[U-Boot] [PATCH] ARM: uniphier: rename function names ph1_* to uniphier_*
Eliminate the "ph1"_ prefixes from function names because "uniphier_" describes the SoC familiy better.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/arm32/debug_ll.S | 28 +++---- arch/arm/mach-uniphier/bcu/bcu-ld4.c | 2 +- arch/arm/mach-uniphier/bcu/bcu-sld3.c | 2 +- arch/arm/mach-uniphier/board_early_init_f.c | 28 +++---- arch/arm/mach-uniphier/boards.c | 34 ++++---- arch/arm/mach-uniphier/boot-mode/boot-device.h | 16 ++-- arch/arm/mach-uniphier/boot-mode/boot-mode-ld4.c | 4 +- arch/arm/mach-uniphier/boot-mode/boot-mode-pro5.c | 4 +- arch/arm/mach-uniphier/boot-mode/boot-mode-pxs2.c | 4 +- arch/arm/mach-uniphier/boot-mode/boot-mode-sld3.c | 4 +- arch/arm/mach-uniphier/boot-mode/boot-mode.c | 8 +- arch/arm/mach-uniphier/boot-mode/cmd_pinmon.c | 8 +- arch/arm/mach-uniphier/clk/clk-ld4.c | 2 +- arch/arm/mach-uniphier/clk/clk-pro4.c | 2 +- arch/arm/mach-uniphier/clk/clk-pro5.c | 2 +- arch/arm/mach-uniphier/clk/clk-pxs2.c | 2 +- arch/arm/mach-uniphier/dram/ddrphy-ld4.c | 3 +- arch/arm/mach-uniphier/dram/ddrphy-regs.h | 3 +- arch/arm/mach-uniphier/dram/umc-ld4.c | 4 +- arch/arm/mach-uniphier/dram/umc-pro4.c | 4 +- arch/arm/mach-uniphier/dram/umc-pxs2.c | 2 +- arch/arm/mach-uniphier/dram/umc-sld8.c | 4 +- arch/arm/mach-uniphier/early-clk/early-clk-ld4.c | 2 +- arch/arm/mach-uniphier/early-clk/early-clk-pro5.c | 2 +- arch/arm/mach-uniphier/early-clk/early-clk-pxs2.c | 2 +- .../early-pinctrl/early-pinctrl-sld3.c | 2 +- arch/arm/mach-uniphier/init.h | 94 +++++++++++----------- arch/arm/mach-uniphier/init/init-ld4.c | 14 ++-- arch/arm/mach-uniphier/init/init-pro4.c | 12 +-- arch/arm/mach-uniphier/init/init-pro5.c | 6 +- arch/arm/mach-uniphier/init/init-pxs2.c | 10 +-- arch/arm/mach-uniphier/init/init-sld3.c | 16 ++-- arch/arm/mach-uniphier/init/init-sld8.c | 14 ++-- arch/arm/mach-uniphier/init/init.c | 12 +-- arch/arm/mach-uniphier/memconf/memconf-pxs2.c | 2 +- arch/arm/mach-uniphier/memconf/memconf-sld3.c | 2 +- arch/arm/mach-uniphier/pinctrl/pinctrl-ld4.c | 2 +- arch/arm/mach-uniphier/pinctrl/pinctrl-ld6b.c | 2 +- arch/arm/mach-uniphier/pinctrl/pinctrl-pro4.c | 2 +- arch/arm/mach-uniphier/pinctrl/pinctrl-pro5.c | 2 +- arch/arm/mach-uniphier/pinctrl/pinctrl-pxs2.c | 2 +- arch/arm/mach-uniphier/pinctrl/pinctrl-sld3.c | 2 +- arch/arm/mach-uniphier/pinctrl/pinctrl-sld8.c | 2 +- arch/arm/mach-uniphier/pll/pll-init-ld4.c | 2 +- arch/arm/mach-uniphier/pll/pll-init-pro4.c | 2 +- arch/arm/mach-uniphier/pll/pll-init-sld3.c | 2 +- arch/arm/mach-uniphier/pll/pll-init-sld8.c | 2 +- arch/arm/mach-uniphier/pll/pll-spectrum-ld4.c | 2 +- arch/arm/mach-uniphier/pll/pll-spectrum-sld3.c | 2 +- arch/arm/mach-uniphier/sbc/sbc-admulti.c | 2 +- arch/arm/mach-uniphier/sbc/sbc-savepin.c | 2 +- 51 files changed, 197 insertions(+), 193 deletions(-)
diff --git a/arch/arm/mach-uniphier/arm32/debug_ll.S b/arch/arm/mach-uniphier/arm32/debug_ll.S index 5db7427..76631f2 100644 --- a/arch/arm/mach-uniphier/arm32/debug_ll.S +++ b/arch/arm/mach-uniphier/arm32/debug_ll.S @@ -29,7 +29,7 @@ ENTRY(debug_ll_init) #if defined(CONFIG_ARCH_UNIPHIER_SLD3) #define UNIPHIER_SLD3_UART_CLK 36864000 cmp r1, #0x25 - bne ph1_sld3_end + bne sld3_end
sg_set_pinsel 64, 1, 4, 4, r0, r1 @ TXD0 -> TXD0
@@ -45,12 +45,12 @@ ENTRY(debug_ll_init) ldr r3, =DIV_ROUND(UNIPHIER_SLD3_UART_CLK, 16 * BAUDRATE)
b init_uart -ph1_sld3_end: +sld3_end: #endif #if defined(CONFIG_ARCH_UNIPHIER_LD4) #define UNIPHIER_LD4_UART_CLK 36864000 cmp r1, #0x26 - bne ph1_ld4_end + bne ld4_end
ldr r0, =SG_IECTRL ldr r1, [r0] @@ -62,12 +62,12 @@ ph1_sld3_end: ldr r3, =DIV_ROUND(UNIPHIER_LD4_UART_CLK, 16 * BAUDRATE)
b init_uart -ph1_ld4_end: +ld4_end: #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO4) #define UNIPHIER_PRO4_UART_CLK 73728000 cmp r1, #0x28 - bne ph1_pro4_end + bne pro4_end
sg_set_pinsel 128, 0, 4, 8, r0, r1 @ TXD0 -> TXD0
@@ -83,12 +83,12 @@ ph1_ld4_end: ldr r3, =DIV_ROUND(UNIPHIER_PRO4_UART_CLK, 16 * BAUDRATE)
b init_uart -ph1_pro4_end: +pro4_end: #endif #if defined(CONFIG_ARCH_UNIPHIER_SLD8) #define UNIPHIER_SLD8_UART_CLK 80000000 cmp r1, #0x29 - bne ph1_sld8_end + bne sld8_end
ldr r0, =SG_IECTRL ldr r1, [r0] @@ -100,12 +100,12 @@ ph1_pro4_end: ldr r3, =DIV_ROUND(UNIPHIER_SLD8_UART_CLK, 16 * BAUDRATE)
b init_uart -ph1_sld8_end: +sld8_end: #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO5) #define UNIPHIER_PRO5_UART_CLK 73728000 cmp r1, #0x2A - bne ph1_pro5_end + bne pro5_end
sg_set_pinsel 47, 0, 4, 8, r0, r1 @ TXD0 -> TXD0 sg_set_pinsel 49, 0, 4, 8, r0, r1 @ TXD1 -> TXD1 @@ -124,12 +124,12 @@ ph1_sld8_end: ldr r3, =DIV_ROUND(UNIPHIER_PRO5_UART_CLK, 16 * BAUDRATE)
b init_uart -ph1_pro5_end: +pro5_end: #endif #if defined(CONFIG_ARCH_UNIPHIER_PXS2) #define UNIPHIER_PXS2_UART_CLK 88900000 cmp r1, #0x2E - bne proxstream2_end + bne pxs2_end
ldr r0, =SG_IECTRL ldr r1, [r0] @@ -149,12 +149,12 @@ ph1_pro5_end: ldr r3, =DIV_ROUND(UNIPHIER_PXS2_UART_CLK, 16 * BAUDRATE)
b init_uart -proxstream2_end: +pxs2_end: #endif #if defined(CONFIG_ARCH_UNIPHIER_LD6B) #define UNIPHIER_LD6B_UART_CLK 88900000 cmp r1, #0x2F - bne ph1_ld6b_end + bne ld6b_end
ldr r0, =SG_IECTRL ldr r1, [r0] @@ -173,7 +173,7 @@ proxstream2_end: ldr r3, =DIV_ROUND(UNIPHIER_LD6B_UART_CLK, 16 * BAUDRATE)
b init_uart -ph1_ld6b_end: +ld6b_end: #endif mov pc, lr
diff --git a/arch/arm/mach-uniphier/bcu/bcu-ld4.c b/arch/arm/mach-uniphier/bcu/bcu-ld4.c index bbe8a74..eeab802 100644 --- a/arch/arm/mach-uniphier/bcu/bcu-ld4.c +++ b/arch/arm/mach-uniphier/bcu/bcu-ld4.c @@ -11,7 +11,7 @@
