[PATCH] Convert CONFIG_BOOTP_SEND_HOSTNAME to Kconfig
This converts the following to Kconfig: CONFIG_BOOTP_SEND_HOSTNAME
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/README b/README index 60d8e77256..6bac583666 100644 --- a/README +++ b/README @@ -1427,7 +1427,6 @@ The following options need to be configured:
CONFIG_BOOTP_NISDOMAIN CONFIG_BOOTP_BOOTFILESIZE - CONFIG_BOOTP_SEND_HOSTNAME CONFIG_BOOTP_NTPSERVER CONFIG_BOOTP_TIMEOFFSET CONFIG_BOOTP_VENDOREX @@ -1442,13 +1441,6 @@ The following options need to be configured: to Link-local IP address configuration if the DHCP server is not available.
- CONFIG_BOOTP_SEND_HOSTNAME - Some DHCP servers are capable - to do a dynamic update of a DNS server. To do this, they - need the hostname of the DHCP requester. - If CONFIG_BOOTP_SEND_HOSTNAME is defined, the content - of the "hostname" environment variable is passed as - option 12 to the DHCP server. - CONFIG_BOOTP_DHCP_REQUEST_DELAY
A 32bit value in microseconds for a delay between diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 4e6a3ca446..57133a7059 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -48,6 +48,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am335x-baltos" CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_SYS_OMAP24_I2C_SPEED=1000 CONFIG_DM_MMC=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 984c33c42f..104e7b5b51 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -37,6 +37,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y # CONFIG_SPL_BLK is not set CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DFU_MMC=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 2030cd3610..d530b9fe45 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -42,6 +42,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_CLK=y CONFIG_CLK_CDCE9XX=y diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index 535a6b4d13..6a5e93b627 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -66,6 +66,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_ENV_IS_NOWHERE=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_SPL_DM=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_LED=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index 31ffbf063a..5d26e675d9 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -39,6 +39,7 @@ CONFIG_OF_LIST="am335x-evm am335x-bone am335x-boneblack am335x-evmsk am335x-bone CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_CLK=y CONFIG_CLK_CDCE9XX=y diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index dfe506f9ed..1007afdba5 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -41,6 +41,7 @@ CONFIG_OF_LIST="am335x-evm am335x-bone am335x-boneblack am335x-evmsk am335x-bone CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_CLK=y CONFIG_CLK_CDCE9XX=y diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index 80d56eb1dd..eeec15ec28 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -67,6 +67,7 @@ CONFIG_ENV_UBI_VOLUME="config" CONFIG_ENV_UBI_VOLUME_REDUND="config_r" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index e45bbe0862..7039a892e6 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -49,6 +49,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index 9df1f11848..960af25493 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -50,6 +50,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index 96c40485e1..1d4478b5f0 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -51,6 +51,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index 8140c99173..45505aefda 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -50,6 +50,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index b048ba19d3..26b3123e81 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -47,6 +47,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index b4c18b2017..e8398c8332 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -50,6 +50,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am3517-evm" CONFIG_ENV_OVERWRITE=y # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_OF_TRANSLATE=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 76e968e9fe..5901b0d441 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -42,6 +42,7 @@ CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 55435f432b..dc640715dc 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -38,6 +38,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 505192252a..d1a84d7464 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -36,6 +36,7 @@ CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index c37d4696e3..5df892f163 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -50,6 +50,7 @@ CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index f1426f73bb..d3806673be 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -47,6 +47,7 @@ CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 22a7d8e760..c3e7d990d0 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -52,6 +52,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 2de84d9c95..ccaff201e7 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -54,6 +54,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index dda38ee1a6..46730fb336 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -59,6 +59,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 2c5544dd21..96b2d7f0ae 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -44,6 +44,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index 9166f63568..59fc182d74 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -44,6 +44,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 5e1c17267d..73be4939e7 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -70,6 +70,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index c35d106768..b0c158cb21 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -73,6 +73,7 @@ CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index d27ed844a0..f7c596ef63 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -77,6 +77,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/brppt2_defconfig b/configs/brppt2_defconfig index a88c19f2f9..1aec25c5d4 100644 --- a/configs/brppt2_defconfig +++ b/configs/brppt2_defconfig @@ -62,6 +62,7 @@ CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index 0ce69a65fc..7e3dff8944 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -76,6 +76,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 149bbc7054..6f381ce2e1 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -69,6 +69,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index 772b9c2b25..6f3370634a 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -44,6 +44,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_MISC=y CONFIG_DM_MMC=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index a588778ea0..0a24a0d290 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -45,6 +45,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:2m(spl),1m(u-boot),1m(u-boot-env),1m(dtb) CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_CMD_PCA953X=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 7471d411d6..8057ca444e 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -57,6 +57,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index d68478c681..e9839b9ca4 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -53,6 +53,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="da850-evm" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 36ef122ba3..bde2f0db6b 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -43,6 +43,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="da850-evm" CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0x60100000 +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_BLK=y CONFIG_DA8XX_GPIO=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 743108d439..3b863829d7 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -53,6 +53,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="da850-evm" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 593e9ca8eb..bd20c435b2 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -33,6 +33,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:512k(x-loader),1920k(u-boot),128k(u-boot- CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_TWL4030_LED=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 5c7b56221d..6f6c50988b 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -56,6 +56,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_DEVICE_REMOVE=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index dc05e81bae..c0e5eef7c0 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -59,6 +59,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_DEVICE_REMOVE=y diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index df797d2d53..18cdd73514 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -55,6 +55,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_DEVICE_REMOVE=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index e914e94faa..2f0266f00e 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -68,6 +68,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 830d430a9d..84b8a4f7fb 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -69,6 +69,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index b0c3ddc202..41eca0cc18 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -45,6 +45,7 @@ CONFIG_DEFAULT_DEVICE_TREE="keystone-k2e-evm" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index 572df03813..d53d604c30 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -33,6 +33,7 @@ CONFIG_DEFAULT_DEVICE_TREE="keystone-k2e-evm" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SYS_I2C_DAVINCI=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 08d79a3093..49bea62306 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -46,6 +46,7 @@ CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_DFU_MMC=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index fcf283b2b1..081e7f1039 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -34,6 +34,7 @@ CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 4ff7b4c04a..d10b27366d 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -45,6 +45,7 @@ CONFIG_DEFAULT_DEVICE_TREE="keystone-k2hk-evm" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 27a52b488f..7eecbe7354 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -33,6 +33,7 @@ CONFIG_DEFAULT_DEVICE_TREE="keystone-k2hk-evm" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SYS_I2C_DAVINCI=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index