[U-Boot] [PATCH 01/24] usb: add device connection/disconnection detection
Provide a function to detect USB device insertion/removal in order to avoid having to do USB enumeration in a tight loop when trying to detect peripheral hotplugging.
Signed-off-by: Vincent Palatin vpalatin@chromium.org
Reviewed-by: Stefan Reinauer reinauer@chromium.org Tested-by: Stefan Reinauer reinauer@chromium.org Signed-off-by: Simon Glass sjg@chromium.org ---
common/usb.c | 26 ++++++++++++++++++++++++++ common/usb_hub.c | 2 +- include/usb.h | 2 ++ 3 files changed, 29 insertions(+), 1 deletion(-)
diff --git a/common/usb.c b/common/usb.c index a4820d3..bde8f31 100644 --- a/common/usb.c +++ b/common/usb.c @@ -148,6 +148,32 @@ int usb_stop(void) return 0; }
+/****************************************************************************** + * Detect if a USB device has been plugged or unplugged. + */ +int usb_detect_change(void) +{ + int i, j; + int change = 0; + + for (j = 0; j < USB_MAX_DEVICE; j++) { + for (i = 0; i < usb_dev[j].maxchild; i++) { + struct usb_port_status status; + + if (usb_get_port_status(&usb_dev[j], i + 1, + &status) < 0) + /* USB request failed */ + continue; + + if (le16_to_cpu(status.wPortChange) & + USB_PORT_STAT_C_CONNECTION) + change++; + } + } + + return change; +} + /* * disables the asynch behaviour of the control message. This is used for data * transfers that uses the exclusiv access to the control and bulk messages. diff --git a/common/usb_hub.c b/common/usb_hub.c index c9be530..bbed1c8 100644 --- a/common/usb_hub.c +++ b/common/usb_hub.c @@ -79,7 +79,7 @@ static int usb_get_hub_status(struct usb_device *dev, void *data) data, sizeof(struct usb_hub_status), USB_CNTL_TIMEOUT); }
-static int usb_get_port_status(struct usb_device *dev, int port, void *data) +int usb_get_port_status(struct usb_device *dev, int port, void *data) { return usb_control_msg(dev, usb_rcvctrlpipe(dev, 0), USB_REQ_GET_STATUS, USB_DIR_IN | USB_RT_PORT, 0, port, diff --git a/include/usb.h b/include/usb.h index 1984e8f..25dddb8 100644 --- a/include/usb.h +++ b/include/usb.h @@ -265,6 +265,7 @@ int usb_kbd_deregister(int force); /* routines */ int usb_init(void); /* initialize the USB Controller */ int usb_stop(void); /* stop the USB Controller */ +int usb_detect_change(void); /* detect if a USB device has been (un)plugged */
int usb_set_protocol(struct usb_device *dev, int ifnum, int protocol); @@ -290,6 +291,7 @@ int usb_get_class_descriptor(struct usb_device *dev, int ifnum, int usb_clear_halt(struct usb_device *dev, int pipe); int usb_string(struct usb_device *dev, int index, char *buf, size_t size); int usb_set_interface(struct usb_device *dev, int interface, int alternate); +int usb_get_port_status(struct usb_device *dev, int port, void *data);
/* big endian -> little endian conversion */ /* some CPUs are already little endian e.g. the ARM920T */
Support this function with driver model also (CONFIG_DM_USB).
drivers/usb/host/usb-uclass.c | 43 +++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 43 insertions(+)
diff --git a/drivers/usb/host/usb-uclass.c b/drivers/usb/host/usb-uclass.c index 714bc0e..8445a42 100644 --- a/drivers/usb/host/usb-uclass.c +++ b/drivers/usb/host/usb-uclass.c @@ -555,6 +555,49 @@ int usb_scan_device(struct udevice *parent, int port, return 0; }
+/* + * Detect if a USB device has been plugged or unplugged. + */ +int usb_detect_change(void) +{ + struct udevice *hub; + struct uclass *uc; + int change = 0; + int ret; + + ret = uclass_get(UCLASS_USB_HUB, &uc); + if (ret) + return ret; + + uclass_foreach_dev(hub, uc) { + struct usb_device *udev; + struct udevice *dev; + + if (!device_active(hub)) + continue; + for (device_find_first_child(hub, &dev); + dev; + device_find_next_child(&dev)) { + struct usb_port_status status; + + if (!device_active(hub)) + continue; + + udev = dev_get_parentdata(hub); + if (usb_get_port_status(udev, udev->portnr, &status) + < 0) + /* USB request failed */ + continue; + + if (le16_to_cpu(status.wPortChange) & + USB_PORT_STAT_C_CONNECTION) + change++; + } + } + + return change; +} + int usb_child_post_bind(struct udevice *dev) { struct usb_dev_platdata *plat = dev_get_parent_platdata(dev);
Hi Simon,
- Detect if a USB device has been plugged or unplugged.
struct uclass *uc;
int change = 0;
int ret;
if (ret)
return ret;
continue;
You check this here.
dev;
continue;
How can this be true here? Maybe you meant to check if the "dev" was active?
