[PATCH v3 1/3] Move bootorder and bootoption apis to lib
Rename and move bootorder and bootoption apis from cmd to lib for re-use between eficonfig and bootmgr
Signed-off-by: Raymond Mao raymond.mao@linaro.org --- Changes in v2 - Ignore EFI_NOT_FOUND returned from efi_bootmgr_update_media_device_boot_option which means no boot options scanned. Changes in v3 - Split the patch into moving and renaming functions and individual patches for each changed functionality
cmd/bootmenu.c | 2 +- cmd/eficonfig.c | 408 +---------------------------------- include/efi_config.h | 5 - include/efi_loader.h | 11 + lib/efi_loader/efi_bootmgr.c | 380 ++++++++++++++++++++++++++++++++ lib/efi_loader/efi_helper.c | 25 +++ 6 files changed, 423 insertions(+), 408 deletions(-)
diff --git a/cmd/bootmenu.c b/cmd/bootmenu.c index 6baeedc69f..01daddca7b 100644 --- a/cmd/bootmenu.c +++ b/cmd/bootmenu.c @@ -351,7 +351,7 @@ static struct bootmenu_data *bootmenu_create(int delay) * UEFI specification requires booting from removal media using * a architecture-specific default image name such as BOOTAA64.EFI. */ - efi_ret = eficonfig_generate_media_device_boot_option(); + efi_ret = efi_bootmgr_update_media_device_boot_option(); if (efi_ret != EFI_SUCCESS && efi_ret != EFI_NOT_FOUND) goto cleanup;
diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c index 720f52b48b..82a80306f4 100644 --- a/cmd/eficonfig.c +++ b/cmd/eficonfig.c @@ -1134,43 +1134,6 @@ out: return ret; }
-/** - * eficonfig_get_unused_bootoption() - get unused "Boot####" index - * - * @buf: pointer to the buffer to store boot option variable name - * @buf_size: buffer size - * @index: pointer to store the index in the BootOrder variable - * Return: status code - */ -efi_status_t eficonfig_get_unused_bootoption(u16 *buf, efi_uintn_t buf_size, - unsigned int *index) -{ - u32 i; - efi_status_t ret; - efi_uintn_t size; - - if (buf_size < u16_strsize(u"Boot####")) - return EFI_BUFFER_TOO_SMALL; - - for (i = 0; i <= 0xFFFF; i++) { - size = 0; - efi_create_indexed_name(buf, buf_size, "Boot", i); - ret = efi_get_variable_int(buf, &efi_global_variable_guid, - NULL, &size, NULL, NULL); - if (ret == EFI_BUFFER_TOO_SMALL) - continue; - else - break; - } - - if (i > 0xFFFF) - return EFI_OUT_OF_RESOURCES; - - *index = i; - - return EFI_SUCCESS; -} - /** * eficonfig_set_boot_option() - set boot option * @@ -1208,46 +1171,6 @@ static efi_status_t eficonfig_set_boot_option(u16 *varname, struct efi_device_pa return ret; }
-/** - * eficonfig_append_bootorder() - append new boot option in BootOrder variable - * - * @index: "Boot####" index to append to BootOrder variable - * Return: status code - */ -efi_status_t eficonfig_append_bootorder(u16 index) -{ - u16 *bootorder; - efi_status_t ret; - u16 *new_bootorder = NULL; - efi_uintn_t last, size, new_size; - - /* append new boot option */ - bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); - last = size / sizeof(u16); - new_size = size + sizeof(u16); - new_bootorder = calloc(1, new_size); - if (!new_bootorder) { - ret = EFI_OUT_OF_RESOURCES; - goto out; - } - memcpy(new_bootorder, bootorder, size); - new_bootorder[last] = index; - - ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, - EFI_VARIABLE_NON_VOLATILE | - EFI_VARIABLE_BOOTSERVICE_ACCESS | - EFI_VARIABLE_RUNTIME_ACCESS, - new_size, new_bootorder, false); - if (ret != EFI_SUCCESS) - goto out; - -out: - free(bootorder); - free(new_bootorder); - - return ret; -} - /** * create_boot_option_entry() - create boot option entry * @@ -1619,7 +1542,7 @@ static efi_status_t eficonfig_process_add_boot_option(void *data) if (!bo) return EFI_OUT_OF_RESOURCES;
- ret = eficonfig_get_unused_bootoption(varname, sizeof(varname), &bo->boot_index); + ret = efi_bootmgr_get_unused_bootoption(varname, sizeof(varname), &bo->boot_index); if (ret != EFI_SUCCESS) return ret;
@@ -1627,7 +1550,7 @@ static efi_status_t eficonfig_process_add_boot_option(void *data) if (ret != EFI_SUCCESS) goto out;
- ret = eficonfig_append_bootorder((u16)bo->boot_index); + ret = efi_bootmgr_append_bootorder((u16)bo->boot_index); if (ret != EFI_SUCCESS) goto out;
@@ -1656,31 +1579,6 @@ static efi_status_t eficonfig_process_boot_selected(void *data) return EFI_SUCCESS; }
-/** - * search_bootorder() - search the boot option index in BootOrder - * - * @bootorder: pointer to the BootOrder variable - * @num: number of BootOrder entry - * @target: target boot option index to search - * @index: pointer to store the index of BootOrder variable - * Return: true if exists, false otherwise - */ -static bool search_bootorder(u16 *bootorder, efi_uintn_t num, u32 target, u32 *index) -{ - u32 i; - - for (i = 0; i < num; i++) { - if (target == bootorder[i]) { - if (index) - *index = i; - - return true; - } - } - - return false; -} - /** * eficonfig_add_boot_selection_entry() - add boot option menu entry * @@ -1805,7 +1703,7 @@ static efi_status_t eficonfig_show_boot_selection(unsigned int *selected)
if (efi_varname_is_load_option(var_name16, &index)) { /* If the index is included in the BootOrder, skip it */ - if (search_bootorder(bootorder, num, index, NULL)) + if (efi_search_bootorder(bootorder, num, index, NULL)) continue;
ret = eficonfig_add_boot_selection_entry(efi_menu, index, selected); @@ -2202,7 +2100,7 @@ static efi_status_t eficonfig_create_change_boot_order_entry(struct efimenu *efi
ret = eficonfig_add_change_boot_order_entry(efi_menu, index, false); @@ -2304,50 +2202,6 @@ out: return ret; }
