[PATCH 1/1] common: return type board_get_usable_ram_top
board_get_usable_ram_top() returns a physical address that is stored in gd->ram_top. The return type of the function should be phys_addr_t like the current type of gd->ram_top.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- arch/arm/mach-imx/imx8m/soc.c | 2 +- arch/arm/mach-mvebu/arm64-common.c | 2 +- arch/arm/mach-rockchip/sdram.c | 2 +- arch/arm/mach-stm32mp/dram_init.c | 2 +- arch/arm/mach-sunxi/board.c | 2 +- arch/arm/mach-tegra/board2.c | 2 +- arch/mips/mach-jz47xx/jz4780/jz4780.c | 2 +- arch/mips/mach-octeon/dram.c | 2 +- arch/riscv/cpu/fu540/dram.c | 2 +- arch/riscv/cpu/fu740/dram.c | 2 +- arch/riscv/cpu/generic/dram.c | 2 +- arch/riscv/cpu/jh7110/dram.c | 2 +- arch/x86/cpu/broadwell/sdram.c | 2 +- arch/x86/cpu/coreboot/sdram.c | 2 +- arch/x86/cpu/efi/payload.c | 2 +- arch/x86/cpu/efi/sdram.c | 2 +- arch/x86/cpu/ivybridge/sdram.c | 2 +- arch/x86/cpu/qemu/dram.c | 2 +- arch/x86/cpu/quark/dram.c | 2 +- arch/x86/cpu/slimbootloader/sdram.c | 2 +- arch/x86/cpu/tangier/sdram.c | 2 +- arch/x86/include/asm/u-boot-x86.h | 2 +- arch/x86/lib/fsp1/fsp_dram.c | 2 +- arch/x86/lib/fsp2/fsp_dram.c | 2 +- board/broadcom/bcmns3/ns3.c | 2 +- board/imgtec/boston/ddr.c | 2 +- board/menlo/m53menlo/m53menlo.c | 2 +- board/raspberrypi/rpi/rpi.c | 2 +- board/ti/am65x/evm.c | 2 +- board/ti/j721e/evm.c | 2 +- board/ti/j721s2/evm.c | 2 +- board/toradex/verdin-am62/verdin-am62.c | 2 +- board/xilinx/common/board.c | 2 +- common/board_f.c | 2 +- include/init.h | 2 +- 35 files changed, 35 insertions(+), 35 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index d5254886be..78b775f449 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -333,7 +333,7 @@ phys_size_t get_effective_memsize(void) } }
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { ulong top_addr;
diff --git a/arch/arm/mach-mvebu/arm64-common.c b/arch/arm/mach-mvebu/arm64-common.c index d3a95730be..4c67f1aba4 100644 --- a/arch/arm/mach-mvebu/arm64-common.c +++ b/arch/arm/mach-mvebu/arm64-common.c @@ -30,7 +30,7 @@ DECLARE_GLOBAL_DATA_PTR; */ #define USABLE_RAM_SIZE 0x80000000ULL
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { unsigned long top = CFG_SYS_SDRAM_BASE + min(gd->ram_size, USABLE_RAM_SIZE);
diff --git a/arch/arm/mach-rockchip/sdram.c b/arch/arm/mach-rockchip/sdram.c index 1d17a740ad..99ecbdc341 100644 --- a/arch/arm/mach-rockchip/sdram.c +++ b/arch/arm/mach-rockchip/sdram.c @@ -216,7 +216,7 @@ int dram_init(void) return 0; }
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { unsigned long top = CFG_SYS_SDRAM_BASE + SDRAM_MAX_SIZE;
diff --git a/arch/arm/mach-stm32mp/dram_init.c b/arch/arm/mach-stm32mp/dram_init.c index 80ba5c2774..7f37b0d2aa 100644 --- a/arch/arm/mach-stm32mp/dram_init.c +++ b/arch/arm/mach-stm32mp/dram_init.c @@ -40,7 +40,7 @@ int dram_init(void) return 0; }
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { phys_size_t size; phys_addr_t reg; diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 391a65a549..78597ad932 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -64,7 +64,7 @@ static struct mm_region sunxi_mem_map[] = { }; struct mm_region *mem_map = sunxi_mem_map;
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { /* Some devices (like the EMAC) have a 32-bit DMA limit. */ if (gd->ram_top > (1ULL << 32)) diff --git a/arch/arm/mach-tegra/board2.c b/arch/arm/mach-tegra/board2.c index 0df18360ca..981768bb0e 100644 --- a/arch/arm/mach-tegra/board2.c +++ b/arch/arm/mach-tegra/board2.c @@ -403,7 +403,7 @@ int dram_init_banksize(void) * This function is called before dram_init_banksize(), so we can't simply * return gd->bd->bi_dram[1].start + gd->bd->bi_dram[1].size. */ -phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { ulong ram_top;
diff --git a/arch/mips/mach-jz47xx/jz4780/jz4780.c b/arch/mips/mach-jz47xx/jz4780/jz4780.c index 15d1eff2ba..676c305fd3 100644 --- a/arch/mips/mach-jz47xx/jz4780/jz4780.c +++ b/arch/mips/mach-jz47xx/jz4780/jz4780.c @@ -76,7 +76,7 @@ void board_init_f(ulong dummy) } #endif /* CONFIG_SPL_BUILD */