#define ch(x) ((x) >= 32 ? 0 : (x) < 0 ? 0x11111111 : 0x11111111 << (x))
-int ph1_ld4_bcu_init(const struct uniphier_board_data *bd) +int uniphier_ld4_bcu_init(const struct uniphier_board_data *bd) { int shift;
diff --git a/arch/arm/mach-uniphier/bcu/bcu-sld3.c b/arch/arm/mach-uniphier/bcu/bcu-sld3.c index b7497e9..493e6d5 100644 --- a/arch/arm/mach-uniphier/bcu/bcu-sld3.c +++ b/arch/arm/mach-uniphier/bcu/bcu-sld3.c @@ -11,7 +11,7 @@
-int ph1_sld3_bcu_init(const struct uniphier_board_data *bd) +int uniphier_sld3_bcu_init(const struct uniphier_board_data *bd) { int shift;
diff --git a/arch/arm/mach-uniphier/board_early_init_f.c b/arch/arm/mach-uniphier/board_early_init_f.c index 8e568ee..6f2adf1 100644 --- a/arch/arm/mach-uniphier/board_early_init_f.c +++ b/arch/arm/mach-uniphier/board_early_init_f.c @@ -15,51 +15,51 @@ int board_early_init_f(void) switch (uniphier_get_soc_type()) { #if defined(CONFIG_ARCH_UNIPHIER_SLD3) case SOC_UNIPHIER_SLD3: - ph1_sld3_pin_init(); + uniphier_sld3_pin_init(); led_puts("U1"); - ph1_ld4_clk_init(); + uniphier_ld4_clk_init(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_LD4) case SOC_UNIPHIER_LD4: - ph1_ld4_pin_init(); + uniphier_ld4_pin_init(); led_puts("U1"); - ph1_ld4_clk_init(); + uniphier_ld4_clk_init(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO4) case SOC_UNIPHIER_PRO4: - ph1_pro4_pin_init(); + uniphier_pro4_pin_init(); led_puts("U1"); - ph1_pro4_clk_init(); + uniphier_pro4_clk_init(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_SLD8) case SOC_UNIPHIER_SLD8: - ph1_sld8_pin_init(); + uniphier_sld8_pin_init(); led_puts("U1"); - ph1_ld4_clk_init(); + uniphier_ld4_clk_init(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO5) case SOC_UNIPHIER_PRO5: - ph1_pro5_pin_init(); + uniphier_pro5_pin_init(); led_puts("U1"); - ph1_pro5_clk_init(); + uniphier_pro5_clk_init(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_PXS2) case SOC_UNIPHIER_PXS2: - proxstream2_pin_init(); + uniphier_pxs2_pin_init(); led_puts("U1"); - proxstream2_clk_init(); + uniphier_pxs2_clk_init(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_LD6B) case SOC_UNIPHIER_LD6B: - ph1_ld6b_pin_init(); + uniphier_ld6b_pin_init(); led_puts("U1"); - proxstream2_clk_init(); + uniphier_pxs2_clk_init(); break; #endif default: diff --git a/arch/arm/mach-uniphier/boards.c b/arch/arm/mach-uniphier/boards.c index 5e98c3f..0d2b94d 100644 --- a/arch/arm/mach-uniphier/boards.c +++ b/arch/arm/mach-uniphier/boards.c @@ -13,7 +13,7 @@ DECLARE_GLOBAL_DATA_PTR;
#if defined(CONFIG_ARCH_UNIPHIER_SLD3) -static const struct uniphier_board_data ph1_sld3_data = { +static const struct uniphier_board_data uniphier_sld3_data = { .dram_freq = 1600, .dram_nr_ch = 3, .dram_ch[0] = { @@ -35,7 +35,7 @@ static const struct uniphier_board_data ph1_sld3_data = { #endif
#if defined(CONFIG_ARCH_UNIPHIER_LD4) -static const struct uniphier_board_data ph1_ld4_data = { +static const struct uniphier_board_data uniphier_ld4_data = { .dram_freq = 1600, .dram_nr_ch = 2, .dram_ddr3plus = true, @@ -54,7 +54,7 @@ static const struct uniphier_board_data ph1_ld4_data = {
#if defined(CONFIG_ARCH_UNIPHIER_PRO4) /* 1GB RAM board */ -static const struct uniphier_board_data ph1_pro4_data = { +static const struct uniphier_board_data uniphier_pro4_data = { .dram_freq = 1600, .dram_nr_ch = 2, .dram_ch[0] = { @@ -70,7 +70,7 @@ static const struct uniphier_board_data ph1_pro4_data = { };
/* 2GB RAM board */ -static const struct uniphier_board_data ph1_pro4_2g_data = { +static const struct uniphier_board_data uniphier_pro4_2g_data = { .dram_freq = 1600, .dram_nr_ch = 2, .dram_ch[0] = { @@ -87,7 +87,7 @@ static const struct uniphier_board_data ph1_pro4_2g_data = { #endif
#if defined(CONFIG_ARCH_UNIPHIER_SLD8) -static const struct uniphier_board_data ph1_sld8_data = { +static const struct uniphier_board_data uniphier_sld8_data = { .dram_freq = 1333, .dram_nr_ch = 2, .dram_ddr3plus = true, @@ -105,7 +105,7 @@ static const struct uniphier_board_data ph1_sld8_data = { #endif
#if defined(CONFIG_ARCH_UNIPHIER_PRO5) -static const struct uniphier_board_data ph1_pro5_data = { +static const struct uniphier_board_data uniphier_pro5_data = { .dram_freq = 1866, .dram_nr_ch = 2, .dram_ch[0] = { @@ -122,7 +122,7 @@ static const struct uniphier_board_data ph1_pro5_data = { #endif
#if defined(CONFIG_ARCH_UNIPHIER_PXS2) -static const struct uniphier_board_data proxstream2_data = { +static const struct uniphier_board_data uniphier_pxs2_data = { .dram_freq = 2133, .dram_nr_ch = 3, .dram_ch[0] = { @@ -144,7 +144,7 @@ static const struct uniphier_board_data proxstream2_data = { #endif
#if defined(CONFIG_ARCH_UNIPHIER_LD6B) -static const struct uniphier_board_data ph1_ld6b_data = { +static const struct uniphier_board_data uniphier_ld6b_data = { .dram_freq = 1866, .dram_nr_ch = 3, .dram_ch[0] = { @@ -172,27 +172,27 @@ struct uniphier_board_id {
static const struct uniphier_board_id uniphier_boards[] = { #if defined(CONFIG_ARCH_UNIPHIER_SLD3) - { "socionext,ph1-sld3", &ph1_sld3_data, }, + { "socionext,ph1-sld3", &uniphier_sld3_data, }, #endif #if defined(CONFIG_ARCH_UNIPHIER_LD4) - { "socionext,ph1-ld4", &ph1_ld4_data, }, + { "socionext,ph1-ld4", &uniphier_ld4_data, }, #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO4) - { "socionext,ph1-pro4-ace", &ph1_pro4_2g_data, }, - { "socionext,ph1-pro4-sanji", &ph1_pro4_2g_data, }, - { "socionext,ph1-pro4", &ph1_pro4_data, }, + { "socionext,ph1-pro4-ace", &uniphier_pro4_2g_data, }, + { "socionext,ph1-pro4-sanji", &uniphier_pro4_2g_data, }, + { "socionext,ph1-pro4", &uniphier_pro4_data, }, #endif #if defined(CONFIG_ARCH_UNIPHIER_SLD8) - { "socionext,ph1-sld8", &ph1_sld8_data, }, + { "socionext,ph1-sld8", &uniphier_sld8_data, }, #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO5) - { "socionext,ph1-pro5", &ph1_pro5_data, }, + { "socionext,ph1-pro5", &uniphier_pro5_data, }, #endif #if defined(CONFIG_ARCH_UNIPHIER_PXS2) - { "socionext,proxstream2", &proxstream2_data, }, + { "socionext,proxstream2", &uniphier_pxs2_data, }, #endif #if defined(CONFIG_ARCH_UNIPHIER_LD6B) - { "socionext,ph1-ld6b", &ph1_ld6b_data, }, + { "socionext,ph1-ld6b", &uniphier_ld6b_data, }, #endif };