-/** - * delete_boot_option() - delete selected boot option - * - * @boot_index: boot option index to delete - * Return: status code - */ -static efi_status_t delete_boot_option(u16 boot_index) -{ - u16 *bootorder; - u16 varname[9]; - efi_status_t ret; - unsigned int index; - efi_uintn_t num, size; - - efi_create_indexed_name(varname, sizeof(varname), - "Boot", boot_index); - ret = efi_set_variable_int(varname, &efi_global_variable_guid, - 0, 0, NULL, false); - if (ret != EFI_SUCCESS) { - log_err("delete boot option(%ls) failed\n", varname); - return ret; - } - - /* update BootOrder if necessary */ - bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); - if (!bootorder) - return EFI_SUCCESS; - - num = size / sizeof(u16); - if (!search_bootorder(bootorder, num, boot_index, &index)) - return EFI_SUCCESS; - - memmove(&bootorder[index], &bootorder[index + 1], - (num - index - 1) * sizeof(u16)); - size -= sizeof(u16); - ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, - EFI_VARIABLE_NON_VOLATILE | - EFI_VARIABLE_BOOTSERVICE_ACCESS | - EFI_VARIABLE_RUNTIME_ACCESS, - size, bootorder, false); - - return ret; -} - /** * eficonfig_process_delete_boot_option() - handler to delete boot option * @@ -2362,7 +2216,7 @@ static efi_status_t eficonfig_process_delete_boot_option(void *data) while (1) { ret = eficonfig_show_boot_selection(&selected); if (ret == EFI_SUCCESS) - ret = delete_boot_option(selected); + ret = efi_bootmgr_delete_boot_option(selected);
if (ret != EFI_SUCCESS) break; @@ -2374,256 +2228,6 @@ static efi_status_t eficonfig_process_delete_boot_option(void *data) return ret; }
-/** - * eficonfig_enumerate_boot_option() - enumerate the possible bootable media - * - * @opt: pointer to the media boot option structure - * @volume_handles: pointer to the efi handles - * @count: number of efi handle - * Return: status code - */ -efi_status_t eficonfig_enumerate_boot_option(struct eficonfig_media_boot_option *opt, - efi_handle_t *volume_handles, efi_status_t count) -{ - u32 i; - struct efi_handler *handler; - efi_status_t ret = EFI_SUCCESS; - - for (i = 0; i < count; i++) { - u16 *p; - u16 dev_name[BOOTMENU_DEVICE_NAME_MAX]; - char *optional_data; - struct efi_load_option lo; - char buf[BOOTMENU_DEVICE_NAME_MAX]; - struct efi_device_path *device_path; - - ret = efi_search_protocol(volume_handles[i], &efi_guid_device_path, &handler); - if (ret != EFI_SUCCESS) - continue; - ret = efi_protocol_open(handler, (void **)&device_path, - efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); - if (ret != EFI_SUCCESS) - continue; - - ret = efi_disk_get_device_name(volume_handles[i], buf, BOOTMENU_DEVICE_NAME_MAX); - if (ret != EFI_SUCCESS) - continue; - - p = dev_name; - utf8_utf16_strncpy(&p, buf, strlen(buf)); - - lo.label = dev_name; - lo.attributes = LOAD_OPTION_ACTIVE; - lo.file_path = device_path; - lo.file_path_length = efi_dp_size(device_path) + sizeof(END); - /* - * Set the dedicated guid to optional_data, it is used to identify - * the boot option that automatically generated by the bootmenu. - * efi_serialize_load_option() expects optional_data is null-terminated - * utf8 string, so set the "1234567" string to allocate enough space - * to store guid, instead of realloc the load_option. - */ - lo.optional_data = "1234567"; - opt[i].size = efi_serialize_load_option(&lo, (u8 **)&opt[i].lo); - if (!opt[i].size) { - ret = EFI_OUT_OF_RESOURCES; - goto out; - } - /* set the guid */ - optional_data = (char *)opt[i].lo + (opt[i].size - u16_strsize(u"1234567")); - memcpy(optional_data, &efi_guid_bootmenu_auto_generated, sizeof(efi_guid_t)); - } - -out: - return ret; -} - -/** - * eficonfig_delete_invalid_boot_option() - delete non-existing boot option - * - * @opt: pointer to the media boot option structure - * @count: number of media boot option structure - * Return: status code - */ -efi_status_t eficonfig_delete_invalid_boot_option(struct eficonfig_media_boot_option *opt, - efi_status_t count) -{ - efi_uintn_t size; - void *load_option; - u32 i, list_size = 0; - struct efi_load_option lo; - u16 *var_name16 = NULL; - u16 varname[] = u"Boot####"; - efi_status_t ret = EFI_SUCCESS; - u16 *delete_index_list = NULL, *p; - efi_uintn_t buf_size; - - buf_size = 128; - var_name16 = malloc(buf_size); - if (!var_name16) - return EFI_OUT_OF_RESOURCES; - - var_name16[0] = 0; - for (;;) { - int index; - efi_guid_t guid; - efi_uintn_t tmp; - - ret = efi_next_variable_name(&buf_size, &var_name16, &guid); - if (ret == EFI_NOT_FOUND) { - /* - * EFI_NOT_FOUND indicates we retrieved all EFI variables. - * This should be treated as success. - */ - ret = EFI_SUCCESS; - break; - } - if (ret != EFI_SUCCESS) - goto out; - - if (!efi_varname_is_load_option(var_name16, &index)) - continue; - - efi_create_indexed_name(varname, sizeof(varname), "Boot", index); - load_option = efi_get_var(varname, &efi_global_variable_guid, &size); - if (!load_option) - continue; - - tmp = size; - ret = efi_deserialize_load_option(&lo, load_option, &size); - if (ret != EFI_SUCCESS) - goto next; - - if (size >= sizeof(efi_guid_bootmenu_auto_generated) && - !guidcmp(lo.optional_data, &efi_guid_bootmenu_auto_generated)) { - for (i = 0; i < count; i++) { - if (opt[i].size == tmp && - memcmp(opt[i].lo, load_option, tmp) == 0) { - opt[i].exist = true; - break; - } - } - - /* - * The entire list of variables must be retrieved by - * efi_get_next_variable_name_int() before deleting the invalid - * boot option, just save the index here. - */ - if (i == count) { - p = realloc(delete_index_list, sizeof(u32) * - (list_size + 1)); - if (!p) { - ret = EFI_OUT_OF_RESOURCES; - goto out; - } - delete_index_list = p; - delete_index_list[list_size++] = index; - } - } -next: - free(load_option); - } - - /* delete all invalid boot options */ - for (i = 0; i < list_size; i++) { - ret = delete_boot_option(delete_index_list[i]); - if (ret != EFI_SUCCESS) - goto out; - } - -out: - free(var_name16); - free(delete_index_list); - - return ret; -} - -/** - * eficonfig_generate_media_device_boot_option() - generate the media device boot option - * - * This function enumerates all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL - * and generate the bootmenu entries. - * This function also provide the BOOT#### variable maintenance for - * the media device entries. - * - Automatically create the BOOT#### variable for the newly detected device, - * this BOOT#### variable