Re: [U-Boot] [PATCH v2 1/2] Exynos5420: Introduce support for the Peach-Pit board
Hi Simon,
Hi Akshay,
On 26 May 2014 03:33, Akshay Saraswat akshay.s@samsung.com wrote:
Hi Simon,
Hi Akshay,
On 21 May 2014 23:23, Akshay Saraswat akshay.s@samsung.com wrote:
While the Exynos5420 chip is used in both Smdk5420 and in the Peach-Pit line of devices, there could be other boards using the same chip, so a common configuration file is being added (exynos5420.h) as well as two common device tree files (exynos54xx.dtsi & exynos5420.dtsi).
The peach board as declared in boards.cfg is a copy of smdk5420 declaration. The configuration files are similar, but define different default device trees, console serial ports and prompts.
The device tree files for smdk5420 and peach-pit inherit from the same common file.
Signed-off-by: Vadim Bendebury vbendeb@chromium.org Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Simon Glass sjg@chromium.org
This looks good to me. I think you might have an extra space in the last column of your boards.cfg addition, and CONFIG_CHROMEOS_PEACH might not be needed.
Will fix these in the next version.
But I can't get pit to boot with these patches - it hangs in SPL. Do you know what is going on?
For me, these patches are working fine. I have tested them over three different pit boards. I am not sure what could be wrong. I will try over more of those boards, if I witness something like this I will update.
I am not actually using the latest Pit hardware, although what I have works fine with the Chromium tree. I suppose it could be a BL1 problems, also I am using 'crosfw' (and thus cros_bundle_firmware) to write to the board. If you have any ideas let me know, but it shouldn't hold up your patches. It just prevents me from adding 'Tested-by' to your patches.
I tested over variety of pit boards. And also, I am using the same BL1 what we used for chromebooks. Definitely, this abnormal boot behaviour is not because of that. But yes I am not doing emerge and I am not using 'crosfw' because I think it will need few other changes. So probably, this is why these patches are not booting. I just did "make peach-pit_config" & "make -j32".
Regards, Akshay Saraswat
Akshay Saraswat