d80e8f90e2..ae8a80fad8 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -45,6 +45,7 @@ CONFIG_DEFAULT_DEVICE_TREE="keystone-k2l-evm" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index e9002551ae..ad70cf998f 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -34,6 +34,7 @@ CONFIG_DEFAULT_DEVICE_TREE="keystone-k2l-evm" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SYS_I2C_DAVINCI=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 7f4549dc74..e722de5df6 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -50,6 +50,7 @@ CONFIG_DEFAULT_DEVICE_TREE="da850-lcdk" CONFIG_SPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 31590b6124..b55858c750 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -54,6 +54,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index d23bc34944..66e5f52f13 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_MMC_OMAP_HS=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_MICREL=y diff --git a/configs/phycore-am335x-r2-wega_defconfig b/configs/phycore-am335x-r2-wega_defconfig index b6d8fdd62b..ea8bd1278a 100644 --- a/configs/phycore-am335x-r2-wega_defconfig +++ b/configs/phycore-am335x-r2-wega_defconfig @@ -57,6 +57,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DM_I2C=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 358cc85050..4af2fa3970 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -68,6 +68,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am335x-pxm50" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 5ac40f52b1..85115d6a78 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -68,6 +68,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 7b9969dacd..83bf0f5e5d 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -69,6 +69,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am335x-rut" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 61b569eb3c..e194ee523d 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -5,9 +5,9 @@ CONFIG_ENV_OFFSET=0x100000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_TARGET_SOCFPGA_SOFTING_VINING_FPGA=y CONFIG_ENV_OFFSET_REDUND=0x110000 -CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_BOOTDELAY=5 @@ -47,6 +47,7 @@ CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_vining_fpga" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index d3d02b5bbe..52870ad910 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -68,6 +68,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig index ea9c3af4de..a9f116bc6f 100644 --- a/configs/ti814x_evm_defconfig +++ b/configs/ti814x_evm_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_FAT=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_MMC_OMAP_HS=y CONFIG_PHY_ET1011C=y CONFIG_MII=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index d4dad47888..6f1d2c40c9 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -50,6 +50,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_OMAP24XX=y diff --git a/include/configs/adp-ae3xx.h b/include/configs/adp-ae3xx.h index 6a65f7a292..a7adb599ca 100644 --- a/include/configs/adp-ae3xx.h +++ b/include/configs/adp-ae3xx.h @@ -21,7 +21,6 @@
#define CONFIG_ARCH_MAP_SYSMEM
-#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_BOOTP_SERVERIP
#ifdef CONFIG_SKIP_LOWLEVEL_INIT diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index e37369b01e..afec9ba242 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -19,7 +19,6 @@
#ifndef CONFIG_SKIP_LOWLEVEL_INIT diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index c881ac6211..c88067c012 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -240,7 +240,6 @@ #endif
#define CONFIG_BOOTP_DEFAULT -#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10
/* I2C configuration */ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 28aa6eb886..a0d815db32 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -35,7 +35,6 @@
/* Ethernet */ #define CONFIG_BOOTP_DEFAULT -#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10
/* Board NAND Info. */ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index b7cc1a137b..6788cb01f6 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -193,7 +193,6 @@ #ifndef CONFIG_SPL_BUILD /* CPSW Ethernet */ #define CONFIG_BOOTP_DEFAULT -#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 #endif
diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index adcd9a12e2..5d5b8f4eb8 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -54,7 +54,6 @@ #define CONFIG_HSMMC2_8BIT
/* CPSW Ethernet */ -#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 #define PHY_ANEG_TIMEOUT 8000 /* PHY needs longer aneg time at 1G */
diff --git a/include/configs/ax25-ae350.h b/include/configs/ax25-ae350.h index bbae60b490..6d53f922b7 100644 --- a/include/configs/ax25-ae350.h +++ b/include/configs/ax25-ae350.h @@ -27,7 +27,6 @@ /* * CPU and Board Configuration Options */ -#define CONFIG_BOOTP_SEND_HOSTNAME
/* * Miscellaneous configurable options diff --git a/include/configs/bur_cfg_common.h b/include/configs/bur_cfg_common.h index 50155368c1..325ef1e754 100644 --- a/include/configs/bur_cfg_common.h +++ b/include/configs/bur_cfg_common.h @@ -24,7 +24,6 @@ "setenv stdout nc;setenv stdin nc;setenv stderr nc\0"