Why parent of the hub? Looking for an upstream hub?
< 0)
continue;
change++;
return change;
int usb_child_post_bind(struct udevice *dev) { struct usb_dev_platdata *plat = dev_get_parent_platdata(dev); --
Thanks, -Joe
We maintain an accumulator for time spent reading from SPI flash, since this can be significant on some platforms. Also add one for decompression time.
include/bootstage.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/bootstage.h b/include/bootstage.h index be44014..fe30ab6 100644 --- a/include/bootstage.h +++ b/include/bootstage.h @@ -195,6 +195,8 @@ enum bootstage_id {
BOOTSTAGE_ID_ACCUM_LCD, BOOTSTAGE_ID_ACCUM_SCSI, + BOOTSTAGE_ID_ACCUM_SPI, + BOOTSTAGE_ID_ACCUM_DECOMP,
/* a few spare for the user, from here */ BOOTSTAGE_ID_USER,
Hi Simon,
Reviewed-by: Joe Hershberger joe.hershberger@ni.com
On 5 May 2015 at 02:27, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Simon,
Reviewed-by: Jagan Teki jteki@openedev.com
Hi Simon,
Applied to u-boot-dm.
This command was missed in the conversion. Add it back for driver model.
common/cmd_i2c.c | 63 +++++++++++++++++++++++++++++++++++++++++++++++++------- 1 file changed, 55 insertions(+), 8 deletions(-)
diff --git a/common/cmd_i2c.c b/common/cmd_i2c.c index ad38cbf..1bc0db8 100644 --- a/common/cmd_i2c.c +++ b/common/cmd_i2c.c @@ -1623,6 +1623,27 @@ int do_edid(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) } #endif /* CONFIG_I2C_EDID */
+#ifdef CONFIG_DM_I2C +static void show_bus(struct udevice *bus) +{ + struct udevice *dev; + + printf("Bus %d:\t%s", bus->req_seq, bus->name); + if (device_active(bus)) + printf(" (active %d)", bus->seq); + printf("\n"); + for (device_find_first_child(bus, &dev); + dev; + device_find_next_child(&dev)) { + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + + printf(" %02x: %s, offset len %x, flags %x\n", + chip->chip_addr, dev->name, chip->offset_len, + chip->flags); + } +} +#endif + /** * do_i2c_show_bus() - Handle the "i2c bus" command-line command * @cmdtp: Command data struct pointer @@ -1632,20 +1653,30 @@ int do_edid(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) * * Returns zero always. */ -#if defined(CONFIG_SYS_I2C) +#if defined(CONFIG_SYS_I2C) || defined(CONFIG_DM_I2C) static int do_i2c_show_bus(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - int i; -#ifndef CONFIG_SYS_I2C_DIRECT_BUS - int j; -#endif - if (argc == 1) { /* show all busses */ +#ifdef CONFIG_DM_I2C + struct udevice *bus; + struct uclass *uc; + int ret; + + ret = uclass_get(UCLASS_I2C, &uc); + if (ret) + return CMD_RET_FAILURE; + uclass_foreach_dev(bus, uc) + show_bus(bus); +#else + int i; + for (i = 0; i < CONFIG_SYS_NUM_I2C_BUSES; i++) { printf("Bus %d:\t%s", i, I2C_ADAP_NR(i)->name); #ifndef CONFIG_SYS_I2C_DIRECT_BUS + int j; + for (j = 0; j < CONFIG_SYS_I2C_MAX_HOPS; j++) { if (i2c_bus[i].next_hop[j].chip == 0) break; @@ -1657,15 +1688,30 @@ static int do_i2c_show_bus(cmd_tbl_t *cmdtp, int flag, int argc, #endif printf("\n"); } +#endif } else { + int i; + /* show specific bus */ i = simple_strtoul(argv[1], NULL, 10); +#ifdef CONFIG_DM_I2C + struct udevice *bus; + int ret; + + ret = uclass_get_device_by_seq(UCLASS_I2C, i, &bus); + if (ret) { + printf("Invalid bus %d: err=%d\n", i, ret); + return CMD_RET_FAILURE; + } + show_bus(bus); +#else if (i >= CONFIG_SYS_NUM_I2C_BUSES) { printf("Invalid bus %d\n", i); return -1; } printf("Bus %d:\t%s", i, I2C_ADAP_NR(i)->name); #ifndef CONFIG_SYS_I2C_DIRECT_BUS + int j; for (j = 0; j < CONFIG_SYS_I2C_MAX_HOPS; j++) { if (i2c_bus[i].next_hop[j].chip == 0) break; @@ -1676,6 +1722,7 @@ static int do_i2c_show_bus(cmd_tbl_t *cmdtp, int flag, int argc, } #endif printf("\n"); +#endif }
