[U-Boot] [PATCH v5] socfpga: Adding Freeze Controller driver
Adding Freeze Controller driver. All HPS IOs need to be in freeze state during pin mux or IO buffer configuration. It is to avoid any glitch which might happen during the configuration from propagating to external devices.
Signed-off-by: Chin Liang See clsee@altera.com Cc: Wolfgang Denk wd@denx.de CC: Pavel Machek pavel@denx.de Cc: Dinh Nguyen dinguyen@altera.com Cc: Tom Rini trini@ti.com Cc: Albert Aribaud albert.u.boot@aribaud.net --- Changes for v5 - Rebase with latest v2014.01-rc1 Changes for v4 - Removed additional lines - Single function call to freeze and thaw all channels Changes for v3 - Removed unused macro in freeze_controller.h Changes for v2 - Removed FREEZE_CONTROLLER_FSM_HW - Removed the get_timer_count_masked and convert to use delay in us - Used shorter local variables --- arch/arm/cpu/armv7/socfpga/Makefile | 2 +- arch/arm/cpu/armv7/socfpga/freeze_controller.c | 216 ++++++++++++++++++++ arch/arm/cpu/armv7/socfpga/spl.c | 9 + .../include/asm/arch-socfpga/freeze_controller.h | 50 +++++ 4 files changed, 276 insertions(+), 1 deletion(-) create mode 100644 arch/arm/cpu/armv7/socfpga/freeze_controller.c create mode 100644 arch/arm/include/asm/arch-socfpga/freeze_controller.h
diff --git a/arch/arm/cpu/armv7/socfpga/Makefile b/arch/arm/cpu/armv7/socfpga/Makefile index dac2bbd..3e84a0c 100644 --- a/arch/arm/cpu/armv7/socfpga/Makefile +++ b/arch/arm/cpu/armv7/socfpga/Makefile @@ -9,4 +9,4 @@
obj-y := lowlevel_init.o obj-y += misc.o timer.o reset_manager.o system_manager.o -obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o diff --git a/arch/arm/cpu/armv7/socfpga/freeze_controller.c b/arch/arm/cpu/armv7/socfpga/freeze_controller.c new file mode 100644 index 0000000..330b4aa --- /dev/null +++ b/arch/arm/cpu/armv7/socfpga/freeze_controller.c @@ -0,0 +1,216 @@ +/* + * Copyright (C) 2013 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/freeze_controller.h> +#include <asm/arch/timer.h> +#include <asm/errno.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_freeze_controller *freeze_controller_base = + (void *)(SOCFPGA_SYSMGR_ADDRESS + SYSMGR_FRZCTRL_ADDRESS); + +/* + * Default state from cold reset is FREEZE_ALL; the global + * flag is set to TRUE to indicate the IO banks are frozen + */ +static uint32_t frzctrl_channel_freeze[FREEZE_CHANNEL_NUM] + = { FREEZE_CTRL_FROZEN, FREEZE_CTRL_FROZEN, + FREEZE_CTRL_FROZEN, FREEZE_CTRL_FROZEN}; + +/* Freeze HPS IOs */ +void sys_mgr_frzctrl_freeze_req(void) +{ + u32 ioctrl_reg_offset; + u32 reg_value; + u32 reg_cfg_mask; + u32 channel_id; + + /* select software FSM */ + writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_SW, &freeze_controller_base->src); + + /* Freeze channel 0 to 2 */ + for (channel_id = 0; channel_id <= 2; channel_id++) { + ioctrl_reg_offset = (u32)( + &freeze_controller_base->vioctrl + + (channel_id << SYSMGR_FRZCTRL_VIOCTRL_SHIFT)); + + /* + * Assert active low enrnsl, plniotri + * and niotri signals + */ + reg_cfg_mask = + SYSMGR_FRZCTRL_VIOCTRL_SLEW_MASK + | SYSMGR_FRZCTRL_VIOCTRL_WKPULLUP_MASK + | SYSMGR_FRZCTRL_VIOCTRL_TRISTATE_MASK; + clrbits_le32(ioctrl_reg_offset, reg_cfg_mask); + + /* + * Note: