[PATCH] xilinx: Show silicon version in SPL
Both Zynq and ZynqMP can show silicon versions in SPL boot flow. It is useful to be aware. The patch is also fixing possition of these bits on ZynqMP.
arch/arm/mach-zynqmp/include/mach/hardware.h | 4 ++-- board/xilinx/zynq/board.c | 3 +++ board/xilinx/zynqmp/zynqmp.c | 1 + 3 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-zynqmp/include/mach/hardware.h b/arch/arm/mach-zynqmp/include/mach/hardware.h index b328837c694f..3d3c48e24731 100644 --- a/arch/arm/mach-zynqmp/include/mach/hardware.h +++ b/arch/arm/mach-zynqmp/include/mach/hardware.h @@ -128,8 +128,8 @@ struct apu_regs {
#define ZYNQMP_CSU_VERSION_EMPTY_SHIFT 20
-#define ZYNQMP_SILICON_VER_MASK 0xF000 -#define ZYNQMP_SILICON_VER_SHIFT 12 +#define ZYNQMP_SILICON_VER_MASK 0xF +#define ZYNQMP_SILICON_VER_SHIFT 0
struct csu_regs { u32 reserved0[4]; diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 7ac069aaafdf..0fc11a48f14c 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -24,6 +24,9 @@ DECLARE_GLOBAL_DATA_PTR;
int board_init(void) { + if (IS_ENABLED(CONFIG_SPL_BUILD)) + printf("Silicon version:\t%d\n", zynq_get_silicon_version()); + return 0; }
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index d18c992e3f8f..8968cf90760f 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -328,6 +328,7 @@ int board_init(void) if (sizeof(CONFIG_ZYNQMP_SPL_PM_CFG_OBJ_FILE) > 1) zynqmp_pmufw_load_config_object(zynqmp_pm_cfg_obj, zynqmp_pm_cfg_obj_size); + printf("Silicon version:\t%d\n", zynqmp_get_silicon_version()); #else if (CONFIG_IS_ENABLED(DM_I2C) && CONFIG_IS_ENABLED(I2C_EEPROM)) xilinx_read_eeprom();
Ășt 2. 2. 2021 v 16:51 odesĂlatel Michal Simek michal.simek@xilinx.com napsal:
#else if (CONFIG_IS_ENABLED(DM_I2C) && CONFIG_IS_ENABLED(I2C_EEPROM)) xilinx_read_eeprom(); -- 2.30.0
Applied. M
Michal Simek
Michal Simek
