[PATCH 1/3] doc: usage: Convert README.vxworks to reST
This converts the existing README.vxworks to reST, and puts it under the doc/usage/os directory.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
doc/usage/index.rst | 8 +++++++ doc/{README.vxworks => usage/os/vxworks.rst} | 22 ++++++++++---------- 2 files changed, 19 insertions(+), 11 deletions(-) rename doc/{README.vxworks => usage/os/vxworks.rst} (93%)
diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 0aacf531b2..b8916971bc 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -52,3 +52,11 @@ Shell commands size true ums + +Booting OS +---------- + +.. toctree:: + :maxdepth: 1 + + os/vxworks diff --git a/doc/README.vxworks b/doc/usage/os/vxworks.rst similarity index 93% rename from doc/README.vxworks rename to doc/usage/os/vxworks.rst index 12a0d744d8..e696c639b2 100644 --- a/doc/README.vxworks +++ b/doc/usage/os/vxworks.rst @@ -1,11 +1,10 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright (C) 2013, Miao Yan miao.yan@windriver.com -# Copyright (C) 2015-2018, Bin Meng bmeng.cn@gmail.com -# Copyright (C) 2019, Lihua Zhao lihua.zhao@windriver.com +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright (C) 2013, Miao Yan miao.yan@windriver.com +.. Copyright (C) 2015-2018, Bin Meng bmeng.cn@gmail.com +.. Copyright (C) 2019, Lihua Zhao lihua.zhao@windriver.com
-VxWorks Support -=============== +VxWorks +=======
This document describes the information about U-Boot loading VxWorks kernel.
@@ -20,7 +19,7 @@ With CONFIG_EFI_LOADER option, it's possible to chain load a VxWorks x86 kernel via the UEFI boot loader application for VxWorks loaded by 'bootefi' command.
VxWorks 7 on PowerPC and ARM ---------------------------- +---------------------------- From VxWorks 7, VxWorks starts adopting device tree as its hardware description mechanism (for PowerPC and ARM), thus requiring boot interface changes. This section will describe the new interface. @@ -35,11 +34,11 @@ For legacy bootm flow, make sure the least significant bit of flags in bootargs is cleared. The calling convention is described below:
For PowerPC, the calling convention of the new VxWorks entry point conforms to -the ePAPR standard, which is shown below (see ePAPR for more details): +the ePAPR standard, which is shown below (see ePAPR for more details)::
void (*kernel_entry)(fdt_addr, 0, 0, EPAPR_MAGIC, boot_IMA, 0, 0)
-For ARM, the calling convention is shown below: +For ARM, the calling convention is shown below::
void (*kernel_entry)(void *fdt_addr)
@@ -47,7 +46,7 @@ When using the Linux compatible standard DTB, the calling convention of VxWorks entry point is exactly the same as the Linux kernel.
When booting a VxWorks 7 kernel (uImage format), the parameters passed to bootm -is like below: +is like below::
bootm <kernel image address> - <device tree address>
@@ -108,6 +107,7 @@ BIOS of the graphics card first. CONFIG_FRAMEBUFFER_SET_VESA_MODE need remain set but care must be taken at which VESA mode is to be set. The supported pixel format is 32-bit RGBA, hence the available VESA mode can only be one of the following: + * FRAMEBUFFER_VESA_MODE_10F * FRAMEBUFFER_VESA_MODE_112 * FRAMEBUFFER_VESA_MODE_115
At present the doc only mentions Arm, PowerPC and x86. RISC-V support has been added since VxWorks SR0650 support for a while, and U-Boot supports loading a RISC-V VxWorks kernel too. Let's document it.
doc/usage/os/vxworks.rst | 11 ++++++++--- 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/doc/usage/os/vxworks.rst b/doc/usage/os/vxworks.rst index e696c639b2..e732f711fb 100644 --- a/doc/usage/os/vxworks.rst +++ b/doc/usage/os/vxworks.rst @@ -13,13 +13,13 @@ Status U-Boot supports loading VxWorks kernels via 'bootvx' and 'bootm' commands. For booting old kernels (6.9.x) on PowerPC and ARM, and all kernel versions on other architectures, 'bootvx' shall be used. For booting VxWorks 7 kernels -on PowerPC and ARM, 'bootm' shall be used. +on PowerPC/ARM/RISC-V, 'bootm' shall be used.
