Re: [U-Boot-Users] how to mkimage for mips ?
zhuzhenhua,您好!
the option -e is to set the first execute instruction address of your linux image and option -a is to set the address which uboot will copy image to when user invoke bootm
======= 2005-12-01 13:40:43 您在来信中写道:=======
for example, if for pb1100, can we use zImage.pb1100 to make uImage? how to set the -a -e in mkimage?
Best regards zhuzhenhua
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files for problems? Stop! Download the new AJAX search engine that makes searching your log files as easy as surfing the web. DOWNLOAD SPLUNK! http://ads.osdn.com/?ad_idv37&alloc_id%16865&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
致 礼!
蔡栋 caidong@kedacom.com 2005-12-01
i set the -a a0x80008000 s the link address as in file arch/mips/Makefile and set the -e 8018a040 asthe address of kernel_entry find in System.map
but when it run into thekernel call, at the first line of 8018a040, it generate a exception, and i find in sdram at 8018a040, it not the kernel_entry code but the first word of my zImage file.
so does anyone use the zImage to make uImage for mips?
Best regards
zhuzhenhua
On 12/1/05, 蔡栋 caidong@kedacom.com wrote:
zhuzhenhua,您好!
致 礼!
zhuzhenhua
蔡栋