is distinguished by the special GUID - * stored in the EFI_LOAD_OPTION.optional_data - * - If the device is not attached to the system, the associated BOOT#### variable - * is automatically deleted. - * - * Return: status code - */ -efi_status_t eficonfig_generate_media_device_boot_option(void) -{ - u32 i; - efi_status_t ret; - efi_uintn_t count; - efi_handle_t *volume_handles = NULL; - struct eficonfig_media_boot_option *opt = NULL; - - ret = efi_locate_handle_buffer_int(BY_PROTOCOL, &efi_simple_file_system_protocol_guid, - NULL, &count, (efi_handle_t **)&volume_handles); - if (ret != EFI_SUCCESS) - return ret; - - opt = calloc(count, sizeof(struct eficonfig_media_boot_option)); - if (!opt) - goto out; - - /* enumerate all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL */ - ret = eficonfig_enumerate_boot_option(opt, volume_handles, count); - if (ret != EFI_SUCCESS) - goto out; - - /* - * System hardware configuration may vary depending on the user setup. - * The boot option is automatically added by the bootmenu. - * If the device is not attached to the system, the boot option needs - * to be deleted. - */ - ret = eficonfig_delete_invalid_boot_option(opt, count); - if (ret != EFI_SUCCESS) - goto out; - - /* add non-existent boot option */ - for (i = 0; i < count; i++) { - u32 boot_index; - u16 var_name[9]; - - if (!opt[i].exist) { - ret = eficonfig_get_unused_bootoption(var_name, sizeof(var_name), - &boot_index); - if (ret != EFI_SUCCESS) - goto out; - - ret = efi_set_variable_int(var_name, &efi_global_variable_guid, - EFI_VARIABLE_NON_VOLATILE | - EFI_VARIABLE_BOOTSERVICE_ACCESS | - EFI_VARIABLE_RUNTIME_ACCESS, - opt[i].size, opt[i].lo, false); - if (ret != EFI_SUCCESS) - goto out; - - ret = eficonfig_append_bootorder(boot_index); - if (ret != EFI_SUCCESS) { - efi_set_variable_int(var_name, &efi_global_variable_guid, - 0, 0, NULL, false); - goto out; - } - } - } - -out: - if (opt) { - for (i = 0; i < count; i++) - free(opt[i].lo); - } - free(opt); - efi_free_pool(volume_handles); - - return ret; -} - /** * eficonfig_init() - do required initialization for eficonfig command * @@ -2709,7 +2313,7 @@ static int do_eficonfig(struct cmd_tbl *cmdtp, int flag, int argc, char *const a if (ret != EFI_SUCCESS) return CMD_RET_FAILURE;
- ret = eficonfig_generate_media_device_boot_option(); + ret = efi_bootmgr_update_media_device_boot_option(); if (ret != EFI_SUCCESS && ret != EFI_NOT_FOUND) return ret;
diff --git a/include/efi_config.h b/include/efi_config.h index 01ce9b2b06..d7c1601137 100644 --- a/include/efi_config.h +++ b/include/efi_config.h @@ -105,11 +105,6 @@ efi_status_t eficonfig_process_common(struct efimenu *efi_menu, void (*item_data_print)(void *), char *(*item_choice)(void *)); efi_status_t eficonfig_process_select_file(void *data); -efi_status_t eficonfig_get_unused_bootoption(u16 *buf, - efi_uintn_t buf_size, u32 *index); -efi_status_t eficonfig_append_bootorder(u16 index); -efi_status_t eficonfig_generate_media_device_boot_option(void); - efi_status_t eficonfig_append_menu_entry(struct efimenu *efi_menu, char *title, eficonfig_entry_func func, void *data); diff --git a/include/efi_loader.h b/include/efi_loader.h index 1542b4b625..31ca1f5d1d 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -516,6 +516,17 @@ extern struct list_head efi_register_notify_events; int efi_init_early(void); /* Initialize efi execution environment */ efi_status_t efi_init_obj_list(void); +/* Append new boot option in BootOrder variable */ +efi_status_t efi_bootmgr_append_bootorder(u16 index); +/* Get unused "Boot####" index */ +efi_status_t efi_bootmgr_get_unused_bootoption(u16 *buf, + efi_uintn_t buf_size, u32 *index); +/* Generate the media device boot option */ +efi_status_t efi_bootmgr_update_media_device_boot_option(void); +/* Delete selected boot option */ +efi_status_t efi_bootmgr_delete_boot_option(u16 boot_index); +/* search the boot option index in BootOrder */ +bool efi_search_bootorder(u16 *bootorder, efi_uintn_t num, u32 target, u32 *index); /* Set up console modes */ void efi_setup_console_size(void); /* Install device tree */ diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 4b24b41047..c329428973 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -347,3 +347,383 @@ efi_status_t efi_bootmgr_load(efi_handle_t *handle, void **load_options) error: return ret; } + +/** + * efi_bootmgr_enumerate_boot_option() - enumerate the possible bootable media + * + * @opt: pointer to the media boot option structure + * @volume_handles: pointer to the efi handles + * @count: number of efi handle + * Return: status code + */ +static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boot_option *opt, + efi_handle_t *volume_handles, + efi_status_t count) +{ + u32 i; + struct efi_handler *handler; + efi_status_t ret = EFI_SUCCESS; + + for (i = 0; i < count; i++) { + u16 *p; + u16 dev_name[BOOTMENU_DEVICE_NAME_MAX]; + char *optional_data; + struct efi_load_option lo; + char buf[BOOTMENU_DEVICE_NAME_MAX]; + struct efi_device_path *device_path; + + ret = efi_search_protocol(volume_handles[i], &efi_guid_device_path, &handler); + if (ret != EFI_SUCCESS) + continue; + ret = efi_protocol_open(handler, (void **)&device_path, + efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + continue; + + ret = efi_disk_get_device_name(volume_handles[i], buf, BOOTMENU_DEVICE_NAME_MAX); + if (ret != EFI_SUCCESS) + continue; + + p = dev_name; + utf8_utf16_strncpy(&p, buf, strlen(buf)); + + lo.label = dev_name; + lo.attributes = LOAD_OPTION_ACTIVE; + lo.file_path = device_path; + lo.file_path_length = efi_dp_size(device_path) + sizeof(END); + /* + * Set the dedicated guid to optional_data, it is used to identify + * the boot option that automatically generated by the bootmenu. + * efi_serialize_load_option() expects optional_data is null-terminated + * utf8 string, so set the "1234567" string to allocate enough space + * to store guid, instead of realloc