[U-Boot] [PATCH 1/3] powerpc/p3041: Add various p3041 specific information
Add P3041 SoC specific information: * SERDES Table * LIODN setup * Portal configuration
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/Makefile | 2 + arch/powerpc/cpu/mpc85xx/p3041_ids.c | 105 +++++++++++++++++++++ arch/powerpc/cpu/mpc85xx/p3041_serdes.c | 151 +++++++++++++++++++++++++++++++ 3 files changed, 258 insertions(+), 0 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/p3041_ids.c create mode 100644 arch/powerpc/cpu/mpc85xx/p3041_serdes.c
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index af7bc09..d0447e2 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -70,6 +70,7 @@ COBJS-$(CONFIG_PCI) += pci.o COBJS-$(CONFIG_FSL_CORENET) += portals.o
# various SoC specific assignments +COBJS-$(CONFIG_PPC_P3041) += p3041_ids.o COBJS-$(CONFIG_PPC_P4080) += p4080_ids.o
COBJS-$(CONFIG_QE) += qe_io.o @@ -91,6 +92,7 @@ COBJS-$(CONFIG_P1021) += p1021_serdes.o COBJS-$(CONFIG_P1022) += p1022_serdes.o COBJS-$(CONFIG_P2010) += p2020_serdes.o COBJS-$(CONFIG_P2020) += p2020_serdes.o +COBJS-$(CONFIG_PPC_P3041) += p3041_serdes.o COBJS-$(CONFIG_PPC_P4080) += p4080_serdes.o
COBJS = $(COBJS-y) diff --git a/arch/powerpc/cpu/mpc85xx/p3041_ids.c b/arch/powerpc/cpu/mpc85xx/p3041_ids.c new file mode 100644 index 0000000..febbee9 --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/p3041_ids.c @@ -0,0 +1,105 @@ +/* + * Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> + +struct qportal_info qp_info[CONFIG_SYS_QMAN_NUM_PORTALS] = { + /* dqrr liodn, frame data liodn, liodn off, sdest */ + SET_QP_INFO( 1, 2, 1, 0), + SET_QP_INFO( 3, 4, 2, 1), + SET_QP_INFO( 5, 6, 3, 2), + SET_QP_INFO( 7, 8, 4, 3), + SET_QP_INFO( 9, 10, 5, 4), + SET_QP_INFO( 0, 0, 0, 5), + SET_QP_INFO( 0, 0, 0, 6), + SET_QP_INFO( 0, 0, 0, 7), + SET_QP_INFO( 0, 0, 0, 0), /* for now sdest to 0 */ + SET_QP_INFO( 0, 0, 0, 0), /* for now sdest to 0 */ +}; + +struct liodn_id_table liodn_tbl[] = { + SET_QMAN_LIODN(31), + SET_BMAN_LIODN(32), + + SET_SDHC_LIODN(1, 64), + + SET_PME_LIODN(117), + + SET_USB_LIODN(1, "fsl-usb2-mph", 125), + SET_USB_LIODN(2, "fsl-usb2-dr", 126), + + SET_SATA_LIODN(1, 127), + SET_SATA_LIODN(2, 128), + + SET_PCI_LIODN(1, 193), + SET_PCI_LIODN(2, 194), + SET_PCI_LIODN(3, 195), + SET_PCI_LIODN(4, 196), + + SET_DMA_LIODN(1, 197), + SET_DMA_LIODN(2, 198), + + SET_GUTS_LIODN("fsl,rapidio-delta", 199, rio1liodnr, 0), + SET_GUTS_LIODN(NULL, 200, rio2liodnr, 0), + SET_GUTS_LIODN(NULL, 201, rio1maintliodnr, 0), + SET_GUTS_LIODN(NULL, 202, rio2maintliodnr, 0), +}; + +#ifdef CONFIG_SYS_DPAA_FMAN +struct liodn_id_table fman1_liodn_tbl[] = { + SET_FMAN_RX_1G_LIODN(1, 0, 10), + SET_FMAN_RX_1G_LIODN(1, 1, 11), + SET_FMAN_RX_1G_LIODN(1, 2, 12), + SET_FMAN_RX_1G_LIODN(1, 3, 13), + SET_FMAN_RX_1G_LIODN(1, 4, 14), + SET_FMAN_RX_10G_LIODN(1, 0, 15), +}; +#endif + +struct liodn_id_table sec_liodn_tbl[] = { + SET_SEC_JR_LIODN_ENTRY(0, 129, 130), + SET_SEC_JR_LIODN_ENTRY(1, 131, 132), + SET_SEC_JR_LIODN_ENTRY(2, 133, 134), + SET_SEC_JR_LIODN_ENTRY(3, 135, 136), + SET_SEC_RTIC_LIODN_ENTRY(a, 154), + SET_SEC_RTIC_LIODN_ENTRY(b, 155), + SET_SEC_RTIC_LIODN_ENTRY(c, 156), + SET_SEC_RTIC_LIODN_ENTRY(d, 157), + SET_SEC_DECO_LIODN_ENTRY(0, 97, 98), + SET_SEC_DECO_LIODN_ENTRY(1, 99, 100), +}; + +struct liodn_id_table liodn_bases[] = { + [FSL_HW_PORTAL_SEC] = SET_LIODN_BASE_2(64, 100), +#ifdef CONFIG_SYS_DPAA_FMAN + [FSL_HW_PORTAL_FMAN1] = SET_LIODN_BASE_1(32), +#endif +#ifdef CONFIG_SYS_DPAA_PME + [FSL_HW_PORTAL_PME] = SET_LIODN_BASE_2(136, 172), +#endif +}; + +int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl); +int fman1_liodn_tbl_sz = ARRAY_SIZE(fman1_liodn_tbl); +int sec_liodn_tbl_sz = ARRAY_SIZE(sec_liodn_tbl); diff --git a/arch/powerpc/cpu/mpc85xx/p3041_serdes.c b/arch/powerpc/cpu/mpc85xx/p3041_serdes.c new file mode 100644 index 0000000..fba9ff2 --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/p3041_serdes.c @@ -0,0 +1,151 @@ +/* + * Copyright 2009-2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_serdes.h> +#include <asm/processor.h> +#include <asm/io.h> +#include "fsl_corenet_serdes.h" + +static u8 serdes_cfg_tbl[][SRDS_MAX_LANES] = { + [0x2] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + PCIE4, AURORA, PCIE3, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, NONE, NONE, SATA1, SATA2, }, + [0x4] = {SRIO2, SRIO2, SRIO2, SRIO2, SRIO1, SRIO1, SRIO1, SRIO1, + PCIE2, AURORA, PCIE3, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, }, + [0xb] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO2, SRIO2, SRIO1, SRIO1, + PCIE2, AURORA, PCIE3, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, NONE, NONE, SATA1, SATA2, }, + [0x10] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, }, + [0x11] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, NONE, SATA1, SATA2, }, + [0x13] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, XAUI_FM1, XAUI_FM1, + XAUI_FM1, XAUI_FM1, }, + [0x14] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, PCIE3, PCIE3, PCIE3, PCIE3, + SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, }, + [0x15] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, }, + [0x16] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, SRIO1, SRIO1, SRIO1, + SRIO1, }, + [0x17] = {SRIO2, SRIO2, SRIO2, SRIO2, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, NONE, SATA1, SATA2, }, + [0x18] = {SRIO2, SRIO2, SRIO2, SRIO2, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, NONE, + NONE, NONE, }, + [0x1b] = {SRIO2, SRIO2, SRIO2, SRIO2, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, }, + [0x1d] = {SRIO2, SRIO2, SRIO2, SRIO2, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, PCIE3, PCIE3, PCIE3, PCIE3, NONE, NONE, + SATA1, SATA2, }, + [0x20] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, XAUI_FM1, XAUI_FM1, + XAUI_FM1, XAUI_FM1, }, + [0x21] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, PCIE3, PCIE3, PCIE3, PCIE3, + SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, }, + [0x22] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, }, + [0x23] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO2, SRIO2, SRIO1, SRIO1, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, NONE, SATA1, SATA2, }, + [0x24] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO2, SRIO2, SRIO1, SRIO1, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, NONE, + NONE, NONE, }, + [0x28] = {PCIE1, PCIE1, PCIE3, PCIE3, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, NONE, SATA1, SATA2, }, + [0x29] = {PCIE1, PCIE1, PCIE3, PCIE3, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, NONE, + NONE, NONE, }, + [0x2a] = {PCIE1, PCIE1, PCIE3, PCIE3, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, XAUI_FM1, XAUI_FM1, + XAUI_FM1, XAUI_FM1, }, + [0x2b] = {PCIE1, PCIE1, PCIE3