[PATCH v4 0/3] binman: Add support for externally encrypted blobs
From: Christian Taedcke christian.taedcke@weidmueller.com
This series adds the functionality to handle externally encrypted blobs to binman. It includes the functionality itself and the corresponding unit tests.
The following block shows an example on how to use this functionality. In the device tree that is parsed by binman a new node encrypted is used:
/ { binman { filename = "u-boot.itb"; fit { ... images { some-bitstream { ... image_bitstream: blob-ext { filename = "bitstream.bin"; }; encrypted { content = <&image_bitstream>; algo = "aes256-gcm"; iv-filename = "bitstream.bin.iv"; key-filename = "bitstream.bin.key"; }; ...
This results in an generated fit image containing the following information:
\ { images { ... some-bitstream { ... data = [...] cipher { algo = "aes256-gcm"; key = <0x...>; iv = <0x...>; }; }; ...
Changes in v4: - fix failing test testEncryptedKeyFile
Changes in v3: - rebase on u-boot-dm/mkim-working - remove unnecessary test testEncryptedNoContent - update doc for functions ObtainContents and ProcessContents - update entries.rst - wrap some lines at 80 cols
Changes in v2: - adapt tests for changed entry implementation - add entry documentation - remove global /cipher node - replace key-name-hint with key-source property
Christian Taedcke (3): binman: Add support for externally encrypted blobs binman: Allow cipher node as special section binman: Add tests for etype encrypted
tools/binman/entries.rst | 88 ++++++++++ tools/binman/etype/encrypted.py | 157 ++++++++++++++++++ tools/binman/etype/section.py | 2 +- tools/binman/ftest.py | 53 ++++++ tools/binman/test/291_encrypted_no_algo.dts | 19 +++ .../test/292_encrypted_invalid_iv_file.dts | 23 +++ .../binman/test/293_encrypted_missing_key.dts | 28 ++++ .../binman/test/294_encrypted_key_source.dts | 29 ++++ tools/binman/test/295_encrypted_key_file.dts | 29 ++++ 9 files changed, 427 insertions(+), 1 deletion(-) create mode 100644 tools/binman/etype/encrypted.py create mode 100644 tools/binman/test/291_encrypted_no_algo.dts create mode 100644 tools/binman/test/292_encrypted_invalid_iv_file.dts create mode 100644 tools/binman/test/293_encrypted_missing_key.dts create mode 100644 tools/binman/test/294_encrypted_key_source.dts create mode 100644 tools/binman/test/295_encrypted_key_file.dts
This adds a new etype encrypted that is derived from collection.
It creates a new cipher node in the related image similar to the cipher node used by u-boot, see boot/image-cipher.c.
Signed-off-by: Christian Taedcke christian.taedcke@weidmueller.com ---
(no changes since v3)
Changes in v3: - rebase on u-boot-dm/mkim-working - update doc for functions ObtainContents and ProcessContents - update entries.rst
Changes in v2: - add entry documentation - remove global /cipher node - replace key-name-hint with key-source property
tools/binman/entries.rst | 88 ++++++++++++++++++ tools/binman/etype/encrypted.py | 157 ++++++++++++++++++++++++++++++++ 2 files changed, 245 insertions(+) create mode 100644 tools/binman/etype/encrypted.py
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index b55f424620..d4bc5de1d3 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -468,6 +468,94 @@ updating the EC on startup via software sync.
