Hi guys,
The v2018.07 release still has this "Failed (-5)" message on boot. When do we plan to fix this?
Regards, Bin
On Tue, Jul 10, 2018 at 11:01:14AM +0800, Bin Meng wrote:
Hello,
Hi guys,
I don't mean for this to sound glib, but I was expecting patches to get posted to change this particular area at least. I thought it had been talked to the point where it was understood what the next steps should look like? Thanks/sorry!
Hello,
Hi guys,
Ok, as nobody volunteered, I'll look into this in my spare time. This thread has all sorts of suggestions, not only about error messages. I guess we need to see some code to have more meaningful discussion. Let me prepare some patch, and then we can discuss if it's a way to go.
Thanks.
-- Tom
Hello,
Hi guys,
Just to have something specific to discuss, I've sent two RFC patches: [1,2]. I suggest we start with messages beautifying first, as this seems to be main concern for most people.
Tom, what do you think about [1,2]? Does it have right to exist at all, or should we go some other way?
Thanks.
[1] https://lists.denx.de/pipermail/u-boot/2018-July/335071.html [2] https://lists.denx.de/pipermail/u-boot/2018-July/335072.html
-- Tom
On Wed, Jul 18, 2018 at 1:14 AM, Sam Protsenko semen.protsenko@linaro.org wrote:
Hello,
Hi guys,
After some discussion, new RFC patch is ready for review: [1]. Personally, I'd also like to prepend error messages with at least two spaces or some other prefix. But that would take introducing new pointer in gd structure. Please let me know what you think.
[1] https://lists.denx.de/pipermail/u-boot/2018-July/335223.html
Thanks.
-- Tom
Dear Sam,
In message CAKaJLVsWKpGeEuS=iZ7QCtZrDfUSA=8GZo3zJDr-VgW-MUCFzA@mail.gmail.com you wrote:
I donpt want to question the purpose of your patch series in genral, but:
This is NOT a bogus warning - actually it is something which is not supposed to happen on any sane system. If it does on your board even after first boot and running "env save" at least once, then you have some problem either in the design or implementation of your board code.
So this is a very valid warning which means: FIX ME!
This needs specification.
If there are several potential sources for the environment, it can be assumed that the first one is supposed to be the primary one, so if this does not work, there _should_ be a warning (or even error) message before U-Boot falls back to alternative storage.
However, in such a case the "using default environment" is apparently wrong...
- We should probably print some human-readable information that we
For any attempt to read the environment from some storage device which fails, a warning SHALL be printed, because this is not supposed to happen.
- And only print the error message in case when U-Boot environment
On 18 February 2018 at 23:22, Wolfgang Denk wd@denx.de wrote:
Dear Sam,
Oh, it's merely a discussion, not a patch series. I probably shouldn't have been added that RFC tag, it's confusing, sorry.
AFAIU, that behavior was changed in the mentioned patch (please see my original message). Let me elaborate a bit. In v2018.01 everything works fine and none errors/warnings are present on my boards (AM57x EVM and X15 board). The problem appears after commit fb69464eae1e ("env: Allow to build multiple environments in Kconfig"). Now U-Boot tries to load the environment from SD card first (uEnv.txt file on FAT partition), and then from eMMC partition. In case when SD card is not inserted, I observe mentioned errors. So I'm not sure how to handle this properly, that's why I created this thread... Let me try and explain my concerns better: 1. On the one hand, it's good to check the environment on both SD card and eMMC (that was done in mentioned patch). This case seems to be legit (at least as far as I understand it), i.e. when SD card is not inserted, it's fine, we just check the env on eMMC 2. But on the other hand, errors shouldn't appear in boot log, if it's legit case, it's confusing the user
Please correct me if I'm wrong, I'm just trying to come up with correct perspective about what should be done about it. Like: 1. Just disable SD card environment (i.e. revert that patch changes for my board). But it's probably a useful feature? 2. Fix errors handling when multiple environments are enabled 3. Some other solution (which I probably don't know about, yet)
In my case, we have two sources for the env: SD card and eMMC. And we have 2 possible state of the board: 1. SD card is inserted. U-Boot will be ran from SD card 2. SD card is not inserted. U-Boot will be ran from eMMC
The question is, how we are supposed to handle environment for those two cases? Right now it's being tested from SD card first, then (if not found), it's going to be tested from eMMC. That's where the error appears (if SD card is not inserted).
