[PATCH] arm: dts: k3-j7200: ddr: Update to 0.5.0 version of DDR for LPDDR 2666MTs
Update the ddr settings to use the DDR reg config tool rev 0.5.0. This enables 2666MTs LPDDR configuration on J7200.
Signed-off-by: Kevin Scholz k-scholz@ti.com Signed-off-by: Praneeth Bajjuri praneeth@ti.com Tested-by: Suman Anna s-anna@ti.com --- ...00.dtsi => k3-j7200-ddr-evm-lp4-2666.dtsi} | 437 +++++++++--------- .../arm/dts/k3-j7200-r5-common-proc-board.dts | 2 +- 2 files changed, 220 insertions(+), 219 deletions(-) rename arch/arm/dts/{k3-j7200-ddr-evm-lp4-1600.dtsi => k3-j7200-ddr-evm-lp4-2666.dtsi} (90%)
diff --git a/arch/arm/dts/k3-j7200-ddr-evm-lp4-1600.dtsi b/arch/arm/dts/k3-j7200-ddr-evm-lp4-2666.dtsi similarity index 90% rename from arch/arm/dts/k3-j7200-ddr-evm-lp4-1600.dtsi rename to arch/arm/dts/k3-j7200-ddr-evm-lp4-2666.dtsi index 12ffd913d1..42ac8c5c89 100644 --- a/arch/arm/dts/k3-j7200-ddr-evm-lp4-1600.dtsi +++ b/arch/arm/dts/k3-j7200-ddr-evm-lp4-2666.dtsi @@ -1,13 +1,14 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * This file was generated by the AM752x_DRA82x_TDA4x_DDRSS_RegConfigTool, Revision: 0.3.0 - * This file was generated on 06/08/2020 - * Includes hand edits + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + * This file was generated by the Jacinto7_DDRSS_RegConfigTool, Revision: 0.5.0 + * This file was generated on 08/07/2020 + * Includes hand-edits */
#define DDRSS_PLL_FHS_CNT 10 -#define DDRSS_PLL_FREQUENCY_1 400000000 -#define DDRSS_PLL_FREQUENCY_2 400000000 +#define DDRSS_PLL_FREQUENCY_1 666500000 +#define DDRSS_PLL_FREQUENCY_2 666500000
#define DDRSS_CTL_00_DATA 0x00000B00 #define DDRSS_CTL_01_DATA 0x00000000 @@ -20,14 +21,14 @@ #define DDRSS_CTL_08_DATA 0x000186A0 #define DDRSS_CTL_09_DATA 0x00000005 #define DDRSS_CTL_10_DATA 0x00000064 -#define DDRSS_CTL_11_DATA 0x00027100 -#define DDRSS_CTL_12_DATA 0x00186A00 +#define DDRSS_CTL_11_DATA 0x000411AB +#define DDRSS_CTL_12_DATA 0x0028B0AB #define DDRSS_CTL_13_DATA 0x00000005 -#define DDRSS_CTL_14_DATA 0x00000640 -#define DDRSS_CTL_15_DATA 0x00027100 -#define DDRSS_CTL_16_DATA 0x00186A00 +#define DDRSS_CTL_14_DATA 0x00000A6B +#define DDRSS_CTL_15_DATA 0x000411AB +#define DDRSS_CTL_16_DATA 0x0028B0AB #define DDRSS_CTL_17_DATA 0x00000005 -#define DDRSS_CTL_18_DATA 0x00000640 +#define DDRSS_CTL_18_DATA 0x00000A6B #define DDRSS_CTL_19_DATA 0x01010000 #define DDRSS_CTL_20_DATA 0x02011001 #define DDRSS_CTL_21_DATA 0x02010000 @@ -37,66 +38,66 @@ #define DDRSS_CTL_25_DATA 0x00000000 #define DDRSS_CTL_26_DATA 0x00000000 #define DDRSS_CTL_27_DATA 0x02020200 -#define DDRSS_CTL_28_DATA 0x00002020 +#define DDRSS_CTL_28_DATA 0x00003636 #define DDRSS_CTL_29_DATA 0x00100000 #define DDRSS_CTL_30_DATA 0x00000000 #define DDRSS_CTL_31_DATA 0x00000000 #define DDRSS_CTL_32_DATA 0x00000000 #define DDRSS_CTL_33_DATA 0x00000000 #define DDRSS_CTL_34_DATA 0x040C0000 -#define DDRSS_CTL_35_DATA 0x081C081C +#define DDRSS_CTL_35_DATA 0x0C300C30 #define DDRSS_CTL_36_DATA 0x00050804 #define DDRSS_CTL_37_DATA 0x09040008 -#define DDRSS_CTL_38_DATA 0x08000204 -#define DDRSS_CTL_39_DATA 0x0B240034 -#define DDRSS_CTL_40_DATA 0x08001910 -#define DDRSS_CTL_41_DATA 0x0B240034 -#define DDRSS_CTL_42_DATA 0x20001910 +#define DDRSS_CTL_38_DATA 0x0D000204 +#define DDRSS_CTL_39_DATA 0x113C0057 +#define DDRSS_CTL_40_DATA 0x0D00291B +#define DDRSS_CTL_41_DATA 0x113C0057 +#define DDRSS_CTL_42_DATA 0x2000291B #define DDRSS_CTL_43_DATA 0x000A0A09 #define DDRSS_CTL_44_DATA 0x040006DB -#define DDRSS_CTL_45_DATA 0x0C0A0904 -#define DDRSS_CTL_46_DATA 0x06006DB0 -#define DDRSS_CTL_47_DATA 0x0C0A0906 -#define DDRSS_CTL_48_DATA 0x06006DB0 -#define DDRSS_CTL_49_DATA 0x02030406 -#define DDRSS_CTL_50_DATA 0x11040500 -#define DDRSS_CTL_51_DATA 0x08121112 +#define DDRSS_CTL_45_DATA 0x130E0B04 +#define DDRSS_CTL_46_DATA 0x0A00B6D0 +#define DDRSS_CTL_47_DATA 0x130E0B0A +#define DDRSS_CTL_48_DATA 0x0A00B6D0 +#define DDRSS_CTL_49_DATA 