[U-Boot] [PATCH 4/6] 4xx: Cleanup PLU405 platform file
This patch - wraps some long lines - removes unused/obsolete functions: misc_init_f() and initdram()
Signed-off-by: Matthias Fuchs mf@esd.eu --- board/esd/plu405/plu405.c | 58 ++++++++++++++++---------------------------- 1 files changed, 21 insertions(+), 37 deletions(-)
diff --git a/board/esd/plu405/plu405.c b/board/esd/plu405/plu405.c index fc71e9a..3db9c0a 100644 --- a/board/esd/plu405/plu405.c +++ b/board/esd/plu405/plu405.c @@ -65,11 +65,9 @@ au_image_t au_image[] = {
int N_AU_IMAGES = (sizeof(au_image) / sizeof(au_image[0]));
- /* Prototypes */ int gunzip(void *, int, unsigned char *, unsigned long *);
- int board_early_init_f (void) { /* @@ -89,24 +87,18 @@ int board_early_init_f (void) mtdcr(uiccr, 0x00000000); /* set all to be non-critical*/ mtdcr(uicpr, 0xFFFFFF99); /* set int polarities */ mtdcr(uictr, 0x10000000); /* set int trigger levels */ - mtdcr(uicvcr, 0x00000001); /* set vect base=0,INT0 highest priority*/ + mtdcr(uicvcr, 0x00000001); /* set vect base=0,INT0 highest prio */ mtdcr(uicsr, 0xFFFFFFFF); /* clear all ints */
/* - * EBC Configuration Register: set ready timeout to 512 ebc-clks -> ca. 15 us + * EBC Configuration Register: set ready timeout to + * 512 ebc-clks -> ca. 15 us */ mtebc (epcr, 0xa8400000); /* ebc always driven */
return 0; }
- -int misc_init_f (void) -{ - return 0; /* dummy implementation */ -} - - int misc_init_r (void) { unsigned char *duart0_mcr = (unsigned char *)((ulong)DUART0_BA + 4); @@ -132,13 +124,16 @@ int misc_init_r (void) printf("\nFPGA: Booting failed "); switch (status) { case ERROR_FPGA_PRG_INIT_LOW: - printf("(Timeout: INIT not low after asserting PROGRAM*)\n "); + printf("(Timeout: INIT not low " + "after asserting PROGRAM*)\n"); break; case ERROR_FPGA_PRG_INIT_HIGH: - printf("(Timeout: INIT not high after deasserting PROGRAM*)\n "); + printf("(Timeout: INIT not high " + "after deasserting PROGRAM*)\n"); break; case ERROR_FPGA_PRG_DONE: - printf("(Timeout: DONE not high after programming FPGA)\n "); + printf("(Timeout: DONE not high " + "after programming FPGA)\n"); break; }
@@ -184,15 +179,16 @@ int misc_init_r (void) /* * Reset external DUARTs */ - out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) | CFG_DUART_RST); /* set reset to high */ - udelay(10); /* wait 10us */ - out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) & ~CFG_DUART_RST); /* set reset to low */ - udelay(1000); /* wait 1ms */ + out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) | CFG_DUART_RST); + udelay(10); + out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) & ~CFG_DUART_RST); + udelay(1000);
/* * Set NAND-FLASH GPIO signals to default */ - out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) & ~(CFG_NAND_CLE | CFG_NAND_ALE)); + out_be32((void*)GPIO0_OR, + in_be32((void*)GPIO0_OR) & ~(CFG_NAND_CLE | CFG_NAND_ALE)); out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) | CFG_NAND_CE);
/* @@ -210,7 +206,6 @@ int misc_init_r (void) return (0); }
- /* * Check Board Identity: */ @@ -231,18 +226,6 @@ int checkboard (void) return 0; }
- -phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -} - - #ifdef CONFIG_IDE_RESET void ide_set_reset(int on) { @@ -260,7 +243,6 @@ void ide_set_reset(int on) } #endif /* CONFIG_IDE_RESET */
- void reset_phy(void) { #ifdef CONFIG_LXT971_NO_SLEEP @@ -272,7 +254,6 @@ void reset_phy(void) #endif }
- #if defined(CFG_EEPROM_WREN) /* Input: <dev_addr> I2C address of EEPROM device to enable. * <state> -1: deliver current state @@ -290,17 +271,20 @@ int eeprom_write_enable (unsigned dev_addr, int state) switch (state) { case 1: /* Enable write access, clear bit GPIO0. */ - out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) & ~CFG_EEPROM_WP); + out_be32((void*)GPIO0_OR, + in_be32((void*)GPIO0_OR) & ~CFG_EEPROM_WP); state = 0; break; case 0: /* Disable write access, set bit GPIO0. */ - out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) | CFG_EEPROM_WP); + out_be32((void*)GPIO0_OR, + in_be32((void*)GPIO0_OR) | CFG_EEPROM_WP); state = 0; break; default: /* Read current status back. */ - state = (0 == (in_be32((void*)GPIO0_OR) & CFG_EEPROM_WP)); + state = (0 == (in_be32((void*)GPIO0_OR) & + CFG_EEPROM_WP)); break; } }
Matthias Fuchs