diff --git a/arch/arm/mach-uniphier/boot-mode/boot-device.h b/arch/arm/mach-uniphier/boot-mode/boot-device.h index 1c59aaa..2e05a47 100644 --- a/arch/arm/mach-uniphier/boot-mode/boot-device.h +++ b/arch/arm/mach-uniphier/boot-mode/boot-device.h @@ -12,15 +12,15 @@ struct boot_device_info { char *info; };
-u32 ph1_sld3_boot_device(void); -u32 ph1_ld4_boot_device(void); -u32 ph1_pro5_boot_device(void); -u32 proxstream2_boot_device(void); +u32 uniphier_sld3_boot_device(void); +u32 uniphier_ld4_boot_device(void); +u32 uniphier_pro5_boot_device(void); +u32 uniphier_pxs2_boot_device(void);
-void ph1_sld3_boot_mode_show(void); -void ph1_ld4_boot_mode_show(void); -void ph1_pro5_boot_mode_show(void); -void proxstream2_boot_mode_show(void); +void uniphier_sld3_boot_mode_show(void); +void uniphier_ld4_boot_mode_show(void); +void uniphier_pro5_boot_mode_show(void); +void uniphier_pxs2_boot_mode_show(void);
u32 spl_boot_device_raw(void);
diff --git a/arch/arm/mach-uniphier/boot-mode/boot-mode-ld4.c b/arch/arm/mach-uniphier/boot-mode/boot-mode-ld4.c index ef52d69..0597618 100644 --- a/arch/arm/mach-uniphier/boot-mode/boot-mode-ld4.c +++ b/arch/arm/mach-uniphier/boot-mode/boot-mode-ld4.c @@ -51,7 +51,7 @@ static int get_boot_mode_sel(void) return (readl(SG_PINMON0) >> 1) & 0x1f; }
-u32 ph1_ld4_boot_device(void) +u32 uniphier_ld4_boot_device(void) { int boot_mode;
@@ -60,7 +60,7 @@ u32 ph1_ld4_boot_device(void) return boot_device_table[boot_mode].type; }
-void ph1_ld4_boot_mode_show(void) +void uniphier_ld4_boot_mode_show(void) { int mode_sel, i;
diff --git a/arch/arm/mach-uniphier/boot-mode/boot-mode-pro5.c b/arch/arm/mach-uniphier/boot-mode/boot-mode-pro5.c index 0ec6a08..f9726f1 100644 --- a/arch/arm/mach-uniphier/boot-mode/boot-mode-pro5.c +++ b/arch/arm/mach-uniphier/boot-mode/boot-mode-pro5.c @@ -52,7 +52,7 @@ static int get_boot_mode_sel(void) return (readl(SG_PINMON0) >> 1) & 0x1f; }
-u32 ph1_pro5_boot_device(void) +u32 uniphier_pro5_boot_device(void) { int boot_mode;
@@ -61,7 +61,7 @@ u32 ph1_pro5_boot_device(void) return boot_device_table[boot_mode].type; }
-void ph1_pro5_boot_mode_show(void) +void uniphier_pro5_boot_mode_show(void) { int mode_sel, i;
diff --git a/arch/arm/mach-uniphier/boot-mode/boot-mode-pxs2.c b/arch/arm/mach-uniphier/boot-mode/boot-mode-pxs2.c index 1b0c183..4b06f74 100644 --- a/arch/arm/mach-uniphier/boot-mode/boot-mode-pxs2.c +++ b/arch/arm/mach-uniphier/boot-mode/boot-mode-pxs2.c @@ -51,7 +51,7 @@ static int get_boot_mode_sel(void) return (readl(SG_PINMON0) >> 1) & 0x1f; }
-u32 proxstream2_boot_device(void) +u32 uniphier_pxs2_boot_device(void) { int boot_mode;
@@ -63,7 +63,7 @@ u32 proxstream2_boot_device(void) return boot_device_table[boot_mode].type; }
-void proxstream2_boot_mode_show(void) +void uniphier_pxs2_boot_mode_show(void) { int mode_sel, i;
diff --git a/arch/arm/mach-uniphier/boot-mode/boot-mode-sld3.c b/arch/arm/mach-uniphier/boot-mode/boot-mode-sld3.c index 0258fae..a4a3c47 100644 --- a/arch/arm/mach-uniphier/boot-mode/boot-mode-sld3.c +++ b/arch/arm/mach-uniphier/boot-mode/boot-mode-sld3.c @@ -83,7 +83,7 @@ static int get_boot_mode_sel(void) return readl(SG_PINMON0) & 0x3f; }
-u32 ph1_sld3_boot_device(void) +u32 uniphier_sld3_boot_device(void) { int boot_mode;
@@ -92,7 +92,7 @@ u32 ph1_sld3_boot_device(void) return boot_device_table[boot_mode].type; }
-void ph1_sld3_boot_mode_show(void) +void uniphier_sld3_boot_mode_show(void) { int mode_sel, i;
diff --git a/arch/arm/mach-uniphier/boot-mode/boot-mode.c b/arch/arm/mach-uniphier/boot-mode/boot-mode.c index 317a4f1..b08cd6c 100644 --- a/arch/arm/mach-uniphier/boot-mode/boot-mode.c +++ b/arch/arm/mach-uniphier/boot-mode/boot-mode.c @@ -21,23 +21,23 @@ u32 spl_boot_device_raw(void) switch (uniphier_get_soc_type()) { #if defined(CONFIG_ARCH_UNIPHIER_SLD3) case SOC_UNIPHIER_SLD3: - return ph1_sld3_boot_device(); + return uniphier_sld3_boot_device(); #endif #if defined(CONFIG_ARCH_UNIPHIER_LD4) || defined(CONFIG_ARCH_UNIPHIER_PRO4) || \ defined(CONFIG_ARCH_UNIPHIER_SLD8) case SOC_UNIPHIER_LD4: case SOC_UNIPHIER_PRO4: case SOC_UNIPHIER_SLD8: - return ph1_ld4_boot_device(); + return uniphier_ld4_boot_device(); #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO5) case SOC_UNIPHIER_PRO5: - return ph1_pro5_boot_device(); + return uniphier_pro5_boot_device(); #endif #if defined(CONFIG_ARCH_UNIPHIER_PXS2) || defined(CONFIG_ARCH_UNIPHIER_LD6B) case SOC_UNIPHIER_PXS2: case SOC_UNIPHIER_LD6B: - return proxstream2_boot_device(); + return uniphier_pxs2_boot_device(); #endif default: return BOOT_DEVICE_NONE; diff --git a/arch/arm/mach-uniphier/boot-mode/cmd_pinmon.c b/arch/arm/mach-uniphier/boot-mode/cmd_pinmon.c index 3a66e2b..bccab62 100644 --- a/arch/arm/mach-uniphier/boot-mode/cmd_pinmon.c +++ b/arch/arm/mach-uniphier/boot-mode/cmd_pinmon.c @@ -17,7 +17,7 @@ static int do_pinmon(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) switch (uniphier_get_soc_type()) { #if