[U-Boot] [PATCH] mx28evk: Remove fecmxc_mii_postcall()
fecmxc_mii_postcall() is specific to the KSZ9021 PHY on m28evk and should not be used on mx28evk, which has LAN8270 instead.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx28evk/mx28evk.c | 25 ------------------------- 1 file changed, 25 deletions(-)
diff --git a/board/freescale/mx28evk/mx28evk.c b/board/freescale/mx28evk/mx28evk.c index d782aea..6e719ff 100644 --- a/board/freescale/mx28evk/mx28evk.c +++ b/board/freescale/mx28evk/mx28evk.c @@ -100,19 +100,6 @@ int board_mmc_init(bd_t *bis)
#ifdef CONFIG_CMD_NET
-#define MII_OPMODE_STRAP_OVERRIDE 0x16 -#define MII_PHY_CTRL1 0x1e -#define MII_PHY_CTRL2 0x1f - -int fecmxc_mii_postcall(int phy) -{ - miiphy_write("FEC1", phy, MII_BMCR, 0x9000); - miiphy_write("FEC1", phy, MII_OPMODE_STRAP_OVERRIDE, 0x0202); - if (phy == 3) - miiphy_write("FEC1", 3, MII_PHY_CTRL2, 0x8180); - return 0; -} - int board_eth_init(bd_t *bis) { struct mxs_clkctrl_regs *clkctrl_regs = @@ -152,24 +139,12 @@ int board_eth_init(bd_t *bis) return -EINVAL; }
- ret = fecmxc_register_mii_postcall(dev, fecmxc_mii_postcall); - if (ret) { - puts("FEC MXS: Unable to register FEC0 mii postcall\n"); - return ret; - } - dev = eth_get_dev_by_name("FEC1"); if (!dev) { puts("FEC MXS: Unable to get FEC1 device entry\n"); return -EINVAL; }
- ret = fecmxc_register_mii_postcall(dev, fecmxc_mii_postcall); - if (ret) { - puts("FEC MXS: Unable to register FEC1 mii postcall\n"); - return ret; - } - return ret; }
Dear Fabio Estevam,
Acked-by: Marek Vasut marex@denx.de
This is a fix, so should go into current release.
- if (phy == 3)
if (ret) {
return ret;
if (ret) {
return ret;
return ret;
Best regards, Marek Vasut
Applied to u-boot-imx (fix), thanks.
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
