[U-Boot] [PATCH 1/2] net: sh_eth: add cache handling
Some CPU needs cache handling. So this patch add the config of CONFIG_SH_ETHER_CACHE_WRITEBACK, and it calls wback function.
Signed-off-by: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com --- drivers/net/sh_eth.c | 9 +++++++++ 1 files changed, 9 insertions(+), 0 deletions(-)
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 86cc324..53d918d 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -36,6 +36,12 @@ #ifndef CONFIG_SH_ETHER_PHY_ADDR # error "Please define CONFIG_SH_ETHER_PHY_ADDR" #endif +#ifdef CONFIG_SH_ETHER_CACHE_WRITEBACK +#define flush_cache_wback(addr, len) \ + dcache_wback_range((u32)addr, (u32)(addr + len - 1)) +#else +#define flush_cache_wback(...) +#endif
#define SH_ETH_PHY_DELAY 50000
@@ -197,6 +203,7 @@ int sh_eth_send(struct eth_device *dev, volatile void *packet, int len) }
/* Update tx descriptor */ + flush_cache_wback(packet, len); port_info->tx_desc_cur->td2 = ADDR_TO_PHY(packet); port_info->tx_desc_cur->td1 = len << 16; /* Must preserve the end of descriptor list indication */ @@ -312,6 +319,7 @@ static int sh_eth_tx_desc_init(struct sh_eth_dev *eth)
tmp_addr = (u32) (((int)port_info->tx_desc_malloc + TX_DESC_SIZE - 1) & ~(TX_DESC_SIZE - 1)); + flush_cache_wback(tmp_addr, NUM_TX_DESC * sizeof(struct tx_desc_s)); /* Make sure we use a P2 address (non-cacheable) */ port_info->tx_desc_base = (struct tx_desc_s *)ADDR_TO_P2(tmp_addr); port_info->tx_desc_cur = port_info->tx_desc_base; @@ -361,6 +369,7 @@ static int sh_eth_rx_desc_init(struct sh_eth_dev *eth)
tmp_addr = (u32) (((int)port_info->rx_desc_malloc + RX_DESC_SIZE - 1) & ~(RX_DESC_SIZE - 1)); + flush_cache_wback(tmp_addr, NUM_RX_DESC * sizeof(struct rx_desc_s)); /* Make sure we use a P2 address (non-cacheable) */ port_info->rx_desc_base = (struct rx_desc_s *)ADDR_TO_P2(tmp_addr);
Applied, thank. Nobuhiro
Dear Nobuhiro Iwamatsu,
Applied, thank.
You are a bit fast. Network code should go throughthe network custodian, or at least it requires his ACK.
Dear Yoshihiro Shimoda,
New config options must be documented in the README.
Dear Wolfgang Denk,
I will document about this option in the README. The README isn't written about the driver now, so I will document about this driver first.
Best regards, Yoshihiro Shimoda
Nobuhiro Iwamatsu
Yoshihiro Shimoda