+.. _etype_encrypted: + +Entry: encrypted: Externally built encrypted binary blob +-------------------------------------------------------- + +This entry provides the functionality to include information about how to +decrypt an encrypted binary. This information is added to the +resulting device tree by adding a new cipher node in the entry's parent +node (i.e. the binary). + +The key that must be used to decrypt the binary is either directly embedded +in the device tree or indirectly by specifying a key source. The key source +can be used as an id of a key that is stored in an external device. + +Using an embedded key +~~~~~~~~~~~~~~~~~~~~~ + +This is an example using an embedded key:: + + encrypted_blob: blob-ext { + filename = "encrypted-blob.bin"; + }; + + encrypted { + content = <&encrypted_blob>; + algo = "aes256-gcm"; + iv-filename = "encrypted-blob.bin.iv"; + key-filename = "encrypted-blob.bin.key"; + }; + +This entry generates the following device tree structure form the example +above:: + + data = [...] + cipher { + algo = "aes256-gcm"; + key = <0x...>; + iv = <0x...>; + }; + +The data property is generated by the blob-ext etype, the cipher node and +its content is generated by this etype. + +Using an external key +~~~~~~~~~~~~~~~~~~~~~ + +Instead of embedding the key itself into the device tree, it is also +possible to address an externally stored key by specifying a 'key-source' +instead of the 'key':: + + encrypted_blob: blob-ext { + filename = "encrypted-blob.bin"; + }; + + encrypted { + content = <&encrypted_blob>; + algo = "aes256-gcm"; + iv-filename = "encrypted-blob.bin.iv"; + key-source = "external-key-id"; + }; + +This entry generates the following device tree structure form the example +above:: + + data = [...] + cipher { + algo = "aes256-gcm"; + key-source = "external-key-id"; + iv = <0x...>; + }; + +Properties +~~~~~~~~~~ + +In addition to the inherited 'collection' for Properties / Entry arguments: + - algo: The encryption algorithm. Currently no algorithm is supported + out-of-the-box. Certain algorithms will be added in future + patches. + - iv-filename: The name of the file containing the initialization + vector (in short iv). See + https://en.wikipedia.org/wiki/Initialization_vector + - key-filename: The name of the file containing the key. Either + key-filename or key-source must be provided. + - key-source: The key that should be used. Either key-filename or + key-source must be provided. + + + .. _etype_fdtmap:
Entry: fdtmap: An entry which contains an FDT map diff --git a/tools/binman/etype/encrypted.py b/tools/binman/etype/encrypted.py new file mode 100644 index 0000000000..7638cfbe7f --- /dev/null +++ b/tools/binman/etype/encrypted.py @@ -0,0 +1,157 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright 2023 Weidmüller Interface GmbH & Co. KG +# Written by Christian Taedcke christian.taedcke@weidmueller.com +# +# Entry-type module for cipher information of encrypted blobs/binaries +# + +from binman.etype.collection import Entry_collection +from dtoc import fdt_util +from u_boot_pylib import tools + +# This is imported if needed +state = None + + +class Entry_encrypted(Entry_collection): + """Externally built encrypted binary blob + + This entry provides the functionality to include information about how to + decrypt an encrypted binary. This information is added to the + resulting device tree by adding a new cipher node in the entry's parent + node (i.e. the binary). + + The key that must be used to decrypt the binary is either directly embedded + in the device tree or indirectly by specifying a key source. The key source + can be used as an id of a key that is stored in an external device. + + Using an embedded key + ~~~~~~~~~~~~~~~~~~~~~ + + This is an example using an embedded key:: + + encrypted_blob: blob-ext { + filename = "encrypted-blob.bin"; + }; + + encrypted { + content = <&encrypted_blob>; + algo = "aes256-gcm"; + iv-filename = "encrypted-blob.bin.iv"; + key-filename = "encrypted-blob.bin.key"; + }; + + This entry generates the following device tree structure form the example + above:: + + data = [...] + cipher { + algo = "aes256-gcm"; + key = <0x...>; + iv = <0x...>; + }; + + The data property is generated by the blob-ext etype, the cipher node and + its content is generated by this etype. + + Using an external key + ~~~~~~~~~~~~~~~~~~~~~ + + Instead of embedding the key itself into the device tree, it is also + possible to address an externally stored key by specifying a 'key-source' + instead of the 'key':: + + encrypted_blob: blob-ext { + filename = "encrypted-blob.bin"; + }; + + encrypted { + content = <&encrypted_blob>; + algo = "aes256-gcm"; + iv-filename = "encrypted-blob.bin.iv"; + key-source = "external-key-id"; + }; + + This entry generates the following device tree structure form the example + above:: + + data = [...] + cipher { + algo = "aes256-gcm"; + key-source = "external-key-id"; + iv = <0x...