0x0203040A +#define DDRSS_CTL_50_DATA 0x1C040500 +#define DDRSS_CTL_51_DATA 0x081D1C1D #define DDRSS_CTL_52_DATA 0x14000D0A #define DDRSS_CTL_53_DATA 0x02010A0A #define DDRSS_CTL_54_DATA 0x01010002 -#define DDRSS_CTL_55_DATA 0x04222208 -#define DDRSS_CTL_56_DATA 0x04131304 -#define DDRSS_CTL_57_DATA 0x00001313 +#define DDRSS_CTL_55_DATA 0x04383808 +#define DDRSS_CTL_56_DATA 0x041F1F04 +#define DDRSS_CTL_57_DATA 0x00001F1F #define DDRSS_CTL_58_DATA 0x00010100 #define DDRSS_CTL_59_DATA 0x03010000 #define DDRSS_CTL_60_DATA 0x00000E08 #define DDRSS_CTL_61_DATA 0x000000BB -#define DDRSS_CTL_62_DATA 0x000000E0 -#define DDRSS_CTL_63_DATA 0x00000C28 -#define DDRSS_CTL_64_DATA 0x000000E0 -#define DDRSS_CTL_65_DATA 0x00000C28 +#define DDRSS_CTL_62_DATA 0x00000176 +#define DDRSS_CTL_63_DATA 0x00001448 +#define DDRSS_CTL_64_DATA 0x00000176 +#define DDRSS_CTL_65_DATA 0x00001448 #define DDRSS_CTL_66_DATA 0x00000005 #define DDRSS_CTL_67_DATA 0x00030000 -#define DDRSS_CTL_68_DATA 0x00380010 -#define DDRSS_CTL_69_DATA 0x0038017E -#define DDRSS_CTL_70_DATA 0x0040017E +#define DDRSS_CTL_68_DATA 0x005D0010 +#define DDRSS_CTL_69_DATA 0x005D0282 +#define DDRSS_CTL_70_DATA 0x00400282 #define DDRSS_CTL_71_DATA 0x00120103 -#define DDRSS_CTL_72_DATA 0x00060005 -#define DDRSS_CTL_73_DATA 0x14080006 -#define DDRSS_CTL_74_DATA 0x05050114 -#define DDRSS_CTL_75_DATA 0x0201030A -#define DDRSS_CTL_76_DATA 0x030C0605 -#define DDRSS_CTL_77_DATA 0x06050201 -#define DDRSS_CTL_78_DATA 0x0001030C +#define DDRSS_CTL_72_DATA 0x000A0005 +#define DDRSS_CTL_73_DATA 0x1F08000A +#define DDRSS_CTL_74_DATA 0x0505011F +#define DDRSS_CTL_75_DATA 0x0301030A +#define DDRSS_CTL_76_DATA 0x03130A07 +#define DDRSS_CTL_77_DATA 0x0A070301 +#define DDRSS_CTL_78_DATA 0x00010313 #define DDRSS_CTL_79_DATA 0x000F000F -#define DDRSS_CTL_80_DATA 0x00E600E6 -#define DDRSS_CTL_81_DATA 0x00E600E6 +#define DDRSS_CTL_80_DATA 0x01800180 +#define DDRSS_CTL_81_DATA 0x01800180 #define DDRSS_CTL_82_DATA 0x03050505 #define DDRSS_CTL_83_DATA 0x03010303 -#define DDRSS_CTL_84_DATA 0x0C050605 -#define DDRSS_CTL_85_DATA 0x03020603 -#define DDRSS_CTL_86_DATA 0x0C050605 -#define DDRSS_CTL_87_DATA 0x03020603 +#define DDRSS_CTL_84_DATA 0x14070A07 +#define DDRSS_CTL_85_DATA 0x03030A03 +#define DDRSS_CTL_86_DATA 0x14070A07 +#define DDRSS_CTL_87_DATA 0x03030A03 #define DDRSS_CTL_88_DATA 0x03010000 #define DDRSS_CTL_89_DATA 0x00010000 #define DDRSS_CTL_90_DATA 0x00000000 @@ -118,20 +119,20 @@ #define DDRSS_CTL_106_DATA 0x00002EC0 #define DDRSS_CTL_107_DATA 0x00000000 #define DDRSS_CTL_108_DATA 0x0000051D -#define DDRSS_CTL_109_DATA 0x00030A00 -#define DDRSS_CTL_110_DATA 0x00030A00 -#define DDRSS_CTL_111_DATA 0x00030A00 -#define DDRSS_CTL_112_DATA 0x00030A00 -#define DDRSS_CTL_113_DATA 0x00030A00 +#define DDRSS_CTL_109_DATA 0x00051200 +#define DDRSS_CTL_110_DATA 0x00051200 +#define DDRSS_CTL_111_DATA 0x00051200 +#define DDRSS_CTL_112_DATA 0x00051200 +#define DDRSS_CTL_113_DATA 0x00051200 #define DDRSS_CTL_114_DATA 0x00000000 -#define DDRSS_CTL_115_DATA 0x00005518 -#define DDRSS_CTL_116_DATA 0x00030A00 -#define DDRSS_CTL_117_DATA 0x00030A00 -#define DDRSS_CTL_118_DATA 0x00030A00 -#define DDRSS_CTL_119_DATA 0x00030A00 -#define DDRSS_CTL_120_DATA 0x00030A00 +#define DDRSS_CTL_115_DATA 0x00008DF8 +#define DDRSS_CTL_116_DATA 0x00051200 +#define DDRSS_CTL_117_DATA 0x00051200 +#define DDRSS_CTL_118_DATA 0x00051200 +#define DDRSS_CTL_119_DATA 0x00051200 +#define DDRSS_CTL_120_DATA 0x00051200 #define DDRSS_CTL_121_DATA 0x00000000 -#define DDRSS_CTL_122_DATA 0x00005518 +#define DDRSS_CTL_122_DATA 0x00008DF8 #define DDRSS_CTL_123_DATA 0x00000000 #define DDRSS_CTL_124_DATA 0x00000000 #define DDRSS_CTL_125_DATA 0x00000000 @@ -140,8 +141,8 @@ #define DDRSS_CTL_128_DATA 0x00000000 #define DDRSS_CTL_129_DATA 0x00000000 #define DDRSS_CTL_130_DATA 0x00000000 -#define DDRSS_CTL_131_DATA 0x05030500 -#define DDRSS_CTL_132_DATA 0x00030503 +#define DDRSS_CTL_131_DATA 