the load_option. + */ + lo.optional_data = "1234567"; + opt[i].size = efi_serialize_load_option(&lo, (u8 **)&opt[i].lo); + if (!opt[i].size) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + /* set the guid */ + optional_data = (char *)opt[i].lo + (opt[i].size - u16_strsize(u"1234567")); + memcpy(optional_data, &efi_guid_bootmenu_auto_generated, sizeof(efi_guid_t)); + } + +out: + return ret; +} + +/** + * efi_bootmgr_delete_invalid_boot_option() - delete non-existing boot option + * + * @opt: pointer to the media boot option structure + * @count: number of media boot option structure + * Return: status code + */ +static efi_status_t efi_bootmgr_delete_invalid_boot_option(struct eficonfig_media_boot_option *opt, + efi_status_t count) +{ + efi_uintn_t size; + void *load_option; + u32 i, list_size = 0; + struct efi_load_option lo; + u16 *var_name16 = NULL; + u16 varname[] = u"Boot####"; + efi_status_t ret = EFI_SUCCESS; + u16 *delete_index_list = NULL, *p; + efi_uintn_t buf_size; + + buf_size = 128; + var_name16 = malloc(buf_size); + if (!var_name16) + return EFI_OUT_OF_RESOURCES; + + var_name16[0] = 0; + for (;;) { + int index; + efi_guid_t guid; + efi_uintn_t tmp; + + ret = efi_next_variable_name(&buf_size, &var_name16, &guid); + if (ret == EFI_NOT_FOUND) { + log_debug("last efi var\n"); + /* + * EFI_NOT_FOUND indicates we retrieved all EFI variables. + * This should be treated as success. + */ + ret = EFI_SUCCESS; + break; + } + + if (ret != EFI_SUCCESS) + goto out; + + if (!efi_varname_is_load_option(var_name16, &index)) + continue; + + efi_create_indexed_name(varname, sizeof(varname), "Boot", index); + load_option = efi_get_var(varname, &efi_global_variable_guid, &size); + if (!load_option) + continue; + + tmp = size; + ret = efi_deserialize_load_option(&lo, load_option, &size); + if (ret != EFI_SUCCESS) + goto next; + + if (size >= sizeof(efi_guid_bootmenu_auto_generated) && + !guidcmp(lo.optional_data, &efi_guid_bootmenu_auto_generated)) { + for (i = 0; i < count; i++) { + if (opt[i].size == tmp && + memcmp(opt[i].lo, load_option, tmp) == 0) { + opt[i].exist = true; + break; + } + } + + /* + * The entire list of variables must be retrieved by + * efi_get_next_variable_name_int() before deleting the invalid + * boot option, just save the index here. + */ + if (i == count) { + log_debug("found index %d can be deleted\n", index); + p = realloc(delete_index_list, sizeof(u32) * + (list_size + 1)); + if (!p) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + delete_index_list = p; + delete_index_list[list_size++] = index; + } + } +next: + free(load_option); + } + + /* delete all invalid boot options */ + for (i = 0; i < list_size; i++) { + log_debug("deleting index %d\n", delete_index_list[i]); + ret = efi_bootmgr_delete_boot_option(delete_index_list[i]); + if (ret != EFI_SUCCESS) + goto out; + } + +out: + free(var_name16); + free(delete_index_list); + + return ret; +} + +/** + * efi_bootmgr_get_unused_bootoption() - get unused "Boot####" index + * + * @buf: pointer to the buffer to store boot option variable name + * @buf_size: buffer size + * @index: pointer to store the index in the BootOrder variable + * Return: status code + */ +efi_status_t efi_bootmgr_get_unused_bootoption(u16 *buf, efi_uintn_t buf_size, + unsigned int *index) +{ + u32 i; + efi_status_t ret; + efi_uintn_t size; + + if (buf_size < u16_strsize(u"Boot####")) + return EFI_BUFFER_TOO_SMALL; + + for (i = 0; i <= 0xFFFF; i++) { + size = 0; + efi_create_indexed_name(buf, buf_size, "Boot", i); + ret = efi_get_variable_int(buf, &efi_global_variable_guid, + NULL, &size, NULL, NULL); + if (ret == EFI_BUFFER_TOO_SMALL) + continue; + else + break; + } + + if (i > 0xFFFF) + return EFI_OUT_OF_RESOURCES; + + *index = i; + + return EFI_SUCCESS; +} + +/** + * efi_bootmgr_append_bootorder() - append new boot option in BootOrder variable + * + * @index: "Boot####" index to append to BootOrder variable + * Return: status code + */ +efi_status_t efi_bootmgr_append_bootorder(u16 index) +{ + u16 *bootorder; + efi_status_t ret; + u16 *new_bootorder = NULL; + efi_uintn_t last, size, new_size; + + /* append new boot option */ + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + last = size / sizeof(u16); + new_size = size + sizeof(u16); + new_bootorder = calloc(1, new_size); + if (!new_bootorder) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + memcpy(new_bootorder, bootorder, size); + new_bootorder[last] = index; + + ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + new_size, new_bootorder, false); + if (ret != EFI_SUCCESS) + goto out; + +out: + free(bootorder); + free(new_bootorder); + + return ret; +} + +/** + * efi_bootmgr_delete_boot_option() - delete selected boot option + * + * @boot_index: boot option index to delete + * Return: status code + */ +efi_status_t efi_bootmgr_delete_boot_option(u16 boot_index) +{ + u16 *bootorder; + u16 varname[9]; + efi_status_t ret; + unsigned int index; + efi_uintn_t num, size; + + efi_create_indexed_name(varname, sizeof(varname), + "Boot", boot_index); + ret = efi_set_variable_int(varname, &efi_global_variable_guid, + 0, 0, NULL, false); + if (ret != EFI_SUCCESS) { + log_err("delete boot option(%ls) failed\n", varname); + return ret; + } + + /* update BootOrder if necessary */ + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + if (!bootorder) + return EFI_SUCCESS; + + num = size / sizeof(u16); + if (!efi_search_bootorder(bootorder, num, boot_index, &index)) + return EFI_SUCCESS; + + memmove(&bootorder[index], &bootorder[index + 1], + (num - index - 1) * sizeof(u16)); + size -= sizeof(u16); + ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + size, bootorder, false); + + return ret; +} + +/** + * efi_bootmgr_update_media_device_boot_option() - generate the media device boot option + * + * This function enumerates all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL + * and generate the bootmenu entries. + * This