[RESEND v1] pxe_utils: add localcmd defination
pxe localboot usage too much limited, i think be useful improve it welcome for any suggestions and feedbacks...
1) add localcmd defination which can used with localboot by default localboot get from env, now we can define it in pxe script 2) localcmd can use without localboot 3) multiline usage for localcmd 4) add short alias ! for localcmd 5) localcmd eval as uboot script (run_command_list) 6) label + localcmd simple usage uboot pxe menu with uboot commands
Usage examples
# standalone usage LABEL update_uboot LOCALCMD ip=$tftp_remote_ip && tftpboot $ip:boot.scr.uimg && script
LABEL reset # multiline usage LOCALCMD echo RESET LOCALCMD reset
LABEL reset again # multiline alias usage ! echo RESET ! reset
LABEL localboot # redefile localcmd for localboot LOCALBOOT 1 LOCALCMD echo temporary redefine localcmd
Signed-off-by: Artem Lapkin art@khadas.com
--- v1: - fix free(label->localcmd) add proper realloc for multiline localcmd --- cmd/pxe_utils.c | 39 ++++++++++++++++++++++++++++++++++++++- cmd/pxe_utils.h | 1 + 2 files changed, 39 insertions(+), 1 deletion(-)
diff --git a/cmd/pxe_utils.c b/cmd/pxe_utils.c index f1ed671a..1fab3d9a 100644 --- a/cmd/pxe_utils.c +++ b/cmd/pxe_utils.c @@ -271,6 +271,9 @@ static void label_destroy(struct pxe_label *label) if (label->kernel) free(label->kernel);
+ if (label->localcmd) + free(label->localcmd); + if (label->config) free(label->config);
@@ -322,7 +325,10 @@ static int label_localboot(struct pxe_label *label) { char *localcmd;
- localcmd = from_env("localcmd"); + if (label->localcmd) + localcmd = label->localcmd; + else + localcmd = from_env("localcmd");
if (!localcmd) return -ENOENT; @@ -470,6 +476,11 @@ static int label_boot(struct cmd_tbl *cmdtp, struct pxe_label *label) return 0; }
+ if (label->localcmd) { + if (!label->localboot_val) + return run_command_list(label->localcmd, strlen(label->localcmd), 0); + } + if (!label->kernel) { printf("No kernel given, skipping %s\n", label->name); @@ -687,6 +698,8 @@ enum token_type { T_APPEND, T_INITRD, T_LOCALBOOT, + T_LOCALCMD, + T_LOCALCMD2, T_DEFAULT, T_PROMPT, T_INCLUDE, @@ -721,6 +734,8 @@ static const struct token keywords[] = { {"kernel", T_KERNEL}, {"linux", T_LINUX}, {"localboot", T_LOCALBOOT}, + {"localcmd", T_LOCALCMD}, + {"!", T_LOCALCMD2}, {"append", T_APPEND}, {"initrd", T_INITRD}, {"include", T_INCLUDE}, @@ -1102,6 +1117,7 @@ static int parse_label(char **c, struct pxe_menu *cfg) int len; char *s = *c; struct pxe_label *label; + char *add, *p; int err;
label = label_create(); @@ -1177,6 +1193,27 @@ static int parse_label(char **c, struct pxe_menu *cfg) err = parse_integer(c, &label->localboot_val); break;
+ case T_LOCALCMD: + case T_LOCALCMD2: + if (label->localcmd) { + err = parse_sliteral(c, &add); + if (err) { + p = realloc(label->localcmd, + strlen(label->localcmd) + + strlen(add) + 2); + if (p) { + label->localcmd = p; + sprintf(label->localcmd, + "%s\n%s", + label->localcmd, add); + } + free(add); + } + } else { + err = parse_sliteral(c, &label->localcmd); + } + break; + case T_IPAPPEND: err = parse_integer(c, &label->ipappend); break; diff --git a/cmd/pxe_utils.h b/cmd/pxe_utils.h index bbdc606b..cdac1327 100644 --- a/cmd/pxe_utils.h +++ b/cmd/pxe_utils.h @@ -49,6 +49,7 @@ struct pxe_label { int attempted; int localboot; int localboot_val; + char *localcmd; struct list_head list; };
Artem Lapkin