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { return CFG_SYS_SDRAM_BASE + (256 * 1024 * 1024); } diff --git a/arch/mips/mach-octeon/dram.c b/arch/mips/mach-octeon/dram.c index 85cb084c13..5b1311d8b5 100644 --- a/arch/mips/mach-octeon/dram.c +++ b/arch/mips/mach-octeon/dram.c @@ -77,7 +77,7 @@ phys_size_t get_effective_memsize(void) return UBOOT_RAM_SIZE_MAX; }
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { if (IS_ENABLED(CONFIG_RAM_OCTEON)) { /* Map a maximum of 256MiB - return not size but address */ diff --git a/arch/riscv/cpu/fu540/dram.c b/arch/riscv/cpu/fu540/dram.c index 44e11bd56c..94d8018407 100644 --- a/arch/riscv/cpu/fu540/dram.c +++ b/arch/riscv/cpu/fu540/dram.c @@ -21,7 +21,7 @@ int dram_init_banksize(void) return fdtdec_setup_memory_banksize(); }
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { /* * Ensure that we run from first 4GB so that all diff --git a/arch/riscv/cpu/fu740/dram.c b/arch/riscv/cpu/fu740/dram.c index d6d4a41d25..8657fcd165 100644 --- a/arch/riscv/cpu/fu740/dram.c +++ b/arch/riscv/cpu/fu740/dram.c @@ -20,7 +20,7 @@ int dram_init_banksize(void) return fdtdec_setup_memory_banksize(); }
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { #ifdef CONFIG_64BIT /* diff --git a/arch/riscv/cpu/generic/dram.c b/arch/riscv/cpu/generic/dram.c index 44e11bd56c..94d8018407 100644 --- a/arch/riscv/cpu/generic/dram.c +++ b/arch/riscv/cpu/generic/dram.c @@ -21,7 +21,7 @@ int dram_init_banksize(void) return fdtdec_setup_memory_banksize(); }
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { /* * Ensure that we run from first 4GB so that all diff --git a/arch/riscv/cpu/jh7110/dram.c b/arch/riscv/cpu/jh7110/dram.c index 2ad3f2044a..1a9fa46d14 100644 --- a/arch/riscv/cpu/jh7110/dram.c +++ b/arch/riscv/cpu/jh7110/dram.c @@ -21,7 +21,7 @@ int dram_init_banksize(void) return fdtdec_setup_memory_banksize(); }
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { /* * Ensure that we run from first 4GB so that all diff --git a/arch/x86/cpu/broadwell/sdram.c b/arch/x86/cpu/broadwell/sdram.c index 1295121ae5..f477d513ef 100644 --- a/arch/x86/cpu/broadwell/sdram.c +++ b/arch/x86/cpu/broadwell/sdram.c @@ -25,7 +25,7 @@ #include <asm/arch/pei_data.h> #include <asm/arch/pm.h>
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { return mrc_common_board_get_usable_ram_top(total_size); } diff --git a/arch/x86/cpu/coreboot/sdram.c b/arch/x86/cpu/coreboot/sdram.c index f4ee4cdf5d..26352df421 100644 --- a/arch/x86/cpu/coreboot/sdram.c +++ b/arch/x86/cpu/coreboot/sdram.c @@ -27,7 +27,7 @@ unsigned int install_e820_map(unsigned int max_entries, * address, and how far U-Boot is moved by relocation are set in the global * data structure. */ -phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { uintptr_t dest_addr = 0; int i; diff --git a/arch/x86/cpu/efi/payload.c b/arch/x86/cpu/efi/payload.c index 19a25dd640..d8920effd3 100644 --- a/arch/x86/cpu/efi/payload.c +++ b/arch/x86/cpu/efi/payload.c @@ -27,7 +27,7 @@ DECLARE_GLOBAL_DATA_PTR; * the relocation address, and how far U-Boot is moved by relocation are * set in the global data structure. */ -phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { struct efi_mem_desc *desc, *end; struct efi_entry_memmap *map; diff --git a/arch/x86/cpu/efi/sdram.c b/arch/x86/cpu/efi/sdram.c index f3086db42c..56f3326146 100644 --- a/arch/x86/cpu/efi/sdram.c +++ b/arch/x86/cpu/efi/sdram.c @@ -11,7 +11,7 @@
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { return (ulong)efi_get_ram_base() + gd->ram_size; } diff --git a/arch/x86/cpu/ivybridge/sdram.c b/arch/x86/cpu/ivybridge/sdram.c index 0718aefbb1..95a826da71 100644 --- a/arch/x86/cpu/ivybridge/sdram.c +++ b/arch/x86/cpu/ivybridge/sdram.c @@ -46,7 +46,7 @@ DECLARE_GLOBAL_DATA_PTR; #define CMOS_OFFSET_MRC_SEED_S3 156 #define CMOS_OFFSET_MRC_SEED_CHK 160
