[PATCH] rockchip: px30: sync the main px30 dtsi from mainline
From: Heiko Stuebner heiko.stuebner@theobroma-systems.com
There have been multiple peripherals added to the main px30 dtsi in the Linux kernel since its addition to u-boot. So to make it easier to sync board devicetrees, update the core dtsi from Linux.
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com --- arch/arm/dts/px30.dtsi | 182 ++++++++++++++++++++++++++++++++++++++--- 1 file changed, 171 insertions(+), 11 deletions(-)
diff --git a/arch/arm/dts/px30.dtsi b/arch/arm/dts/px30.dtsi index 0d2325a77f..b6c79e7ed3 100644 --- a/arch/arm/dts/px30.dtsi +++ b/arch/arm/dts/px30.dtsi @@ -10,6 +10,7 @@ #include <dt-bindings/pinctrl/rockchip.h> #include <dt-bindings/power/px30-power.h> #include <dt-bindings/soc/rockchip,boot-mode.h> +#include <dt-bindings/thermal/thermal.h>
/ { compatible = "rockchip,px30"; @@ -113,16 +114,11 @@ compatible = "operating-points-v2"; opp-shared;
- opp-408000000 { - opp-hz = /bits/ 64 <408000000>; - opp-microvolt = <950000 950000 1350000>; - clock-latency-ns = <40000>; - opp-suspend; - }; opp-600000000 { opp-hz = /bits/ 64 <600000000>; opp-microvolt = <950000 950000 1350000>; clock-latency-ns = <40000>; + opp-suspend; }; opp-816000000 { opp-hz = /bits/ 64 <816000000>; @@ -186,6 +182,55 @@ <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; };
+ thermal_zones: thermal-zones { + soc_thermal: soc-thermal { + polling-delay-passive = <20>; + polling-delay = <1000>; + sustainable-power = <750>; + thermal-sensors = <&tsadc 0>; + + trips { + threshold: trip-point-0 { + temperature = <70000>; + hysteresis = <2000>; + type = "passive"; + }; + + target: trip-point-1 { + temperature = <85000>; + hysteresis = <2000>; + type = "passive"; + }; + + soc_crit: soc-crit { + temperature = <115000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&target>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + contribution = <4096>; + }; + + map1 { + trip = <&target>; + cooling-device = <&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + contribution = <4096>; + }; + }; + }; + + gpu_thermal: gpu-thermal { + polling-delay-passive = <100>; /* milliseconds */ + polling-delay = <1000>; /* milliseconds */ + thermal-sensors = <&tsadc 1>; + }; + }; + xin24m: xin24m { compatible = "fixed-clock"; #clock-cells = <0>; @@ -370,6 +415,36 @@ compatible = "rockchip,px30-io-voltage-domain"; status = "disabled"; }; + + lvds: lvds { + compatible = "rockchip,px30-lvds"; + phys = <&dsi_dphy>; + phy-names = "dphy"; + rockchip,grf = <&grf>; + rockchip,output = "lvds"; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + + lvds_vopb_in: endpoint@0 { + reg = <0>; + remote-endpoint = <&vopb_out_lvds>; + }; + + lvds_vopl_in: endpoint@1 { + reg = <1>; + remote-endpoint = <&vopl_out_lvds>; + }; + }; + }; + }; };
uart1: serial@ff158000 { @@ -650,6 +725,26 @@ }; };
+ tsadc: tsadc@ff280000 { + compatible = "rockchip,px30-tsadc"; + reg = <0x0 0xff280000 0x0 0x100>; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; + assigned-clocks = <&cru SCLK_TSADC>; + assigned-clock-rates = <50000>; + clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>; + clock-names = "tsadc", "apb_pclk"; + resets = <&cru SRST_TSADC>; + reset-names = "tsadc-apb"; + rockchip,grf = <&grf>; + rockchip,hw-tshut-temp = <120000>; + pinctrl-names = "init", "default", "sleep"; + pinctrl-0 = <&tsadc_otp_gpio>; + pinctrl-1 = <&tsadc_otp_out>; + pinctrl-2 = <&tsadc_otp_gpio>; + #thermal-sensor-cells = <1>; + status = "disabled"; + }; + saradc: saradc@ff288000 { compatible = "rockchip,px30-saradc", "rockchip,rk3399-saradc"; reg = <0x0 0xff288000 0x0 0x100>; @@ -706,12 +801,48 @@ #reset-cells = <1>; };