defined(CONFIG_ARCH_UNIPHIER_SLD3) case SOC_UNIPHIER_SLD3: - ph1_sld3_boot_mode_show(); + uniphier_sld3_boot_mode_show(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_LD4) || defined(CONFIG_ARCH_UNIPHIER_PRO4) || \ @@ -25,18 +25,18 @@ static int do_pinmon(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) case SOC_UNIPHIER_LD4: case SOC_UNIPHIER_PRO4: case SOC_UNIPHIER_SLD8: - ph1_ld4_boot_mode_show(); + uniphier_ld4_boot_mode_show(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO5) case SOC_UNIPHIER_PRO5: - ph1_pro5_boot_mode_show(); + uniphier_pro5_boot_mode_show(); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_PXS2) || defined(CONFIG_ARCH_UNIPHIER_LD6B) case SOC_UNIPHIER_PXS2: case SOC_UNIPHIER_LD6B: - proxstream2_boot_mode_show(); + uniphier_pxs2_boot_mode_show(); break; #endif default: diff --git a/arch/arm/mach-uniphier/clk/clk-ld4.c b/arch/arm/mach-uniphier/clk/clk-ld4.c index 7a34bee..f11fb53 100644 --- a/arch/arm/mach-uniphier/clk/clk-ld4.c +++ b/arch/arm/mach-uniphier/clk/clk-ld4.c @@ -9,7 +9,7 @@ #include "../init.h" #include "../sc-regs.h"
-void ph1_ld4_clk_init(void) +void uniphier_ld4_clk_init(void) { u32 tmp;
diff --git a/arch/arm/mach-uniphier/clk/clk-pro4.c b/arch/arm/mach-uniphier/clk/clk-pro4.c index c784c31..b163e3c 100644 --- a/arch/arm/mach-uniphier/clk/clk-pro4.c +++ b/arch/arm/mach-uniphier/clk/clk-pro4.c @@ -9,7 +9,7 @@ #include "../init.h" #include "../sc-regs.h"
-void ph1_pro4_clk_init(void) +void uniphier_pro4_clk_init(void) { u32 tmp;
diff --git a/arch/arm/mach-uniphier/clk/clk-pro5.c b/arch/arm/mach-uniphier/clk/clk-pro5.c index 039da73..628f5c8 100644 --- a/arch/arm/mach-uniphier/clk/clk-pro5.c +++ b/arch/arm/mach-uniphier/clk/clk-pro5.c @@ -9,7 +9,7 @@ #include "../init.h" #include "../sc-regs.h"
-void ph1_pro5_clk_init(void) +void uniphier_pro5_clk_init(void) { u32 tmp;
diff --git a/arch/arm/mach-uniphier/clk/clk-pxs2.c b/arch/arm/mach-uniphier/clk/clk-pxs2.c index a528f04..8548353 100644 --- a/arch/arm/mach-uniphier/clk/clk-pxs2.c +++ b/arch/arm/mach-uniphier/clk/clk-pxs2.c @@ -9,7 +9,7 @@ #include "../init.h" #include "../sc-regs.h"
-void proxstream2_clk_init(void) +void uniphier_pxs2_clk_init(void) { u32 tmp;
diff --git a/arch/arm/mach-uniphier/dram/ddrphy-ld4.c b/arch/arm/mach-uniphier/dram/ddrphy-ld4.c index eb9bf24..c9e164f 100644 --- a/arch/arm/mach-uniphier/dram/ddrphy-ld4.c +++ b/arch/arm/mach-uniphier/dram/ddrphy-ld4.c @@ -27,7 +27,8 @@ static u32 ddrphy_dtpr2[DRAM_FREQ_NR] = {0x5002c200, 0xa00214f8}; static u32 ddrphy_mr0[DRAM_FREQ_NR] = {0x00000b51, 0x00000d71}; static u32 ddrphy_mr2[DRAM_FREQ_NR] = {0x00000290, 0x00000298};
-int ph1_ld4_ddrphy_init(struct ddrphy __iomem *phy, int freq, bool ddr3plus) +int uniphier_ld4_ddrphy_init(struct ddrphy __iomem *phy, int freq, + bool ddr3plus) { enum dram_freq freq_e; u32 tmp; diff --git a/arch/arm/mach-uniphier/dram/ddrphy-regs.h b/arch/arm/mach-uniphier/dram/ddrphy-regs.h index a1d51ce..a8fe6a0 100644 --- a/arch/arm/mach-uniphier/dram/ddrphy-regs.h +++ b/arch/arm/mach-uniphier/dram/ddrphy-regs.h @@ -159,7 +159,8 @@ struct ddrphy { #define NR_DATX8_PER_DDRPHY 2
#ifndef __ASSEMBLY__ -int ph1_ld4_ddrphy_init(struct ddrphy __iomem *phy, int freq, bool ddr3plus); +int uniphier_ld4_ddrphy_init(struct ddrphy __iomem *phy, int freq, + bool ddr3plus); void ddrphy_prepare_training(struct ddrphy __iomem *phy, int rank); int ddrphy_training(struct ddrphy __iomem *phy); #endif diff --git a/arch/arm/mach-uniphier/dram/umc-ld4.c b/arch/arm/mach-uniphier/dram/umc-ld4.c index 72447cc..fc75864 100644 --- a/arch/arm/mach-uniphier/dram/umc-ld4.c +++ b/arch/arm/mach-uniphier/dram/umc-ld4.c @@ -152,7 +152,7 @@ static int umc_ch_init(void __iomem *dc_base, void __iomem *ca_base,
writel(0x00000101, dc_base + UMC_DIOCTLA);
- ret = ph1_ld4_ddrphy_init(phy_base, freq, ddr3plus); + ret = uniphier_ld4_ddrphy_init(phy_base, freq, ddr3plus); if (ret) return ret;
@@ -164,7 +164,7 @@ static int umc_ch_init(void __iomem *dc_base, void __iomem *ca_base, return umc_dramcont_init(dc_base, ca_base, freq, size, ddr3plus); }
-int ph1_ld4_umc_init(const struct uniphier_board_data *bd) +int uniphier_ld4_umc_init(const struct uniphier_board_data *bd) { void __iomem *umc_base = (void __iomem *)0x5b800000; void __iomem *ca_base = umc_base + 0x00001000; diff --git a/arch/arm/mach-uniphier/dram/umc-pro4.c b/arch/arm/mach-uniphier/dram/umc-pro4.c index 23fb7b9..853f561 100644 --- a/arch/arm/mach-uniphier/dram/umc-pro4.c +++ b/arch/arm/mach-uniphier/dram/umc-pro4.c @@ -142,7 +142,7 @@ static int umc_ch_init(void __iomem *dc_base, void __iomem *ca_base, writel(0x00000100 | ((1 << (phy + 1)) - 1), dc_base + UMC_DIOCTLA);
@@ -158,7 +158,7 @@ static int umc_ch_init(void __iomem *dc_base, void __iomem *ca_base, ddr3plus); }
-int ph1_pro4_umc_init(const struct uniphier_board_data *bd) +int uniphier_pro4_umc_init(const struct uniphier_board_data *bd) { void __iomem *umc_base = (void __iomem *)0x5b800000; void __iomem *ca_base = umc_base + 0x00001000; diff --git a/arch/arm/mach-uniphier/dram/umc-pxs2.c b/arch/arm/mach-uniphier/dram/umc-pxs2.c index 50c0238..b4da3d2 100644 --- a/arch/arm/mach-uniphier/dram/umc-pxs2.c +++ b/arch/arm/mach-uniphier/dram/umc-pxs2.c @@ -598,7 +598,7 @@ static void um_init(void __iomem *um_base) writel(0x000000ff, um_base + UMC_MBUS3); }