>; + }; + + Properties + ~~~~~~~~~~ + + In addition to the inherited 'collection' for Properties / Entry arguments: + - algo: The encryption algorithm. Currently no algorithm is supported + out-of-the-box. Certain algorithms will be added in future + patches. + - iv-filename: The name of the file containing the initialization + vector (in short iv). See + https://en.wikipedia.org/wiki/Initialization_vector + - key-filename: The name of the file containing the key. Either + key-filename or key-source must be provided. + - key-source: The key that should be used. Either key-filename or + key-source must be provided. + """ + + def __init__(self, section, etype, node): + # Put this here to allow entry-docs and help to work without libfdt + global state + from binman import state + + super().__init__(section, etype, node) + self.required_props = ['algo', 'iv-filename'] + self._algo = None + self._iv_filename = None + self._key_name_hint = None + self._key_filename = None + + def ReadNode(self): + super().ReadNode() + + self._algo = fdt_util.GetString(self._node, 'algo') + self._iv_filename = fdt_util.GetString(self._node, 'iv-filename') + self._key_filename = fdt_util.GetString(self._node, 'key-filename') + self._key_source = fdt_util.GetString(self._node, 'key-source') + + if self._key_filename is None and self._key_source is None: + self.Raise("Provide either 'key-filename' or 'key-source'") + + def gen_entries(self): + super().gen_entries() + + iv_filename = tools.get_input_filename(self._iv_filename) + iv = tools.read_file(iv_filename, binary=True) + + cipher_node = state.AddSubnode(self._node.parent, "cipher") + cipher_node.AddString("algo", self._algo) + cipher_node.AddData("iv", iv) + + if self._key_filename: + key_filename = tools.get_input_filename(self._key_filename) + key = tools.read_file(key_filename, binary=True) + cipher_node.AddData("key", key) + + if self._key_source: + cipher_node.AddString("key-source", self._key_source) + + def ObtainContents(self): + """Set to empty contents + + Ensure that linked content is not added to the device tree again from + this entry. + """ + self.SetContents(b'') + return True + + def ProcessContents(self): + """Set to empty contents + + Ensure that linked content is not added to the device tree again from + this entry. + """ + return self.ProcessContentsUpdate(b'')
Hi Christian,
Changes in v3:
Changes in v2:
- encrypted_blob: blob-ext {
- encrypted {
Why is this content reference needed?
It does not look like this content is used by the etype and if the etype intends to encrypt the content this etype should probably be a section and wrap content nodes instead of referencing it.
If the content is not intended to be encrypted by this etype the name of the etype is misleading, cipher may be a better name if the intended use is to produce a cipher node for an already encrypted blob.
Also look like something like the following could be added without an etype and just the IsSpecialSubnode patch. An etype may be more convenient.
cipher { algo = "aes256-gcm"; key = /incbin/("/path/to/encrypted-blob.bin.key"); iv = /incbin/("/path/to/encrypted-blob.bin.iv"); };
Regards, Jonas
- data = [...]
- cipher {
key = <0x...>;
iv = <0x...>;
- encrypted {
- data = [...]
- cipher {
iv = <0x...>;
patches.
https://en.wikipedia.org/wiki/Initialization_vector>> + - key-filename: The name of the file containing the key. Either
.. _etype_fdtmap:
- """Externally built encrypted binary blob
- This entry provides the functionality to include information about how to
- decrypt an encrypted binary. This information is added to the
- resulting device tree by adding a new cipher node in the entry's parent
- node (i.e. the binary).
- The key that must be used to decrypt the binary is either directly embedded
- in the device tree or indirectly by specifying a key source. The key source
- can be used as an id of a key that is stored in an external device.
- Using an embedded key
- This is an example using an embedded key::
encrypted {
- This entry generates the following device tree structure form the example
- above::
data = [...]
cipher {
key = <0x...>;
iv = <0x...>;
- The data property is generated by the blob-ext etype, the cipher node and
- its content is generated by this etype.
- Using an external key
- Instead of embedding the key itself into the device tree, it is also
- possible to address an externally stored key by specifying a 'key-source'
- instead of the 'key'::
encrypted {
- above::
data = [...]
cipher {
iv = <0x...>;
- Properties
- In addition to the inherited 'collection' for Properties / Entry arguments:
patches.
- def __init__(self, section, etype, node):
global state
self._algo = None
- def ReadNode(self):
super().ReadNode()
- def gen_entries(self):
- def ObtainContents(self):
this entry.
return True
- def ProcessContents(self):
this entry.
Hello Jonas,
Am 10.07.2023 um 12:48 schrieb Jonas Karlman:
Hi Christian,
Changes in v3:
Changes in v2:
- encrypted {
Now it is not used at all in the code. It is only some kind of documentation that shows which data is encrypted. It was used in a previous patch to determine the size of the encrypted data. I will remove this in the next version of the patch.
This etype is not meant to encrypt the data. Because of this i named the etype encrypted and not encrypt. But i can rename the etype to cipher, since it only adds a cipher node into the generated device tree.