, PCIE3, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, }, + [0x2f] = {PCIE1, PCIE1, PCIE3, PCIE3, SRIO2, SRIO2, SRIO1, SRIO1, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, }, + [0x31] = {PCIE1, PCIE1, PCIE3, PCIE3, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, NONE, + NONE, NONE, }, + [0x33] = {PCIE1, PCIE1, PCIE3, PCIE3, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, }, + [0x34] = {PCIE1, PCIE1, PCIE1, PCIE1, SGMII_FM1_DTSEC1, + SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, AURORA, + AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, NONE, + NONE, SATA1, SATA2, }, + [0x35] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, AURORA, AURORA, XAUI_FM1, + XAUI_FM1, XAUI_FM1, XAUI_FM1, NONE, NONE, SATA1, SATA2, }, + [0x36] = {PCIE1, PCIE1, PCIE3, PCIE3, SGMII_FM1_DTSEC1, + SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, AURORA, + AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, NONE, + NONE, SATA1, SATA2, }, + [0x37] = {PCIE1, PCIE1, PCIE3, PCIE3, PCIE2, PCIE2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, AURORA, AURORA, XAUI_FM1, + XAUI_FM1, XAUI_FM1, XAUI_FM1, NONE, NONE, SATA1, SATA2, }, +}; + +enum srds_prtcl serdes_get_prtcl(int cfg, int lane) +{ + if (!serdes_lane_enabled(lane)) + return NONE; + + return serdes_cfg_tbl[cfg][lane]; +} + +int is_serdes_prtcl_valid(u32 prtcl) { + int i; + + if (prtcl > ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + + for (i = 0; i < SRDS_MAX_LANES; i++) { + if (serdes_cfg_tbl[prtcl][i] != NONE) + return 1; + } + + return 0; +}
Add P5020 SoC specific information: * SERDES Table * LIODN setup * Portal configuration
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/Makefile | 2 + arch/powerpc/cpu/mpc85xx/p5020_ids.c | 105 +++++++++++++++++++++ arch/powerpc/cpu/mpc85xx/p5020_serdes.c | 151 +++++++++++++++++++++++++++++++ 3 files changed, 258 insertions(+), 0 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/p5020_ids.c create mode 100644 arch/powerpc/cpu/mpc85xx/p5020_serdes.c
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index d0447e2..0bf9d5d 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -72,6 +72,7 @@ COBJS-$(CONFIG_FSL_CORENET) += portals.o # various SoC specific assignments COBJS-$(CONFIG_PPC_P3041) += p3041_ids.o COBJS-$(CONFIG_PPC_P4080) += p4080_ids.o +COBJS-$(CONFIG_PPC_P5020) += p5020_ids.o
COBJS-$(CONFIG_QE) += qe_io.o COBJS-$(CONFIG_CPM2) += serial_scc.o @@ -94,6 +95,7 @@ COBJS-$(CONFIG_P2010) += p2020_serdes.o COBJS-$(CONFIG_P2020) += p2020_serdes.o COBJS-$(CONFIG_PPC_P3041) += p3041_serdes.o COBJS-$(CONFIG_PPC_P4080) += p4080_serdes.o +COBJS-$(CONFIG_PPC_P5020) += p5020_serdes.o
COBJS = $(COBJS-y) COBJS += cpu.o diff --git a/arch/powerpc/cpu/mpc85xx/p5020_ids.c b/arch/powerpc/cpu/mpc85xx/p5020_ids.c new file mode 100644 index 0000000..febbee9 --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/p5020_ids.c @@ -0,0 +1,105 @@ +/* + * Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> + +struct qportal_info qp_info[CONFIG_SYS_QMAN_NUM_PORTALS] = { + /* dqrr liodn, frame data liodn, liodn off, sdest */ + SET_QP_INFO( 1, 2, 1, 0), + SET_QP_INFO( 3, 4, 2, 1), + SET_QP_INFO( 5, 6, 3, 2), + SET_QP_INFO( 7, 8, 4, 3), + SET_QP_INFO( 9, 10, 5, 4), + SET_QP_INFO( 0, 0, 0, 5), + SET_QP_INFO( 0, 0, 0, 6), + SET_QP_INFO( 0, 0, 0, 7), + SET_QP_INFO( 0, 0, 0, 0), /* for now sdest to 0 */ + SET_QP_INFO( 