0x07030500 +#define DDRSS_CTL_132_DATA 0x00030703 #define DDRSS_CTL_133_DATA 0x0A090000 #define DDRSS_CTL_134_DATA 0x0A090701 #define DDRSS_CTL_135_DATA 0x0900000E @@ -176,23 +177,23 @@ #define DDRSS_CTL_164_DATA 0x000A0000 #define DDRSS_CTL_165_DATA 0x000D0005 #define DDRSS_CTL_166_DATA 0x000D0404 -#define DDRSS_CTL_167_DATA 0x005000A0 -#define DDRSS_CTL_168_DATA 0x060600C8 -#define DDRSS_CTL_169_DATA 0x00A000C8 -#define DDRSS_CTL_170_DATA 0x00C80050 -#define DDRSS_CTL_171_DATA 0x00C80606 +#define DDRSS_CTL_167_DATA 0x0086010B +#define DDRSS_CTL_168_DATA 0x0A0A014E +#define DDRSS_CTL_169_DATA 0x010B014E +#define DDRSS_CTL_170_DATA 0x014E0086 +#define DDRSS_CTL_171_DATA 0x014E0A0A #define DDRSS_CTL_172_DATA 0x00000000 #define DDRSS_CTL_173_DATA 0x00000000 #define DDRSS_CTL_174_DATA 0x00000000 -#define DDRSS_CTL_175_DATA 0x12A40084 -#define DDRSS_CTL_176_DATA 0x2B0012A4 +#define DDRSS_CTL_175_DATA 0x24C40084 +#define DDRSS_CTL_176_DATA 0x2B0024C4 #define DDRSS_CTL_177_DATA 0x00002B2B #define DDRSS_CTL_178_DATA 0x36000000 #define DDRSS_CTL_179_DATA 0x27270036 #define DDRSS_CTL_180_DATA 0x0F0F0000 #define DDRSS_CTL_181_DATA 0x00000000 #define DDRSS_CTL_182_DATA 0x00841515 -#define DDRSS_CTL_183_DATA 0x12A412A4 +#define DDRSS_CTL_183_DATA 0x24C424C4 #define DDRSS_CTL_184_DATA 0x2B2B2B00 #define DDRSS_CTL_185_DATA 0x00000000 #define DDRSS_CTL_186_DATA 0x00363600 @@ -270,12 +271,12 @@ #define DDRSS_CTL_258_DATA 0x00320040 #define DDRSS_CTL_259_DATA 0x00020008 #define DDRSS_CTL_260_DATA 0x00400100 -#define DDRSS_CTL_261_DATA 0x00180320 +#define DDRSS_CTL_261_DATA 0x00280536 #define DDRSS_CTL_262_DATA 0x01000200 -#define DDRSS_CTL_263_DATA 0x03200040 -#define DDRSS_CTL_264_DATA 0x00000018 -#define DDRSS_CTL_265_DATA 0x00280003 -#define DDRSS_CTL_266_DATA 0x01000028 +#define DDRSS_CTL_263_DATA 0x05360040 +#define DDRSS_CTL_264_DATA 0x00000028 +#define DDRSS_CTL_265_DATA 0x00430003 +#define DDRSS_CTL_266_DATA 0x01000043 #define DDRSS_CTL_267_DATA 0x00000000 #define DDRSS_CTL_268_DATA 0x01010000 #define DDRSS_CTL_269_DATA 0x00000202 @@ -327,14 +328,14 @@ #define DDRSS_CTL_315_DATA 0x01000101 #define DDRSS_CTL_316_DATA 0x01010001 #define DDRSS_CTL_317_DATA 0x00010101 -#define DDRSS_CTL_318_DATA 0x05050503 -#define DDRSS_CTL_319_DATA 0x08080C0C -#define DDRSS_CTL_320_DATA 0x00090308 -#define DDRSS_CTL_321_DATA 0x000C030F -#define DDRSS_CTL_322_DATA 0x000C0311 -#define DDRSS_CTL_323_DATA 0x0C090011 +#define DDRSS_CTL_318_DATA 0x05070703 +#define DDRSS_CTL_319_DATA 0x0A081414 +#define DDRSS_CTL_320_DATA 0x0009030A +#define DDRSS_CTL_321_DATA 0x080C030F +#define DDRSS_CTL_322_DATA 0x080C0306 +#define DDRSS_CTL_323_DATA 0x0C090006 #define DDRSS_CTL_324_DATA 0x0100000C -#define DDRSS_CTL_325_DATA 0x03020301 +#define DDRSS_CTL_325_DATA 0x05020501 #define DDRSS_CTL_326_DATA 0x00000002 #define DDRSS_CTL_327_DATA 0x00000000 #define DDRSS_CTL_328_DATA 0x00010000 @@ -396,7 +397,7 @@ #define DDRSS_CTL_384_DATA 0x00000000 #define DDRSS_CTL_385_DATA 0x00000000 #define DDRSS_CTL_386_DATA 0x00000000 -#define DDRSS_CTL_387_DATA 0x26261B00 +#define DDRSS_CTL_387_DATA 0x2E2E1B00 #define DDRSS_CTL_388_DATA 0x000A0000 #define DDRSS_CTL_389_DATA 0x00000176 #define DDRSS_CTL_390_DATA 0x00000200 @@ -406,22 +407,22 @@ #define DDRSS_CTL_394_DATA 0x00000462 #define DDRSS_CTL_395_DATA 0x00000E9C #define DDRSS_CTL_396_DATA 0x00000204 -#define DDRSS_CTL_397_DATA 0x00001850 +#define DDRSS_CTL_397_DATA 0x00002890 #define DDRSS_CTL_398_DATA 0x00000200 #define DDRSS_CTL_399_DATA 0x00000200 #define DDRSS_CTL_400_DATA 0x00000200 #define DDRSS_CTL_401_DATA 0x00000200 -#define DDRSS_CTL_402_DATA 0x000048F0 -#define DDRSS_CTL_403_DATA 0x0000F320 -#define DDRSS_CTL_404_DATA 0x00000408 -#define DDRSS_CTL_405_DATA 0x00001850 +#define DDRSS_CTL_402_DATA 0x000079B0 +#define DDRSS_CTL_403_DATA 0x000195A0 +#define DDRSS_CTL_404_DATA 0x0000080E +#define DDRSS_CTL_405_DATA 0x00002890 #define