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { return mrc_common_board_get_usable_ram_top(total_size); } diff --git a/arch/x86/cpu/qemu/dram.c b/arch/x86/cpu/qemu/dram.c index 1a52d1dc52..d83abf0052 100644 --- a/arch/x86/cpu/qemu/dram.c +++ b/arch/x86/cpu/qemu/dram.c @@ -72,7 +72,7 @@ int dram_init_banksize(void) * the relocation address, and how far U-Boot is moved by relocation are * set in the global data structure. */ -phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { return qemu_get_low_memory_size(); } diff --git a/arch/x86/cpu/quark/dram.c b/arch/x86/cpu/quark/dram.c index 8b1ee2d5ae..ad98f3e07b 100644 --- a/arch/x86/cpu/quark/dram.c +++ b/arch/x86/cpu/quark/dram.c @@ -184,7 +184,7 @@ int dram_init_banksize(void) * the relocation address, and how far U-Boot is moved by relocation are * set in the global data structure. */ -phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { return gd->ram_size; } diff --git a/arch/x86/cpu/slimbootloader/sdram.c b/arch/x86/cpu/slimbootloader/sdram.c index d748d5c7d4..fbb33b246e 100644 --- a/arch/x86/cpu/slimbootloader/sdram.c +++ b/arch/x86/cpu/slimbootloader/sdram.c @@ -48,7 +48,7 @@ static struct sbl_memory_map_info *get_memory_map_info(void) * @total_size: The memory size that u-boot occupies * Return: : The top available memory address lower than 4GB */ -phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { struct sbl_memory_map_info *data; int i; diff --git a/arch/x86/cpu/tangier/sdram.c b/arch/x86/cpu/tangier/sdram.c index 8a4b1c5d2d..ee74a1f043 100644 --- a/arch/x86/cpu/tangier/sdram.c +++ b/arch/x86/cpu/tangier/sdram.c @@ -204,7 +204,7 @@ unsigned int install_e820_map(unsigned int max_entries, * address, and how far U-Boot is moved by relocation are set in the global * data structure. */ -phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { struct sfi_table_simple *sb; struct sfi_mem_entry *mentry; diff --git a/arch/x86/include/asm/u-boot-x86.h b/arch/x86/include/asm/u-boot-x86.h index 02a8b0f152..3acc58ad74 100644 --- a/arch/x86/include/asm/u-boot-x86.h +++ b/arch/x86/include/asm/u-boot-x86.h @@ -77,7 +77,7 @@ int x86_cleanup_before_linux(void); void x86_enable_caches(void); void x86_disable_caches(void); int x86_init_cache(void); -phys_size_t board_get_usable_ram_top(phys_size_t total_size); +phys_addr_t board_get_usable_ram_top(phys_size_t total_size); int default_print_cpuinfo(void);
/* Set up a UART which can be used with printch(), printhex8(), etc. */ diff --git a/arch/x86/lib/fsp1/fsp_dram.c b/arch/x86/lib/fsp1/fsp_dram.c index 5825221d1e..eee9ce54b1 100644 --- a/arch/x86/lib/fsp1/fsp_dram.c +++ b/arch/x86/lib/fsp1/fsp_dram.c @@ -34,7 +34,7 @@ int dram_init(void) * the relocation address, and how far U-Boot is moved by relocation are * set in the global data structure. */ -phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { return fsp_get_usable_lowmem_top(gd->arch.hob_list); } diff --git a/arch/x86/lib/fsp2/fsp_dram.c b/arch/x86/lib/fsp2/fsp_dram.c index f9ea1ab3ba..a1432239cf 100644 --- a/arch/x86/lib/fsp2/fsp_dram.c +++ b/arch/x86/lib/fsp2/fsp_dram.c @@ -77,7 +77,7 @@ int dram_init(void) return 0; }
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { if (!ll_boot_init()) return gd->ram_size; diff --git a/board/broadcom/bcmns3/ns3.c b/board/broadcom/bcmns3/ns3.c index 2a78df670c..7ae6742c4b 100644 --- a/board/broadcom/bcmns3/ns3.c +++ b/board/broadcom/bcmns3/ns3.c @@ -183,7 +183,7 @@ int dram_init_banksize(void) }
/* Limit RAM used by U-Boot to the DDR first bank End region */ -phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { return BCM_NS3_MEM_END; } diff --git a/board/imgtec/boston/ddr.c b/board/imgtec/boston/ddr.c index 8532225dc0..cecf454011 100644 --- a/board/imgtec/boston/ddr.c +++ b/board/imgtec/boston/ddr.c @@ -23,7 +23,7 @@ int dram_init(void) return 0; }
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { DECLARE_GLOBAL_DATA_PTR;
diff --git a/board/menlo/m53menlo/m53menlo.c b/board/menlo/m53menlo/m53menlo.c index ca3b81c57f..b8dffb0e48 100644 --- a/board/menlo/m53menlo/m53menlo.c +++ b/board/menlo/m53menlo/m53menlo.c @@ -42,7 +42,7 @@ DECLARE_GLOBAL_DATA_PTR;
