[U-Boot] [PATCH 0/2] Add sdram capacity auto detect for rk3288
The rk3288 spl size is very close to 32KB while the rk3288 bootrom has the limitation of maximum size of SPL is 32KB. After apply this patch, the SPL size will exceed 32KB if we do not enable macro CONFIG_ROCKCHIP_SPL_BACK_TO_BROM.
I think this patch is usful and should be go upstream other than the size issue.
This patch has test with 2GB DDR3 and 2GB/4GB LPDDR3.
Kever Yang (2): rk3288: sdram: auto-detect the capacity dts: rk3288: remove node in dmc which not need anymore
arch/arm/dts/rk3288-evb.dts | 3 - arch/arm/dts/rk3288-fennec.dts | 3 - arch/arm/dts/rk3288-firefly.dts | 2 - arch/arm/dts/rk3288-miniarm.dts | 3 - arch/arm/dts/rk3288-popmetal.dts | 3 - arch/arm/dts/rk3288-rock2-square.dts | 2 - arch/arm/dts/rk3288-veyron.dtsi | 2 - arch/arm/mach-rockchip/rk3288/sdram_rk3288.c | 237 ++++++++++++++++++++++----- 8 files changed, 198 insertions(+), 57 deletions(-)
Add support for rk3288 dram capacity auto detect, support DDR3 and LPDDR3, DDR2 is not supported. The program will automatically detect: - channel number - rank number - column address number - row address number
The dts file do not need to describe those info after apply this patch.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/mach-rockchip/rk3288/sdram_rk3288.c | 237 ++++++++++++++++++++++----- 1 file changed, 198 insertions(+), 39 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3288/sdram_rk3288.c b/arch/arm/mach-rockchip/rk3288/sdram_rk3288.c index cf9ef2e..faabbd4 100644 --- a/arch/arm/mach-rockchip/rk3288/sdram_rk3288.c +++ b/arch/arm/mach-rockchip/rk3288/sdram_rk3288.c @@ -57,6 +57,10 @@ struct rk3288_sdram_params { struct regmap *map; };
+#define TEST_PATTEN 0x5aa5f00f +#define DQS_GATE_TRAINING_ERROR_RANK0 (1 << 4) +#define DQS_GATE_TRAINING_ERROR_RANK1 (2 << 4) + #ifdef CONFIG_SPL_BUILD static void copy_to_reg(u32 *dest, const u32 *src, u32 n) { @@ -214,7 +218,7 @@ static void ddr_set_en_bst_odt(struct rk3288_grf *grf, uint channel, }
static void pctl_cfg(u32 channel, struct rk3288_ddr_pctl *pctl, - const struct rk3288_sdram_params *sdram_params, + struct rk3288_sdram_params *sdram_params, struct rk3288_grf *grf) { unsigned int burstlen; @@ -264,7 +268,7 @@ static void pctl_cfg(u32 channel, struct rk3288_ddr_pctl *pctl, }
static void phy_cfg(const struct chan_info *chan, u32 channel, - const struct rk3288_sdram_params *sdram_params) + struct rk3288_sdram_params *sdram_params) { struct rk3288_ddr_publ *publ = chan->publ; struct rk3288_msch *msch = chan->msch; @@ -446,7 +450,7 @@ static void set_bandwidth_ratio(const struct chan_info *chan, u32 channel, }
static int data_training(const struct chan_info *chan, u32 channel, - const struct rk3288_sdram_params *sdram_params) + struct rk3288_sdram_params *sdram_params) { unsigned int j; int ret = 0; @@ -549,7 +553,7 @@ static void move_to_access_state(const struct chan_info *chan) }
static void dram_cfg_rbc(const struct chan_info *chan, u32 chnum, - const struct rk3288_sdram_params *sdram_params) + struct rk3288_sdram_params *sdram_params) { struct rk3288_ddr_publ *publ = chan->publ;
@@ -563,7 +567,7 @@ static void dram_cfg_rbc(const struct chan_info *chan, u32 chnum, }