DDRSS_CTL_406_DATA 0x00000200 #define DDRSS_CTL_407_DATA 0x00000200 #define DDRSS_CTL_408_DATA 0x00000200 #define DDRSS_CTL_409_DATA 0x00000200 -#define DDRSS_CTL_410_DATA 0x000048F0 -#define DDRSS_CTL_411_DATA 0x0000F320 -#define DDRSS_CTL_412_DATA 0x02020408 +#define DDRSS_CTL_410_DATA 0x000079B0 +#define DDRSS_CTL_411_DATA 0x000195A0 +#define DDRSS_CTL_412_DATA 0x0202080E #define DDRSS_CTL_413_DATA 0x03030202 #define DDRSS_CTL_414_DATA 0x00000022 #define DDRSS_CTL_415_DATA 0x00000000 @@ -432,13 +433,13 @@ #define DDRSS_CTL_420_DATA 0x00000000 #define DDRSS_CTL_421_DATA 0x00030000 #define DDRSS_CTL_422_DATA 0x0006001E -#define DDRSS_CTL_423_DATA 0x000E0026 -#define DDRSS_CTL_424_DATA 0x000E0026 +#define DDRSS_CTL_423_DATA 0x0013002B +#define DDRSS_CTL_424_DATA 0x0013002B #define DDRSS_CTL_425_DATA 0x00000000 #define DDRSS_CTL_426_DATA 0x00000000 #define DDRSS_CTL_427_DATA 0x02000000 #define DDRSS_CTL_428_DATA 0x01000404 -#define DDRSS_CTL_429_DATA 0x01080108 +#define DDRSS_CTL_429_DATA 0x05120512 #define DDRSS_CTL_430_DATA 0x00000105 #define DDRSS_CTL_431_DATA 0x00010101 #define DDRSS_CTL_432_DATA 0x00010101 @@ -447,8 +448,8 @@ #define DDRSS_CTL_435_DATA 0x02000201 #define DDRSS_CTL_436_DATA 0x02010000 #define DDRSS_CTL_437_DATA 0x00000200 -#define DDRSS_CTL_438_DATA 0x10060000 -#define DDRSS_CTL_439_DATA 0x00000110 +#define DDRSS_CTL_438_DATA 0x18060000 +#define DDRSS_CTL_439_DATA 0x00000118 #define DDRSS_CTL_440_DATA 0xFFFFFFFF #define DDRSS_CTL_441_DATA 0xFFFFFFFF #define DDRSS_CTL_442_DATA 0x00000000 @@ -504,10 +505,10 @@ #define DDRSS_PI_32_DATA 0x00000000 #define DDRSS_PI_33_DATA 0x01010102 #define DDRSS_PI_34_DATA 0x00000000 -#define DDRSS_PI_35_DATA 0x000000AA -#define DDRSS_PI_36_DATA 0x00000055 -#define DDRSS_PI_37_DATA 0x000000B5 -#define DDRSS_PI_38_DATA 0x0000004A +#define DDRSS_PI_35_DATA 0x55555A5A +#define DDRSS_PI_36_DATA 0x5555A5A5 +#define DDRSS_PI_37_DATA 0x00005A5A +#define DDRSS_PI_38_DATA 0x0000A5A5 #define DDRSS_PI_39_DATA 0x00000056 #define DDRSS_PI_40_DATA 0x000000A9 #define DDRSS_PI_41_DATA 0x000000A9 @@ -515,12 +516,12 @@ #define DDRSS_PI_43_DATA 0x00000000 #define DDRSS_PI_44_DATA 0x00000000 #define DDRSS_PI_45_DATA 0x000F0F00 -#define DDRSS_PI_46_DATA 0x00000015 +#define DDRSS_PI_46_DATA 0x00000017 #define DDRSS_PI_47_DATA 0x000007D0 #define DDRSS_PI_48_DATA 0x00000300 #define DDRSS_PI_49_DATA 0x00000000 #define DDRSS_PI_50_DATA 0x00000000 -#define DDRSS_PI_51_DATA 0x01000000 +#define DDRSS_PI_51_DATA 0x04080000 #define DDRSS_PI_52_DATA 0x00010101 #define DDRSS_PI_53_DATA 0x00000000 #define DDRSS_PI_54_DATA 0x00030000 @@ -632,18 +633,18 @@ #define DDRSS_PI_160_DATA 0x00000000 #define DDRSS_PI_161_DATA 0x00010000 #define DDRSS_PI_162_DATA 0x00000000 -#define DDRSS_PI_163_DATA 0x10100100 +#define DDRSS_PI_163_DATA 0x1B1B0100 #define DDRSS_PI_164_DATA 0x00000034 -#define DDRSS_PI_165_DATA 0x00000043 -#define DDRSS_PI_166_DATA 0x00020043 +#define DDRSS_PI_165_DATA 0x00000051 +#define DDRSS_PI_166_DATA 0x00020051 #define DDRSS_PI_167_DATA 0x02000200 -#define DDRSS_PI_168_DATA 0x1C080C04 -#define DDRSS_PI_169_DATA 0x000E1C08 +#define DDRSS_PI_168_DATA 0x300C0C04 +#define DDRSS_PI_169_DATA 0x000E300C #define DDRSS_PI_170_DATA 0x000000BB -#define DDRSS_PI_171_DATA 0x000000E0 -#define DDRSS_PI_172_DATA 0x00000C28 -#define DDRSS_PI_173_DATA 0x000000E0 -#define DDRSS_PI_174_DATA 0x04000C28 +#define DDRSS_PI_171_DATA 0x00000176 +#define DDRSS_PI_172_DATA 0x00001448 +#define DDRSS_PI_173_DATA 0x00000176 +#define DDRSS_PI_174_DATA 0x04001448 #define DDRSS_PI_175_DATA 0x01010404 #define DDRSS_PI_176_DATA 0x00001501 #define DDRSS_PI_177_DATA 0x00150015 @@ -652,82 +653,82 @@ #define DDRSS_PI_180_DATA 0x00000000 #define DDRSS_PI_181_DATA 0x01010101 #define DDRSS_PI_182_DATA 0x00000101 -#define DDRSS_PI_183_DATA 0x00000000 -#define DDRSS_PI_184_DATA 0x00000000 -#define DDRSS_PI_185_DATA 0x08040000 -#define DDRSS_PI_186_DATA 0x04040208 +#define DDRSS_PI_183_DATA 0x00000100 +#define DDRSS_PI_184_DATA 0x00000100 +#define DDRSS_PI_185_DATA 0x0E040100 +#define DDRSS_PI_186_DATA 0x0808020E #define DDRSS_PI_187_DATA 0x00040402 #define DDRSS_PI_188_DATA 0x000C8034 -#define DDRSS_PI_189_DATA 0x0014003C -#define DDRSS_PI_190_DATA 0x0014003C +#define DDRSS_PI_189_DATA 0x00198041 +#define DDRSS_PI_190_DATA 0x00198041 #define DDRSS_PI_191_DATA 0x01010101 #define DDRSS_PI_192_DATA 0x0002000D -#define DDRSS_PI_193_DATA 0x000200C8 -#define DDRSS_PI_194_DATA 0x010000C8 +#define DDRSS_PI_193_DATA 0x0002014E +#define DDRSS_PI_194_DATA 0x0100014E #define DDRSS_PI_195_DATA 0x000E000E -#define DDRSS_PI_196_DATA 0x00C90100 -#define DDRSS_PI_197_DATA 0x010000C9 -#define DDRSS_PI_198_DATA 0x00C900C9 +#define DDRSS_PI_196_DATA 0x014F0100 +#define DDRSS_PI_197_DATA 0x0100014F +#define DDRSS_PI_198_DATA 0x014F014F #define DDRSS_PI_199_DATA 0x32103200 #define DDRSS_PI_200_DATA 0x01013210 #define DDRSS_PI_201_DATA 0x0A070601 -#define DDRSS_PI_202_DATA 0x0D09070D -#define DDRSS_PI_203_DATA 0x0D09070D -#define DDRSS_PI_204_DATA 0x0000C00D +#define DDRSS_PI_202_DATA 0x140D080D +#define DDRSS_PI_203_DATA 0x140D0810 +#define DDRSS_PI_204_DATA 0x0000C010 #define DDRSS_PI_205_DATA 0x00C01000 #define DDRSS_PI_206_DATA 0x00C01000 #define DDRSS_PI_207_DATA 0x00021000 -#define DDRSS_PI_208_DATA 0x0016000D -#define DDRSS_PI_209_DATA 0x001600C8 -#define DDRSS_PI_210_DATA 0x001100C8 +#define DDRSS_PI_208_DATA 0x001C000D +#define DDRSS_PI_209_DATA 0x001C014E +#define DDRSS_PI_210_DATA 0x0011014E #define DDRSS_PI_211_DATA 0x32000056 #define DDRSS_PI_212_DATA 0x00000301 -#define DDRSS_PI_213_DATA 0x00580020 +#define DDRSS_PI_213_DATA 0x005A002A #define DDRSS_PI_214_DATA 0x03013212 -#define DDRSS_PI_215_DATA 0x00002000 -#define DDRSS_PI_216_DATA 0x32120058 +#define DDRSS_PI_215_DATA 0x00002A00 +#define DDRSS_PI_216_DATA 0x3212005A #define DDRSS_PI_217_DATA 0x09000301 #define DDRSS_PI_218_DATA 0x04010504 #define DDRSS_PI_219_DATA 0x0400062B #define DDRSS_PI_220_DATA 0x0A032001 -#define DDRSS_PI_221_DATA 0x1113090A -#define DDRSS_PI_222_DATA 0x0000120C -#define DDRSS_PI_223_DATA 0x240062B8 -#define DDRSS_PI_224_DATA 0x0C0C2003 -#define DDRSS_PI_225_DATA 0x1113090A -#define DDRSS_PI_226_DATA 0x0000120C -#define DDRSS_PI_227_DATA 0x240062B8 -#define DDRSS_PI_228_DATA 0x0C0C2003 -#define DDRSS_PI_229_DATA 0x0001760A +#define DDRSS_PI_221_DATA 0x1C1F0B0A +#define DDRSS_PI_222_DATA 0x00001D12 +#define DDRSS_PI_223_DATA 0x3C00A488 +#define DDRSS_PI_224_DATA 0x13142005 +#define DDRSS_PI_225_DATA 0x1C1F0B0E +#define DDRSS_PI_226_DATA 0x00001D12 +#define DDRSS_PI_227_DATA 0x3C00A488 +#define DDRSS_PI_228_DATA 0x13142005 +#define DDRSS_PI_229_DATA 0x0001760E #define DDRSS_PI_230_DATA 0x00000E9C -#define DDRSS_PI_231_DATA 0x00001850 -#define DDRSS_PI_232_DATA 0x0000F320 -#define DDRSS_PI_233_DATA 0x00001850 -#define DDRSS_PI_234_DATA 0x0000F320 -#define DDRSS_PI_235_DATA 0x00E6000F -#define DDRSS_PI_236_DATA 0x030300E6 +#define DDRSS_PI_231_DATA 0x00002890 +#define DDRSS_PI_232_DATA 0x000195A0 +#define DDRSS_PI_233_DATA 0x00002890 +#define DDRSS_PI_234_DATA 0x000195A0 +#define DDRSS_PI_235_DATA 0x0180000F +#define DDRSS_PI_236_DATA 0x03030180 #define DDRSS_PI_237_DATA 0x00271003 #define DDRSS_PI_238_DATA 0x000186A0 #define DDRSS_PI_239_DATA 0x00000005 #define DDRSS_PI_240_DATA 0x00000064 #define DDRSS_PI_241_DATA 0x0000000F -#define DDRSS_PI_242_DATA 0x00027100 +#define DDRSS_PI_242_DATA 0x000411AB #define DDRSS_PI_243_DATA 0x000186A0 #define DDRSS_PI_244_DATA 0x00000005 -#define DDRSS_PI_245_DATA 0x00000640 -#define DDRSS_PI_246_DATA 0x000000E6 -#define DDRSS_PI_247_DATA 0x00027100 +#define DDRSS_PI_245_DATA 0x00000A6B +#define DDRSS_PI_246_DATA 0x00000180 +#define DDRSS_PI_247_DATA 0x000411AB #define DDRSS_PI_248_DATA 0x000186A0 #define DDRSS_PI_249_DATA 0x00000005 -#define DDRSS_PI_250_DATA 0x00000640 -#define DDRSS_PI_251_DATA 0x010000E6 +#define DDRSS_PI_250_DATA 0x00000A6B +#define DDRSS_PI_251_DATA 0x01000180 #define DDRSS_PI_252_DATA 0x00320040 #define DDRSS_PI_253_DATA 0x00010008 -#define DDRSS_PI_254_DATA 0x03200040 -#define DDRSS_PI_255_DATA 0x00010018 -#define DDRSS_PI_256_DATA 0x03200040 -#define DDRSS_PI_257_DATA 0x00000318 -#define DDRSS_PI_258_DATA 0x00280028 +#define DDRSS_PI_254_DATA 0x05360040 +#define DDRSS_PI_255_DATA 0x00010028 +#define DDRSS_PI_256_DATA 0x05360040 +#define DDRSS_PI_257_DATA 0x00000328 +#define DDRSS_PI_258_DATA 0x00430043 #define DDRSS_PI_259_DATA 0x00040404 #define DDRSS_PI_260_DATA 0x00000055 #define DDRSS_PI_261_DATA 0x55003C5A @@ -746,27 +747,27 @@ #define DDRSS_PI_274_DATA 0x00000000 #define DDRSS_PI_275_DATA 0x002B0084 #define DDRSS_PI_276_DATA 0x00150000 -#define DDRSS_PI_277_DATA 0x362B12A4 +#define DDRSS_PI_277_DATA 0x362B24C4 #define DDRSS_PI_278_DATA 0x00150F27 -#define DDRSS_PI_279_DATA 0x362B12A4 +#define DDRSS_PI_279_DATA 0x362B24C4 #define DDRSS_PI_280_DATA 0x00150F27 #define DDRSS_PI_281_DATA 0x002B0084 #define DDRSS_PI_282_DATA 0x00150000 -#define DDRSS_PI_283_DATA 0x362B12A4 +#define DDRSS_PI_283_DATA 0x362B24C4 #define DDRSS_PI_284_DATA 0x00150F27 -#define DDRSS_PI_285_DATA 0x362B12A4 +#define DDRSS_PI_285_DATA 0x362B24C4 #define DDRSS_PI_286_DATA 0x00150F27 #define DDRSS_PI_287_DATA 0x002B0084 #define DDRSS_PI_288_DATA 0x00150000 -#define DDRSS_PI_289_DATA 0x362B12A4 +#define DDRSS_PI_289_DATA 0x362B24C4 #define DDRSS_PI_290_DATA 0x00150F27 -#define DDRSS_PI_291_DATA 0x362B12A4 +#define DDRSS_PI_291_DATA 0x362B24C4 #define DDRSS_PI_292_DATA 0x00150F27 #define DDRSS_PI_293_DATA 0x002B0084 #define DDRSS_PI_294_DATA 0x00150000 -#define DDRSS_PI_295_DATA 0x362B12A4 +#define DDRSS_PI_295_DATA 0x362B24C4 #define DDRSS_PI_296_DATA 0x00150F27 -#define DDRSS_PI_297_DATA 0x362B12A4 +#define DDRSS_PI_297_DATA 0x362B24C4 #define DDRSS_PI_298_DATA 0x00150F27 #define DDRSS_PI_299_DATA 0x00000000
@@ -788,10 +789,10 @@ #define DDRSS_PHY_15_DATA 0x00030066 #define DDRSS_PHY_16_DATA 0x00000000 #define DDRSS_PHY_17_DATA 0x00000301 -#define DDRSS_PHY_18_DATA 0x0000AAAA -#define DDRSS_PHY_19_DATA 0x00005555 -#define DDRSS_PHY_20_DATA 0x0000B5B5 -#define DDRSS_PHY_21_DATA 0x00004A4A +#define DDRSS_PHY_18_DATA 0x55555A5A +#define DDRSS_PHY_19_DATA 0x5555A5A5 +#define DDRSS_PHY_20_DATA 0x00005A5A +#define DDRSS_PHY_21_DATA 0x0000A5A5 #define DDRSS_PHY_22_DATA 0x00005656 #define DDRSS_PHY_23_DATA 0x0000A9A9 #define DDRSS_PHY_24_DATA 0x0000A9A9 @@ -862,7 +863,7 @@ #define DDRSS_PHY_89_DATA 0x10100303 #define DDRSS_PHY_90_DATA 0x10101010 #define DDRSS_PHY_91_DATA 0x10101010 -#define DDRSS_PHY_92_DATA 0x00011010 +#define DDRSS_PHY_92_DATA 0x00021010 #define DDRSS_PHY_93_DATA 0x00100010 #define DDRSS_PHY_94_DATA 0x00100010 #define DDRSS_PHY_95_DATA 0x00100010 @@ -872,18 +873,18 @@ #define DDRSS_PHY_99_DATA 0x31C06000 #define DDRSS_PHY_100_DATA 0x07AB0340 #define DDRSS_PHY_101_DATA 0x00C0C001 -#define DDRSS_PHY_102_DATA 0x05040001 +#define DDRSS_PHY_102_DATA 0x09080001 #define DDRSS_PHY_103_DATA 0x10001000 -#define DDRSS_PHY_104_DATA 0x0C053E42 -#define DDRSS_PHY_105_DATA 0x0F0C1D01 +#define DDRSS_PHY_104_DATA 0x0C063E42 +#define DDRSS_PHY_105_DATA 0x0F0C2701 #define DDRSS_PHY_106_DATA 0x01000140 -#define DDRSS_PHY_107_DATA 0x0C000420 -#define DDRSS_PHY_108_DATA 0x000001CC +#define DDRSS_PHY_107_DATA 0x04000420 +#define DDRSS_PHY_108_DATA 0x00000255 #define DDRSS_PHY_109_DATA 0x0A0000D0 #define DDRSS_PHY_110_DATA 0x00030200 #define DDRSS_PHY_111_DATA 0x02800000 #define DDRSS_PHY_112_DATA 0x80800000 -#define DDRSS_PHY_113_DATA 0x00052010 +#define DDRSS_PHY_113_DATA 0x00092010 #define DDRSS_PHY_114_DATA 0x76543210 #define DDRSS_PHY_115_DATA 0x00000008 #define DDRSS_PHY_116_DATA 0x02800280 @@ -900,8 +901,8 @@ #define DDRSS_PHY_127_DATA 0x00A000A0 #define DDRSS_PHY_128_DATA 0x00A000A0 #define DDRSS_PHY_129_DATA 0x00A000A0 -#define DDRSS_PHY_130_DATA 0x011900A0 -#define DDRSS_PHY_131_DATA 0x01A00002 +#define DDRSS_PHY_130_DATA 0x01C400A0 +#define DDRSS_PHY_131_DATA 0x01A00003 #define DDRSS_PHY_132_DATA 0x00000000 #define DDRSS_PHY_133_DATA 0x00000000 #define DDRSS_PHY_134_DATA 0x00080200 @@ -1044,10 +1045,10 @@ #define DDRSS_PHY_271_DATA 0x00030066 #define DDRSS_PHY_272_DATA 0x00000000 #define DDRSS_PHY_273_DATA 0x00000301 -#define DDRSS_PHY_274_DATA 0x0000AAAA -#define DDRSS_PHY_275_DATA 0x00005555 -#define DDRSS_PHY_276_DATA 0x0000B5B5 -#define DDRSS_PHY_277_DATA 0x00004A4A +#define DDRSS_PHY_274_DATA 0x55555A5A +#define DDRSS_PHY_275_DATA 0x5555A5A5 +#define DDRSS_PHY_276_DATA 0x00005A5A +#define DDRSS_PHY_277_DATA 0x0000A5A5 #define DDRSS_PHY_278_DATA 0x00005656 #define DDRSS_PHY_279_DATA 0x0000A9A9 #define DDRSS_PHY_280_DATA 0x0000A9A9 @@ -1118,7 +1119,7 @@ #define DDRSS_PHY_345_DATA 0x10100303 #define DDRSS_PHY_346_DATA 0x10101010 #define DDRSS_PHY_347_DATA 0x10101010 -#define DDRSS_PHY_348_DATA 0x00011010 +#define DDRSS_PHY_348_DATA 0x00021010 #define DDRSS_PHY_349_DATA 0x00100010 #define DDRSS_PHY_350_DATA 0x00100010 #define DDRSS_PHY_351_DATA 0x00100010 @@ -1128,18 +1129,18 @@ #define DDRSS_PHY_355_DATA 0x31C06000 #define DDRSS_PHY_356_DATA 0x07AB0340 #define DDRSS_PHY_357_DATA 0x00C0C001 -#define DDRSS_PHY_358_DATA 0x05040001 +#define DDRSS_PHY_358_DATA 0x09080001 #define DDRSS_PHY_359_DATA 0x10001000 -#define DDRSS_PHY_360_DATA 0x0C053E42 -#define DDRSS_PHY_361_DATA 0x0F0C1D01 +#define DDRSS_PHY_360_DATA 0x0C063E42 +#define DDRSS_PHY_361_DATA 0x0F0C2701 #define DDRSS_PHY_362_DATA 0x01000140 -#define DDRSS_PHY_363_DATA 0x0C000420 -#define DDRSS_PHY_364_DATA 0x000001CC +#define DDRSS_PHY_363_DATA 0x04000420 +#define DDRSS_PHY_364_DATA 0x00000255 #define DDRSS_PHY_365_DATA 0x0A0000D0 #define DDRSS_PHY_366_DATA 0x00030200 #define DDRSS_PHY_367_DATA 0x02800000 #define DDRSS_PHY_368_DATA 0x80800000 -#define DDRSS_PHY_369_DATA 0x00052010 +#define DDRSS_PHY_369_DATA 0x00092010 #define DDRSS_PHY_370_DATA 0x76543210 #define DDRSS_PHY_371_DATA 0x00000008 #define DDRSS_PHY_372_DATA 0x02800280 @@ -1156,8 +1157,8 @@ #define DDRSS_PHY_383_DATA 0x00A000A0 #define DDRSS_PHY_384_DATA 0x00A000A0 #define DDRSS_PHY_385_DATA 0x00A000A0 -#define DDRSS_PHY_386_DATA 0x011900A0 -#define DDRSS_PHY_387_DATA 0x01A00002 +#define DDRSS_PHY_386_DATA 0x01C400A0 +#define DDRSS_PHY_387_DATA 0x01A00003 #define DDRSS_PHY_388_DATA 0x00000000 #define DDRSS_PHY_389_DATA 0x00000000 #define DDRSS_PHY_390_DATA 0x00080200 @@ -1300,10 +1301,10 @@ #define DDRSS_PHY_527_DATA 0x00030066 #define DDRSS_PHY_528_DATA 0x00000000 #define DDRSS_PHY_529_DATA 0x00000301 -#define DDRSS_PHY_530_DATA 0x0000AAAA -#define DDRSS_PHY_531_DATA 0x00005555 -#define DDRSS_PHY_532_DATA 0x0000B5B5 -#define DDRSS_PHY_533_DATA 0x00004A4A +#define DDRSS_PHY_530_DATA 0x55555A5A +#define DDRSS_PHY_531_DATA 0x5555A5A5 +#define DDRSS_PHY_532_DATA 0x00005A5A +#define DDRSS_PHY_533_DATA 0x0000A5A5 #define DDRSS_PHY_534_DATA 0x00005656 #define DDRSS_PHY_535_DATA 0x0000A9A9 #define DDRSS_PHY_536_DATA 0x0000A9A9 @@ -1374,7 +1375,7 @@ #define DDRSS_PHY_601_DATA 0x10100303 #define DDRSS_PHY_602_DATA 0x10101010 #define DDRSS_PHY_603_DATA 0x10101010 -#define DDRSS_PHY_604_DATA 0x00011010 +#define DDRSS_PHY_604_DATA 0x00021010 #define DDRSS_PHY_605_DATA 0x00100010 #define DDRSS_PHY_606_DATA 0x00100010 #define DDRSS_PHY_607_DATA 0x00100010 @@ -1384,18 +1385,18 @@ #define DDRSS_PHY_611_DATA 0x31C06000 #define DDRSS_PHY_612_DATA 0x07AB0340 #define DDRSS_PHY_613_DATA 0x00C0C001 -#define DDRSS_PHY_614_DATA 0x05040001 +#define DDRSS_PHY_614_DATA 0x09080001 #define DDRSS_PHY_615_DATA 0x10001000 -#define DDRSS_PHY_616_DATA 0x0C053E42 -#define DDRSS_PHY_617_DATA 0x0F0C1D01 +#define DDRSS_PHY_616_DATA 0x0C063E42 +#define DDRSS_PHY_617_DATA 0x0F0C2701 #define DDRSS_PHY_618_DATA 0x01000140 -#define DDRSS_PHY_619_DATA 0x0C000420 -#define DDRSS_PHY_620_DATA 0x000001CC +#define