Ok, you are saying that the error shouldn't happen. But the only way I see to change that, is to implement conditional probing for the environment. Like: 1. If we are being booted from SD card, load the environment only from SD card 2. If we are being booted from eMMC, load the environment only from eMMC
Am I correct? If so, it's not how it's implemented right now (judging from those errors in logs)... I want to be absolutely clear about how do we want to see this, before doing something...
Thanks.
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de When in doubt, mumble; when in trouble, delegate; when in charge, ponder. -- James H. Boren
Dear Sam,
In message CAKaJLVvL-E7b5XKqixM4yn=2rXW5qzRRS5ijkWRjmdetdakZ2Q@mail.gmail.com you wrote:
I think we both are talking about the same thing. I just see it differently :-)
If the user configures the system to try the SDCard first for the environment, and it cannot find it there, then this should be considered an error situation (even if recoverable by falling back to secondary storage), and at least a warning must be printed (or an error, if there is no secondary storage configured).
I agree with you that both the part about the CRC error and the part about using the default environment are wrong in this case, so the tezt of the warning message needs to be fixed - it should say clearly that the attempt to _read_ the environment from storage device _XXX_ failed.
- On the one hand, it's good to check the environment on both SD
If this is what is configured, yes. In this case I would expoect to see something like this:
# Warning: Can't read environment from SDCard, trying now: eMMC.
or such [eventually - and if available - with additional information like "no card present"].
- But on the other hand, errors shouldn't appear in boot log, if
Well, the "legit case" is that the primary storage for the environment works. If it is not available, this is something that the user should be made aware of.
- Just disable SD card environment (i.e. revert that patch changes
It is definitely a useful feature in many situations.
On the other hand, as always you should know what you are doing. For example:
Assume no error/warning is printed when no SDCard is present. Then the user might not even be aware that the SDCard is being probed. He may assume he can secure his system for example by setting bootdelay=0 to prevent commandline access in U-Boot. And apparently this will work fine for him - until someone comes along wh inserts a SDCard with different environment settings.
I think it is a good ide to inform the user what is actually going on...
- Fix errors handling when multiple environments are enabled
THis is definitely needed, agreed.
- SD card is inserted. U-Boot will be ran from SD card
- SD card is not inserted. U-Boot will be ran from eMMC
I think this is pretty clear: the configuration apparently selects SDCard as the primary storage for the environment and probes it first. When it is not present, it tries the second best option, eMMC. In this case a warning is appropriate. And i eMMC does not work either, then an error message must be printed.
- If we are being booted from SD card, load the environment only from SD card
- If we are being booted from eMMC, load the environment only from eMMC
This is another configuration. it is as valid as the other one. I assume you can insert a SDCard without SPL/U-Boot on it, so you will still boot from eMMC, but read the environment from SDCard?
There are many configurations which could be implemented, but they all should be explicit about the "search order" for the environment.
Of course ou can make this as complicated as you like. One could also define a policy if all storage locations are equal, so you don't care where the environment is coming from as long as any of them works. Or you define a clear sequence, in which case you will want to be informed (warning) when the primary location does not work. One could even make this behavious switchable at run-time. But: do we really need that?
I would expect, that the strict order primary forst, then try next storage devices in strict sequence, and warn for not working ones, is what most users expect and find useful.
Dear Sam,
That patch intent was to keep the current behaviour as is for all users, so the fact that you now have the FAT environment enabled is an unwanted side-effect.
Maxime
On Tue, 20 Feb 2018 09:00:56 +0100 Maxime Ripard maxime.ripard@bootlin.com wrote:
Dear Sam,
The same situation is on Beagle Bone Black. Even though with OE it is built to use eMMC for storing its envs, by default it also has envs in FAT support enabled.
For that reason, u-boot on this board looks for envs in FAT first and similar message is printed.
IMHO, we now have (unintentionally) the situation where implicitly reading envs from FAT has the highest priority.
Maxime
Lukasz Majewski
Dear Sam,
It's not so much unintentional but rather that the mechanism to define the priority order isn't being provided specifically by board/ti/am335x/board.c so we get the default order.
And one thing that I think does need to happen now is that the error messages about "didn't find valid environment in ..." need to be rethought a bit. It would probably also make sense to move from every env operation tries every possible env location to env init finds the first valid location, tells the user clearly it's using that, and then always uses it.
Dear Sam,
It really was unintentional to me :)
The point of that commit really was to not introduce new environments to anyone. The fact that we now have FAT being higher priority than MMC is a side effect of that since we now have two environments enabled. If we only had the MMC, we wouldn't have any issue with it, and that was my intent.
