[U-Boot] [PATCH] drivers/usb/gadget: select objects by obj-$(CONFIG-...)
Before switching to the real Kbuild, drivers/usb/gadget/Makefile must be fixed. If none of CONFIG_USB_GADGET, CONFIG_USB_ETHER, CONFIG_USB_DEVICE is defined, both obj- and obj-y get empty.
We need non-empty obj- or obj-y on each Makefile to generate built-in.o on the real Kbuild.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- drivers/usb/gadget/Makefile | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index f52d3f4..f13b172 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -5,12 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# if defined(CONFIG_USB_GADGET) || defined(CONFIG_USB_ETHER) -# Everytime you forget how crufty makefiles can get things like -# this remind you... -ifneq (,$(CONFIG_USB_GADGET)$(CONFIG_USB_ETHER)) -obj-y += epautoconf.o config.o usbstring.o -endif +obj-$(CONFIG_USB_GADGET) += epautoconf.o config.o usbstring.o +obj-$(CONFIG_USB_ETHER) += epautoconf.o config.o usbstring.o
# new USB gadget layer dependencies ifdef CONFIG_USB_GADGET
Masahiro Yamada