0, 0, 0, 0), /* for now sdest to 0 */ +}; + +struct liodn_id_table liodn_tbl[] = { + SET_QMAN_LIODN(31), + SET_BMAN_LIODN(32), + + SET_SDHC_LIODN(1, 64), + + SET_PME_LIODN(117), + + SET_USB_LIODN(1, "fsl-usb2-mph", 125), + SET_USB_LIODN(2, "fsl-usb2-dr", 126), + + SET_SATA_LIODN(1, 127), + SET_SATA_LIODN(2, 128), + + SET_PCI_LIODN(1, 193), + SET_PCI_LIODN(2, 194), + SET_PCI_LIODN(3, 195), + SET_PCI_LIODN(4, 196), + + SET_DMA_LIODN(1, 197), + SET_DMA_LIODN(2, 198), + + SET_GUTS_LIODN("fsl,rapidio-delta", 199, rio1liodnr, 0), + SET_GUTS_LIODN(NULL, 200, rio2liodnr, 0), + SET_GUTS_LIODN(NULL, 201, rio1maintliodnr, 0), + SET_GUTS_LIODN(NULL, 202, rio2maintliodnr, 0), +}; + +#ifdef CONFIG_SYS_DPAA_FMAN +struct liodn_id_table fman1_liodn_tbl[] = { + SET_FMAN_RX_1G_LIODN(1, 0, 10), + SET_FMAN_RX_1G_LIODN(1, 1, 11), + SET_FMAN_RX_1G_LIODN(1, 2, 12), + SET_FMAN_RX_1G_LIODN(1, 3, 13), + SET_FMAN_RX_1G_LIODN(1, 4, 14), + SET_FMAN_RX_10G_LIODN(1, 0, 15), +}; +#endif + +struct liodn_id_table sec_liodn_tbl[] = { + SET_SEC_JR_LIODN_ENTRY(0, 129, 130), + SET_SEC_JR_LIODN_ENTRY(1, 131, 132), + SET_SEC_JR_LIODN_ENTRY(2, 133, 134), + SET_SEC_JR_LIODN_ENTRY(3, 135, 136), + SET_SEC_RTIC_LIODN_ENTRY(a, 154), + SET_SEC_RTIC_LIODN_ENTRY(b, 155), + SET_SEC_RTIC_LIODN_ENTRY(c, 156), + SET_SEC_RTIC_LIODN_ENTRY(d, 157), + SET_SEC_DECO_LIODN_ENTRY(0, 97, 98), + SET_SEC_DECO_LIODN_ENTRY(1, 99, 100), +}; + +struct liodn_id_table liodn_bases[] = { + [FSL_HW_PORTAL_SEC] = SET_LIODN_BASE_2(64, 100), +#ifdef CONFIG_SYS_DPAA_FMAN + [FSL_HW_PORTAL_FMAN1] = SET_LIODN_BASE_1(32), +#endif +#ifdef CONFIG_SYS_DPAA_PME + [FSL_HW_PORTAL_PME] = SET_LIODN_BASE_2(136, 172), +#endif +}; + +int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl); +int fman1_liodn_tbl_sz = ARRAY_SIZE(fman1_liodn_tbl); +int sec_liodn_tbl_sz = ARRAY_SIZE(sec_liodn_tbl); diff --git a/arch/powerpc/cpu/mpc85xx/p5020_serdes.c b/arch/powerpc/cpu/mpc85xx/p5020_serdes.c new file mode 100644 index 0000000..fba9ff2 --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/p5020_serdes.c @@ -0,0 +1,151 @@ +/* + * Copyright 2009-2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_serdes.h> +#include <asm/processor.h> +#include <asm/io.h> +#include "fsl_corenet_serdes.h" + +static u8 serdes_cfg_tbl[][SRDS_MAX_LANES] = { + [0x2] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + PCIE4, AURORA, PCIE3, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, NONE, NONE, SATA1, SATA2, }, + [0x4] = {SRIO2, SRIO2, SRIO2, SRIO2, SRIO1, SRIO1, SRIO1, SRIO1, + PCIE2, AURORA, PCIE3, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, }, + [0xb] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO2, SRIO2, SRIO1, SRIO1, + PCIE2, AURORA, PCIE3, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, NONE, NONE, SATA1, SATA2, }, + [0x10] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, PCIE1, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, }, + [0x11] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, NONE, SATA1, SATA2, }, + [0x13] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, XAUI_FM1, XAUI_FM1, + XAUI_FM1, XAUI_FM1, }, + [0x14] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, PCIE3, PCIE3, PCIE3, PCIE3, + SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, }, + [0x15] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, }, + [0x16] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