[U-Boot-Users] U-Boot/Kermit Problem
I am facing a problem in loading a binary file from minicom. Whenver I try to load, it is going in an infinite loop.
=> loadb 100000 ## Ready for binary (kermit) download to 0x00100000 at 9600 bps...
I configured kermit as told in the DULG/SystemSetup Manual.... Only change I made is
set speed 9600 instead of 115200
I am getting stuck here. After going through the u-boot source code .... The calling sequence is ....
-load_serial_bin -k_recv
Inside k_recv the code where I stucked up here is ...
----------------------------ACTUAL CODE----------------------------------- /* get a packet */ /* wait for the starting character or ^C */ for (;;) { switch (serial_getc ()) { case START_CHAR: /* start packet */ goto START; case ETX_CHAR: /* ^C waiting for packet*/ return (0); default: ; } } ----------------------------ACTUAL CODE UP TO HERE------------------------
I think it continiously in the for loop. When I press control-C then it will come comeout saying ....
## Total Size = 0x00000000 = 0 Bytes ## Start Addr = 0x00100000
Can anyabody help me why it is happening ? Any help will be appreciated.
-regards, -Ashish
########################################################################### Ashish R Dhawane Research Engineer W-CDMA Group (3G RAN)
Contacts: --------- Tel(O) :+91-80-2282168 (Direct Line) Tel(O/Lab) :+91-80-2263399 X 329 Fax(O) :+91-80-2282168 Mobile :98455 36814 E-Mail(s) :ashishdhawane@yahoo.com, ashish@cyberspace.org
Surface Address (O): Surface Address (R): -------------------- -------------------- Centre for Development of Telematics, #50, Ground Floor, 12th Cross, 71/1, Sneha Complex, Ayyappa Block, Manorayan Palya, Millers Road, Sultan Palya Main Road, Bangalore-560052, RT Nagar Post,Bangalore-560032, Karnataka, India. Karnataka, India. ###########################################################################
Hi Ashish, Check whether your serial_getc() function is returning 0. Your serial_get() function should not return 0 if LSR_DR is 0. I hope this will solve your problem.
Regards Ganapathi C
----- Original Message ----- From: "Ashish R Dhawane" ashish@cdotb.ernet.in To: u-boot-users@lists.sourceforge.net Sent: Thursday, April 29, 2004 12:28 PM Subject: [U-Boot-Users] U-Boot/Kermit Problem
-regards, -Ashish
Contacts:
This SF.Net email is sponsored by: Oracle 10g Get certified on the hottest thing ever to hit the market... Oracle 10g. Take an Oracle 10g class now, and we'll give you the exam FREE. http://ads.osdn.com/?ad_id=3149&alloc_id=8166&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
In message Pine.OSF.4.21.0404291125360.22727-100000@ws9.cdotb.ernet.in you wrote:
The DULG also warns you NOT to use minicom - for good reasons.
If you use kermit for file download anyway, just use it as terminal program, too.
Ashish R Dhawane
ganapathi