You are right, with the removal of the global /cipher node in v2, it would be possible to do this without implementing a new etype. The benfit of the etype is that there is a check, that the required properties are set. In addition the search directory for the provided binaries can be controlled via the environment variable BINMAN_INDIRS instead of providing the search path to dtc.
I would prefer to keep the etype.
Regards, Jonas
Regards, Christian
- data = [...]
- cipher {
key = <0x...>;
iv = <0x...>;
- encrypted {
- data = [...]
- cipher {
iv = <0x...>;
patches.
.. _etype_fdtmap:
encrypted {
- above::
data = [...]
cipher {
key = <0x...>;
iv = <0x...>;
encrypted {
- above::
data = [...]
cipher {
iv = <0x...>;
- Properties
patches.
global state
self._algo = None
super().ReadNode()
this entry.
return True
this entry.
Hello Jonas,
On 10.07.2023 12:48, Jonas Karlman wrote:
Hi Christian,
Changes in v3:
Changes in v2:
- encrypted {
I tried renaming the etype to cipher, but this leads to further complications. After renaming the etype to cipher, the node cipher in the device tree has basically two different states/meanings. Initially it contains the input to binman, so binman passes the node and its properties to the etype, so the etype can evaluate it. After this is done the cipher node contains new, different properties that should not be evaluated by binman again, but simply written out to the generated device tree. But since binman does not simply parse the device tree once and writes out the result, i get an error when binman tries to pass the generated cipher node (containing the new properties that should end up in the resulting device tree) to the cipher etype again.
So in the next version of the patch series i would keep the etype name encrypted.
Regards, Jonas
- data = [...]
- cipher {
key = <0x...>;
iv = <0x...>;
- encrypted {
- data = [...]
- cipher {
iv = <0x...>;
patches.
.. _etype_fdtmap:
encrypted {
- above::
data = [...]
cipher {
key = <0x...>;
iv = <0x...>;
encrypted {
- above::
data = [...]
cipher {
iv = <0x...>;
- Properties
patches.
global state
self._algo = None
super().ReadNode()
this entry.
return True
this entry.
Regards, Christian
Hi Christian,
On Tue, 11 Jul 2023 at 08:58, Taedcke, Christian christian.taedcke-oss@weidmueller.com wrote:
Hello Jonas,
Hi Christian,
Changes in v3:
Changes in v2:
- encrypted {
Could you please post the error you get? Binman should not process the nodes more than once. I might be able to fix it.
Hello Simon,
thank you for your help so far.
On 11.07.2023 17:01, Simon Glass wrote:
Hi Christian,
Hello Jonas,
Hi Christian,
Changes in v3:
Changes in v2:
- encrypted {
I misinterpreted my issue. So my etype is not processed twice.
But i am not able to replace the cipher node or the content of the cipher node. When i try to get the binman output in the unit test, i always get the original cipher node, not the one that i am trying to create in my etype.
The unit test looks like this: data = self._DoReadFileDtb('295_cipher_key_file.dts')[0] dtb = fdt.Fdt.FromData(data) dtb.Scan() node = dtb.GetNode('/images/u-boot/cipher')
Is this the correct sequence for the unit test?
In the new cipher etype, i tried 2 approaches, none of them worked for me:
1. Delete all properties from the current node (self._node) and add the new properties. To delete the properties i used: props = list(self._node.props) for prop in props: self._node.DeleteProp(prop)
2. Delete the current cipher node completely and create a new one. parent = self._node.parent self._node.purge() cipher_node = state.AddSubnode(parent, "cipher")
I tried this in the etype method "def gen_entries(self)" and also in "def ProcessFdt(self, fdt)"
How can i replace the initial cipher node that is read from the dts file with a new cipher node that is created in the etype?
Regards, Christian
Hi Christian,
On Wed, 12 Jul 2023 at 03:20, Taedcke, Christian christian.taedcke-oss@weidmueller.com wrote:
Hello Simon,
Hi Christian,
Hello Jonas,
Hi Christian,
Changes in v3:
Changes in v2:
- encrypted {
You should be aware that Binman fakes almost all data in tests, by default. For example the 'u-boot' entry results in contents of '1234'. This is for easy inspection and debugging.
If you use _DoReadFileRealDtb() it will avoid that.
