Re: [U-Boot] [PATCH] ARM: tegra: add Jetson TK1 board
On 03/26/2014 02:59 PM, Tom Warren wrote:
I'll fix it on application. Pinmux changes and this patch should be in/tested late today, and if it looks good to you I'll issue a PR to Albert.
Aren't you only sending "ARM: tegra: make all I2C ports open-drain" for 2014.04? I was assuming the other pinmux driver change would all go into the next release, since they were posted well after the merge window.
-----Original Message----- From: Stephen Warren [mailto:swarren@wwwdotorg.org] Sent: Tuesday, March 25, 2014 12:17 PM To: Wolfgang Denk; Tom Warren Cc: u-boot@lists.denx.de; Simon Glass; Stephen Warren Subject: Re: [U-Boot] [PATCH] ARM: tegra: add Jetson TK1 board
On 03/25/2014 01:13 PM, Wolfgang Denk wrote:
Dear Stephen,
In message <1395769173-8143-1-git-send-email-
swarren@wwwdotorg.org> you wrote:
Jetson TK1 is an NVIDIA Tegra124 reference board, which shares much of its design with Venice2.
+++ b/include/configs/jetson-tk1.h @@ -0,0 +1,79 @@ +/*
- (C) Copyright 2013-2014
- NVIDIA Corporation <www.nvidia.com>
- SPDX-License-Identifier: GPL-2.0
Is there any specific reason this is not GPL-2.0+ ?
Oops. I evidently cut/paste from the wrong place. Please consider that to say GPL-2.0+. Tom, can you fix this while applying, or do you want a repost (I'd probably hold off on a repost until after 2014.04 is out in case there are any other comments).
-- nvpublic
Stephen Warren