function also provide the BOOT#### variable maintenance for + * the media device entries. + * - Automatically create the BOOT#### variable for the newly detected device, + * this BOOT#### variable is distinguished by the special GUID + * stored in the EFI_LOAD_OPTION.optional_data + * - If the device is not attached to the system, the associated BOOT#### variable + * is automatically deleted. + * + * Return: status code + */ +efi_status_t efi_bootmgr_update_media_device_boot_option(void) +{ + u32 i; + efi_status_t ret; + efi_uintn_t count; + efi_handle_t *volume_handles = NULL; + struct eficonfig_media_boot_option *opt = NULL; + + ret = efi_locate_handle_buffer_int(BY_PROTOCOL, + &efi_simple_file_system_protocol_guid, + NULL, &count, + (efi_handle_t **)&volume_handles); + if (ret != EFI_SUCCESS) + return ret; + + opt = calloc(count, sizeof(struct eficonfig_media_boot_option)); + if (!opt) + goto out; + + /* enumerate all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL */ + ret = efi_bootmgr_enumerate_boot_option(opt, volume_handles, count); + if (ret != EFI_SUCCESS) + goto out; + + /* + * System hardware configuration may vary depending on the user setup. + * The boot option is automatically added by the bootmenu. + * If the device is not attached to the system, the boot option needs + * to be deleted. + */ + ret = efi_bootmgr_delete_invalid_boot_option(opt, count); + if (ret != EFI_SUCCESS) + goto out; + + /* add non-existent boot option */ + for (i = 0; i < count; i++) { + u32 boot_index; + u16 var_name[9]; + + if (!opt[i].exist) { + ret = efi_bootmgr_get_unused_bootoption(var_name, sizeof(var_name), + &boot_index); + if (ret != EFI_SUCCESS) + goto out; + + ret = efi_set_variable_int(var_name, &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + opt[i].size, opt[i].lo, false); + if (ret != EFI_SUCCESS) + goto out; + + ret = efi_bootmgr_append_bootorder(boot_index); + if (ret != EFI_SUCCESS) { + efi_set_variable_int(var_name, &efi_global_variable_guid, + 0, 0, NULL, false); + goto out; + } + } + } + +out: + if (opt) { + for (i = 0; i < count; i++) { + if (opt[i].lo) + free(opt[i].lo); + } + free(opt); + } + efi_free_pool(volume_handles); + + return ret; +} diff --git a/lib/efi_loader/efi_helper.c b/lib/efi_loader/efi_helper.c index 1f4ab2b419..cdfd16ea77 100644 --- a/lib/efi_loader/efi_helper.c +++ b/lib/efi_loader/efi_helper.c @@ -257,3 +257,28 @@ efi_status_t efi_next_variable_name(efi_uintn_t *size, u16 **buf, efi_guid_t *gu
return ret; } + +/** + * efi_search_bootorder() - search the boot option index in BootOrder + * + * @bootorder: pointer to the BootOrder variable + * @num: number of BootOrder entry + * @target: target boot option index to search + * @index: pointer to store the index of BootOrder variable + * Return: true if exists, false otherwise + */ +bool efi_search_bootorder(u16 *bootorder, efi_uintn_t num, u32 target, u32 *index) +{ + u32 i; + + for (i = 0; i < num; i++) { + if (target == bootorder[i]) { + if (index) + *index = i; + + return true; + } + } + + return false; +}
Changes for complying to EFI spec §3.5.1.1 'Removable Media Boot Behavior'. Boot variables can be automatically generated during a removable media is probed. At the same time, unused boot variables will be detected and removed.
lib/efi_loader/efi_disk.c | 7 +++++++ lib/efi_loader/efi_variable.c | 10 +++++++++- lib/efi_loader/efi_variable_tee.c | 5 +++++ 3 files changed, 21 insertions(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index d2256713a8..ca5f07f2ec 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -687,6 +687,13 @@ int efi_disk_probe(void *ctx, struct event *event) return -1; }
+ /* only do the boot option management when UEFI sub-system is initialized */ + if (efi_obj_list_initialized == EFI_SUCCESS) { + ret = efi_bootmgr_update_media_device_boot_option(); + if (ret != EFI_SUCCESS && ret != EFI_NOT_FOUND) + return -1; + } + return 0; }
diff --git a/lib/efi_loader/efi_variable.c b/lib/efi_loader/efi_variable.c index be95ed44e6..fe71144358 100644 --- a/lib/efi_loader/efi_variable.c +++ b/lib/efi_loader/efi_variable.c @@ -476,6 +476,14 @@ efi_status_t efi_init_variables(void) log_err("Invalid EFI variable seed\n"); }
+ ret = efi_init_secure_state(); + if (ret != EFI_SUCCESS) + return ret;
- return efi_init_secure_state(); + /* update boot option management after variable service initialized */ + ret = efi_bootmgr_update_media_device_boot_option(); + if (ret != EFI_SUCCESS && ret != EFI_NOT_FOUND) + return ret; + + return EFI_SUCCESS; } diff --git a/lib/efi_loader/efi_variable_tee.c b/lib/efi_loader/efi_variable_tee.c index dfef18435d..2995d4a583 100644 --- a/lib/efi_loader/efi_variable_tee.c +++ b/lib/efi_loader/efi_variable_tee.c @@ -748,5 +748,10 @@ efi_status_t efi_init_variables(void) if (ret != EFI_SUCCESS) return ret;
+ /* update boot option management after variable service initialized */ + ret = efi_bootmgr_update_media_device_boot_option(); + if (ret != EFI_SUCCESS && ret != EFI_NOT_FOUND) + return ret; + return EFI_SUCCESS; }
Changes in v2
Changes in v3
- /* only do the boot option management when UEFI sub-system is initialized */
- if (efi_obj_list_initialized == EFI_SUCCESS) {
return -1;
- ret = efi_init_secure_state();
return ret;
- /* update boot option management after variable service initialized */
- ret = efi_bootmgr_update_media_device_boot_option();
- if (ret != EFI_SUCCESS && ret != EFI_NOT_FOUND)
return ret;
return ret;
You don't need this if, just return ret
2.25.1
Regards /Ilias
Hi Ilias,
On Tue, 16 May 2023 at 01:59, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Changes in v2
Changes in v3
initialized */
return -1;
return ret;
initialized */
return ret;
return EFI_SUCCESS;
initialized */
return ret;
We have to differentiate EFI_NOT_FOUND here for no removable medias are detected, otherwise efi_init_obj_list() will return failure if the return code of efi_init_variables() is not EFI_SUCCESS.
