[PATCH] lib: optee: migration optee_copy_fdt_nodes for OF_LIVE support
The optee_copy_fdt_nodes is only used to copy op-tee nodes of U-Boot device tree (from gd->fdt_blob when OF_LIVE is not activated) to external device tree but it is not compatible with OF_LIVE.
This patch migrates all used function fdt_ functions to read node on old_blob to ofnode functions, compatible with OF_LIVE and remove this parameter "old_blob".
The generated "device tree" is checked on stm32mp platform with OF_LIVE activated.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
common/image-fdt.c | 2 +- include/tee/optee.h | 4 ++-- lib/optee/optee.c | 45 ++++++++++++++++++--------------------------- 3 files changed, 21 insertions(+), 30 deletions(-)
diff --git a/common/image-fdt.c b/common/image-fdt.c index 707b44a69d..bf5fbbf6e9 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -561,7 +561,7 @@ int image_setup_libfdt(bootm_headers_t *images, void *blob, goto err; }
- fdt_ret = optee_copy_fdt_nodes(gd->fdt_blob, blob); + fdt_ret = optee_copy_fdt_nodes(blob); if (fdt_ret) { printf("ERROR: transfer of optee nodes to new fdt failed: %s\n", fdt_strerror(fdt_ret)); diff --git a/include/tee/optee.h b/include/tee/optee.h index affa937da0..ebdfe5e98d 100644 --- a/include/tee/optee.h +++ b/include/tee/optee.h @@ -71,9 +71,9 @@ static inline int optee_verify_bootm_image(unsigned long image_addr, #endif
#if defined(CONFIG_OPTEE) && defined(CONFIG_OF_LIBFDT) -int optee_copy_fdt_nodes(const void *old_blob, void *new_blob); +int optee_copy_fdt_nodes(void *new_blob); #else -static inline int optee_copy_fdt_nodes(const void *old_blob, void *new_blob) +static inline int optee_copy_fdt_nodes(void *new_blob) { return 0; } diff --git a/lib/optee/optee.c b/lib/optee/optee.c index 9e6606568f..a097fec28b 100644 --- a/lib/optee/optee.c +++ b/lib/optee/optee.c @@ -8,6 +8,8 @@ #include <image.h> #include <log.h> #include <malloc.h> +#include <dm/ofnode.h> +#include <linux/ioport.h> #include <linux/libfdt.h> #include <tee/optee.h>
@@ -69,17 +71,11 @@ error: }
#if defined(CONFIG_OF_LIBFDT) -static int optee_copy_firmware_node(const void *old_blob, void *fdt_blob) +static int optee_copy_firmware_node(ofnode node, void *fdt_blob) { - int old_offs, offs, ret, len; + int offs, ret, len; const void *prop;
- old_offs = fdt_path_offset(old_blob, "/firmware/optee"); - if (old_offs < 0) { - debug("Original OP-TEE Device Tree node not found"); - return old_offs; - } - offs = fdt_path_offset(fdt_blob, "/firmware"); if (offs < 0) { offs = fdt_path_offset(fdt_blob, "/"); @@ -96,7 +92,7 @@ static int optee_copy_firmware_node(const void *old_blob, void *fdt_blob) return offs;
/* copy the compatible property */ - prop = fdt_getprop(old_blob, old_offs, "compatible", &len); + prop = ofnode_get_property(node, "compatible", &len); if (!prop) { debug("missing OP-TEE compatible property"); return -EINVAL; @@ -107,7 +103,7 @@ static int optee_copy_firmware_node(const void *old_blob, void *fdt_blob) return ret;
/* copy the method property */ - prop = fdt_getprop(old_blob, old_offs, "method", &len); + prop = ofnode_get_property(node, "method", &len); if (!prop) { debug("missing OP-TEE method property"); return -EINVAL; @@ -120,19 +116,18 @@ static int optee_copy_firmware_node(const void *old_blob, void *fdt_blob) return 0; }
-int optee_copy_fdt_nodes(const void *old_blob, void *new_blob) +int optee_copy_fdt_nodes(void *new_blob) { - int nodeoffset, subnode, ret; - struct fdt_resource res; - - if (fdt_check_header(old_blob)) - return -EINVAL; + ofnode node, subnode; + int ret; + struct resource res;
if (fdt_check_header(new_blob)) return -EINVAL;
/* only proceed if there is an /firmware/optee node */ - if (fdt_path_offset(old_blob, "/firmware/optee") < 0) { + node = ofnode_path("/firmware/optee"); + if (!ofnode_valid(node)) { debug("No OP-TEE firmware node in old fdt, nothing to do"); return 0; } @@ -147,20 +142,17 @@ int optee_copy_fdt_nodes(const void *old_blob, void *new_blob) return 0; }
- ret = optee_copy_firmware_node(old_blob, new_blob); + ret = optee_copy_firmware_node(node, new_blob); if (ret < 0) { printf("Failed to add OP-TEE firmware node\n"); return ret; }
/* optee inserts its memory regions as reserved-memory nodes */ - nodeoffset = fdt_subnode_offset(old_blob, 0, "reserved-memory"); - if (nodeoffset >= 0) { - for (subnode = fdt_first_subnode(old_blob, nodeoffset); - subnode >= 0; - subnode = fdt_next_subnode(old_blob, subnode)) { - const char *name = fdt_get_name(old_blob, - subnode, NULL); + node = ofnode_path("/reserved-memory"); + if (ofnode_valid(node)) { + ofnode_for_each_subnode(subnode, node) { + const char *name = ofnode_get_name(subnode); if (!name) return -EINVAL;
@@ -169,8 +161,7 @@ int optee_copy_fdt_nodes(const void *old_blob, void *new_blob) continue;
/* check if this subnode has a reg property */ - ret = fdt_get_resource(old_blob, subnode, "reg", 0, - &res); + ret = ofnode_read_resource(subnode, 0, &res); if (!ret) { struct fdt_memory carveout = { .start = res.start,
Patrick Delaunay