, SRIO1, SRIO1, SRIO1, + SRIO1, }, + [0x17] = {SRIO2, SRIO2, SRIO2, SRIO2, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, NONE, SATA1, SATA2, }, + [0x18] = {SRIO2, SRIO2, SRIO2, SRIO2, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, NONE, + NONE, NONE, }, + [0x1b] = {SRIO2, SRIO2, SRIO2, SRIO2, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, }, + [0x1d] = {SRIO2, SRIO2, SRIO2, SRIO2, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, PCIE3, PCIE3, PCIE3, PCIE3, NONE, NONE, + SATA1, SATA2, }, + [0x20] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, XAUI_FM1, XAUI_FM1, + XAUI_FM1, XAUI_FM1, }, + [0x21] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, PCIE3, PCIE3, PCIE3, PCIE3, + SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, }, + [0x22] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, }, + [0x23] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO2, SRIO2, SRIO1, SRIO1, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, NONE, SATA1, SATA2, }, + [0x24] = {PCIE1, PCIE1, PCIE1, PCIE1, SRIO2, SRIO2, SRIO1, SRIO1, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, NONE, + NONE, NONE, }, + [0x28] = {PCIE1, PCIE1, PCIE3, PCIE3, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, NONE, SATA1, SATA2, }, + [0x29] = {PCIE1, PCIE1, PCIE3, PCIE3, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, NONE, + NONE, NONE, }, + [0x2a] = {PCIE1, PCIE1, PCIE3, PCIE3, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, XAUI_FM1, XAUI_FM1, + XAUI_FM1, XAUI_FM1, }, + [0x2b] = {PCIE1, PCIE1, PCIE3, PCIE3, PCIE2, PCIE2, PCIE2, PCIE2, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, }, + [0x2f] = {PCIE1, PCIE1, PCIE3, PCIE3, SRIO2, SRIO2, SRIO1, SRIO1, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, }, + [0x31] = {PCIE1, PCIE1, PCIE3, PCIE3, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, NONE, + NONE, NONE, }, + [0x33] = {PCIE1, PCIE1, PCIE3, PCIE3, SRIO1, SRIO1, SRIO1, SRIO1, + AURORA, AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, + NONE, NONE, SATA1, SATA2, }, + [0x34] = {PCIE1, PCIE1, PCIE1, PCIE1, SGMII_FM1_DTSEC1, + SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, AURORA, + AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, NONE, + NONE, SATA1, SATA2, }, + [0x35] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, AURORA, AURORA, XAUI_FM1, + XAUI_FM1, XAUI_FM1, XAUI_FM1, NONE, NONE, SATA1, SATA2, }, + [0x36] = {PCIE1, PCIE1, PCIE3, PCIE3, SGMII_FM1_DTSEC1, + SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, AURORA, + AURORA, XAUI_FM1, XAUI_FM1, XAUI_FM1, XAUI_FM1, NONE, + NONE, SATA1, SATA2, }, + [0x37] = {PCIE1, PCIE1, PCIE3, PCIE3, PCIE2, PCIE2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, AURORA, AURORA, XAUI_FM1, + XAUI_FM1, XAUI_FM1, XAUI_FM1, NONE, NONE, SATA1, SATA2, }, +}; + +enum srds_prtcl serdes_get_prtcl(int cfg, int lane) +{ + if (!serdes_lane_enabled(lane)) + return NONE; + + return serdes_cfg_tbl[cfg][lane]; +} + +int is_serdes_prtcl_valid(u32 prtcl) { + int i; + + if (prtcl > ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + + for (i = 0; i < SRDS_MAX_LANES; i++) { + if (serdes_cfg_tbl[prtcl][i] != NONE) + return 1; + } + + return 0; +}
Add P2040 SoC specific information: * SERDES Table * LIODN setup * Portal configuration