DDRSS_PHY_619_DATA 0x04000420 +#define DDRSS_PHY_620_DATA 0x00000255 #define DDRSS_PHY_621_DATA 0x0A0000D0 #define DDRSS_PHY_622_DATA 0x00030200 #define DDRSS_PHY_623_DATA 0x02800000 #define DDRSS_PHY_624_DATA 0x80800000 -#define DDRSS_PHY_625_DATA 0x00052010 +#define DDRSS_PHY_625_DATA 0x00092010 #define DDRSS_PHY_626_DATA 0x76543210 #define DDRSS_PHY_627_DATA 0x00000008 #define DDRSS_PHY_628_DATA 0x02800280 @@ -1412,8 +1413,8 @@ #define DDRSS_PHY_639_DATA 0x00A000A0 #define DDRSS_PHY_640_DATA 0x00A000A0 #define DDRSS_PHY_641_DATA 0x00A000A0 -#define DDRSS_PHY_642_DATA 0x011900A0 -#define DDRSS_PHY_643_DATA 0x01A00002 +#define DDRSS_PHY_642_DATA 0x01C400A0 +#define DDRSS_PHY_643_DATA 0x01A00003 #define DDRSS_PHY_644_DATA 0x00000000 #define DDRSS_PHY_645_DATA 0x00000000 #define DDRSS_PHY_646_DATA 0x00080200 @@ -1556,10 +1557,10 @@ #define DDRSS_PHY_783_DATA 0x00030066 #define DDRSS_PHY_784_DATA 0x00000000 #define DDRSS_PHY_785_DATA 0x00000301 -#define DDRSS_PHY_786_DATA 0x0000AAAA -#define DDRSS_PHY_787_DATA 0x00005555 -#define DDRSS_PHY_788_DATA 0x0000B5B5 -#define DDRSS_PHY_789_DATA 0x00004A4A +#define DDRSS_PHY_786_DATA 0x55555A5A +#define DDRSS_PHY_787_DATA 0x5555A5A5 +#define DDRSS_PHY_788_DATA 0x00005A5A +#define DDRSS_PHY_789_DATA 0x0000A5A5 #define DDRSS_PHY_790_DATA 0x00005656 #define DDRSS_PHY_791_DATA 0x0000A9A9 #define DDRSS_PHY_792_DATA 0x0000A9A9 @@ -1630,7 +1631,7 @@ #define DDRSS_PHY_857_DATA 0x10100303 #define DDRSS_PHY_858_DATA 0x10101010 #define DDRSS_PHY_859_DATA 0x10101010 -#define DDRSS_PHY_860_DATA 0x00011010 +#define DDRSS_PHY_860_DATA 0x00021010 #define DDRSS_PHY_861_DATA 0x00100010 #define DDRSS_PHY_862_DATA 0x00100010 #define DDRSS_PHY_863_DATA 0x00100010 @@ -1640,18 +1641,18 @@ #define DDRSS_PHY_867_DATA 0x31C06000 #define DDRSS_PHY_868_DATA 0x07AB0340 #define DDRSS_PHY_869_DATA 0x00C0C001 -#define DDRSS_PHY_870_DATA 0x05040001 +#define DDRSS_PHY_870_DATA 0x09080001 #define DDRSS_PHY_871_DATA 0x10001000 -#define DDRSS_PHY_872_DATA 0x0C053E42 -#define DDRSS_PHY_873_DATA 0x0F0C1D01 +#define DDRSS_PHY_872_DATA 0x0C063E42 +#define DDRSS_PHY_873_DATA 0x0F0C2701 #define DDRSS_PHY_874_DATA 0x01000140 -#define DDRSS_PHY_875_DATA 0x0C000420 -#define DDRSS_PHY_876_DATA 0x000001CC +#define DDRSS_PHY_875_DATA 0x04000420 +#define DDRSS_PHY_876_DATA 0x00000255 #define DDRSS_PHY_877_DATA 0x0A0000D0 #define DDRSS_PHY_878_DATA 0x00030200 #define DDRSS_PHY_879_DATA 0x02800000 #define DDRSS_PHY_880_DATA 0x80800000 -#define DDRSS_PHY_881_DATA 0x00052010 +#define DDRSS_PHY_881_DATA 0x00092010 #define DDRSS_PHY_882_DATA 0x76543210 #define DDRSS_PHY_883_DATA 0x00000008 #define DDRSS_PHY_884_DATA 0x02800280 @@ -1668,13 +1669,13 @@ #define DDRSS_PHY_895_DATA 0x00A000A0 #define DDRSS_PHY_896_DATA 0x00A000A0 #define DDRSS_PHY_897_DATA 0x00A000A0 -#define DDRSS_PHY_898_DATA 0x011900A0 -#define DDRSS_PHY_899_DATA 0x01A00002 +#define DDRSS_PHY_898_DATA 0x01C400A0 +#define DDRSS_PHY_899_DATA 0x01A00003 #define DDRSS_PHY_900_DATA 0x00000000 #define DDRSS_PHY_901_DATA 0x00000000 #define DDRSS_PHY_902_DATA 0x00080200 #define DDRSS_PHY_903_DATA 0x00000000 -#define DDRSS_PHY_904_DATA 0x20202010 +#define DDRSS_PHY_904_DATA 0x20202000 #define DDRSS_PHY_905_DATA 0x20202020 #define DDRSS_PHY_906_DATA 0xF0F02020 #define DDRSS_PHY_907_DATA 0x00000000 diff --git a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts index 0491432060..69d8600c19 100644 --- a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts @@ -6,7 +6,7 @@ /dts-v1/;
#include "k3-j7200-som-p0.dtsi" -#include "k3-j7200-ddr-evm-lp4-1600.dtsi" +#include "k3-j7200-ddr-evm-lp4-2666.dtsi" #include "k3-j721e-ddr.dtsi"
Applied to https://source.denx.de/u-boot/custodians/u-boot-ti.git master, thanks! [1/1] arm: dts: k3-j7200: ddr: Update to 0.5.0 version of DDR for LPDDR 2666MTs https://source.denx.de/u-boot/custodians/u-boot-ti/-/commit/dc9f1009b1
-- Thanks and Regards, Lokesh
Lokesh Vutla
praneeth@ti.com