static void dram_all_config(const struct dram_info *dram, - const struct rk3288_sdram_params *sdram_params) + struct rk3288_sdram_params *sdram_params) { unsigned int chan; u32 sys_reg = 0; @@ -589,9 +593,173 @@ static void dram_all_config(const struct dram_info *dram, writel(sys_reg, &dram->pmu->sys_reg[2]); rk_clrsetreg(&dram->sgrf->soc_con2, 0x1f, sdram_params->base.stride); } +const int ddrconf_table[] = { + /* col row */ + 0, + ((1 << 4) | 1), + ((2 << 4) | 1), + ((3 << 4) | 1), + ((4 << 4) | 1), + ((1 << 4) | 2), + ((2 << 4) | 2), + ((3 << 4) | 2), + ((1 << 4) | 0), + ((2 << 4) | 0), + ((3 << 4) | 0), + 0, + 0, + 0, + 0, + ((4 << 4) | 2), +}; + +static int sdram_rank_bw_detect(struct dram_info *dram, int channel, + struct rk3288_sdram_params *sdram_params) +{ + int reg; + int need_trainig = 0; + const struct chan_info *chan = &dram->chan[channel]; + struct rk3288_ddr_publ *publ = chan->publ; + + if (-1 == data_training(chan, channel, sdram_params)) { + reg = readl(&publ->datx8[0].dxgsr[0]); + /* Check the result for rank 0 */ + if ((channel == 0) && (reg & DQS_GATE_TRAINING_ERROR_RANK0)) { + debug("data training fail!\n"); + return -EIO; + } else if ((channel == 1) && + (reg & DQS_GATE_TRAINING_ERROR_RANK0)) { + sdram_params->num_channels = 1; + } + + /* Check the result for rank 1 */ + if (reg & DQS_GATE_TRAINING_ERROR_RANK1) { + sdram_params->ch[channel].rank = 1; + clrsetbits_le32(&publ->pgcr, 0xF << 18, + sdram_params->ch[channel].rank << 18); + need_trainig = 1; + } + reg = readl(&publ->datx8[2].dxgsr[0]); + if (reg & (1 << 4)) { + sdram_params->ch[channel].bw = 1; + set_bandwidth_ratio(chan, channel, + sdram_params->ch[channel].bw, + dram->grf); + need_trainig = 1; + } + } + /* Assume the Die bit width are the same with the chip bit width*/ + sdram_params->ch[channel].dbw = sdram_params->ch[channel].bw; + + if (need_trainig && + (-1 == data_training(chan, channel, sdram_params))) { + if (sdram_params->base.dramtype == LPDDR3) { + ddr_phy_ctl_reset(dram->cru, channel, 1); + udelay(10); + ddr_phy_ctl_reset(dram->cru, channel, 0); + udelay(10); + } + debug("2nd data training failed!"); + return -EIO; + } + + return 0; +} + +static void sdram_col_row_detect(struct dram_info *dram, int channel, + struct rk3288_sdram_params *sdram_params) +{ + int row, col; + unsigned int addr; + const struct chan_info *chan = &dram->chan[channel]; + struct rk3288_ddr_pctl *pctl = chan->pctl; + struct rk3288_ddr_publ *publ = chan->publ; + /* Detect col */ + for (col = 11; col >= 9; col--) { + writel(0, CONFIG_SYS_SDRAM_BASE); + addr = CONFIG_SYS_SDRAM_BASE + + (1 << (col + sdram_params->ch[channel].bw - 1)); + writel(TEST_PATTEN, addr); + if ((readl(addr) == TEST_PATTEN) && + (readl(CONFIG_SYS_SDRAM_BASE) == 0)) + break; + } + if (col == 8) + debug("Col detect error\n"); + else + sdram_params->ch[channel].col = col; + + move_to_config_state(publ, pctl); + writel(4, &chan->msch->ddrconf); + move_to_access_state(chan); + /* Detect row*/ + for (row = 16; row >= 12; row--) { + writel(0, CONFIG_SYS_SDRAM_BASE); + addr = CONFIG_SYS_SDRAM_BASE + (1 << (row + 15 - 1)); + writel(TEST_PATTEN, addr); + if ((readl(addr) == TEST_PATTEN) && + (readl(CONFIG_SYS_SDRAM_BASE) == 0)) + break; + } + if (row == 11) + debug("Row detect error\n"); + else + sdram_params->ch[channel].cs0_row = row; + sdram_params->ch[channel].cs1_row = row; + sdram_params->ch[channel].row_3_4 = 0; + debug("chn %d col %d, row %d\n", channel, col, row); +} + +static void sdram_get_niu_config(struct