-int proxstream2_umc_init(const struct uniphier_board_data *bd) +int uniphier_pxs2_umc_init(const struct uniphier_board_data *bd) { void __iomem *um_base = (void __iomem *)0x5b600000; void __iomem *umc_ch_base = (void __iomem *)0x5b800000; diff --git a/arch/arm/mach-uniphier/dram/umc-sld8.c b/arch/arm/mach-uniphier/dram/umc-sld8.c index 6cacd25..e831766 100644 --- a/arch/arm/mach-uniphier/dram/umc-sld8.c +++ b/arch/arm/mach-uniphier/dram/umc-sld8.c @@ -155,7 +155,7 @@ static int umc_ch_init(void __iomem *dc_base, void __iomem *ca_base,
@@ -167,7 +167,7 @@ static int umc_ch_init(void __iomem *dc_base, void __iomem *ca_base, return umc_dramcont_init(dc_base, ca_base, freq, size, ddr3plus); }
-int ph1_sld8_umc_init(const struct uniphier_board_data *bd) +int uniphier_sld8_umc_init(const struct uniphier_board_data *bd) { void __iomem *umc_base = (void __iomem *)0x5b800000; void __iomem *ca_base = umc_base + 0x00001000; diff --git a/arch/arm/mach-uniphier/early-clk/early-clk-ld4.c b/arch/arm/mach-uniphier/early-clk/early-clk-ld4.c index 6574767..c98081f 100644 --- a/arch/arm/mach-uniphier/early-clk/early-clk-ld4.c +++ b/arch/arm/mach-uniphier/early-clk/early-clk-ld4.c @@ -11,7 +11,7 @@ #include "../init.h" #include "../sc-regs.h"
-int ph1_ld4_early_clk_init(const struct uniphier_board_data *bd) +int uniphier_ld4_early_clk_init(const struct uniphier_board_data *bd) { u32 tmp;
diff --git a/arch/arm/mach-uniphier/early-clk/early-clk-pro5.c b/arch/arm/mach-uniphier/early-clk/early-clk-pro5.c index d986358..5fc8cd0 100644 --- a/arch/arm/mach-uniphier/early-clk/early-clk-pro5.c +++ b/arch/arm/mach-uniphier/early-clk/early-clk-pro5.c @@ -9,7 +9,7 @@ #include "../init.h" #include "../sc-regs.h"
-int ph1_pro5_early_clk_init(const struct uniphier_board_data *bd) +int uniphier_pro5_early_clk_init(const struct uniphier_board_data *bd) { u32 tmp;
diff --git a/arch/arm/mach-uniphier/early-clk/early-clk-pxs2.c b/arch/arm/mach-uniphier/early-clk/early-clk-pxs2.c index a573a96..92b2dcb 100644 --- a/arch/arm/mach-uniphier/early-clk/early-clk-pxs2.c +++ b/arch/arm/mach-uniphier/early-clk/early-clk-pxs2.c @@ -11,7 +11,7 @@ #include "../init.h" #include "../sc-regs.h"
-int proxstream2_early_clk_init(const struct uniphier_board_data *bd) +int uniphier_pxs2_early_clk_init(const struct uniphier_board_data *bd) { u32 tmp;
diff --git a/arch/arm/mach-uniphier/early-pinctrl/early-pinctrl-sld3.c b/arch/arm/mach-uniphier/early-pinctrl/early-pinctrl-sld3.c index 7923644..22c07fb 100644 --- a/arch/arm/mach-uniphier/early-pinctrl/early-pinctrl-sld3.c +++ b/arch/arm/mach-uniphier/early-pinctrl/early-pinctrl-sld3.c @@ -7,7 +7,7 @@ #include "../init.h" #include "../sg-regs.h"
-int ph1_sld3_early_pin_init(const struct uniphier_board_data *bd) +int uniphier_sld3_early_pin_init(const struct uniphier_board_data *bd) { /* Comment format: PAD Name -> Function Name */
diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index cef9d62..3abf4aa 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -26,26 +26,28 @@ struct uniphier_board_data {
const struct uniphier_board_data *uniphier_get_board_param(void);
-int ph1_sld3_init(const struct uniphier_board_data *bd); -int ph1_ld4_init(const struct uniphier_board_data *bd); -int ph1_pro4_init(const struct uniphier_board_data *bd); -int ph1_sld8_init(const struct uniphier_board_data *bd); -int ph1_pro5_init(const struct uniphier_board_data *bd); -int proxstream2_init(const struct uniphier_board_data *bd); +int uniphier_sld3_init(const struct uniphier_board_data *bd); +int uniphier_ld4_init(const struct uniphier_board_data *bd); +int uniphier_pro4_init(const struct uniphier_board_data *bd); +int uniphier_sld8_init(const struct uniphier_board_data *bd); +int uniphier_pro5_init(const struct uniphier_board_data *bd); +int uniphier_pxs2_init(const struct uniphier_board_data *bd);
#if defined(CONFIG_MICRO_SUPPORT_CARD) -int sbc_admulti_init(const struct uniphier_board_data *bd); -int sbc_savepin_init(const struct uniphier_board_data *bd); +int uniphier_sbc_init_admulti(const struct uniphier_board_data *bd); +int uniphier_sbc_init_savepin(const struct uniphier_board_data *bd); int uniphier_sld3_sbc_init(const struct uniphier_board_data *bd); int uniphier_ld4_sbc_init(const struct uniphier_board_data *bd); int uniphier_pxs2_sbc_init(const struct uniphier_board_data *bd); #else -static inline int sbc_admulti_init(const struct uniphier_board_data *bd) +static inline int uniphier_sbc_init_admulti( + const struct uniphier_board_data *bd) { return 0; }
-static inline int sbc_savepin_init(const struct uniphier_board_data *bd) +static inline int uniphier_sbc_init_savepin( + const struct uniphier_board_data *bd) { return 0; } @@ -66,44 +68,44 @@ static inline int uniphier_pxs2_sbc_init(const struct uniphier_board_data *bd) } #endif
-int ph1_sld3_bcu_init(const struct uniphier_board_data *bd); -int ph1_ld4_bcu_init(const struct uniphier_board_data *bd); +int uniphier_sld3_bcu_init(const struct uniphier_board_data *bd); +int uniphier_ld4_bcu_init(const struct uniphier_board_data *bd);