static u32 mx53_dram_size[2];
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { /* * WARNING: We must override get_effective_memsize() function here diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 1057ebb994..2b5f5d68db 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -334,7 +334,7 @@ static void set_fdt_addr(void) /* * Prevent relocation from stomping on a firmware provided FDT blob. */ -phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { if ((gd->ram_top - fw_dtb_pointer) > SZ_64M) return gd->ram_top; diff --git a/board/ti/am65x/evm.c b/board/ti/am65x/evm.c index 706b219818..d52ac332f8 100644 --- a/board/ti/am65x/evm.c +++ b/board/ti/am65x/evm.c @@ -59,7 +59,7 @@ int dram_init(void) return 0; }
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { #ifdef CONFIG_PHYS_64BIT /* Limit RAM used by U-Boot to the DDR low region */ diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 2398bead78..38fe447d8f 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -55,7 +55,7 @@ int dram_init(void) return 0; }
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { #ifdef CONFIG_PHYS_64BIT /* Limit RAM used by U-Boot to the DDR low region */ diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index 8eaca9d5af..7795300abc 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -43,7 +43,7 @@ int dram_init(void) return 0; }
-phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { #ifdef CONFIG_PHYS_64BIT /* Limit RAM used by U-Boot to the DDR low region */ diff --git a/board/toradex/verdin-am62/verdin-am62.c b/board/toradex/verdin-am62/verdin-am62.c index 5b166b14ca..a3d1d07a0c 100644 --- a/board/toradex/verdin-am62/verdin-am62.c +++ b/board/toradex/verdin-am62/verdin-am62.c @@ -37,7 +37,7 @@ int dram_init(void) /* * Avoid relocated U-Boot clash with Linux reserved-memory on 512 MB SoM */ -phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { return 0x9C000000; } diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 0328d68e75..906d5e3c2d 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -627,7 +627,7 @@ int embedded_dtb_select(void) #endif
#if defined(CONFIG_LMB) -phys_size_t board_get_usable_ram_top(phys_size_t total_size) +phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { phys_size_t size; phys_addr_t reg; diff --git a/common/board_f.c b/common/board_f.c index 791c1e601c..e9f4edb93d 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -330,7 +330,7 @@ __weak int mach_cpu_init(void) }
/* Get the top of usable RAM */ -__weak phys_size_t board_get_usable_ram_top(phys_size_t total_size) +__weak phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { #if defined(CFG_SYS_SDRAM_BASE) && CFG_SYS_SDRAM_BASE > 0 /* diff --git a/include/init.h b/include/init.h index 8873081685..b1e1451166 100644 --- a/include/init.h +++ b/include/init.h @@ -304,7 +304,7 @@ int show_board_info(void); * * @param total_size Size of U-Boot (unused?) */ -phys_size_t board_get_usable_ram_top(phys_size_t total_size); +phys_addr_t board_get_usable_ram_top(phys_size_t total_size);
int board_early_init_f(void);
Hi Heinrich,
On Sat, 12 Aug 2023 at 23:01, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
While you are here, could you please fix the function comment?
- @param total_size Size of U-Boot (unused?)
It seems confused about the param, and we should have a return value.
Also should explain what this function is used for.
-- 2.40.1
On 8/13/23 15:36, Simon Glass wrote:
Hi Heinrich,
The parameter with the monitor length (size of U-Boot code) is not used anywhere (though it is passed on to functions like mrc_common_board_get_usable_ram_top() where it isn't used either).
We should try to eliminate the parameter in further patches.
That explanation exists.
I will put the documentation fix into a separate patch so we can apply it to 2023.10. I don't know if Tom wants to apply this patch to next or to 2023.10.
Best regards
Heinrich
-- 2.40.1
Hi Heinrich,
I'm thinking we should take this for v2023.10.