Delay for 20ns at min + * Assert active low bhniotri signal and de-assert + * active high csrdone + */ + reg_cfg_mask + = SYSMGR_FRZCTRL_VIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_VIOCTRL_CFG_MASK; + clrbits_le32(ioctrl_reg_offset, reg_cfg_mask); + + /* Set global flag to indicate channel is frozen */ + frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_FROZEN; + } + + /* Freeze channel 3 */ + /* + * Assert active low enrnsl, plniotri and + * niotri signals + */ + reg_cfg_mask + = SYSMGR_FRZCTRL_HIOCTRL_SLEW_MASK + | SYSMGR_FRZCTRL_HIOCTRL_WKPULLUP_MASK + | SYSMGR_FRZCTRL_HIOCTRL_TRISTATE_MASK; + clrbits_le32(&freeze_controller_base->hioctrl, reg_cfg_mask); + + /* + * assert active low bhniotri & nfrzdrv signals, + * de-assert active high csrdone and assert + * active high frzreg and nfrzdrv signals + */ + reg_value = readl(&freeze_controller_base->hioctrl); + reg_cfg_mask + = SYSMGR_FRZCTRL_HIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_HIOCTRL_CFG_MASK; + reg_value + = (reg_value & ~reg_cfg_mask) + | SYSMGR_FRZCTRL_HIOCTRL_REGRST_MASK + | SYSMGR_FRZCTRL_HIOCTRL_OCTRST_MASK; + writel(reg_value, &freeze_controller_base->hioctrl); + + /* + * assert active high reinit signal and de-assert + * active high pllbiasen signals + */ + reg_value = readl(&freeze_controller_base->hioctrl); + reg_value + = (reg_value & + ~SYSMGR_FRZCTRL_HIOCTRL_OCT_CFGEN_CALSTART_MASK) + | SYSMGR_FRZCTRL_HIOCTRL_DLLRST_MASK; + writel(reg_value, &freeze_controller_base->hioctrl); + + /* Set global flag to indicate channel is frozen */ + frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_FROZEN; +} + +/* Unfreeze/Thaw HPS IOs */ +void sys_mgr_frzctrl_thaw_req(void) +{ + u32 ioctrl_reg_offset; + u32 reg_cfg_mask; + u32 reg_value; + u32 channel_id; + + /* select software FSM */ + writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_SW, &freeze_controller_base->src); + + /* Thaw channel 0 to 2 */ + for (channel_id = 0; channel_id <= 2; channel_id++) { + ioctrl_reg_offset + = (u32)(&freeze_controller_base->vioctrl + + (channel_id << SYSMGR_FRZCTRL_VIOCTRL_SHIFT)); + + /* + * Assert active low bhniotri signal and + * de-assert active high csrdone + */ + reg_cfg_mask + = SYSMGR_FRZCTRL_VIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_VIOCTRL_CFG_MASK; + setbits_le32(ioctrl_reg_offset, reg_cfg_mask); + + /* + * Note: Delay for 20ns at min + * de-assert active low plniotri and niotri signals + */ + reg_cfg_mask + = SYSMGR_FRZCTRL_VIOCTRL_WKPULLUP_MASK + | SYSMGR_FRZCTRL_VIOCTRL_TRISTATE_MASK; + setbits_le32(ioctrl_reg_offset, reg_cfg_mask); + + /* + * Note: Delay for 20ns at min + * de-assert active low enrnsl signal + */ + setbits_le32(ioctrl_reg_offset, + SYSMGR_FRZCTRL_VIOCTRL_SLEW_MASK); + + /* Set global flag to indicate channel is thawed */ + frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_THAWED; + } + + /* Thaw channel 3 */ + /* de-assert active high reinit signal */ + clrbits_le32(&freeze_controller_base->hioctrl, + SYSMGR_FRZCTRL_HIOCTRL_DLLRST_MASK); + + /* + * Note: Delay for 40ns at min + * assert active high pllbiasen signals + */ + setbits_le32(&freeze_controller_base->hioctrl, + SYSMGR_FRZCTRL_HIOCTRL_OCT_CFGEN_CALSTART_MASK); + + /* + * Delay 