[PATCH v1 6/9] rockchip: RK3568: Read the reset cause from clock reset unit for RK356x SoC
Read the reset cause from clock reset unit for RK356x SoC.
Cc: Jagan Teki jagan@edgeble.ai Signed-off-by: Anand Moon anand@edgeble.ai --- arch/arm/mach-rockchip/cpu-info.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/mach-rockchip/cpu-info.c b/arch/arm/mach-rockchip/cpu-info.c index 77833c8fce..114608b506 100644 --- a/arch/arm/mach-rockchip/cpu-info.c +++ b/arch/arm/mach-rockchip/cpu-info.c @@ -12,6 +12,8 @@ #include <asm/arch-rockchip/cru_rk3328.h> #elif IS_ENABLED(CONFIG_ROCKCHIP_RK3399) #include <asm/arch-rockchip/cru_rk3399.h> +#elif IS_ENABLED(CONFIG_ROCKCHIP_RK33568) +#include <asm/arch-rockchip/cru_rk3568.h> #endif #include <asm/arch-rockchip/hardware.h> #include <linux/err.h> @@ -22,6 +24,8 @@ char *get_reset_cause(void) struct rk3328_cru *cru = rockchip_get_cru(); #elif IS_ENABLED(CONFIG_ROCKCHIP_RK3399) struct rockchip_cru *cru = rockchip_get_cru(); +#elif IS_ENABLED(CONFIG_ROCKCHIP_RK3568) + struct rk3568_cru *cru = rockchip_get_cru(); #endif char *cause = NULL;
Hi Anand,
- struct rk3568_cru *cru = rockchip_get_cru();
This is strictly not needed for RK3568 after the commit 6e710897aa31 ("rockchip: cru: Enable cpu info support for rk3568").
Suggest you use same/similar workaround or cleanup the include/define statement in arch/arm/include/asm/arch-rockchip/cru.h for all SoCs.
Also at least one RK SoC have other bits set in the glb_rst_st reg.
Suggest you add following:
GLB_RST_MASK = GENMASK(5, 0),
and use something like:
switch (cru->glb_rst_st & GLB_RST_MASK) {
or "unknown reset" is reported on affected SoCs.
I have also seen POR always being reported even after a reboot so please confirm that reset reason works on the SoCs/boards you enable this on.
Regards, Jonas
Hi Jonas,
Dropping @edgeble.ai email ID as it is not working
On Thu, 16 May 2024 at 19:48, Jonas Karlman jonas@kwiboo.se wrote:
Hi Anand,
Read the reset cause from the clock reset unit for RK356x SoC.
Ok, thanks for this input.
Ok, I will check this and update you on this.
Regards, Jonas
Thanks -Anand
Hi Jonas,
On Fri, 17 May 2024 at 13:15, Anand Moon linux.amoon@gmail.com wrote:
Hi Jonas,
Hi Anand,
I have made changes for all the SoC that supports this reading of CRU only build these SoCs,I don't have all the boards to test.
On rock64 with reboot command, it shows (RST)
U-Boot 2024.07-rc3-00021-gb23d5619e6-dirty (May 24 2024 - 12:55:26 +0530)
SoC: Rockchip rk3328 Reset cause: RST Model: Pine64 Rock64
with poweroff command, it shows (POR)
SoC: Rockchip rk3328 Reset cause: POR
Actually, for RK3568 and RK3688 SoC, we are not able to read the reset cause via CRU glb_rst_st is always set to zero.
Either the user space with poweroff and reboot command not updating the CRU or the u-boot is not registering the sysreset to read the reset cause.
# dm tree clk 5 [ + ] rockchip_rk3588_cru |-- clock-controller@fd7c0000 sysreset 0 [ ] rockchip_sysreset | |-- sysreset reset 0 [ + ] rockchip_reset | `-- reset
Thanks -Anand
Anand Moon
Anand Moon
Jonas Karlman