/* Network defines */ -#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10
/* Network console */ diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 55d9f5352b..857a5d86dd 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -44,7 +44,6 @@
/* CPSW Ethernet support */ #define CONFIG_BOOTP_DEFAULT -#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_SYS_RX_ETH_BUFFER 64
/* USB support */ diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index d15d69a14c..a4d69686e1 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -163,7 +163,6 @@ * Network & Ethernet Configuration */ #ifdef CONFIG_DRIVER_TI_EMAC -#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 #endif
diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index f90c1c5a18..5ef0fe7f92 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -65,7 +65,6 @@ /* BOOTP/DHCP options */ #define CONFIG_BOOTP_NISDOMAIN #define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_BOOTP_TIMEOFFSET #undef CONFIG_BOOTP_VENDOREX
diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 14cd82f5a3..1653c7d2df 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -62,7 +62,6 @@ #define CONFIG_HSMMC2_8BIT
/* diff --git a/include/configs/microchip_mpfs_icicle.h b/include/configs/microchip_mpfs_icicle.h index 8ddfc6f14d..8a7470545b 100644 --- a/include/configs/microchip_mpfs_icicle.h +++ b/include/configs/microchip_mpfs_icicle.h @@ -10,7 +10,6 @@ /* * CPU and Board Configuration Options */ -#define CONFIG_BOOTP_SEND_HOSTNAME
/* * Miscellaneous configurable options diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index ad3bacb8f2..6d552b09d4 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -153,7 +153,6 @@ */ #ifdef CONFIG_DRIVER_TI_EMAC #define CONFIG_BOOTP_DEFAULT -#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 #endif
diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 273a15a41a..0dde5d19ca 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -67,7 +67,6 @@ #define CONFIG_KEEP_SERVERADDR #define CONFIG_UDP_CHECKSUM #define CONFIG_TIMESTAMP -#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_BOOTP_SERVERIP
#ifndef SANDBOX_NO_SDL diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 91134a4421..fc5a8c672b 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -166,7 +166,6 @@ */
/* NAND support */ diff --git a/include/configs/socfpga_vining_fpga.h b/include/configs/socfpga_vining_fpga.h index 8b97cd93a7..06976d804c 100644 --- a/include/configs/socfpga_vining_fpga.h +++ b/include/configs/socfpga_vining_fpga.h @@ -18,9 +18,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR
/* Ethernet on SoC (EMAC) */ -#if defined(CONFIG_CMD_NET) -#define CONFIG_BOOTP_SEND_HOSTNAME -#endif
/* Extra Environment */ #define CONFIG_HOSTNAME "socfpga_vining_fpga" diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index f4d73b3069..c78fe6e7d9 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -118,7 +118,6 @@ * ethernet support, EMAC * */ -#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10
/* Defines for SPL */ diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index bba48f3c66..6f8072067b 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -143,7 +143,6 @@ #endif
/* Ethernet */ -#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 #define CONFIG_PHY_ET1011C_TX_CLK_FIX
diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 7ca749a568..44fdc4c300 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -87,7 +87,6 @@ #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE)
/* Since SPL did pll and ddr initialization for us, diff --git a/include/configs/ti_am335x_common.h b/include/configs/ti_am335x_common.h index 4b3981b9b0..c57b20a06a 100644 --- a/include/configs/ti_am335x_common.h +++ b/include/configs/ti_am335x_common.h @@ -27,7 +27,6 @@
#ifndef CONFIG_SPL_BUILD /* Network defines. */ -#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 #endif
diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index fb1dc2dbeb..cb20dc01b7 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -67,7 +67,6 @@
/* Network Configuration */ #define CONFIG_BOOTP_DEFAULT -#define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 32 #define CONFIG_SYS_SGMII_REFCLK_MHZ 312 #define CONFIG_SYS_SGMII_LINERATE_MHZ 1250 diff --git a/net/Kconfig b/net/Kconfig index ac6d0cf8a6..e6c3e09aa7 100644 --- a/net/Kconfig +++ b/net/Kconfig @@ -8,6 +8,16 @@ menuconfig NET
if NET
+config BOOTP_SEND_HOSTNAME + bool "Send hostname to DNS server" + help + Some DHCP servers are capable to do a dynamic update of a + DNS server. To do this, they need the hostname of the DHCP + requester. + If CONFIG_BOOTP_SEND_HOSTNAME is defined, the content + of the "hostname" environment variable is passed as + option 12 to the DHCP server. + config NET_RANDOM_ETHADDR bool "Random ethaddr if unset" help diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 9a7f0fba0c..131678ffb7 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -132,7 +132,6 @@ CONFIG_BOOTP_ID_CACHE_SIZE CONFIG_BOOTP_MAY_FAIL CONFIG_BOOTP_NISDOMAIN CONFIG_BOOTP_RANDOM_DELAY -CONFIG_BOOTP_SEND_HOSTNAME CONFIG_BOOTP_SERVERIP CONFIG_BOOTP_TIMEOFFSET CONFIG_BOOTP_VENDOREX
Adam Ford