1000 intosc. intosc is based on eosc1 + * Use worst case which is fatest eosc1=50MHz, delay required + * is 1/50MHz * 1000 = 20us + */ + udelay(20); + + /* + * de-assert active low bhniotri signals, + * assert active high csrdone and nfrzdrv signal + */ + reg_value = readl(&freeze_controller_base->hioctrl); + reg_value = (reg_value + | SYSMGR_FRZCTRL_HIOCTRL_BUSHOLD_MASK + | SYSMGR_FRZCTRL_HIOCTRL_CFG_MASK) + & ~SYSMGR_FRZCTRL_HIOCTRL_OCTRST_MASK; + writel(reg_value, &freeze_controller_base->hioctrl); + + /* + * Delay 33 intosc + * Use worst case which is fatest eosc1=50MHz, delay required + * is 1/50MHz * 33 = 660ns ~= 1us + */ + udelay(1); + + /* de-assert active low plniotri and niotri signals */ + reg_cfg_mask + = SYSMGR_FRZCTRL_HIOCTRL_WKPULLUP_MASK + | SYSMGR_FRZCTRL_HIOCTRL_TRISTATE_MASK; + + setbits_le32(&freeze_controller_base->hioctrl, reg_cfg_mask); + + /* + * Note: Delay for 40ns at min + * de-assert active high frzreg signal + */ + clrbits_le32(&freeze_controller_base->hioctrl, + SYSMGR_FRZCTRL_HIOCTRL_REGRST_MASK); + + /* + * Note: Delay for 40ns at min + * de-assert active low enrnsl signal + */ + setbits_le32(&freeze_controller_base->hioctrl, + SYSMGR_FRZCTRL_HIOCTRL_SLEW_MASK); + + /* Set global flag to indicate channel is thawed */ + frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_THAWED; +} + diff --git a/arch/arm/cpu/armv7/socfpga/spl.c b/arch/arm/cpu/armv7/socfpga/spl.c index 74bceab..36a00c3 100644 --- a/arch/arm/cpu/armv7/socfpga/spl.c +++ b/arch/arm/cpu/armv7/socfpga/spl.c @@ -13,6 +13,7 @@ #include <asm/arch/reset_manager.h> #include <spl.h> #include <asm/arch/system_manager.h> +#include <asm/arch/freeze_controller.h>
@@ -27,6 +28,10 @@ u32 spl_boot_device(void) void spl_board_init(void) { #ifndef CONFIG_SOCFPGA_VIRTUAL_TARGET + debug("Freezing all I/O banks\n"); + /* freeze all IO banks */ + sys_mgr_frzctrl_freeze_req(); + /* configure the pin muxing through system manager */ sysmgr_pinmux_init(); #endif /* CONFIG_SOCFPGA_VIRTUAL_TARGET */ @@ -34,6 +39,10 @@ void spl_board_init(void) /* de-assert reset for peripherals and bridges based on handoff */ reset_deassert_peripherals_handoff();
+ debug("Unfreezing/Thaw all I/O banks\n"); + /* unfreeze / thaw all IO banks */ + sys_mgr_frzctrl_thaw_req(); + /* enable console uart printing */ preloader_console_init(); } diff --git a/arch/arm/include/asm/arch-socfpga/freeze_controller.h b/arch/arm/include/asm/arch-socfpga/freeze_controller.h new file mode 100644 index 0000000..120f20e --- /dev/null +++ b/arch/arm/include/asm/arch-socfpga/freeze_controller.h @@ -0,0 +1,50 @@ +/* + * Copyright (C) 2013 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _FREEZE_CONTROLLER_H_ +#define _FREEZE_CONTROLLER_H_ + +struct socfpga_freeze_controller { + u32 vioctrl; + u32 padding[3]; + u32 hioctrl; + u32 src; + u32 hwctrl; +}; + +#define FREEZE_CHANNEL_NUM (4) + +typedef enum { + FREEZE_CTRL_FROZEN = 0, + FREEZE_CTRL_THAWED = 1 +} FREEZE_CTRL_CHAN_STATE; + +#define SYSMGR_FRZCTRL_ADDRESS 0x40 +#define SYSMGR_FRZCTRL_SRC_VIO1_ENUM_SW 0x0 +#define SYSMGR_FRZCTRL_SRC_VIO1_ENUM_HW 0x1 +#define SYSMGR_FRZCTRL_VIOCTRL_SLEW_MASK 0x00000010 +#define