return EFI_SUCCESS;
2.25.1
Regards /Ilias
On Tue, May 16, 2023 at 10:17:14AM -0400, Raymond Mao wrote:
Hi Ilias,
Changes in v2
Changes in v3
initialized */
return -1;
return ret;
initialized */
return ret;
return EFI_SUCCESS;
initialized */
return ret;
Ah fair enough. This seems fine then, please resend the series with the changes in patch #3
Thanks /Ilias
return EFI_SUCCESS;
2.25.1
Regards /Ilias
The boot variables automatically generated for removable medias should be with short form of device path without device nodes. This is a requirement for the case that a removable media is plugged into a different port but is still able to work with the existing boot variables.
cmd/bootmenu.c | 2 +- cmd/eficonfig.c | 2 +- include/efi_loader.h | 2 +- lib/efi_loader/efi_bootmgr.c | 16 +++++++++++++--- lib/efi_loader/efi_disk.c | 2 +- lib/efi_loader/efi_variable.c | 2 +- lib/efi_loader/efi_variable_tee.c | 2 +- 7 files changed, 19 insertions(+), 9 deletions(-)
diff --git a/cmd/bootmenu.c b/cmd/bootmenu.c index 01daddca7b..058b47c69a 100644 --- a/cmd/bootmenu.c +++ b/cmd/bootmenu.c @@ -351,7 +351,7 @@ static struct bootmenu_data *bootmenu_create(int delay) * UEFI specification requires booting from removal media using * a architecture-specific default image name such as BOOTAA64.EFI. */ - efi_ret = efi_bootmgr_update_media_device_boot_option(); + efi_ret = efi_bootmgr_update_media_device_boot_option(true); if (efi_ret != EFI_SUCCESS && efi_ret != EFI_NOT_FOUND) goto cleanup;
diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c index 82a80306f4..38371bfea6 100644 --- a/cmd/eficonfig.c +++ b/cmd/eficonfig.c @@ -2313,7 +2313,7 @@ static int do_eficonfig(struct cmd_tbl *cmdtp, int flag, int argc, char *const a if (ret != EFI_SUCCESS) return CMD_RET_FAILURE;
- ret = efi_bootmgr_update_media_device_boot_option(); + ret = efi_bootmgr_update_media_device_boot_option(true); if (ret != EFI_SUCCESS && ret != EFI_NOT_FOUND) return ret;
diff --git a/include/efi_loader.h b/include/efi_loader.h index 31ca1f5d1d..0a69f08d6c 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -522,7 +522,7 @@ efi_status_t efi_bootmgr_append_bootorder(u16 index); efi_status_t efi_bootmgr_get_unused_bootoption(u16 *buf, efi_uintn_t buf_size, u32 *index); /* Generate the media device boot option */ -efi_status_t efi_bootmgr_update_media_device_boot_option(void); +efi_status_t efi_bootmgr_update_media_device_boot_option(bool short_path); /* Delete selected boot option */ efi_status_t efi_bootmgr_delete_boot_option(u16 boot_index); /* search the boot option index in BootOrder */ diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index c329428973..c4bc8b354f 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -354,11 +354,13 @@ error: * @opt: pointer to the media boot option structure * @volume_handles: pointer to the efi handles * @count: number of efi handle + * @short_path: use short form device path for matching * Return: status code */ static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boot_option *opt, efi_handle_t *volume_handles, - efi_status_t count) + efi_status_t count, + bool short_path) { u32 i; struct efi_handler *handler; @@ -387,6 +389,13 @@ static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boo p = dev_name; utf8_utf16_strncpy(&p, buf, strlen(buf));
+ /* use short form device path */ + if (short_path) { + device_path = efi_dp_shorten(device_path); + if (!device_path) + continue; + } + lo.label = dev_name; lo.attributes = LOAD_OPTION_ACTIVE; lo.file_path = device_path; @@ -651,9 +660,10 @@ efi_status_t efi_bootmgr_delete_boot_option(u16 boot_index) * - If the device is not attached to the system, the associated BOOT#### variable * is automatically deleted. * + * @short_path: use short form device path for matching * Return: status code */ -efi_status_t efi_bootmgr_update_media_device_boot_option(void) +efi_status_t efi_bootmgr_update_media_device_boot_option(bool short_path) { u32 i; efi_status_t ret; @@ -673,7 +683,7 @@ efi_status_t efi_bootmgr_update_media_device_boot_option(void) goto out;
/* enumerate all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL */ - ret = efi_bootmgr_enumerate_boot_option(opt, volume_handles, count); + ret = efi_bootmgr_enumerate_boot_option(opt, volume_handles, count, short_path); if (ret != EFI_SUCCESS) goto out;
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index ca5f07f2ec..7effffa8d5 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -689,7 +689,7 @@ int efi_disk_probe(void *ctx, struct event *event)
/* only do the boot option management when UEFI sub-system is initialized */ if (efi_obj_list_initialized == EFI_SUCCESS) { - ret = efi_bootmgr_update_media_device_boot_option(); + ret = efi_bootmgr_update_media_device_boot_option(true); if (ret != EFI_SUCCESS && ret != EFI_NOT_FOUND) return -1; } diff --git a/lib/efi_loader/efi_variable.c b/lib/efi_loader/efi_variable.c index fe71144358..be3f40333d 100644 --- a/lib/efi_loader/efi_variable.c +++ b/lib/efi_loader/efi_variable.c @@ -481,7 +481,7 @@ efi_status_t efi_init_variables(void) return ret;
/* update boot option management after variable service initialized */ - ret = efi_bootmgr_update_media_device_boot_option(); + ret = efi_bootmgr_update_media_device_boot_option(true); if (ret != EFI_SUCCESS && ret != EFI_NOT_FOUND) return ret;
diff --git a/lib/efi_loader/efi_variable_tee.c b/lib/efi_loader/efi_variable_tee.c index 2995d4a583..481c4985ab 100644 --- a/lib/efi_loader/efi_variable_tee.c +++ b/lib/efi_loader/efi_variable_tee.c @@ -749,7 +749,7 @@ efi_status_t efi_init_variables(void) return ret;
Hi Raymond,
Changes in v2
Changes in v3
- @count: number of efi handle
- @short_path: use short form device path for matching
- Return: status code
efi_status_t count)
efi_status_t count,
bool short_path)
Are there cases where the normal device path is used? If not we can get rid of the bool option entirely
if (short_path) {
if (!device_path)
continue;
- lo.label = dev_name; lo.attributes = LOAD_OPTION_ACTIVE; lo.file_path = device_path;
Thanks /Ilias
Hi Ilias,
On Tue, 16 May 2023 at 01:57, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Raymond,
Changes in v2
Changes in v3
efi_handle_t
*volume_handles,
efi_status_t count)
efi_status_t count,
bool short_path)
[RM] At the moment no. I can revise the patch to remove the bool option if we don't want to reserve the ability to support normal device paths for the future.
