[U-Boot] how do you build u-boot under Windows XP SP2
I've tried building u-boot 1.3.3 under cygwin and the make fails. Can anyone help?
I need to build under Windows.
Thanks.
Christopher M. Fairfax Sr. Software Engineer Rockwell Collins +1 540-428-3344 +1 540-428-3301 cmfairfa@rockwellcollins.com This message contains PRIVILEGED AND PROPRIETARY INFORMATION intended solely for the use of the addressee(s) named above. Any disclosure, distribution, copying or use of the information by others is strictly prohibited. If you have received this message in error, please advise the sender by immediate reply and delete the original message. Thank you.
Before all the negative emails fly in regarding how foolish you are to develop under windows ... :)
Have you tried CoLinux?
Its a port of Linux that runs as a windows process.
I haven't tried it for U-Boot development, but it should work just fine.
Cheers, Dave
Dear David Hawkins,
See for example http://www.denx.de/en/News/#NewsELDKcoLinux OK, that's with an old version of the ELDK (release 4.1) on it, but it shows how to set up things.
David Hawkins
