[PATCH v2] serial: mxs: Add MXS AUART driver
Add trivial driver for the MXS AUART IP. This is the other UART IP present in i.MX23 and i.MX28, used to drive the non-DUART ports.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Andrejs Cainikovs andrejs.cainikovs@toradex.com Cc: Fabio Estevam festevam@gmail.com Cc: Fedor Ross fedor.ross@ifm.com Cc: Jim Liu jim.t90615@gmail.com Cc: Johan Jonker jbx6244@gmail.com Cc: Marek Vasut marex@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Samuel Holland samuel@sholland.org Cc: Sean Anderson sean.anderson@seco.com Cc: Simon Glass sjg@chromium.org Cc: Stanley Chu yschu@nuvoton.com Cc: Stefan Bosch stefan_b@posteo.net Cc: Stefan Roese sr@denx.de Cc: Stefano Babic sbabic@denx.de Cc: Ye Li ye.li@nxp.com --- V2: Flip the input data test condition --- drivers/serial/Kconfig | 8 +++ drivers/serial/Makefile | 1 + drivers/serial/serial_mxs.c | 129 ++++++++++++++++++++++++++++++++++++ 3 files changed, 138 insertions(+) create mode 100644 drivers/serial/serial_mxs.c
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 7faf6784442..59b2be55751 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -956,6 +956,14 @@ config MSM_GENI_SERIAL Driver works in FIFO mode. Multiple baudrates supported.
+config MXS_AUART_SERIAL + bool "MXS AUART" + depends on DM_SERIAL + help + Support for Freescale i.MX23 / i.MX28 AUART or Application UART IP. + This IP is present in the aforementioned SoCs, however this is not + the IP used to drive the Debug UART port, for that see PL01X_SERIAL . + config OCTEON_SERIAL_BOOTCMD bool "MIPS Octeon PCI remote bootcmd input" depends on ARCH_OCTEON diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 01fef3f323b..403ab1ded68 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -46,6 +46,7 @@ obj-$(CONFIG_BCM283X_MU_SERIAL) += serial_bcm283x_mu.o obj-$(CONFIG_BCM283X_PL011_SERIAL) += serial_bcm283x_pl011.o obj-$(CONFIG_MSM_SERIAL) += serial_msm.o obj-$(CONFIG_MSM_GENI_SERIAL) += serial_msm_geni.o +obj-$(CONFIG_MXS_AUART_SERIAL) += serial_mxs.o obj-$(CONFIG_MVEBU_A3700_UART) += serial_mvebu_a3700.o obj-$(CONFIG_MPC8XX_CONS) += serial_mpc8xx.o obj-$(CONFIG_NULLDEV_SERIAL) += serial_nulldev.o diff --git a/drivers/serial/serial_mxs.c b/drivers/serial/serial_mxs.c new file mode 100644 index 00000000000..3659948b872 --- /dev/null +++ b/drivers/serial/serial_mxs.c @@ -0,0 +1,129 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023 Marek Vasut marex@denx.de + */ +#include <common.h> +#include <dm.h> +#include <malloc.h> +#include <serial.h> +#include <wait_bit.h> + +#define SET_REG 0x4 +#define CLR_REG 0x8 + +#define AUART_CTRL0 0x00 +#define AUART_CTRL1 0x10 +#define AUART_CTRL2 0x20 +#define AUART_LINECTRL 0x30 +#define AUART_INTR 0x50 +#define AUART_DATA 0x60 +#define AUART_STAT 0x70 + +#define AUART_CTRL0_SFTRST BIT(31) +#define AUART_CTRL0_CLKGATE BIT(30) + +#define AUART_CTRL2_UARTEN BIT(0) + +#define AUART_LINECTRL_BAUD_DIVINT(v) (((v) & 0xffff) << 16) +#define AUART_LINECTRL_BAUD_DIVFRAC(v) (((v) & 0x3f) << 8) +#define AUART_LINECTRL_WLEN(v) ((((v) - 5) & 0x3) << 5) + +#define AUART_STAT_TXFE BIT(27) +#define AUART_STAT_TXFF BIT(25) +#define AUART_STAT_RXFE BIT(24) + +#define AUART_CLK 24000000 + +struct mxs_auart_uart_priv { + void __iomem *base; +}; + +static int mxs_auart_uart_setbrg(struct udevice *dev, int baudrate) +{ + struct mxs_auart_uart_priv *priv = dev_get_priv(dev); + u32 div; + + writel(AUART_CTRL0_CLKGATE, priv->base + AUART_CTRL0 + CLR_REG); + writel(AUART_CTRL0_SFTRST, priv->base + AUART_CTRL0 + CLR_REG); + + writel(AUART_CTRL2_UARTEN, priv->base + AUART_CTRL2 + SET_REG); + + writel(0, priv->base + AUART_INTR); + + div = DIV_ROUND_CLOSEST(AUART_CLK * 32, baudrate); + + /* Disable FIFO, baudrate, 8N1. */ + writel(AUART_LINECTRL_BAUD_DIVFRAC(div & 0x3F) | + AUART_LINECTRL_BAUD_DIVINT(div >> 6) | + AUART_LINECTRL_WLEN(8), + priv->base + AUART_LINECTRL); + + return 0; +} + +static int mxs_auart_uart_pending(struct udevice *dev, bool input) +{ + struct mxs_auart_uart_priv *priv = dev_get_priv(dev); + u32 stat = readl(priv->base + AUART_STAT); + + if (input) + return !(stat & AUART_STAT_RXFE); + + return !!(stat & AUART_STAT_TXFE); +} + +static int mxs_auart_uart_putc(struct udevice *dev, const char ch) +{ + struct mxs_auart_uart_priv *priv = dev_get_priv(dev); + u32 stat = readl(priv->base + AUART_STAT); + + if (stat & AUART_STAT_TXFF) + return -EAGAIN; + + writel(ch, priv->base + AUART_DATA); + + return 0; +} + +static int mxs_auart_uart_getc(struct udevice *dev) +{ + struct mxs_auart_uart_priv *priv = dev_get_priv(dev); + + if (!mxs_auart_uart_pending(dev, true)) + return -EAGAIN; + + return readl(priv->base + AUART_DATA) & 0xff; +} + +static int mxs_auart_uart_probe(struct udevice *dev) +{ + struct mxs_auart_uart_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -EINVAL; + + return mxs_auart_uart_setbrg(dev, CONFIG_BAUDRATE); +} + +static const struct dm_serial_ops mxs_auart_uart_ops = { + .putc = mxs_auart_uart_putc, + .pending = mxs_auart_uart_pending, + .getc = mxs_auart_uart_getc, + .setbrg = mxs_auart_uart_setbrg, +}; + +static const struct udevice_id mxs_auart_uart_ids[] = { + { .compatible = "fsl,imx23-auart", }, + { .compatible = "fsl,imx28-auart", }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(mxs_auart_serial) = { + .name = "mxs-auart", + .id = UCLASS_SERIAL, + .of_match = mxs_auart_uart_ids, + .probe = mxs_auart_uart_probe, + .ops = &mxs_auart_uart_ops, + .priv_auto = sizeof(struct mxs_auart_uart_priv), +};
Add trivial driver for the MXS AUART IP. This is the other UART IP present in i.MX23 and i.MX28, used to drive the non-DUART ports. Signed-off-by: Marek Vasut marex@denx.de
Best regards, Stefano Babic
sbabic@denx.de