rk3288_sdram_params *sdram_params) +{ + int i, tmp, size; + + tmp = sdram_params->ch[0].col - 9; + tmp -= sdram_params->ch[0].bw >> 1; + tmp |= ((sdram_params->ch[0].cs0_row - 12) << 4); + size = sizeof(ddrconf_table)/sizeof(ddrconf_table[0]); + for (i = 0; i < size; i++) + if (tmp == ddrconf_table[i]) + break; + if (i >= size) + debug("niu config not found\n"); + else + sdram_params->base.ddrconfig = i; +} + +static void sdram_get_stride(struct rk3288_sdram_params *sdram_params) +{ + int stride = -1; + long cap = sdram_params->num_channels * (1u << + (sdram_params->ch[0].cs0_row + + sdram_params->ch[0].col + + (sdram_params->ch[0].rank - 1) + + sdram_params->ch[0].bw + + 3 - 20)); + + switch (cap) { + case 512: + stride = 0; + break; + case 1024: + stride = 5; + break; + case 2048: + stride = 9; + break; + case 4096: + stride = 0xd; + break; + default: + stride = -1; + debug("could not find correct stride, cap error!\n"); + break; + } + sdram_params->base.stride = stride; +}
static int sdram_init(struct dram_info *dram, - const struct rk3288_sdram_params *sdram_params) + struct rk3288_sdram_params *sdram_params) { int channel; int zqcr; @@ -619,12 +787,13 @@ static int sdram_init(struct dram_info *dram, struct rk3288_ddr_pctl *pctl = chan->pctl; struct rk3288_ddr_publ *publ = chan->publ;
+ if (channel) + rk_clrsetreg(&dram->sgrf->soc_con2, 0x1f, 0x17); + else + rk_clrsetreg(&dram->sgrf->soc_con2, 0x1f, 0x1a); phy_pctrl_reset(dram->cru, publ, channel); phy_dll_bypass_set(publ, sdram_params->base.ddr_freq);
- if (channel >= sdram_params->num_channels) - continue; - dfi_cfg(pctl, sdram_params->base.dramtype);
pctl_cfg(channel, pctl, sdram_params, dram->grf); @@ -658,16 +827,20 @@ static int sdram_init(struct dram_info *dram, udelay(1); }
+ /* Using 32bit bus width for detect */ + sdram_params->ch[channel].bw = 2; set_bandwidth_ratio(chan, channel, sdram_params->ch[channel].bw, dram->grf); /* - * set cs + * set cs, using n=3 for detect * CS0, n=1 * CS1, n=2 * CS0 & CS1, n = 3 */ + sdram_params->ch[channel].rank = 2, clrsetbits_le32(&publ->pgcr, 0xF << 18, (sdram_params->ch[channel].rank | 1) << 18); + /* DS=40ohm,ODT=155ohm */ zqcr = 1 << ZDEN_SHIFT | 2 << PU_ONDIE_SHIFT | 2 << PD_ONDIE_SHIFT | 0x19 << PU_OUTPUT_SHIFT | @@ -693,16 +866,8 @@ static int sdram_init(struct dram_info *dram, } }
- if (-1 == data_training(chan, channel, sdram_params)) { - if (sdram_params->base.dramtype == LPDDR3) { - ddr_phy_ctl_reset(dram->cru, channel, 1); - udelay(10); - ddr_phy_ctl_reset(dram->cru, channel, 0); - udelay(10); - } - debug("failed!"); - return -EIO; - } + /* Detect the rank and bit-width with data-training */ + sdram_rank_bw_detect(dram, channel, sdram_params);
if (sdram_params->base.dramtype == LPDDR3) { u32 i; @@ -710,8 +875,18 @@ static int sdram_init(struct dram_info *dram, for (i = 0; i < 17; i++) send_command_op(pctl, 1, MRR_CMD, i, 0); } + writel(15, &chan->msch->ddrconf); move_to_access_state(chan); + /* DDR3 and LPDDR3 are always 8 bank, no need detect */ + sdram_params->ch[channel].bk = 3; + /* Detect Col and Row number*/ + sdram_col_row_detect(dram, channel, sdram_params); } + /* Find NIU DDR configuration */ + sdram_get_niu_config(sdram_params); + /* Find stride setting */ + sdram_get_stride(sdram_params); + dram_all_config(dram, sdram_params); debug("%s done\n", __func__);