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/p2040_serdes.c | 66 +++++++++++++++++++++++++++++++ arch/powerpc/cpu/mpc8xxx/cpu.c | 2 + arch/powerpc/include/asm/processor.h | 2 + 3 files changed, 70 insertions(+), 0 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/p2040_serdes.c
diff --git a/arch/powerpc/cpu/mpc85xx/p2040_serdes.c b/arch/powerpc/cpu/mpc85xx/p2040_serdes.c new file mode 100644 index 0000000..a96eff4 --- /dev/null +++ b/arch/powerpc/cpu/mpc85xx/p2040_serdes.c @@ -0,0 +1,66 @@ +/* + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_serdes.h> +#include <asm/processor.h> +#include <asm/io.h> +#include "fsl_corenet_serdes.h" + +static u8 serdes_cfg_tbl[][SRDS_MAX_LANES] = { + [0x2] = {NONE, NONE, PCIE1, PCIE1, SRIO1, SRIO1, SRIO1, SRIO1, + NONE, NONE, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, NONE, NONE, NONE, }, + [0x5] = {NONE, NONE, PCIE1, PCIE3, PCIE2, PCIE2, PCIE2, PCIE2, + NONE, NONE, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, NONE, NONE, NONE, }, + [0x8] = {NONE, NONE, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, PCIE2, + PCIE2, PCIE2, PCIE2, NONE, NONE, NONE, NONE, SATA1, + SATA2, NONE, NONE, NONE, NONE, }, + [0xa] = {NONE, NONE, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, PCIE2, + PCIE2, PCIE2, PCIE2, NONE, NONE, PCIE3, PCIE3, PCIE3, + PCIE3, NONE, NONE, NONE, NONE, }, + [0xf] = {NONE, NONE, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, SRIO2, + SRIO2, SRIO1, SRIO1, NONE, NONE, PCIE3, SGMII_FM1_DTSEC5, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, NONE, NONE, NONE, }, + [0x14] = {NONE, NONE, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, PCIE2, + PCIE2, SRIO1, SRIO1, NONE, NONE, AURORA, + SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, + NONE, NONE, NONE, }, + [0x16] = {NONE, NONE, PCIE1, PCIE3, PCIE2, PCIE2, SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, NONE, NONE, NONE, NONE, SATA1, SATA2, NONE, + NONE, NONE, NONE, }, + [0x1a] = {NONE, NONE, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, SRIO2, + SRIO2, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, NONE, + NONE, NONE, SATA1, SATA2, NONE, NONE, NONE, NONE, }, + [0x1c] = {NONE, NONE, PCIE1, SGMII_FM1_DTSEC2, PCIE2, PCIE2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, NONE, NONE, AURORA, + SGMII_FM1_DTSEC5, NONE, NONE, NONE, NONE, NONE, NONE, }, +}; + +enum srds_prtcl serdes_get_prtcl(int cfg, int lane) +{ + if (!serdes_lane_enabled(lane)) + return NONE; + + return serdes_cfg_tbl[cfg][lane]; +} diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index 5b30fbd..79d988c 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -80,6 +80,8 @@ struct cpu_type cpu_type_list [] = { CPU_TYPE_ENTRY(P2010, P2010_E, 1), CPU_TYPE_ENTRY(P2020, P2020, 2), CPU_TYPE_ENTRY(P2020, P2020_E, 2), + CPU_TYPE_ENTRY(P2040, P2040, 4), + CPU_TYPE_ENTRY(P2040, P2040_E, 4), CPU_TYPE_ENTRY(P3041, P3041, 4), CPU_TYPE_ENTRY(P3041, P3041_E, 4), CPU_TYPE_ENTRY(P4040, P4040, 4), diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 71fafa3..a0af71e 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -1054,6 +1054,8 @@ #define SVR_P2010_E 0x80EB00 #define SVR_P2020 0x80E200 #define SVR_P2020_E 0x80EA00 +#define SVR_P2040 0x821000 +#define SVR_P2040_E 0x821800 #define SVR_P3041 0x821103 #define SVR_P3041_E 0x821903 #define SVR_P4040 0x820100
- SERDES Table
- LIODN setup
- Portal configuration
applied to 85xx
- k
- SERDES Table
- LIODN setup
applied to 85xx
- k
Kumar Gala