if (short_path) {
if (!device_path)
continue;
Thanks /Ilias
Hi Raymond,
Heinrichm you had some concerns on the previous version of this patchset wrt to the current code. Do you think the rework should take place here? Or are you ok in cleaning it up in a follow up series?
Changes in v2
Changes in v3
if (efi_ret != EFI_SUCCESS && efi_ret != EFI_NOT_FOUND) goto cleanup;efi_ret = efi_bootmgr_update_media_device_boot_option();
- eficonfig_get_unused_bootoption() - get unused "Boot####" index
- @buf: pointer to the buffer to store boot option variable name
- @buf_size: buffer size
- @index: pointer to store the index in the BootOrder variable
- u32 i;
- efi_status_t ret;
- efi_uintn_t size;
size = 0;
continue;
else
break;
- if (i > 0xFFFF)
- *index = i;
- eficonfig_set_boot_option() - set boot option
- eficonfig_append_bootorder() - append new boot option in BootOrder variable
- @index: "Boot####" index to append to BootOrder variable
- u16 *bootorder;
- efi_status_t ret;
goto out;
goto out;
-out:
- free(bootorder);
- return ret;
- create_boot_option_entry() - create boot option entry
- ret = efi_bootmgr_get_unused_bootoption(varname, sizeof(varname), &bo->boot_index); if (ret != EFI_SUCCESS) return ret;
- ret = efi_bootmgr_append_bootorder((u16)bo->boot_index); if (ret != EFI_SUCCESS) goto out;
- search_bootorder() - search the boot option index in BootOrder
- @bootorder: pointer to the BootOrder variable
- @num: number of BootOrder entry
- @target: target boot option index to search
- @index: pointer to store the index of BootOrder variable
- Return: true if exists, false otherwise
- u32 i;
if (index)
*index = i;
return true;
- return false;
- eficonfig_add_boot_selection_entry() - add boot option menu entry
if (efi_search_bootorder(bootorder, num, index, NULL)) continue; ret = eficonfig_add_boot_selection_entry(efi_menu, index, selected);
if (efi_search_bootorder(bootorder, num, index, NULL)) continue; ret = eficonfig_add_change_boot_order_entry(efi_menu, index, false);
- delete_boot_option() - delete selected boot option
- @boot_index: boot option index to delete
- u16 *bootorder;
- u16 varname[9];
- efi_status_t ret;
0, 0, NULL, false);
return ret;
- if (!bootorder)
return EFI_SUCCESS;
return EFI_SUCCESS;
- return ret;
- eficonfig_process_delete_boot_option() - handler to delete boot option
- eficonfig_enumerate_boot_option() - enumerate the possible bootable media
- @opt: pointer to the media boot option structure
- @volume_handles: pointer to the efi handles
- u32 i;
u16 *p;
continue;
continue;
continue;
p = dev_name;
if (!opt[i].size) {
goto out;
/* set the guid */
-out:
- return ret;
- eficonfig_delete_invalid_boot_option() - delete non-existing boot option
- @count: number of media boot option structure
efi_status_t count)
- efi_uintn_t size;
- buf_size = 128;
- if (!var_name16)
- for (;;) {
int index;
efi_guid_t guid;
efi_uintn_t tmp;
ret = EFI_SUCCESS;
break;
goto out;
continue;
if (!load_option)
continue;
tmp = size;
goto next;
break;
if (i == count) {
(list_size + 1));
if (!p) {
goto out;
-next:
free(load_option);
goto out;
-out:
- free(var_name16);
- return ret;
- eficonfig_generate_media_device_boot_option() - generate the media device boot option
- This function enumerates all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL
- and generate the bootmenu entries.
- This function also provide the BOOT#### variable maintenance for
- the media device entries.
- u32 i;
- efi_status_t ret;
return ret;
- if (!opt)
goto out;
goto out;
* to be deleted.
goto out;
u32 boot_index;
u16 var_name[9];
&boot_index);
goto out;
goto out;
0, 0, NULL, false);
goto out;
-out:
- if (opt) {
free(opt[i].lo);
- free(opt);
- return ret;
- eficonfig_init() - do required initialization for eficonfig command
- ret = efi_bootmgr_update_media_device_boot_option(); if (ret != EFI_SUCCESS && ret != EFI_NOT_FOUND) return ret;
- efi_bootmgr_enumerate_boot_option() - enumerate the possible bootable media
efi_status_t count)
- u32 i;
u16 *p;
continue;
continue;
continue;
p = dev_name;
if (!opt[i].size) {
goto out;
/* set the guid */
+out:
- return ret;
- efi_bootmgr_delete_invalid_boot_option() - delete non-existing boot option
efi_status_t count)
- efi_uintn_t size;
- buf_size = 128;
- if (!var_name16)
- for (;;) {
int index;
efi_guid_t guid;
efi_uintn_t tmp;
ret = EFI_SUCCESS;
break;
goto out;
continue;
if (!load_option)
continue;
tmp = size;
goto next;
break;
if (i == count) {
(list_size + 1));
if (!p) {
goto out;
+next:
free(load_option);
goto out;
+out:
- free(var_name16);
- return ret;
- efi_bootmgr_get_unused_bootoption() - get unused "Boot####" index
- u32 i;
- efi_status_t ret;
- efi_uintn_t size;
size = 0;
continue;
else
break;
- if (i > 0xFFFF)
- *index = i;
- efi_bootmgr_append_bootorder() - append new boot option in BootOrder variable
- u16 *bootorder;
- efi_status_t ret;
goto out;
goto out;
+out:
- free(bootorder);
- return ret;
- efi_bootmgr_delete_boot_option() - delete selected boot option
- u16 *bootorder;
- u16 varname[9];
- efi_status_t ret;
0, 0, NULL, false);
return ret;
- if (!bootorder)
return EFI_SUCCESS;
- if (!efi_search_bootorder(bootorder, num, boot_index, &index))
return EFI_SUCCESS;
- return ret;
- efi_bootmgr_update_media_device_boot_option() - generate the media device boot option
- u32 i;
- efi_status_t ret;
NULL, &count,
return ret;
- if (!opt)
goto out;
goto out;
* to be deleted.