@@ -743,7 +918,6 @@ size_t sdram_size_mb(struct rk3288_pmu *pmu) SYS_REG_BW_MASK)); row_3_4 = sys_reg >> SYS_REG_ROW_3_4_SHIFT(ch) & SYS_REG_ROW_3_4_MASK; - chipsize_mb = (1 << (cs0_row + col + bk + bw - 20));
if (rank > 1) @@ -814,21 +988,10 @@ static int rk3288_dmc_ofdata_to_platdata(struct udevice *dev) struct rk3288_sdram_params *params = dev_get_platdata(dev); const void *blob = gd->fdt_blob; int node = dev->of_offset; - int i, ret; + int ret;
- params->num_channels = fdtdec_get_int(blob, node, - "rockchip,num-channels", 1); - for (i = 0; i < params->num_channels; i++) { - ret = fdtdec_get_byte_array(blob, node, - "rockchip,sdram-channel", - (u8 *)¶ms->ch[i], - sizeof(params->ch[i])); - if (ret) { - debug("%s: Cannot read rockchip,sdram-channel\n", - __func__); - return -EINVAL; - } - } + /* Controller support dual-channel, set default channel num to 2 */ + params->num_channels = 2; ret = fdtdec_get_int_array(blob, node, "rockchip,pctl-timing", (u32 *)¶ms->pctl_timing, sizeof(params->pctl_timing) / sizeof(u32)); @@ -871,10 +1034,6 @@ static int conv_of_platdata(struct udevice *dev) struct dtd_rockchip_rk3288_dmc *of_plat = &plat->of_plat; int i, ret;
- for (i = 0; i < 2; i++) { - memcpy(&plat->ch[i], of_plat->rockchip_sdram_channel, - sizeof(plat->ch[i])); - } memcpy(&plat->pctl_timing, of_plat->rockchip_pctl_timing, sizeof(plat->pctl_timing)); memcpy(&plat->phy_timing, of_plat->rockchip_phy_timing,
Since we implement the dram capacity auto detect, we don't need to set the channel number and sdram-channel in dts.
arch/arm/dts/rk3288-evb.dts | 3 --- arch/arm/dts/rk3288-fennec.dts | 3 --- arch/arm/dts/rk3288-firefly.dts | 2 -- arch/arm/dts/rk3288-miniarm.dts | 3 --- arch/arm/dts/rk3288-popmetal.dts | 3 --- arch/arm/dts/rk3288-rock2-square.dts | 2 -- arch/arm/dts/rk3288-veyron.dtsi | 2 -- 7 files changed, 18 deletions(-)
diff --git a/arch/arm/dts/rk3288-evb.dts b/arch/arm/dts/rk3288-evb.dts index 3e1ee58..3f03e13 100644 --- a/arch/arm/dts/rk3288-evb.dts +++ b/arch/arm/dts/rk3288-evb.dts @@ -17,7 +17,6 @@ };
&dmc { - rockchip,num-channels = <2>; rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 @@ -25,8 +24,6 @@ 0x8 0x1f4>; rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 0x0 0xc3 0x6 0x2>; - /* Add a dummy value to cause of-platdata think this is bytes */ - rockchip,sdram-channel = /bits/ 8 <0x2 0xa 0x3 0x2 0x2 0x0 0xe 0xe 0xff>; rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 0>; };
diff --git a/arch/arm/dts/rk3288-fennec.dts b/arch/arm/dts/rk3288-fennec.dts index 36e9f3d..66ddf8d 100644 --- a/arch/arm/dts/rk3288-fennec.dts +++ b/arch/arm/dts/rk3288-fennec.dts @@ -17,7 +17,6 @@ };
diff --git a/arch/arm/dts/rk3288-firefly.dts b/arch/arm/dts/rk3288-firefly.dts index 3176d50..97568a3 100644 --- a/arch/arm/dts/rk3288-firefly.dts +++ b/arch/arm/dts/rk3288-firefly.dts @@ -22,7 +22,6 @@ };
&dmc { - rockchip,num-channels = <2>; rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 @@ -31,7 +30,6 @@ rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 0xa60 0x40 0x10 0x0>; /* Add a dummy value to cause of-platdata think this is bytes */ - rockchip,sdram-channel = /bits/ 8 <0x1 0xa 0x3 0x2 0x1 0x0 0xf 0xf 0xff>; rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; };
diff --git a/arch/arm/dts/rk3288-miniarm.dts b/arch/arm/dts/rk3288-miniarm.dts index c741082..9083028 100644 --- a/arch/arm/dts/rk3288-miniarm.dts +++ b/arch/arm/dts/rk3288-miniarm.dts @@ -17,7 +17,6 @@ };
