[U-Boot] [PATCH] AX88180: fix media typos
Signed-off-by: Hoan Hoang hnhoan@i-syst.com Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/net/ax88180.c | 20 ++++++++++---------- 1 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/drivers/net/ax88180.c b/drivers/net/ax88180.c index d843397..5d12fcf 100644 --- a/drivers/net/ax88180.c +++ b/drivers/net/ax88180.c @@ -50,9 +50,9 @@ */ static void ax88180_rx_handler (struct eth_device *dev); static int ax88180_phy_initial (struct eth_device *dev); -static void ax88180_meidia_config (struct eth_device *dev); -static unsigned long get_CicadaPHY_meida_mode (struct eth_device *dev); -static unsigned long get_MarvellPHY_meida_mode (struct eth_device *dev); +static void ax88180_media_config (struct eth_device *dev); +static unsigned long get_CicadaPHY_media_mode (struct eth_device *dev); +static unsigned long get_MarvellPHY_media_mode (struct eth_device *dev); static unsigned short ax88180_mdio_read (struct eth_device *dev, unsigned long regaddr); static void ax88180_mdio_write (struct eth_device *dev, @@ -300,7 +300,7 @@ static int ax88180_phy_initial (struct eth_device *dev) return 1; }
-static void ax88180_meidia_config (struct eth_device *dev) +static void ax88180_media_config (struct eth_device *dev) { struct ax88180_private *priv = (struct ax88180_private *)dev->priv; unsigned long bmcr_val, bmsr_val; @@ -346,9 +346,9 @@ static void ax88180_meidia_config (struct eth_device *dev)
/* Get real media mode here */ if (priv->PhyID0 == MARVELL_88E1111_PHYIDR0) { - RealMediaMode = get_MarvellPHY_meida_mode (dev); + RealMediaMode = get_MarvellPHY_media_mode (dev); } else if (priv->PhyID0 == CICADA_CIS8201_PHYIDR0) { - RealMediaMode = get_CicadaPHY_meida_mode (dev); + RealMediaMode = get_CicadaPHY_media_mode (dev); } else { RealMediaMode = MEDIA_1000FULL; } @@ -424,7 +424,7 @@ static void ax88180_meidia_config (struct eth_device *dev) return; }
-static unsigned long get_MarvellPHY_meida_mode (struct eth_device *dev) +static unsigned long get_MarvellPHY_media_mode (struct eth_device *dev) { unsigned long m88_ssr; unsigned long MediaMode; @@ -457,7 +457,7 @@ static unsigned long get_MarvellPHY_meida_mode (struct eth_device *dev) return MediaMode; }
-static unsigned long get_CicadaPHY_meida_mode (struct eth_device *dev) +static unsigned long get_CicadaPHY_media_mode (struct eth_device *dev) { unsigned long tmp_regval; unsigned long MediaMode; @@ -522,7 +522,7 @@ static int ax88180_init (struct eth_device *dev, bd_t * bd) dev->enetaddr[4] | (((unsigned short)dev->enetaddr[5]) << 8); OUTW (dev, tmp_regval, MACID2);
- ax88180_meidia_config (dev); + ax88180_media_config (dev);
OUTW (dev, DEFAULT_RXFILTER, RXFILTER);
@@ -558,7 +558,7 @@ static int ax88180_recv (struct eth_device *dev) if (ISR_Status & ISR_PHY) { /* Read ISR register once to clear PHY interrupt bit */ tmp_regval = ax88180_mdio_read (dev, M88_ISR); - ax88180_meidia_config (dev); + ax88180_media_config (dev); }
if ((ISR_Status & ISR_RX) || (ISR_Status & ISR_RXBUFFOVR)) {
Hi Mike,
On 5/10/2010 1:09 PM, Mike Frysinger wrote:
Signed-off-by: Hoan Hoanghnhoan@i-syst.com Signed-off-by: Mike Frysingervapier@gentoo.org
Applied to net/next.
regards, Ben
Ben Warren
Mike Frysinger