Is there an easy way (one in tools/ ?) to try to diff two configs between revisions?
Not all environments have an init callback, so we'd rather need to do that at load time. However, I guess we also want to inform users if a higher priority load has failed somehow.
Maxime
Dear Sam,
In message CAKaJLVsWKpGeEuS=iZ7QCtZrDfUSA=8GZo3zJDr-VgW-MUCFzA@mail.gmail.com you wrote: > > Right now U-Boot and SPL logs are cluttered with bogus warnings > like these (on X15 board, but I'm pretty sure it should appear > on many others): > > Loading Environment from FAT... > *** Warning - bad CRC, using default environment
So, what happened here is that the defconfig file says ENV_IS_IN_MMC but we also have 'default y if MMC_OMAP_HS && TI_COMMON_CMD_OPTIONS' in env/Kconfig.
Riffing off what I just said to Simon, I was thinking that at env_init() we set the default env_driver, and then introduce a new sub-command to 'env' so that a user can specify where they want the env to be stored (or if you do env default -f -a, re-read).
Dear Sam,
But it's like that already, isnt' it? Env load selects the first valid location in the list and env save uses that location. All other env operations work on the environment in memory.
Also, for transitioning e.g. from MMC to FAT, we would need a mechanism to store to an environment place other than the one selected at load time.
Simon
Dear Sam,
In message CAKaJLVsWKpGeEuS=iZ7QCtZrDfUSA=8GZo3zJDr-VgW-MUCFzA@mail.gmail.com you wrote: >Right now U-Boot and SPL logs are cluttered with bogus warnings >like these (on X15 board, but I'm pretty sure it should appear >on many others): > > Loading Environment from FAT... > *** Warning - bad CRC, using default environment I donpt want to question the purpose of your patch series in genral, but:
For saveenv we have: for (prio = 0; (drv = env_driver_lookup(ENVOP_SAVE, prio)); prio++) { ...
Ah, so we have different valid use cases. Maybe a new env sub-command, switch?
On 18 February 2018 at 23:22, Wolfgang Denk wd@denx.de wrote: > Dear Sam, > > In message > CAKaJLVsWKpGeEuS=iZ7QCtZrDfUSA=8GZo3zJDr-VgW-MUCFzA@mail.gmail.com > you wrote: >> Right now U-Boot and SPL logs are cluttered with bogus warnings >> like these (on X15 board, but I'm pretty sure it should appear >> on many others): >> >> Loading Environment from FAT... >> *** Warning - bad CRC, using default environment > I donpt want to question the purpose of your patch series in > genral, but: Oh, it's merely a discussion, not a patch series. I probably shouldn't have been added that RFC tag, it's confusing, sorry. > This is NOT a bogus warning - actually it is something which is > not supposed to happen on any sane system. If it does on your > board even after first boot and running "env save" at least once, > then you have some problem either in the design or implementation > of your board code. > > So this is a very valid warning which means: FIX ME! AFAIU, that behavior was changed in the mentioned patch (please see my original message). Let me elaborate a bit. In v2018.01 everything works fine and none errors/warnings are present on my boards (AM57x EVM and X15 board). The problem appears after commit fb69464eae1e ("env: Allow to build multiple environments in Kconfig"). Now U-Boot tries to load the environment from SD card first (uEnv.txt file on FAT partition), and then from eMMC partition. In case when SD card is not inserted, I observe mentioned errors. So I'm not sure how to handle this properly, that's why I created this thread... Let me try and explain my concerns better:
Yes, but I think env_get_location() called from env_driver_lookup() returns gd->env_load_location for saving... That seems a little hidden though...
Something like that, yes.