&dmc { - rockchip,num-channels = <2>; rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 @@ -25,8 +24,6 @@ 0x5 0x0>; rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 0xa60 0x40 0x10 0x0>; - /* Add a dummy value to cause of-platdata think this is bytes */ - rockchip,sdram-channel = /bits/ 8 <0x1 0xa 0x3 0x2 0x1 0x0 0xf 0xf 0xff>; rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; };
diff --git a/arch/arm/dts/rk3288-popmetal.dts b/arch/arm/dts/rk3288-popmetal.dts index 3f61a61..284d5ed 100644 --- a/arch/arm/dts/rk3288-popmetal.dts +++ b/arch/arm/dts/rk3288-popmetal.dts @@ -17,7 +17,6 @@ };
diff --git a/arch/arm/dts/rk3288-rock2-square.dts b/arch/arm/dts/rk3288-rock2-square.dts index 2c30355..11c580a 100644 --- a/arch/arm/dts/rk3288-rock2-square.dts +++ b/arch/arm/dts/rk3288-rock2-square.dts @@ -184,7 +184,6 @@ };
&dmc { - rockchip,num-channels = <2>; rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 @@ -192,7 +191,6 @@ 0x5 0x0>; rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 0xa60 0x40 0x10 0x0>; - rockchip,sdram-channel = /bits/ 8 <0x1 0xa 0x3 0x2 0x1 0x0 0xf 0xf 0xff>; rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; };
diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi index d9d5187..2ffe39c 100644 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ b/arch/arm/dts/rk3288-veyron.dtsi @@ -245,7 +245,6 @@ 533000 1150000 666000 1200000 >; - rockchip,num-channels = <2>; rockchip,pctl-timing = <0x29a 0xc8 0x1f4 0x42 0x4e 0x4 0xea 0xa 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 @@ -253,7 +252,6 @@ 0x5 0x0>; rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 0xa60 0x40 0x10 0x0>; - rockchip,sdram-channel = /bits/ 8 <0x1 0xa 0x3 0x2 0x1 0x0 0xf 0xf 0xff>; rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; };
Thanks for the patch!
Unfortunately, fails to build the firefly-rk3288 target, using arm-linux-gnueabihf-gcc (Debian 6.1.1-9) 6.1.1 20160705, applied to u-boot master 01c5075506afcb7a74e0db8600af8979f45881b5:
CC spl/arch/arm/mach-rockchip/rk3288/sdram_rk3288.o arch/arm/mach-rockchip/rk3288/sdram_rk3288.c: In function 'conv_of_platdata': arch/arm/mach-rockchip/rk3288/sdram_rk3288.c:1042:30: error: 'struct dtd_rockchip_rk3288_dmc' has no member named 'rockchip_num_channels'; did you mean 'rockchip_noc'? plat->num_channels = of_plat->rockchip_num_channels; ^~ arch/arm/mach-rockchip/rk3288/sdram_rk3288.c:1035:6: warning: unused variable 'i' [-Wunused-variable] int i, ret; ^ scripts/Makefile.build:280: recipe for target 'spl/arch/arm/mach-rockchip/rk3288/sdram_rk3288.o' failed make[3]: *** [spl/arch/arm/mach-rockchip/rk3288/sdram_rk3288.o] Error 1 scripts/Makefile.build:425: recipe for target 'spl/arch/arm/mach-rockchip/rk3288' failed make[2]: *** [spl/arch/arm/mach-rockchip/rk3288] Error 2 scripts/Makefile.spl:292: recipe for target 'spl/arch/arm/mach-rockchip' failed make[1]: *** [spl/arch/arm/mach-rockchip] Error 2 Makefile:1334: recipe for target 'spl/u-boot-spl' failed make: *** [spl/u-boot-spl] Error 2
live well, vagrant
hi Vagrant,
- plat->num_channels = of_plat->rockchip_num_channels; + plat->num_channels = 2;
firefly-rk3288 deploy CONFIG_OF_PLATDATA, driver read platform data from include/generated/dt-structs.h which is generated according to dts file. Please try above change.