- ret = efi_bootmgr_delete_invalid_boot_option(opt, count);
goto out;
u32 boot_index;
u16 var_name[9];
&boot_index);
goto out;
goto out;
0, 0, NULL, false);
goto out;
+out:
- if (opt) {
if (opt[i].lo)
free(opt[i].lo);
free(opt);
- return ret;
return ret; }
- efi_search_bootorder() - search the boot option index in BootOrder
- u32 i;
if (index)
*index = i;
return true;
- return false;
2.25.1
Hi Ilias,
I think we can address Heinrich's comments in a follow up patch set. The concerns are more related to refactoring on the logic of existing functions and less to the functionality we want to enable with these patches.
Thanks. Regards, Raymond
On Tue, 16 May 2023 at 01:58, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Raymond,
Changes in v2
Changes in v3
delay)
using
BOOTAA64.EFI.
buf_size,
u32 i;
efi_status_t ret;
efi_uintn_t size;
size = 0;
continue;
else
break;
if (i > 0xFFFF)
*index = i;
return EFI_SUCCESS;
return ret;
variable
u16 *bootorder;
efi_status_t ret;
&size);
goto out;
goto out;
-out:
free(bootorder);
return ret;
&bo->boot_index);
&bo->boot_index);
return EFI_SUCCESS;
target, u32 *index)
u32 i;
if (index)
*index = i;
return true;
return false;
it */
NULL))
index, selected);
it */
NULL))
continue; ret =
u16 *bootorder;
u16 varname[9];
efi_status_t ret;
unsigned int index;
0, 0, NULL, false);
return ret;
&size);
if (!bootorder)
return EFI_SUCCESS;
return EFI_SUCCESS;
return ret;
option
ret = efi_bootmgr_delete_boot_option(selected); if (ret != EFI_SUCCESS) break;
return ret;
media
efi_status_t count)
u32 i;
u16 *p;
continue;
efi_root, NULL,
continue;
continue;
p = dev_name;
sizeof(END);
identify
bootmenu.
null-terminated
enough space
**)&opt[i].lo);
if (!opt[i].size) {
goto out;
/* set the guid */
-out:
return ret;
option
efi_status_t count)
efi_uintn_t size;
void *load_option;
buf_size = 128;
if (!var_name16)
var_name16[0] = 0;
for (;;) {
int index;
efi_guid_t guid;
efi_uintn_t tmp;
&guid);
variables.
ret = EFI_SUCCESS;
break;
goto out;
continue;
index);
if (!load_option)
continue;
tmp = size;
goto next;
break;
by
if (i == count) {
(list_size + 1));
if (!p) {
goto out;
-next:
free(load_option);
goto out;
-out:
free(var_name16);
return ret;
device boot option
detected device,
BOOT#### variable
u32 i;
efi_status_t ret;
efi_uintn_t count;
return ret;
if (!opt)
goto out;
goto out;
setup.
needs
* to be deleted.
goto out;
u32 boot_index;
u16 var_name[9];
sizeof(var_name),
&boot_index);
goto out;
false);
goto out;
0, 0, NULL, false);
goto out;
-out:
if (opt) {
free(opt[i].lo);
free(opt);
return ret;
efimenu *efi_menu,
*index);
func,
void *data);
*index);
u32 *index);
bootable media
efi_handle_t
*volume_handles,
efi_status_t count)
u32 i;
u16 *p;
continue;
efi_root, NULL,
continue;
continue;
p = dev_name;
sizeof(END);
identify
bootmenu.
null-terminated
enough space
**)&opt[i].lo);
if (!opt[i].size) {
goto out;
/* set the guid */
+out:
return ret;
option
efi_status_t
count)
efi_uintn_t size;
void *load_option;
buf_size = 128;
if (!var_name16)
var_name16[0] = 0;
for (;;) {
int index;
efi_guid_t guid;
efi_uintn_t tmp;
&guid);
variables.
ret = EFI_SUCCESS;
break;
goto out;
continue;
index);
if (!load_option)
continue;
tmp = size;
goto next;
break;
by
if (i == count) {
deleted\n", index);
(list_size + 1));
if (!p) {
goto out;
+next:
free(load_option);
goto out;
+out:
free(var_name16);
return ret;
buf_size,
u32 i;
efi_status_t ret;
efi_uintn_t size;
size = 0;
continue;
else
break;
if (i > 0xFFFF)
*index = i;
return EFI_SUCCESS;
variable
u16 *bootorder;
efi_status_t ret;
&size);
goto out;
goto out;
+out:
free(bootorder);
return ret;
u16 *bootorder;
u16 varname[9];
efi_status_t ret;
unsigned int index;
0, 0, NULL, false);
return ret;
&size);
if (!bootorder)
return EFI_SUCCESS;
return EFI_SUCCESS;
return ret;
device boot option
detected device,
BOOT#### variable
u32 i;
efi_status_t ret;
efi_uintn_t count;
NULL, &count,
(efi_handle_t
return ret;
if (!opt)
goto out;
count);
goto out;
setup.
needs
* to be deleted.
goto out;
u32 boot_index;
u16 var_name[9];
sizeof(var_name),
&boot_index);
goto out;
false);
goto out;
0, 0, NULL, false);
goto out;
+out:
if (opt) {
if (opt[i].lo)
free(opt[i].lo);
free(opt);
return ret;
return ret;
u32 *index)
u32 i;
if (index)
*index = i;
return true;
return false;
2.25.1
Ilias Apalodimas
Raymond Mao