SYSMGR_FRZCTRL_VIOCTRL_WKPULLUP_MASK 0x00000008 +#define SYSMGR_FRZCTRL_VIOCTRL_TRISTATE_MASK 0x00000004 +#define SYSMGR_FRZCTRL_VIOCTRL_BUSHOLD_MASK 0x00000002 +#define SYSMGR_FRZCTRL_VIOCTRL_CFG_MASK 0x00000001 +#define SYSMGR_FRZCTRL_HIOCTRL_SLEW_MASK 0x00000010 +#define SYSMGR_FRZCTRL_HIOCTRL_WKPULLUP_MASK 0x00000008 +#define SYSMGR_FRZCTRL_HIOCTRL_TRISTATE_MASK 0x00000004 +#define SYSMGR_FRZCTRL_HIOCTRL_BUSHOLD_MASK 0x00000002 +#define SYSMGR_FRZCTRL_HIOCTRL_CFG_MASK 0x00000001 +#define SYSMGR_FRZCTRL_HIOCTRL_REGRST_MASK 0x00000080 +#define SYSMGR_FRZCTRL_HIOCTRL_OCTRST_MASK 0x00000040 +#define SYSMGR_FRZCTRL_HIOCTRL_OCT_CFGEN_CALSTART_MASK 0x00000100 +#define SYSMGR_FRZCTRL_HIOCTRL_DLLRST_MASK 0x00000020 +#define SYSMGR_FRZCTRL_HWCTRL_VIO1REQ_MASK 0x00000001 +#define SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_ENUM_FROZEN 0x2 +#define SYSMGR_FRZCTRL_HWCTRL_VIO1STATE_ENUM_THAWED 0x1 +#define SYSMGR_FRZCTRL_VIOCTRL_SHIFT 0x2 + +void sys_mgr_frzctrl_freeze_req(void); +void sys_mgr_frzctrl_thaw_req(void); + +#endif /* _FREEZE_CONTROLLER_H_ */
Hi Chin,
Changes for v5
Changes for v4
Changes for v3
Changes for v2
- Copyright (C) 2013 Altera Corporation <www.altera.com>
- Default state from cold reset is FREEZE_ALL; the global
- flag is set to TRUE to indicate the IO banks are frozen
- = { FREEZE_CTRL_FROZEN, FREEZE_CTRL_FROZEN,
- FREEZE_CTRL_FROZEN, FREEZE_CTRL_FROZEN};
- u32 ioctrl_reg_offset;
- u32 reg_value;
- u32 reg_cfg_mask;
- u32 channel_id;
- /* select software FSM */
- writel(SYSMGR_FRZCTRL_SRC_VIO1_ENUM_SW, &freeze_controller_base->src);
- /* Freeze channel 0 to 2 */
- for (channel_id = 0; channel_id <= 2; channel_id++) {
reg_cfg_mask =
reg_cfg_mask
- /* Freeze channel 3 */
* niotri signals
- reg_cfg_mask
- clrbits_le32(&freeze_controller_base->hioctrl, reg_cfg_mask);
- reg_value = readl(&freeze_controller_base->hioctrl);
- reg_cfg_mask
- reg_value
- writel(reg_value, &freeze_controller_base->hioctrl);
- reg_value
= (reg_value &
- /* Set global flag to indicate channel is frozen */
- frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_FROZEN;
- u32 reg_cfg_mask;
- u32 reg_value;
- u32 channel_id;
- /* Thaw channel 0 to 2 */
ioctrl_reg_offset
reg_cfg_mask
reg_cfg_mask
- /* Thaw channel 3 */
- /* de-assert active high reinit signal */
- setbits_le32(&freeze_controller_base->hioctrl,
- udelay(20);
- reg_value = (reg_value
* Delay 33 intosc
- udelay(1);
- /* de-assert active low plniotri and niotri signals */
- reg_cfg_mask
- setbits_le32(&freeze_controller_base->hioctrl, reg_cfg_mask);
- /* Set global flag to indicate channel is thawed */
- frzctrl_channel_freeze[channel_id] = FREEZE_CTRL_THAWED;
- debug("Freezing all I/O banks\n");
- /* freeze all IO banks */
- sys_mgr_frzctrl_freeze_req();
- /* configure the pin muxing through system manager */ sysmgr_pinmux_init();
- debug("Unfreezing/Thaw all I/O banks\n");
- /* unfreeze / thaw all IO banks */
- sys_mgr_frzctrl_thaw_req();
- /* enable console uart printing */ preloader_console_init();
- u32 vioctrl;
- u32 padding[3];
- u32 hioctrl;
- u32 src;
- u32 hwctrl;
+typedef enum {
- FREEZE_CTRL_FROZEN = 0,
- FREEZE_CTRL_THAWED = 1
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Chin Liang See