@Kever,
Please fix below.
arch/arm/mach-rockchip/rk3288/sdram_rk3288.c: In function ‘conv_of_platdata’: arch/arm/mach-rockchip/rk3288/sdram_rk3288.c:1035:6: warning: unused variable ‘i’ [-Wunused-variable]
live well, vagrant
With CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y, it fails to boot with no output on the console.
With this change, it builds, but it hangs at boot:
U-Boot SPL 2016.09-rc2+dfsg1-2~20160910~6 (Sep 10 2016 - 18:51:28) Trying to boot from MMC1
U-Boot 2016.09-rc2+dfsg1-2~20160910~6 (Sep 10 2016 - 18:51:28 +0000)
Model: Firefly-RK3288 DRAM:
This is on a firefly with 2GB of ram. I also have one with 4GB of ram, hence my interest in this patch series!
live well, vagrant
hi Vagrant,
Could you help to add DEBUG macro in common.h like: #indef CONFIG_SPL_BUILD #define DEBUG #endif
So that we can figure out where it is.
live well, vagrant
Hi Kever,
With regards to the SPL size issue, I believe that the CONFIG_ROCKCHIP_SPL_BACK_TO_BROM option should work with all of the rk3288 boards. So if your patch causes unbootable SPL's because they're too big, then you should probably enable the BROM macro (and disable OF_PLATDATA).
Firefly uses a different method to shrink the SPL which causes a bunch of changes throughout the codebase. This patch would need to be applied to the OF_PLATDATA sections for firefly to work.
Vagrant,
An alternative for you might be to disable OF_PLATDATA for firefly and enable BACK_TO_BROM. You may not be getting any output because you didn't modify your burning process. See the README.rockchip section on CONFIG_ROCKCHIP_SPL_BACK_TO_BROM for details, but you have to dd your images slightly differently with this macro enabled.
Also, you might get more info from Ziyuan's DEBUG advice.
Sandy Patterson
On Sun, Sep 11, 2016 at 10:01 PM, Ziyuan Xu xzy.xu@rock-chips.com wrote:
hi Vagrant,
live well, vagrant
Hi Sandy Patterson,
On 09/15/2016 08:00 PM, Sandy Patterson wrote:
Hi Kever,
Thanks for your comment, I will update a V2 patch after I make sure it works with other board, but I don't have a firefly on my hand currently.
I think you mean my patch need to work with: - BROM enabled and OF_PLATDATA disabled - BROM disabled and OF_PLATDATA enabled right?
Vagrant,
Hi Vagrant,
Once you see the SPL output message, that means the DRAM init is OK, to double check if the DRAM init correct, you can add log for return value of sdram_size_mb() after apply my patch.
Thanks, - Kever
Sandy Patterson
On Sun, Sep 11, 2016 at 10:01 PM, Ziyuan Xu <xzy.xu@rock-chips.com mailto:xzy.xu@rock-chips.com> wrote:
hi Vagrant, On 2016年09月11日 03:01, Vagrant Cascadian wrote: On 2016-09-10, Ziyuan Xu wrote: On 2016年09月09日 03:28, Vagrant Cascadian wrote: On 2016-09-08, Kever Yang wrote: The rk3288 spl size is very close to 32KB while the rk3288 bootrom has the limitation of maximum size of SPL is 32KB. After apply this patch, the SPL size will exceed 32KB if we do not enable macro CONFIG_ROCKCHIP_SPL_BACK_TO_BROM. With CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y, it fails to boot with no output on the console. This patch has test with 2GB DDR3 and 2GB/4GB LPDDR3. Thanks for the patch! Unfortunately, fails to build the firefly-rk3288 target, using arm-linux-gnueabihf-gcc (Debian 6.1.1-9) 6.1.1 20160705, applied to u-boot master 01c5075506afcb7a74e0db8600af8979f45881b5: CC spl/arch/arm/mach-rockchip/rk3288/sdram_rk3288.o arch/arm/mach-rockchip/rk3288/sdram_rk3288.c: In function 'conv_of_platdata': arch/arm/mach-rockchip/rk3288/sdram_rk3288.c:1042:30: error: 'struct dtd_rockchip_rk3288_dmc' has no member named 'rockchip_num_channels'; did you mean 'rockchip_noc'? plat->num_channels = of_plat->rockchip_num_channels; - plat->num_channels = of_plat->rockchip_num_channels; + plat->num_channels = 2; firefly-rk3288 deploy CONFIG_OF_PLATDATA, driver read platform data from include/generated/dt-structs.h which is generated according to dts file. Please try above change. With this change, it builds, but it hangs at boot: U-Boot SPL 2016.09-rc2+dfsg1-2~20160910~6 (Sep 10 2016 - 18:51:28) Trying to boot from MMC1 U-Boot 2016.09-rc2+dfsg1-2~20160910~6 (Sep 10 2016 - 18:51:28 +0000) Model: Firefly-RK3288 DRAM: Could you help to add DEBUG macro in common.h like: #indef CONFIG_SPL_BUILD #define DEBUG #endif So that we can figure out where it is. This is on a firefly with 2GB of ram. I also have one with 4GB of ram, hence my interest in this patch series! live well, vagrant
I wasn't able to successfully build with OF_PLATDATA disabled; sounds like there are more patches needed for firefly for that to work.