Simon
On 18 February 2018 at 23:22, Wolfgang Denk wd@denx.de wrote: >Dear Sam, > >In message >CAKaJLVsWKpGeEuS=iZ7QCtZrDfUSA=8GZo3zJDr-VgW-MUCFzA@mail.gmail.com >you wrote: >>Right now U-Boot and SPL logs are cluttered with bogus warnings >>like these (on X15 board, but I'm pretty sure it should appear >>on many others): >> >> Loading Environment from FAT... >> *** Warning - bad CRC, using default environment >I donpt want to question the purpose of your patch series in >genral, but: Oh, it's merely a discussion, not a patch series. I probably shouldn't have been added that RFC tag, it's confusing, sorry. >This is NOT a bogus warning - actually it is something which is >not supposed to happen on any sane system. If it does on your >board even after first boot and running "env save" at least once, >then you have some problem either in the design or implementation >of your board code. > >So this is a very valid warning which means: FIX ME! AFAIU, that behavior was changed in the mentioned patch (please see my original message). Let me elaborate a bit. In v2018.01 everything works fine and none errors/warnings are present on my boards (AM57x EVM and X15 board). The problem appears after commit fb69464eae1e ("env: Allow to build multiple environments in Kconfig"). Now U-Boot tries to load the environment from SD card first (uEnv.txt file on FAT partition), and then from eMMC partition. In case when SD card is not inserted, I observe mentioned errors. So I'm not sure how to handle this properly, that's why I created this thread... Let me try and explain my concerns better:
In the default case, env_driver_lookup will return the location where the environment with the highest priority has been loaded.
We implemented it by overwriting the priority look up.
Maxime
On Mon, Feb 19, 2018 at 07:47:52PM +0200, Sam Protsenko wrote: >On 18 February 2018 at 23:22, Wolfgang Denk wd@denx.de wrote: >>Dear Sam, >> >>In message >>CAKaJLVsWKpGeEuS=iZ7QCtZrDfUSA=8GZo3zJDr-VgW-MUCFzA@mail.gmail.com >>you wrote: >>>Right now U-Boot and SPL logs are cluttered with bogus warnings >>>like these (on X15 board, but I'm pretty sure it should appear >>>on many others): >>> >>> Loading Environment from FAT... >>> *** Warning - bad CRC, using default environment >>I donpt want to question the purpose of your patch series in >>genral, but: >Oh, it's merely a discussion, not a patch series. I probably >shouldn't have been added that RFC tag, it's confusing, sorry. >>This is NOT a bogus warning - actually it is something which is >>not supposed to happen on any sane system. If it does on your >>board even after first boot and running "env save" at least once, >>then you have some problem either in the design or implementation >>of your board code. >> >>So this is a very valid warning which means: FIX ME! >AFAIU, that behavior was changed in the mentioned patch (please see >my original message). Let me elaborate a bit. In v2018.01 everything >works fine and none errors/warnings are present on my boards (AM57x >EVM and X15 board). The problem appears after commit fb69464eae1e >("env: Allow to build multiple environments in Kconfig"). Now U-Boot >tries to load the environment from SD card first (uEnv.txt file on >FAT partition), and then from eMMC partition. In case when SD card >is not inserted, I observe mentioned errors. So I'm not sure how to >handle this properly, that's why I created this thread... Let me >try and explain my concerns better: > 1. On the one hand, it's good to check the environment on both SD >card and eMMC (that was done in mentioned patch). This case seems to >be legit (at least as far as I understand it), i.e. when SD card is >not inserted, it's fine, we just check the env on eMMC > 2. But on the other hand, errors shouldn't appear in boot log, if >it's legit case, it's confusing the user That patch intent was to keep the current behaviour as is for all users, so the fact that you now have the FAT environment enabled is an unwanted side-effect.
The general sunxi case is "We need to move from offset to FAT file" as there's not really generally other valid cases. But on other SoCs we can both say that it's valid to move from eMMC (we put env in an unbootable by the SoC boot partition) to FAT, or not want to move it at all.
Another case I've been thinking of, but would be handled by the code as-is, is the "Beagleboard vs Beagleboard xM" case where the board code needs to check which we're on and keep env on NAND or finally have env on file on FAT". But even then, allowing an explicit switch might be needed, if people want to migrate env to FAT, even on original Beagleboard.
Ah, right. That definitely makes sense.
Maxime
Dear Lukasz,
This makes clear that this area needs more than just a casual "fix". We must make sure to implement a policy that is consistent and useful:
1. The user should be able to select which devices are probed for the environment. 2. He should be able to specify the exact order in which this probing takes place. 3. Enough information should be printed so the user knows where his environment is coming from, and which devices may have been probed without success. The messages should be clear and easy to understand.
Obviously it is not possible to adjust this configuration at run-time - accessing some environment variable to determine where to read the environment from is a nice chicken-and-egg problem. So this is some _compile time_ configuration, i. e. it probably requires some Kconfig magic plus appropriate code changes.
Just fixing an error message is not enough.
participants (8)
Bin Meng
Lukasz Majewski
Maxime Ripard
Robert Nelson
Sam Protsenko
Simon Goldschmidt
