[U-Boot] [PATCH] Kconfig: BOOTCOMMAND: Define default set of boot commands in Kconfig
This patch gives an opportunity to override the defined CONFIG_BOOTCOMMAND (at <board_config.h> files) with set of commands defined in board _defconfig file.
Rationale: This change allows having two different u-boot builds - one for production and one (far more larger) for factory setup.
Signed-off-by: Lukasz Majewski lukma@denx.de --- cmd/Kconfig | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index d6d130e..e5c12a9 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -30,6 +30,21 @@ config SYS_PROMPT This string is displayed in the command line to the left of the cursor.
+config BOOTCMD_OVERRIDE + bool "Override default CONFIG_BOOTCOMMAND define" + help + This option allows overriding the CONFIG_BOOTCOMMAND define + from the Kconfig as many boards define their default set of + commands with CONFIG_BOOTCOMMAND. + +config BOOTCOMMAND + string "Default boot commands" + depends on BOOTCMD_OVERRIDE + default "" + help + This string contains the set of u-boot commands to be executed + by default. + menu "Autoboot options"
config AUTOBOOT
I don't get it, sorry. We need to move CONFIG_BOOTCOMMAND into Kconfig with some other logic so that distro_bootcmd stuff works.
The state of the art: ---------------------
Many boards use CONFIG_BOOTCOMMAND as a set of commands to be executed at boot time:
bootcmd=CONFIG_BOOTCOMMAND
One notable user of it is config_distro_bootcmd.h
Rationale: ----------
With this patch I can:
1. Setup one set of commands to be executed by default - e.g.:
bootcmd="run boot_mmc"
and
2. Have other defconfig - e.g. <my_board>_factory_defconfig, which enables some extra stuff (like USB, gadget, gpt write, etc) and is used solely for factory flashing.
By having the opportunity to override CONFIG_BOOTCOMMAND in Kconfig, I can use the same code base and just adjust Kconfig for board.
What do you mean by "some other logic"?
Right.
Rationale:
- Setup one set of commands to be executed by default - e.g.:
and
- Have other defconfig - e.g. <my_board>_factory_defconfig, which
Well, CONFIG_BOOTCOMMAND needs to be moved to Kconfig itself. Figuring out some of the "how" will take a little work. And a little re-organization. But that needs doing.
Right.
Rationale:
and
Cannot we start with the approach proposed by this commit?
How would you see the rework done?
Right.
Rationale:
and
I'd like to see something that tries to move CONFIG_BOOTCOMMAND around. Move the distro boot things into include/environment/ and use the post-processed command as value in configs/*_defconfig as fits, or put things into something else in include/environment/ for other repeated but not distro boot commands.
Right.
Rationale:
and
The proposed above changes are orthogonal to this patch.
This patch _only_ gives the opportunity to override current BOOTCOMMAND settings. This functionality allows the same code base for two distinct u-boot builds - namely factory (for flashing) and production one.
Such approach is very convenient with OE builds.
Hi Tom,
Right.
Rationale:
and
I've not received any reply from you regarding following argument for this patch:
The whole discussion can be find at: https://patchwork.ozlabs.org/patch/812174/
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
On Fri, Oct 27, 2017 at 02:04:53PM +0200, Lukasz Majewski wrote:
Hi Tom,
>This patch gives an opportunity to override the defined >CONFIG_BOOTCOMMAND (at <board_config.h> files) with set of >commands defined in board _defconfig file. > >Rationale: This change allows having two different u-boot >builds - one for production and one (far more larger) for >factory setup. > >Signed-off-by: Lukasz Majewski lukma@denx.de
Right.
Rationale:
and
The problem I see is that we should instead move CONFIG_BOOTCOMMAND to Kconfig and OE/similar can override bootcmd via .cfg or similar. To that end, I've started the migration at least for distro_bootcmd and some of the cases where it's not just 'run distro_bootcmd' being used. I hope to post it shortly, once I've migrated a few more options.
Hi Tom,
Hi Tom,
On 09/11/2017 07:31 PM, Tom Rini wrote: >On Sun, Sep 10, 2017 at 08:25:02PM +0200, Lukasz Majewski >wrote: > >>This patch gives an opportunity to override the defined >>CONFIG_BOOTCOMMAND (at <board_config.h> files) with set of >>commands defined in board _defconfig file. >> >>Rationale: This change allows having two different u-boot >>builds - one for production and one (far more larger) for >>factory setup. >> >>Signed-off-by: Lukasz Majewski lukma@denx.de > >I don't get it, sorry. We need to move CONFIG_BOOTCOMMAND >into Kconfig with some other logic so that distro_bootcmd >stuff works. >
Right.
Rationale:
and
I see. Thanks for update on this topic.
Lukasz Majewski
Lukasz Majewski
Łukasz Majewski