Thanks! Unfortunately, even after using the burning process for CONFIG_ROCKCHIP_SPL_BACK_TO_BROM described in README.rockchip.
The patches (on top of what was submitted in this series) I've applied to v2016.09 are:
Index: u-boot/include/common.h =================================================================== --- u-boot.orig/include/common.h +++ u-boot/include/common.h @@ -95,6 +95,10 @@ typedef volatile unsigned char vu_char; #define CONFIG_SYS_SUPPORT_64BIT_DATA #endif
+#ifndef CONFIG_SPL_BUILD +#define DEBUG +#endif + #ifdef DEBUG #define _DEBUG 1 #else
Index: u-boot/arch/arm/mach-rockchip/rk3288/sdram_rk3288.c =================================================================== --- u-boot.orig/arch/arm/mach-rockchip/rk3288/sdram_rk3288.c +++ u-boot/arch/arm/mach-rockchip/rk3288/sdram_rk3288.c @@ -1039,7 +1039,7 @@ static int conv_of_platdata(struct udevi memcpy(&plat->phy_timing, of_plat->rockchip_phy_timing, sizeof(plat->phy_timing)); memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base)); - plat->num_channels = of_plat->rockchip_num_channels; + plat->num_channels = 2; ret = regmap_init_mem_platdata(dev, of_plat->reg, ARRAY_SIZE(of_plat->reg) / 2, &plat->map);
Index: u-boot/configs/firefly-rk3288_defconfig =================================================================== --- u-boot.orig/configs/firefly-rk3288_defconfig +++ u-boot/configs/firefly-rk3288_defconfig @@ -70,3 +70,4 @@ CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y # CONFIG_SPL_OF_LIBFDT is not set +CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y
I think I'll wait for an updated series to do more tests, so I'm not testing patches on patches on patches. Also reduces the liklihood of me misinterpreting what people are suggesting to try.
live well, vagrant
Hi Kever and Vagrant,
I tested this patch on my rock2 board against 2016.09. (I didn't have my board with me over the weekend)
1) It seems the BACK_TO_BROM feature is broken. It doesn't boot using the 2016.09. I'm afraid I don't have the time to track it down. 2) It seems the SPL is still small enough to test this feature. (vagrant you can forget about the back to brom feature unless you need more SPL space).
3) I get the same behavior as Vagrant on the rock2 board. I'm including DEBUG output in case that helps Kever. I tried to trace it, but it seems a larger undertaking than I can manage right now. (vagrant, you can add DEBUG #define's into the file include/configs/firefly-rk3288.h to get the output below.. my guess is it's similar.)
This trace is almost exactly the same between enabling the SDRAM detection and not. I marked the point where it halts. The fdt is a slightly different size, but that is expected.