- Delete all properties from the current node (self._node) and add the
- Delete the current cipher node completely and create a new one. parent = self._node.parent self._node.purge() cipher_node = state.AddSubnode(parent, "cipher")
You should only need to add the new properties, as with 2. The purge should not be necessary unless you are deleting things, etc.
The new encrypted etype generates a cipher node in the device tree that should not be evaluated by binman, but still be kept in the output device tree.
tools/binman/etype/section.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index 7c4d312c16..fb49e85a76 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -179,7 +179,7 @@ class Entry_section(Entry): Returns: bool: True if the node is a special one, else False """ - start_list = ('hash', 'signature', 'template') + start_list = ('cipher', 'hash', 'signature', 'template') return any(node.name.startswith(name) for name in start_list)
def ReadNode(self):
Changes in v3:
As a follow-up if you have time - can you add a list of the special nodes to the docs?
Add tests to reach 100% code coverage for the added etype encrypted.
Changes in v3: - rebase on u-boot-dm/mkim-working - remove unnecessary test testEncryptedNoContent - wrap some lines at 80 cols
tools/binman/ftest.py | 53 +++++++++++++++++++ tools/binman/test/291_encrypted_no_algo.dts | 19 +++++++ .../test/292_encrypted_invalid_iv_file.dts | 23 ++++++++ .../binman/test/293_encrypted_missing_key.dts | 28 ++++++++++ .../binman/test/294_encrypted_key_source.dts | 29 ++++++++++ tools/binman/test/295_encrypted_key_file.dts | 29 ++++++++++ 6 files changed, 181 insertions(+) create mode 100644 tools/binman/test/291_encrypted_no_algo.dts create mode 100644 tools/binman/test/292_encrypted_invalid_iv_file.dts create mode 100644 tools/binman/test/293_encrypted_missing_key.dts create mode 100644 tools/binman/test/294_encrypted_key_source.dts create mode 100644 tools/binman/test/295_encrypted_key_file.dts
diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index e53181afb7..c1ace9a401 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -94,6 +94,8 @@ ROCKCHIP_TPL_DATA = b'rockchip-tpl' TEST_FDT1_DATA = b'fdt1' TEST_FDT2_DATA = b'test-fdt2' ENV_DATA = b'var1=1\nvar2="2"' +ENCRYPTED_IV_DATA = b'123456' +ENCRYPTED_KEY_DATA = b'abcde' PRE_LOAD_MAGIC = b'UBSH' PRE_LOAD_VERSION = 0x11223344.to_bytes(4, 'big') PRE_LOAD_HDR_SIZE = 0x00001000.to_bytes(4, 'big') @@ -226,6 +228,10 @@ class TestFunctional(unittest.TestCase): # Newer OP_TEE file in v1 binary format cls.make_tee_bin('tee.bin')
+ # test files for encrypted tests + TestFunctional._MakeInputFile('encrypted-file.iv', ENCRYPTED_IV_DATA) + TestFunctional._MakeInputFile('encrypted-file.key', ENCRYPTED_KEY_DATA) + cls.comp_bintools = {} for name in COMP_BINTOOLS: cls.comp_bintools[name] = bintool.Bintool.create(name) @@ -6884,6 +6890,53 @@ fdt fdtmap Extract the devicetree blob from the fdtmap # Move to next spl_data = content[:0x18]
+ def testEncryptedNoAlgo(self): + with self.assertRaises(ValueError) as e: + self._DoReadFileDtb('291_encrypted_no_algo.dts') + self.assertIn( + "Node '/binman/fit/images/u-boot/encrypted': 'encrypted' entry is missing properties: algo iv-filename", + str(e.exception)) + + def testEncryptedInvalidIvfile(self): + with self.assertRaises(ValueError) as e: + self._DoReadFileDtb('292_encrypted_invalid_iv_file.dts') + self.assertIn("Filename 'invalid-iv-file' not found in input path", + str(e.exception)) + + def testEncryptedMissingKey(self): + with self.assertRaises(ValueError) as e: + self._DoReadFileDtb('293_encrypted_missing_key.dts') + self.assertIn( + "Node '/binman/fit/images/u-boot/encrypted': Provide either 'key-filename' or 'key-source'", + str(e.exception)) + + def testEncryptedKeySource(self): + data = self._DoReadFileDtb('294_encrypted_key_source.dts')[0] + + dtb = fdt.Fdt.FromData(data) + dtb.Scan() + + node = dtb.GetNode('/images/u-boot/cipher') + self.assertEqual('algo-name', node.props['algo'].value) + self.assertEqual('key-source-value', node.props['key-source'].value) + self.assertEqual(ENCRYPTED_IV_DATA, + tools.to_bytes(''.join(node.props['iv'].value))) + self.assertNotIn('key', node.props) + + def testEncryptedKeyFile(self): + data = self._DoReadFileDtb('295_encrypted_key_file.dts')[0] + + dtb = fdt.Fdt.FromData(data) + dtb.Scan() + + node = dtb.GetNode('/images/u-boot/cipher') + self.assertEqual('algo-name', node.props['algo'].value) + self.assertEqual(ENCRYPTED_IV_DATA, + tools.to_bytes(''.join(node.props['iv'].value))) + self.assertEqual(ENCRYPTED_KEY_DATA, + tools.to_bytes(''.join(node.props['key'].value))) + self.assertNotIn('key-source', node.props) +
if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/291_encrypted_no_algo.dts b/tools/binman/test/291_encrypted_no_algo.dts new file mode 100644 index 0000000000..71975c0116 --- /dev/null +++ b/tools/binman/test/291_encrypted_no_algo.dts @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: GPL-2.0+ +/dts-v1/; + +/ { + binman { + fit { + images { + u-boot { + encrypted { + content = <&data>; + }; + + data: data { + }; + }; + }; + }; + }; +}; diff --git a/tools/binman/test/292_encrypted_invalid_iv_file.dts b/tools/binman/test/292_encrypted_invalid_iv_file.dts new file mode 100644 index 0000000000..1764d5e503 --- /dev/null +++ b/tools/binman/test/292_encrypted_invalid_iv_file.dts @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0+ +/dts-v1/; + +/ { + binman { + fit { + images { + u-boot { + blob: blob { + filename = "blobfile"; + }; + + encrypted { + content = <&blob>; + algo = "some-algo"; + key-source = "key"; + iv-filename = "invalid-iv-file"; + }; + }; + }; + }; + }; +}; diff --git a/tools/binman/test/293_encrypted_missing_key.dts b/tools/binman/test/293_encrypted_missing_key.dts new file mode 100644 index 0000000000..9d342d6f45 --- /dev/null +++ b/tools/binman/test/293_encrypted_missing_key.dts @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + fit { + description = "test desc"; + + images { + u-boot { + blob: blob { + filename = "blobfile"; + }; + + encrypted { + content = <&blob>; + algo = "algo-name"; + iv-filename = "encrypted-file.iv"; + }; + }; + }; + }; + }; +}; diff --git a/tools/binman/test/294_encrypted_key_source.dts b/tools/binman/test/294_encrypted_key_source.dts new file mode 100644 index 0000000000..d2529b9c3a --- /dev/null +++ b/tools/binman/test/294_encrypted_key_source.dts @@ -0,0 +1,29 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + fit { + description = "test desc"; + + images { + u-boot { + blob: blob { + filename = "blobfile"; + }; + + encrypted { + content = <&blob>; + algo = "algo-name"; + key-source = "key-source-value"; + iv-filename = "encrypted-file.iv"; + }; + }; + }; + }; + }; +}; diff --git a/tools/binman/test/295_encrypted_key_file.dts b/tools/binman/test/295_encrypted_key_file.dts new file mode 100644 index 0000000000..71f1ab47b1 --- /dev/null +++ b/tools/binman/test/295_encrypted_key_file.dts @@ -0,0 +1,29 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + fit { + description = "test desc"; + + images { + u-boot { + blob: blob { + filename = "blobfile"; + }; + + encrypted { + content = <&blob>; + algo = "algo-name"; + iv-filename = "encrypted-file.iv"; + key-filename = "encrypted-file.key"; + }; + }; + }; + }; + }; +};
Hi Christian,
Changes in v4:
Changes in v3:
Changes in v2:
nit below:
- def testEncryptedNoAlgo(self):
self.assertIn(
str(e.exception))
- def testEncryptedInvalidIvfile(self):
Please can you add a one-line comment to all of these function?
str(e.exception))
- def testEncryptedMissingKey(self):
self.assertIn(
str(e.exception))
- def testEncryptedKeySource(self):
dtb.Scan()
- def testEncryptedKeyFile(self):
dtb.Scan()
Jonas Karlman
Taedcke, Christian
