[U-Boot-Users] [for clues] No rule to make target .depend
Hi all, I am newbie. I am trying to port u-boot to my board. I did these things: 1. copy a existing board directory, say m5445evb, to a new one "mercury" 2. copy the M5445X_config section and rename it to "MERCURY_config" 3. change board name "m5445evb" in the "@mkconfig -a ..." line to mercury but when I try to compile u-boot make says "no rule to make target .depend", needed by lib_mercury.a in the board/freescale/mercury directory. I can compile u-boot for m5445evb normally. What's the matter?
In message 6bb35d250805202300k58ffd3f5h3b5664b46c368d58@mail.gmail.com you wrote:
You failed to adapt board/freescale/mercury/Makefile to your new board. Are you sure this is indeed a Freescale board? If not, then why is it located in the Freescale vendor directory?
I found the stupid mistake. I copy the entire directory and forget to modify the Makefile inside. just rename the $(ORIG_BOARD).c to $(NEW_BOARD).c since there is a line in Makefile: OBJS = $(BOARD).o. There is no mercury.c so make is unhappy. However the make give me confusing messages. Hope this mail be helpful to other newbies.
It's adapted from the evaluation board.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de History tends to exaggerate. -- Col. Green, "The Savage Curtain", stardate 5906.4
YIngjian Zhan