Sandy
initcall: 0010af55 U-Boot code: 00100000 -> 0014F8C0 BSS: -> 0018D1B8 initcall: 0010add1 initcall: 0010b359 Model: Radxa Rock 2 Square initcall: 0010af95 DRAM: initcall: 00100d19 malloc_simple: size=3c, ptr=7d8, limit=2000: fe79c uclass_find_device_by_seq: 0 -1 uclass_find_device_by_seq: 0 0 - -1 -1 - not found fdtdec_get_int_array: interrupts get_prop_check_min_len: interrupts malloc_simple: size=4, ptr=7dc, limit=2000: fe7d8 uclass_find_device_by_seq: 0 -1 uclass_find_device_by_seq: 0 0 - -1 1 - -1 -1 - -1 0 - found uclass_find_device_by_seq: 0 1 - -1 1 - found uclass_find_device_by_seq: 0 2 - -1 1 - -1 -1 - -1 0 - -1 -1 - not found fdtdec_get_int_array: interrupts get_prop_check_min_len: interrupts malloc_simple: size=14, ptr=7f0, limit=2000: fe7dc malloc_simple: size=4, ptr=7f4, limit=2000: fe7f0 uclass_find_device_by_seq: 0 -1 uclass_find_device_by_seq: 0 0 - -1 1 - -1 -1 - -1 0 - found uclass_find_device_by_seq: 0 1 - -1 1 - found uclass_find_device_by_seq: 0 2 - -1 1 - -1 -1 - -1 0 - -1 2 - found uclass_find_device_by_seq: 0 3 - -1 1 - -1 -1 - -1 0 - -1 2 - not found fdtdec_get_int_array: interrupts get_prop_check_min_len: interrupts malloc_simple: size=14, ptr=808, limit=2000: fe7f4 malloc_simple: size=c, ptr=814, limit=2000: fe808 uclass_find_device_by_seq: 0 -1 uclass_find_device_by_seq: 0 0 - -1 -1 - not found fdtdec_get_int_array: interrupts get_prop_check_min_len: interrupts OF: ** translation for device clock-controller@ff760000 ** OF: bus is default (na=1, ns=1) on OF: translating address: 000076ff OF: reached root node clk_request(dev=000fe474, clk=000fe7bc) SDRAM base=0, size=80000000 initcall: 0010b129 Monitor len: 0008D1B8 Ram size: 80000000 Ram top: 80000000 initcall: 0010adf1 initcall: 0010af0d TLB table from 7fff0000 to 7fff4000 initcall: 0010af75 video_reserve: Reserving 4f0000 bytes at 7fb00000 for video device 'vop@ff940000' Video frame buffers from 7fb00000 to 7fff0000 initcall: 0010ae05 initcall: 0010aecd Reserving 564k for U-Boot at: 7fa72000 initcall: 0010aea5 Reserving 32776k for malloc() at: 7da70000 initcall: 0010b059 Reserving 80 Bytes for Board Info at: 7da6ffb0 initcall: 0010ae09 initcall: 0010ae7d Reserving 200 Bytes for Global Data at: 7da6fee8 initcall: 0010ae2d Reserving 38464 Bytes for FDT at: 7da668a8 initcall: 0010ae11 initcall: 0010b18d initcall: 0010b113 initcall: 0010b099
RAM Configuration: ====== SDRAM DETECTION FEATURE HALTS HERE ======== Bank #0: 0 2 GiB
DRAM: 2 GiB initcall: 0010ae19 New Stack Pointer is: 7da66880 initcall: 0010b02d initcall: 0010afd5 Relocation Offset is: 7f972000 Relocating to 7fa72000, new gd at 7da6fee8, sp at 7da66880 initcall: 7fa7d1cd initcall: 7fa7d1d1 initcall: 0010b32d (relocated to 7fa7d32d) dram_bank_mmu_setup: bank: 0 initcall: 0010b305 (relocated to 7fa7d305) efi_runtime_relocate: Relocating to offset=7fa72000
Hi Sandy,
Thanks for your test and for your log, my source code do have one bug and I have fix and upload the V2 patch set.
- It seems the BACK_TO_BROM feature is broken. It doesn't boot using
It works fine on my evb, do you flash the image correctly? it's different with the way you don't use BACK_TO_BROM.
Regards, - Kever
- It seems the SPL is still small enough to test this feature.
- I get the same behavior as Vagrant on the rock2 board. I'm
Sandy
- -1 -1
- not found
- -1 1
- -1 -1
- -1 0
- found
- -1 1
- found
- -1 1
- -1 -1
- -1 0
- -1 -1
- not found
- -1 1
- -1 -1
- -1 0
- found
- -1 1
- found
- -1 1
- -1 -1
- -1 0
- -1 2
- found
- -1 1
- -1 -1
- -1 0
- -1 2
- not found
- -1 -1
- not found
- It seems the BACK_TO_BROM feature is broken. It doesn't boot using the
Well, I tested again on the latest master branch and its working now. I probably had something screwed up. I did notice that the BACK_TO_BROM was moved to Kconfig.
Kever Yang
Sandy Patterson
Vagrant Cascadian
Ziyuan Xu
