[U-Boot] Command to Assign a RAM value to a variable
In order to perform a crc32 integrity check of a zImage, I would like to read the zImage length from its header (offset 0x2C). To perform this I would need a command letting me to set an environment variable to the value of a certain RAM address.
If this command is not available (maybe I'm just not able to find it out!) and if there is no other way for my purpose, I can try implementing it.
I would need something like # m2v[.b, .w, .l] <variable_name> <ram address>
Waiting for comments, Davide
________________________________
Ce message, ainsi que tous les fichiers joints à ce message, peuvent contenir des informations sensibles et/ ou confidentielles ne devant pas être divulguées. Si vous n'êtes pas le destinataire de ce message (ou que vous recevez ce message par erreur), nous vous remercions de le notifier immédiatement à son expéditeur, et de détruire ce message. Toute copie, divulgation, modification, utilisation ou diffusion, non autorisée, directe ou indirecte, de tout ou partie de ce message, est strictement interdite.
This e-mail, and any document attached hereby, may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorized, direct or indirect, copying, disclosure, distribution or other use of the material or parts thereof is strictly forbidden.
Hi Davide,
On Tue, May 5, 2015 at 9:35 AM, Davide BONFANTI davide.bonfanti@bticino.it wrote:
See the command called setexpr. Just #define CONFIG_CMD_SETEXPR
setexpr[.b, .w, .l] name [*]value - load a value into a variable
Cheers, -Joe
Davide BONFANTI
Joe Hershberger
