[U-Boot-Users] MAKEALL patch
Corection MAKEALL script.
Signed of by: Michal Simek monstr@monstr.eu
diff --git a/MAKEALL b/MAKEALL index 127faa8..2b44244 100755 --- a/MAKEALL +++ b/MAKEALL @@ -348,7 +348,7 @@ build_target() { ${MAKE} ${JOBS} all 2>&1 >${LOG_DIR}/$target.MAKELOG \ | tee ${LOG_DIR}/$target.ERR
- ${CROSS_COMPILE:-ppc_8xx-}size ${BUILD_DIR}/u-boot \ + ${CROSS_COMPILE}size ${BUILD_DIR}/u-boot \ | tee -a ${LOG_DIR}/$target.MAKELOG }
- ${CROSS_COMPILE}size ${BUILD_DIR}/u-boot \ | tee -a ${LOG_DIR}/$target.MAKELOG
What is the specific bug you intend to fix here? Using ppc_8xx-size in case CROSS_COMPILE is not set is not worse than using the native "size" command, it seems. Actually, given the fact that the majority supported of boards are PowerPC, it is right in most cases.
So why do you think it should be changed?
Hi Wolfgang,
I think size utility do the same function as ppc_8xx-size. I tried 4 cross tools and the result is the same. (Logs are below) And in man page you can find: "size can automatically recognize many formats" in --target option.
From my point of view is size utility better than error message.
And I think that many developers use different cross tools than ppc_8xx-.
Best regards, Michal Simek
microblaze@monstr u-boot-microblaze]$ ./MAKEALL xupv2p Configuring for xupv2p board... ./MAKEALL: line 351: ppc_8xx-size: command not found
[microblaze@monstr u-boot-microblaze]$ ./MAKEALL xupv2p Configuring for xupv2p board... text data bss dec hex filename 89326 21479 214916 325721 4f859 ./u-boot
[microblaze@monstr u-boot-microblaze]$ size u-boot text data bss dec hex filename 89326 21479 214916 325721 4f859 u-boot
[microblaze@monstr u-boot-microblaze]$ microblaze-uclinux-size u-boot text data bss dec hex filename 89326 21479 214916 325721 4f859 u-boot
[microblaze@monstr u-boot-microblaze]$ powerpc-405-linux-gnu-size u-boot text data bss dec hex filename 89326 21479 214916 325721 4f859 u-boot [microblaze@monstr u-boot-microblaze]$
[microblaze@monstr bin]$ powerpc-linux-uclibc-size u-boot text data bss dec hex filename 89326 21479 214916 325721 4f859 u-boot [microblaze@monstr bin]$
It depends on the build options if it supports the target architecture or not.
The "in --target option" is the important part here.
Which error message? If you set CROSS_COMPILE to any sane value for your system, or set it to the empty string, no error will be caused.
Please show which error you are trying to fix.
ive posted this patch a few times but never gotten a response ...
this code is wrong because ppc_8xx-size rarely exists for people who are not doing ppc development while size almost always exists.
so while the toplevel Makefile will setup a default CROSS prefix based on the board config, the MAKEALL script does not have access to that information, so for everyone who lacks ppc_8xx-size, using the MAKEALL script yields annoying broken output by default.
consider my typical use case: ./MAKEALL blackfin i do not have CROSS_COMPILE set in my env and this is OK because the top level Makefile sets it by default to bfin-uclinux-. -mike
Thanks Mike.
Michal Simek
Mike Frysinger