int memconf_init(const struct uniphier_board_data *bd); -int ph1_sld3_memconf_init(const struct uniphier_board_data *bd); -int proxstream2_memconf_init(const struct uniphier_board_data *bd); - -int ph1_sld3_pll_init(const struct uniphier_board_data *bd); -int ph1_ld4_pll_init(const struct uniphier_board_data *bd); -int ph1_pro4_pll_init(const struct uniphier_board_data *bd); -int ph1_sld8_pll_init(const struct uniphier_board_data *bd); - -int ph1_sld3_enable_dpll_ssc(const struct uniphier_board_data *bd); -int ph1_ld4_enable_dpll_ssc(const struct uniphier_board_data *bd); - -int ph1_ld4_early_clk_init(const struct uniphier_board_data *bd); -int ph1_pro5_early_clk_init(const struct uniphier_board_data *bd); -int proxstream2_early_clk_init(const struct uniphier_board_data *bd); - -int ph1_sld3_early_pin_init(const struct uniphier_board_data *bd); - -int ph1_ld4_umc_init(const struct uniphier_board_data *bd); -int ph1_pro4_umc_init(const struct uniphier_board_data *bd); -int ph1_sld8_umc_init(const struct uniphier_board_data *bd); -int proxstream2_umc_init(const struct uniphier_board_data *bd); - -void ph1_sld3_pin_init(void); -void ph1_ld4_pin_init(void); -void ph1_pro4_pin_init(void); -void ph1_sld8_pin_init(void); -void ph1_pro5_pin_init(void); -void proxstream2_pin_init(void); -void ph1_ld6b_pin_init(void); - -void ph1_ld4_clk_init(void); -void ph1_pro4_clk_init(void); -void ph1_pro5_clk_init(void); -void proxstream2_clk_init(void); +int uniphier_sld3_memconf_init(const struct uniphier_board_data *bd); +int uniphier_pxs2_memconf_init(const struct uniphier_board_data *bd); + +int uniphier_sld3_pll_init(const struct uniphier_board_data *bd); +int uniphier_ld4_pll_init(const struct uniphier_board_data *bd); +int uniphier_pro4_pll_init(const struct uniphier_board_data *bd); +int uniphier_sld8_pll_init(const struct uniphier_board_data *bd); + +int uniphier_sld3_enable_dpll_ssc(const struct uniphier_board_data *bd); +int uniphier_ld4_enable_dpll_ssc(const struct uniphier_board_data *bd); + +int uniphier_ld4_early_clk_init(const struct uniphier_board_data *bd); +int uniphier_pro5_early_clk_init(const struct uniphier_board_data *bd); +int uniphier_pxs2_early_clk_init(const struct uniphier_board_data *bd); + +int uniphier_sld3_early_pin_init(const struct uniphier_board_data *bd); + +int uniphier_ld4_umc_init(const struct uniphier_board_data *bd); +int uniphier_pro4_umc_init(const struct uniphier_board_data *bd); +int uniphier_sld8_umc_init(const struct uniphier_board_data *bd); +int uniphier_pxs2_umc_init(const struct uniphier_board_data *bd); + +void uniphier_sld3_pin_init(void); +void uniphier_ld4_pin_init(void); +void uniphier_pro4_pin_init(void); +void uniphier_sld8_pin_init(void); +void uniphier_pro5_pin_init(void); +void uniphier_pxs2_pin_init(void); +void uniphier_ld6b_pin_init(void); + +void uniphier_ld4_clk_init(void); +void uniphier_pro4_clk_init(void); +void uniphier_pro5_clk_init(void); +void uniphier_pxs2_clk_init(void);
#define pr_err(fmt, args...) printf(fmt, ##args)
diff --git a/arch/arm/mach-uniphier/init/init-ld4.c b/arch/arm/mach-uniphier/init/init-ld4.c index 5295cd0..b1c9b5d 100644 --- a/arch/arm/mach-uniphier/init/init-ld4.c +++ b/arch/arm/mach-uniphier/init/init-ld4.c @@ -10,16 +10,16 @@ #include "../init.h" #include "../micro-support-card.h"
-int ph1_ld4_init(const struct uniphier_board_data *bd) +int uniphier_ld4_init(const struct uniphier_board_data *bd) { - ph1_ld4_bcu_init(bd); + uniphier_ld4_bcu_init(bd);
- sbc_savepin_init(bd); + uniphier_sbc_init_savepin(bd); uniphier_ld4_sbc_init(bd);
support_card_reset();
- ph1_ld4_pll_init(bd); + uniphier_ld4_pll_init(bd);
support_card_init();
@@ -29,7 +29,7 @@ int ph1_ld4_init(const struct uniphier_board_data *bd)
led_puts("L1");
- ph1_ld4_early_clk_init(bd); + uniphier_ld4_early_clk_init(bd);
led_puts("L2");
@@ -44,7 +44,7 @@ int ph1_ld4_init(const struct uniphier_board_data *bd) { int res;
- res = ph1_ld4_umc_init(bd); + res = uniphier_ld4_umc_init(bd); if (res < 0) { while (1) ; @@ -53,7 +53,7 @@ int ph1_ld4_init(const struct uniphier_board_data *bd)
led_puts("L5");
- ph1_ld4_enable_dpll_ssc(bd); + uniphier_ld4_enable_dpll_ssc(bd);
led_puts("L6");
diff --git a/arch/arm/mach-uniphier/init/init-pro4.c b/arch/arm/mach-uniphier/init/init-pro4.c index 456fb48..3528d84 100644 --- a/arch/arm/mach-uniphier/init/init-pro4.c +++ b/arch/arm/mach-uniphier/init/init-pro4.c @@ -10,13 +10,13 @@ #include "../init.h" #include "../micro-support-card.h"
-int ph1_pro4_init(const struct uniphier_board_data *bd) +int uniphier_pro4_init(const struct uniphier_board_data *bd) { - sbc_savepin_init(bd); + uniphier_sbc_init_savepin(bd);
- ph1_pro4_pll_init(bd); + uniphier_pro4_pll_init(bd);
@@ -26,7 +26,7 @@ int ph1_pro4_init(const struct uniphier_board_data *bd)
led_puts("L1");
led_puts("L2");
@@ -41,7 +41,7 @@ int ph1_pro4_init(const struct uniphier_board_data *bd) { int res;
- res = ph1_pro4_umc_init(bd); + res = uniphier_pro4_umc_init(bd); if (res < 0) { while (1) ; @@ -50,7 +50,7 @@ int ph1_pro4_init(const struct uniphier_board_data *bd)
led_puts("L5");
led_puts("L6");
diff --git a/arch/arm/mach-uniphier/init/init-pro5.c b/arch/arm/mach-uniphier/init/init-pro5.c index c2c6803..c809ae7 100644 --- a/arch/arm/mach-uniphier/init/init-pro5.c +++ b/arch/arm/mach-uniphier/init/init-pro5.c @@ -10,9 +10,9 @@ #include "../init.h" #include "../micro-support-card.h"
-int ph1_pro5_init(const struct uniphier_board_data *bd) +int uniphier_pro5_init(const struct uniphier_board_data *bd) { - sbc_savepin_init(bd); + uniphier_sbc_init_savepin(bd);
@@ -24,7 +24,7 @@ int ph1_pro5_init(const struct uniphier_board_data *bd)
led_puts("L1");
- ph1_pro5_early_clk_init(bd); + uniphier_pro5_early_clk_init(bd);
led_puts("L2");
diff --git a/arch/arm/mach-uniphier/init/init-pxs2.c b/arch/arm/mach-uniphier/init/init-pxs2.c index 2d4b6fb..5e07db1 100644 --- a/arch/arm/mach-uniphier/init/init-pxs2.c +++ b/arch/arm/mach-uniphier/init/init-pxs2.c @@ -10,11 +10,11 @@ #include "../init.h" #include "../micro-support-card.h"
-int proxstream2_init(const struct uniphier_board_data *bd) +int uniphier_pxs2_init(const struct uniphier_board_data *bd) { int ret;
- sbc_savepin_init(bd); + uniphier_sbc_init_savepin(bd); uniphier_pxs2_sbc_init(bd);
