[U-Boot-Users] [PATCH 4/4] mpc86xx: Remove old CFG_CMD_* references.
Signed-off-by: Jon Loeliger jdl@freescale.com ---
Since the config file has already been updated, the old CFG_CMD_* names are never used within the cpu/86xx directory. They can be removed entirely now.
cpu/mpc86xx/traps.c | 12 ++++++------ 1 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/cpu/mpc86xx/traps.c b/cpu/mpc86xx/traps.c index 06334b7..fab1975 100644 --- a/cpu/mpc86xx/traps.c +++ b/cpu/mpc86xx/traps.c @@ -34,7 +34,7 @@ #include <command.h> #include <asm/processor.h>
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) int (*debugger_exception_handler)(struct pt_regs *) = 0; #endif
@@ -122,7 +122,7 @@ MachineCheckException(struct pt_regs *regs) return; }
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler) (regs)) return; #endif @@ -155,7 +155,7 @@ MachineCheckException(struct pt_regs *regs) void AlignmentException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler) (regs)) return; #endif @@ -170,7 +170,7 @@ ProgramCheckException(struct pt_regs *regs) unsigned char *p = regs ? (unsigned char *)(regs->nip) : NULL; int i, j;
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler) (regs)) return; #endif @@ -193,7 +193,7 @@ ProgramCheckException(struct pt_regs *regs) void SoftEmuException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler) (regs)) return; #endif @@ -205,7 +205,7 @@ SoftEmuException(struct pt_regs *regs) void UnknownException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler) (regs)) return; #endif
Jon Loeliger