-VxWorks 7 on PowerPC and ARM ----------------------------- +VxWorks 7 on PowerPC/ARM/RISC-V +------------------------------- From VxWorks 7, VxWorks starts adopting device tree as its hardware description mechanism (for PowerPC and ARM), thus requiring boot interface changes. This section will describe the new interface. @@ -45,6 +45,11 @@ For ARM, the calling convention is shown below:: When using the Linux compatible standard DTB, the calling convention of VxWorks entry point is exactly the same as the Linux kernel.
+For RISC-V, there is no legacy bootm flow as VxWorks always uses the same boot +interface as the Linux kernel, with the calling convention below:: + + void (*kernel_entry)(unsigned long hartid, void *fdt_addr) + When booting a VxWorks 7 kernel (uImage format), the parameters passed to bootm is like below::
A man-page for bootvx might be useful.
Nits: .. code-block:: C
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
- void (*kernel_entry)(unsigned long hartid, void *fdt_addr)
- When booting a VxWorks 7 kernel (uImage format), the parameters passed to bootm is like below::
This converts the existing README.plan9 to reST, and puts it under the doc/usage/os directory.
doc/usage/index.rst | 1 + doc/{README.plan9 => usage/os/plan9.rst} | 12 ++++++++---- 2 files changed, 9 insertions(+), 4 deletions(-) rename doc/{README.plan9 => usage/os/plan9.rst} (89%)
diff --git a/doc/usage/index.rst b/doc/usage/index.rst index b8916971bc..ecb4908fd1 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -59,4 +59,5 @@ Booting OS .. toctree:: :maxdepth: 1
+ os/plan9 os/vxworks diff --git a/doc/README.plan9 b/doc/usage/os/plan9.rst similarity index 89% rename from doc/README.plan9 rename to doc/usage/os/plan9.rst index 2d3d0e0cf6..f91712c009 100644 --- a/doc/README.plan9 +++ b/doc/usage/os/plan9.rst @@ -1,3 +1,10 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Steven Stallion +.. June 2013 + +Plan 9 +====== + Plan 9 from Bell Labs kernel images require additional setup to pass configuration information to the kernel. An environment variable named confaddr must be defined with the same value as CONFADDR (see mem.h). @@ -10,9 +17,6 @@ bootargs environment variable will be copied.
If no command line arguments or bootargs are defined, CONFADDR is left uninitialized to permit manual configuration. For example, PC-style -configuration could be simulated by issuing a fatload in bootcmd: +configuration could be simulated by issuing a fatload in bootcmd::
# setenv bootcmd fatload mmc 0 $confaddr plan9.ini; ...; bootm - -Steven Stallion -June 2013
- os/plan9 os/vxworks
+Plan 9 +======
- Plan 9 from Bell Labs kernel images require additional setup to pass
Does U-Boot support any hardware that Plan 9 supports?
Or can we simply drop this document?
Is this prompt correct? I cannot find any defconfig where CONFIG_SYS_PROMPT="# ".
Best regards
Heinrich
diff --git a/doc/usage/index.rst b/doc/usage/index.rst index b8916971bc..ecb4908fd1 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -59,4 +59,5 @@ Booting OS .. toctree:: :maxdepth: 1 + os/plan9 os/vxworks diff --git a/doc/README.plan9 b/doc/usage/os/plan9.rst similarity index 89% rename from doc/README.plan9 rename to doc/usage/os/plan9.rst index 2d3d0e0cf6..f91712c009 100644 --- a/doc/README.plan9 +++ b/doc/usage/os/plan9.rst @@ -1,3 +1,10 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Steven Stallion +.. June 2013
+Plan 9 +======
https://p9f.org/magic/man2html/8/booting describes the Raspberry Pi and OMAP3 as supported by Plan 9.
http://9p.io/sources/contrib/miller/9pi.img.gz is meant to be an image for the Raspberry Pi. See description at https://bendyworks.com/blog/getting-plan-9-running-on-the-raspberry-pi
So let's keep this document.
configuration information to the kernel. An environment variable named confaddr must be defined with the same value as CONFADDR (see mem.h). @@ -10,9 +17,6 @@ bootargs environment variable will be copied. If no command line arguments or bootargs are defined, CONFADDR is left uninitialized to permit manual configuration. For example, PC-style -configuration could be simulated by issuing a fatload in bootcmd: +configuration could be simulated by issuing a fatload in bootcmd:: # setenv bootcmd fatload mmc 0 $confaddr plan9.ini; ...; bootm
Best regards
Heinrich
+.. toctree::
- :maxdepth: 1
- os/vxworks
-VxWorks Support
+VxWorks +=======
.. code-block:: c
Nits: Syntaxhighlighting depends on specifying the language.
.. code-block:: c
Bin Meng