support_card_reset(); @@ -24,11 +24,11 @@ int proxstream2_init(const struct uniphier_board_data *bd) led_puts("L0");
memconf_init(bd); - proxstream2_memconf_init(bd); + uniphier_pxs2_memconf_init(bd);
led_puts("L1");
- proxstream2_early_clk_init(bd); + uniphier_pxs2_early_clk_init(bd);
led_puts("L2");
@@ -40,7 +40,7 @@ int proxstream2_init(const struct uniphier_board_data *bd)
led_puts("L4");
- ret = proxstream2_umc_init(bd); + ret = uniphier_pxs2_umc_init(bd); if (ret) return ret;
diff --git a/arch/arm/mach-uniphier/init/init-sld3.c b/arch/arm/mach-uniphier/init/init-sld3.c index c48126f..473e0c8 100644 --- a/arch/arm/mach-uniphier/init/init-sld3.c +++ b/arch/arm/mach-uniphier/init/init-sld3.c @@ -10,31 +10,31 @@ #include "../init.h" #include "../micro-support-card.h"
-int ph1_sld3_init(const struct uniphier_board_data *bd) +int uniphier_sld3_init(const struct uniphier_board_data *bd) { - ph1_sld3_bcu_init(bd); + uniphier_sld3_bcu_init(bd);
- sbc_admulti_init(bd); + uniphier_sbc_init_admulti(bd); uniphier_sld3_sbc_init(bd);
- ph1_sld3_pll_init(bd); + uniphier_sld3_pll_init(bd);
led_puts("L0");
memconf_init(bd); - ph1_sld3_memconf_init(bd); + uniphier_sld3_memconf_init(bd);
led_puts("L1");
led_puts("L2");
- ph1_sld3_early_pin_init(bd); + uniphier_sld3_early_pin_init(bd);
led_puts("L3");
@@ -46,7 +46,7 @@ int ph1_sld3_init(const struct uniphier_board_data *bd)
led_puts("L5");
- ph1_sld3_enable_dpll_ssc(bd); + uniphier_sld3_enable_dpll_ssc(bd);
led_puts("L6");
diff --git a/arch/arm/mach-uniphier/init/init-sld8.c b/arch/arm/mach-uniphier/init/init-sld8.c index 1f31ca6..07c6d60 100644 --- a/arch/arm/mach-uniphier/init/init-sld8.c +++ b/arch/arm/mach-uniphier/init/init-sld8.c @@ -10,16 +10,16 @@ #include "../init.h" #include "../micro-support-card.h"
-int ph1_sld8_init(const struct uniphier_board_data *bd) +int uniphier_sld8_init(const struct uniphier_board_data *bd) { - ph1_ld4_bcu_init(bd); + uniphier_ld4_bcu_init(bd);
- ph1_sld8_pll_init(bd); + uniphier_sld8_pll_init(bd);
@@ -29,7 +29,7 @@ int ph1_sld8_init(const struct uniphier_board_data *bd)
led_puts("L1");
led_puts("L2");
@@ -44,7 +44,7 @@ int ph1_sld8_init(const struct uniphier_board_data *bd) { int res;
- res = ph1_sld8_umc_init(bd); + res = uniphier_sld8_umc_init(bd); if (res < 0) { while (1) ; @@ -53,7 +53,7 @@ int ph1_sld8_init(const struct uniphier_board_data *bd)
led_puts("L5");
led_puts("L6");
diff --git a/arch/arm/mach-uniphier/init/init.c b/arch/arm/mach-uniphier/init/init.c index 7316d51..c56c44c 100644 --- a/arch/arm/mach-uniphier/init/init.c +++ b/arch/arm/mach-uniphier/init/init.c @@ -26,33 +26,33 @@ void spl_board_init(void) switch (uniphier_get_soc_type()) { #if defined(CONFIG_ARCH_UNIPHIER_SLD3) case SOC_UNIPHIER_SLD3: - ph1_sld3_init(param); + uniphier_sld3_init(param); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_LD4) case SOC_UNIPHIER_LD4: - ph1_ld4_init(param); + uniphier_ld4_init(param); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO4) case SOC_UNIPHIER_PRO4: - ph1_pro4_init(param); + uniphier_pro4_init(param); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_SLD8) case SOC_UNIPHIER_SLD8: - ph1_sld8_init(param); + uniphier_sld8_init(param); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_PRO5) case SOC_UNIPHIER_PRO5: - ph1_pro5_init(param); + uniphier_pro5_init(param); break; #endif #if defined(CONFIG_ARCH_UNIPHIER_PXS2) || defined(CONFIG_ARCH_UNIPHIER_LD6B) case SOC_UNIPHIER_PXS2: case SOC_UNIPHIER_LD6B: - proxstream2_init(param); + uniphier_pxs2_init(param); break; #endif default: diff --git a/arch/arm/mach-uniphier/memconf/memconf-pxs2.c b/arch/arm/mach-uniphier/memconf/memconf-pxs2.c index c47fe0a..bf14d0d 100644 --- a/arch/arm/mach-uniphier/memconf/memconf-pxs2.c +++ b/arch/arm/mach-uniphier/memconf/memconf-pxs2.c @@ -12,7 +12,7 @@ #include "../init.h" #include "../sg-regs.h"
-int proxstream2_memconf_init(const struct uniphier_board_data *bd) +int uniphier_pxs2_memconf_init(const struct uniphier_board_data *bd) { u32 tmp; unsigned long size_per_word; diff --git a/arch/arm/mach-uniphier/memconf/memconf-sld3.c b/arch/arm/mach-uniphier/memconf/memconf-sld3.c index 6fdf910..948f82c 100644 --- a/arch/arm/mach-uniphier/memconf/memconf-sld3.c +++ b/arch/arm/mach-uniphier/memconf/memconf-sld3.c @@ -12,7 +12,7 @@ #include "../init.h" #include "../sg-regs.h"
-int ph1_sld3_memconf_init(const struct uniphier_board_data *bd) +int uniphier_sld3_memconf_init(const struct uniphier_board_data *bd) { u32 tmp; unsigned long size_per_word; diff --git a/arch/arm/mach-uniphier/pinctrl/pinctrl-ld4.c b/arch/arm/mach-uniphier/pinctrl/pinctrl-ld4.c index 2fe2c7f..625d40c 100644 --- a/arch/arm/mach-uniphier/pinctrl/pinctrl-ld4.c +++ b/arch/arm/mach-uniphier/pinctrl/pinctrl-ld4.c @@ -9,7 +9,7 @@ #include "../init.h" #include "../sg-regs.h"
-void ph1_ld4_pin_init(void) +void uniphier_ld4_pin_init(void) { u32 tmp;
diff --git a/arch/arm/mach-uniphier/pinctrl/pinctrl-ld6b.c b/arch/arm/mach-uniphier/pinctrl/pinctrl-ld6b.c index 4faeaf5..913722b 100644 --- a/arch/arm/mach-uniphier/pinctrl/pinctrl-ld6b.c +++ b/arch/arm/mach-uniphier/pinctrl/pinctrl-ld6b.c @@ -9,7 +9,7 @@ #include "../init.h" #include "../sg-regs.h"
-void ph1_ld6b_pin_init(void) +void uniphier_ld6b_pin_init(void) { /* Comment format: PAD Name -> Function Name */
diff --git a/arch/arm/mach-uniphier/pinctrl/pinctrl-pro4.c b/arch/arm/mach-uniphier/pinctrl/pinctrl-pro4.c index b08ca1e..3796491 100644 --- a/arch/arm/mach-uniphier/pinctrl/pinctrl-pro4.c +++ b/arch/arm/mach-uniphier/pinctrl/pinctrl-pro4.c @@ -9,7 +9,7 @@ #include "../init.h" #include "../sg-regs.h"
