[PATCH 1/1] disk: fix blk_get_device_part_str()
blk_get_device_part_str() should always initialize all info fields including sys_ind. As a side effect the code is simplified.
Replace '(0 ==' by '(!' to conform with Linux coding style.
Fixes: 4d907025d6a5 ("sandbox: restore ability to access host fs through standard commands") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- disk/part.c | 23 +++++------------------ 1 file changed, 5 insertions(+), 18 deletions(-)
diff --git a/disk/part.c b/disk/part.c index 2eb30ebe97..5ee60a7fb5 100644 --- a/disk/part.c +++ b/disk/part.c @@ -433,25 +433,17 @@ int blk_get_device_part_str(const char *ifname, const char *dev_part_str, int part; struct disk_partition tmpinfo;
+ *dev_desc = NULL; + memset(info, 0, sizeof(*info)); + #if IS_ENABLED(CONFIG_SANDBOX) || IS_ENABLED(CONFIG_SEMIHOSTING) /* * Special-case a pseudo block device "hostfs", to allow access to the * host's own filesystem. */ - if (0 == strcmp(ifname, "hostfs")) { - *dev_desc = NULL; - info->start = 0; - info->size = 0; - info->blksz = 0; - info->bootable = 0; + if (!strcmp(ifname, "hostfs")) { strcpy((char *)info->type, BOOT_PART_TYPE); strcpy((char *)info->name, "Host filesystem"); -#if CONFIG_IS_ENABLED(PARTITION_UUIDS) - info->uuid[0] = 0; -#endif -#ifdef CONFIG_PARTITION_TYPE_GUID - info->type_guid[0] = 0; -#endif
return 0; } @@ -462,19 +454,14 @@ int blk_get_device_part_str(const char *ifname, const char *dev_part_str, * Special-case ubi, ubi goes through a mtd, rather than through * a regular block device. */ - if (0 == strcmp(ifname, "ubi")) { + if (!strcmp(ifname, "ubi")) { if (!ubifs_is_mounted()) { printf("UBIFS not mounted, use ubifsmount to mount volume first!\n"); return -EINVAL; }
- *dev_desc = NULL; - memset(info, 0, sizeof(*info)); strcpy((char *)info->type, BOOT_PART_TYPE); strcpy((char *)info->name, "UBI"); -#if CONFIG_IS_ENABLED(PARTITION_UUIDS) - info->uuid[0] = 0; -#endif return 0; } #endif
Hello Heinrich,
Looks good to me, thanks!
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Heiko Schocher
