[U-Boot] [PATCH v2] pci/fsl_pci_init: Use PCIe capability to determine if controller is PCIe
Change the code to use the PCIe capabilities register to determine if we are a PCIe controller or not. Additionally cleaned up some white space and formatting in the file.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- * Fixed whitespace issue
drivers/pci/fsl_pci_init.c | 32 +++++++++++++------------------- include/pci.h | 1 + 2 files changed, 14 insertions(+), 19 deletions(-)
diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index c40ab30..5c54c4f 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -137,16 +137,12 @@ void fsl_pci_init(struct pci_controller *hose, u32 cfg_addr, u32 cfg_data) { u16 temp16; u32 temp32; - int busno = hose->first_busno; - int enabled; + int enabled, r, inbound = 0; u16 ltssm; - u8 temp8; - int r; - int bridge; - int inbound = 0; + u8 temp8, pcie_cap; volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *)cfg_addr; struct pci_region *reg = hose->regions + hose->region_count; - pci_dev_t dev = PCI_BDF(busno,0,0); + pci_dev_t dev = PCI_BDF(hose->first_busno, 0, 0);
/* Initialize ATMU registers based on hose regions and flags */ volatile pot_t *po = &pci->pot[1]; /* skip 0 */ @@ -198,6 +194,9 @@ void fsl_pci_init(struct pci_controller *hose, u32 cfg_addr, u32 cfg_data) } }
+ /* see if we are a PCIe or PCI controller */ + pci_hose_read_config_byte(hose, dev, FSL_PCIE_CAP_ID, &pcie_cap); + pci_register_hose(hose); pciauto_config_init(hose); /* grab pci_{mem,prefetch,io} */ hose->current_busno = hose->first_busno; @@ -212,11 +211,7 @@ void fsl_pci_init(struct pci_controller *hose, u32 cfg_addr, u32 cfg_data) temp32 |= 0xf000e; /* set URR, FER, NFER (but not CER) */ pci_hose_write_config_dword(hose, dev, PCI_DCR, temp32);
- pci_hose_read_config_byte (hose, dev, PCI_HEADER_TYPE, &temp8); - bridge = temp8 & PCI_HEADER_TYPE_BRIDGE; /* Bridge, such as pcie */ - - if ( bridge ) { - + if (pcie_cap == PCI_CAP_ID_EXP) { pci_hose_read_config_word(hose, dev, PCI_LTSSM, <ssm); enabled = ltssm >= PCI_LTSSM_L0;
@@ -260,14 +255,12 @@ void fsl_pci_init(struct pci_controller *hose, u32 cfg_addr, u32 cfg_data) #endif hose->current_busno++; /* Start scan with secondary */ pciauto_prescan_setup_bridge(hose, dev, hose->current_busno); - }
/* Use generic setup_device to initialize standard pci regs, * but do not allocate any windows since any BAR found (such * as PCSRBAR) is not in this cpu's memory space. */ - pciauto_setup_device(hose, dev, 0, hose->pci_mem, hose->pci_prefetch, hose->pci_io);
@@ -294,7 +287,10 @@ void fsl_pci_init(struct pci_controller *hose, u32 cfg_addr, u32 cfg_data) hose->last_busno = hose->current_busno; }
- if ( bridge ) { /* update limit regs and subordinate busno */ + /* if we are PCIe - update limit regs and subordinate busno + * for the virtual P2P bridge + */ + if (pcie_cap == PCI_CAP_ID_EXP) { pciauto_postscan_setup_bridge(hose, dev, hose->last_busno); } #else @@ -302,15 +298,13 @@ void fsl_pci_init(struct pci_controller *hose, u32 cfg_addr, u32 cfg_data) #endif
/* Clear all error indications */ - - if (bridge) + if (pcie_cap == PCI_CAP_ID_EXP) pci->pme_msg_det = 0xffffffff; pci->pedr = 0xffffffff;
pci_hose_read_config_word (hose, dev, PCI_DSR, &temp16); if (temp16) { - pci_hose_write_config_word(hose, dev, - PCI_DSR, 0xffff); + pci_hose_write_config_word(hose, dev, PCI_DSR, 0xffff); }
pci_hose_read_config_word (hose, dev, PCI_SEC_STATUS, &temp16); diff --git a/include/pci.h b/include/pci.h index aaa4554..491f814 100644 --- a/include/pci.h +++ b/include/pci.h @@ -222,6 +222,7 @@ #define PCI_CAP_ID_SLOTID 0x04 /* Slot Identification */ #define PCI_CAP_ID_MSI 0x05 /* Message Signalled Interrupts */ #define PCI_CAP_ID_CHSWP 0x06 /* CompactPCI HotSwap */ +#define PCI_CAP_ID_EXP 0x10 /* PCI Express */ #define PCI_CAP_LIST_NEXT 1 /* Next capability in the list */ #define PCI_CAP_FLAGS 2 /* Capability defined flags (16 bits) */ #define PCI_CAP_SIZEOF 4
Kumar Gala