+ usb2phy_grf: syscon@ff2c0000 { + compatible = "rockchip,px30-usb2phy-grf", "syscon", + "simple-mfd"; + reg = <0x0 0xff2c0000 0x0 0x10000>; + #address-cells = <1>; + #size-cells = <1>; + + u2phy: usb2-phy@100 { + compatible = "rockchip,px30-usb2phy"; + reg = <0x100 0x20>; + clocks = <&pmucru SCLK_USBPHY_REF>; + clock-names = "phyclk"; + #clock-cells = <0>; + assigned-clocks = <&cru USB480M>; + assigned-clock-parents = <&u2phy>; + clock-output-names = "usb480m_phy"; + status = "disabled"; + + u2phy_host: host-port { + #phy-cells = <0>; + interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "linestate"; + status = "disabled"; + }; + + u2phy_otg: otg-port { + #phy-cells = <0>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "otg-bvalid", "otg-id", + "linestate"; + status = "disabled"; + }; + }; + }; + dsi_dphy: phy@ff2e0000 { compatible = "rockchip,px30-dsi-dphy"; reg = <0x0 0xff2e0000 0x0 0x10000>; clocks = <&pmucru SCLK_MIPIDSIPHY_REF>, <&cru PCLK_MIPIDSIPHY>; clock-names = "ref", "pclk"; - #clock-cells = <0>; resets = <&cru SRST_MIPIDSIPHY_P>; reset-names = "apb"; #phy-cells = <0>; @@ -731,6 +862,8 @@ g-rx-fifo-size = <280>; g-tx-fifo-size = <256 128 128 64 32 16>; g-use-dma; + phys = <&u2phy_otg>; + phy-names = "usb2-phy"; power-domains = <&power PX30_PD_USB>; status = "disabled"; }; @@ -741,6 +874,8 @@ interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_HOST>; clock-names = "usbhost"; + phys = <&u2phy_host>; + phy-names = "usb"; power-domains = <&power PX30_PD_USB>; status = "disabled"; }; @@ -751,6 +886,8 @@ interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_HOST>; clock-names = "usbhost"; + phys = <&u2phy_host>; + phy-names = "usb"; power-domains = <&power PX30_PD_USB>; status = "disabled"; }; @@ -823,17 +960,30 @@ status = "disabled"; };
+ gpu: gpu@ff400000 { + compatible = "rockchip,px30-mali", "arm,mali-bifrost"; + reg = <0x0 0xff400000 0x0 0x4000>; + interrupts = <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "job", "mmu", "gpu"; + clocks = <&cru SCLK_GPU>; + #cooling-cells = <2>; + power-domains = <&power PX30_PD_GPU>; + status = "disabled"; + }; + dsi: dsi@ff450000 { compatible = "rockchip,px30-mipi-dsi"; reg = <0x0 0xff450000 0x0 0x10000>; interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_MIPI_DSI>, <&dsi_dphy>; - clock-names = "pclk", "pll"; - resets = <&cru SRST_MIPIDSI_HOST_P>; - reset-names = "apb"; + clocks = <&cru PCLK_MIPI_DSI>; + clock-names = "pclk"; phys = <&dsi_dphy>; phy-names = "dphy"; power-domains = <&power PX30_PD_VO>; + resets = <&cru SRST_MIPIDSI_HOST_P>; + reset-names = "apb"; rockchip,grf = <&grf>; #address-cells = <1>; #size-cells = <0>; @@ -883,6 +1033,11 @@ reg = <0>; remote-endpoint = <&dsi_in_vopb>; }; + + vopb_out_lvds: endpoint@1 { + reg = <1>; + remote-endpoint = <&lvds_vopb_in>; + }; }; };
@@ -920,6 +1075,11 @@ reg = <0>; remote-endpoint = <&dsi_in_vopl>; }; + + vopl_out_lvds: endpoint@1 { + reg = <1>; + remote-endpoint = <&lvds_vopl_in>; + }; }; };
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
opp-408000000 {
opp-suspend;
opp-600000000 { opp-hz = /bits/ 64 <600000000>; opp-microvolt = <950000 950000 1350000>; clock-latency-ns = <40000>;};
}; opp-816000000 { opp-hz = /bits/ 64 <816000000>;opp-suspend;
- thermal_zones: thermal-zones {
trips {
type = "passive";
type = "passive";
type = "critical";
cooling-maps {
map0 {
trip = <&target>;
map1 {
trip = <&target>;
- xin24m: xin24m { compatible = "fixed-clock"; #clock-cells = <0>;
lvds: lvds {
phys = <&dsi_dphy>;
phy-names = "dphy";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
#size-cells = <0>;
reg = <0>;
reg = <1>;
- tsadc: tsadc@ff280000 {
- saradc: saradc@ff288000 { compatible = "rockchip,px30-saradc", "rockchip,rk3399-saradc"; reg = <0x0 0xff288000 0x0 0x100>;
- usb2phy_grf: syscon@ff2c0000 {
"simple-mfd";
#size-cells = <1>;
reg = <0x100 0x20>;
#clock-cells = <0>;
#phy-cells = <0>;
#phy-cells = <0>;
"linestate";
- dsi_dphy: phy@ff2e0000 { compatible = "rockchip,px30-dsi-dphy"; reg = <0x0 0xff2e0000 0x0 0x10000>; clocks = <&pmucru SCLK_MIPIDSIPHY_REF>, <&cru PCLK_MIPIDSIPHY>; clock-names = "ref", "pclk";
resets = <&cru SRST_MIPIDSIPHY_P>; reset-names = "apb"; #phy-cells = <0>;#clock-cells = <0>;
power-domains = <&power PX30_PD_USB>; status = "disabled"; };phy-names = "usb2-phy";
power-domains = <&power PX30_PD_USB>; status = "disabled"; };phy-names = "usb";
- gpu: gpu@ff400000 {
- dsi: dsi@ff450000 { compatible = "rockchip,px30-mipi-dsi"; reg = <0x0 0xff450000 0x0 0x10000>; interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>;
phys = <&dsi_dphy>; phy-names = "dphy"; power-domains = <&power PX30_PD_VO>;clock-names = "pclk";
rockchip,grf = <&grf>; #address-cells = <1>; #size-cells = <0>;reset-names = "apb";
reg = <1>;
reg = <1>;
Heiko Stuebner
Kever Yang