-void ph1_pro4_pin_init(void) +void uniphier_pro4_pin_init(void) { /* Comment format: PAD Name -> Function Name */
diff --git a/arch/arm/mach-uniphier/pinctrl/pinctrl-pro5.c b/arch/arm/mach-uniphier/pinctrl/pinctrl-pro5.c index 79160d6..32ba923 100644 --- a/arch/arm/mach-uniphier/pinctrl/pinctrl-pro5.c +++ b/arch/arm/mach-uniphier/pinctrl/pinctrl-pro5.c @@ -9,7 +9,7 @@ #include "../init.h" #include "../sg-regs.h"
-void ph1_pro5_pin_init(void) +void uniphier_pro5_pin_init(void) { /* Comment format: PAD Name -> Function Name */
diff --git a/arch/arm/mach-uniphier/pinctrl/pinctrl-pxs2.c b/arch/arm/mach-uniphier/pinctrl/pinctrl-pxs2.c index a662db8..2d62ab3 100644 --- a/arch/arm/mach-uniphier/pinctrl/pinctrl-pxs2.c +++ b/arch/arm/mach-uniphier/pinctrl/pinctrl-pxs2.c @@ -9,7 +9,7 @@ #include "../init.h" #include "../sg-regs.h"
-void proxstream2_pin_init(void) +void uniphier_pxs2_pin_init(void) { /* Comment format: PAD Name -> Function Name */
diff --git a/arch/arm/mach-uniphier/pinctrl/pinctrl-sld3.c b/arch/arm/mach-uniphier/pinctrl/pinctrl-sld3.c index f85ed53..62edc49 100644 --- a/arch/arm/mach-uniphier/pinctrl/pinctrl-sld3.c +++ b/arch/arm/mach-uniphier/pinctrl/pinctrl-sld3.c @@ -7,7 +7,7 @@ #include "../init.h" #include "../sg-regs.h"
-void ph1_sld3_pin_init(void) +void uniphier_sld3_pin_init(void) { #ifdef CONFIG_USB_EHCI sg_set_pinsel(13, 0, 4, 4); /* USB0OC */ diff --git a/arch/arm/mach-uniphier/pinctrl/pinctrl-sld8.c b/arch/arm/mach-uniphier/pinctrl/pinctrl-sld8.c index f3fae1d..1c97c8b 100644 --- a/arch/arm/mach-uniphier/pinctrl/pinctrl-sld8.c +++ b/arch/arm/mach-uniphier/pinctrl/pinctrl-sld8.c @@ -9,7 +9,7 @@ #include "../init.h" #include "../sg-regs.h"
-void ph1_sld8_pin_init(void) +void uniphier_sld8_pin_init(void) { /* Comment format: PAD Name -> Function Name */
diff --git a/arch/arm/mach-uniphier/pll/pll-init-ld4.c b/arch/arm/mach-uniphier/pll/pll-init-ld4.c index b2de9e8..57c1d9f 100644 --- a/arch/arm/mach-uniphier/pll/pll-init-ld4.c +++ b/arch/arm/mach-uniphier/pll/pll-init-ld4.c @@ -183,7 +183,7 @@ static void vpll_init(void) writel(tmp, SC_VPLL27BCTRL); }
-int ph1_ld4_pll_init(const struct uniphier_board_data *bd) +int uniphier_ld4_pll_init(const struct uniphier_board_data *bd) { int ret;
diff --git a/arch/arm/mach-uniphier/pll/pll-init-pro4.c b/arch/arm/mach-uniphier/pll/pll-init-pro4.c index 69d518d..a7e4e0e 100644 --- a/arch/arm/mach-uniphier/pll/pll-init-pro4.c +++ b/arch/arm/mach-uniphier/pll/pll-init-pro4.c @@ -145,7 +145,7 @@ static void vpll_init(void) writel(tmp, SC_VPLL27BCTRL); }
-int ph1_pro4_pll_init(const struct uniphier_board_data *bd) +int uniphier_pro4_pll_init(const struct uniphier_board_data *bd) { int ret;
diff --git a/arch/arm/mach-uniphier/pll/pll-init-sld3.c b/arch/arm/mach-uniphier/pll/pll-init-sld3.c index b93806c..5b4f2e3 100644 --- a/arch/arm/mach-uniphier/pll/pll-init-sld3.c +++ b/arch/arm/mach-uniphier/pll/pll-init-sld3.c @@ -6,7 +6,7 @@
-int ph1_sld3_pll_init(const struct uniphier_board_data *bd) +int uniphier_sld3_pll_init(const struct uniphier_board_data *bd) { /* add pll init code here */ return 0; diff --git a/arch/arm/mach-uniphier/pll/pll-init-sld8.c b/arch/arm/mach-uniphier/pll/pll-init-sld8.c index 3c75504..b26106e 100644 --- a/arch/arm/mach-uniphier/pll/pll-init-sld8.c +++ b/arch/arm/mach-uniphier/pll/pll-init-sld8.c @@ -188,7 +188,7 @@ static void vpll_init(void) writel(tmp, SC_VPLL27BCTRL); }
-int ph1_sld8_pll_init(const struct uniphier_board_data *bd) +int uniphier_sld8_pll_init(const struct uniphier_board_data *bd) { dpll_init(); upll_init(); diff --git a/arch/arm/mach-uniphier/pll/pll-spectrum-ld4.c b/arch/arm/mach-uniphier/pll/pll-spectrum-ld4.c index a1c8089..dc97697 100644 --- a/arch/arm/mach-uniphier/pll/pll-spectrum-ld4.c +++ b/arch/arm/mach-uniphier/pll/pll-spectrum-ld4.c @@ -9,7 +9,7 @@ #include "../init.h" #include "../sc-regs.h"
-int ph1_ld4_enable_dpll_ssc(const struct uniphier_board_data *bd) +int uniphier_ld4_enable_dpll_ssc(const struct uniphier_board_data *bd) { u32 tmp;
diff --git a/arch/arm/mach-uniphier/pll/pll-spectrum-sld3.c b/arch/arm/mach-uniphier/pll/pll-spectrum-sld3.c index 94654ee..ff09a92 100644 --- a/arch/arm/mach-uniphier/pll/pll-spectrum-sld3.c +++ b/arch/arm/mach-uniphier/pll/pll-spectrum-sld3.c @@ -10,7 +10,7 @@ #include "../init.h" #include "../sc-regs.h"
-int ph1_sld3_enable_dpll_ssc(const struct uniphier_board_data *bd) +int uniphier_sld3_enable_dpll_ssc(const struct uniphier_board_data *bd) { u32 tmp;
diff --git a/arch/arm/mach-uniphier/sbc/sbc-admulti.c b/arch/arm/mach-uniphier/sbc/sbc-admulti.c index 8e9f8eb..05108dd 100644 --- a/arch/arm/mach-uniphier/sbc/sbc-admulti.c +++ b/arch/arm/mach-uniphier/sbc/sbc-admulti.c @@ -19,7 +19,7 @@ #define SBCTRL1_ADMULTIPLX_MEM_VALUE 0x03005500 #define SBCTRL2_ADMULTIPLX_MEM_VALUE 0x14000010
-int sbc_admulti_init(const struct uniphier_board_data *bd) +int uniphier_sbc_init_admulti(const struct uniphier_board_data *bd) { /* * Only CS1 is connected to support card. diff --git a/arch/arm/mach-uniphier/sbc/sbc-savepin.c b/arch/arm/mach-uniphier/sbc/sbc-savepin.c index e3e3daa..41e9796 100644 --- a/arch/arm/mach-uniphier/sbc/sbc-savepin.c +++ b/arch/arm/mach-uniphier/sbc/sbc-savepin.c @@ -22,7 +22,7 @@ #define SBCTRL2_SAVEPIN_MEM_VALUE 0x34000009 #define SBCTRL4_SAVEPIN_MEM_VALUE 0x02110210
-int sbc_savepin_init(const struct uniphier_board_data *bd) +int uniphier_sbc_init_savepin(const struct uniphier_board_data *bd) { /* * Only CS1 is connected to support card.
2016-03-30 20:17 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Masahiro Yamada