return 0; @@ -1835,7 +1882,7 @@ static int do_i2c_reset(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv }
static cmd_tbl_t cmd_i2c_sub[] = { -#if defined(CONFIG_SYS_I2C) +#if defined(CONFIG_SYS_I2C) || defined(CONFIG_DM_I2C) U_BOOT_CMD_MKENT(bus, 1, 1, do_i2c_show_bus, "", ""), #endif U_BOOT_CMD_MKENT(crc32, 3, 1, do_i2c_crc, "", ""), @@ -1902,7 +1949,7 @@ static int do_i2c(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) /***************************************************/ #ifdef CONFIG_SYS_LONGHELP static char i2c_help_text[] = -#if defined(CONFIG_SYS_I2C) +#if defined(CONFIG_SYS_I2C) || defined(CONFIG_DM_I2C) "bus [muxtype:muxaddr:muxchannel] - show I2C bus info\n" #endif "crc32 chip address[.0, .1, .2] count - compute CRC32 checksum\n"
Hi Simon,
printf("\n");
dev;
chip->flags);
+} +#endif
- do_i2c_show_bus() - Handle the "i2c bus" command-line command
- @cmdtp: Command data struct pointer
- Returns zero always.
int i;
int j;
-#endif
struct uclass *uc;
int ret;
if (ret)
show_bus(bus);
+#else
int i;
int j;
int i;
int ret;
if (ret) {
show_bus(bus);
It's too bad we are already on a 3rd model for I2C and the 1st is still kicking around. We have the same problem on the Ethernet phy drivers as soon as I add DM support. I intend to address that one at some point before too long... maybe even before I add DM support. Maybe we need a deadline for this in I2C like we had for common board?
#endif U_BOOT_CMD_MKENT(crc32, 3, 1, do_i2c_crc, "", ""), @@ -1902,7 +1949,7 @@ static int do_i2c(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) /***************************************************/ #ifdef CONFIG_SYS_LONGHELP static char i2c_help_text[] = -#if defined(CONFIG_SYS_I2C) +#if defined(CONFIG_SYS_I2C) || defined(CONFIG_DM_I2C) "bus [muxtype:muxaddr:muxchannel] - show I2C bus info\n" #endif "crc32 chip address[.0, .1, .2] count - compute CRC32 checksum\n" -- 2.2.0.rc0.207.ga3a616c
Cheers, -Joe
Hello Simon,
Am 04.05.2015 19:30, schrieb Simon Glass:
- struct udevice *dev;
- printf("Bus %d:\t%s", bus->req_seq, bus->name);
- if (device_active(bus))
- printf("\n");
- for (device_find_first_child(bus, &dev);
dev;
chip->flags);
+} +#endif
- int i;
- int j;
-#endif
struct uclass *uc;
int ret;
if (ret)
show_bus(bus);
+#else
int i;
- for (i = 0; i < CONFIG_SYS_NUM_I2C_BUSES; i++) { printf("Bus %d:\t%s", i, I2C_ADAP_NR(i)->name); #ifndef CONFIG_SYS_I2C_DIRECT_BUS
int j;
I thought this drops an error, because var j is declared in the middle of code, but just tried it with gcc 4.7.2 and gcc 4.8.1 vor the mgcoge board, drops no warning, so:
Acked-by: Heiko Schocher hs@denx.de
Thanks!
bye, Heiko
int i;
- /* show specific bus */ i = simple_strtoul(argv[1], NULL, 10);
int ret;
if (ret) {
show_bus(bus);
Hi Heiko,
On 5 May 2015 at 23:44, Heiko Schocher hs@denx.de wrote:
Hello Simon,
printf("\n");
dev;
chip->flags);
+} +#endif
int i;
int j;
-#endif
struct uclass *uc;
int ret;
if (ret)
show_bus(bus);
+#else
int i;
#ifndef CONFIG_SYS_I2C_DIRECT_BUSfor (i = 0; i < CONFIG_SYS_NUM_I2C_BUSES; i++) { printf("Bus %d:\t%s", i, I2C_ADAP_NR(i)->name);
int j;
Yes, I probably shouldn't do that.
[snip]
On 6 May 2015 at 08:34, Simon Glass sjg@chromium.org wrote:
Hi Heiko,
Hello Simon,
printf("\n");
dev;
chip->flags);
+} +#endif
int i;
int j;
-#endif
struct uclass *uc;
int ret;
if (ret)
show_bus(bus);
+#else
int i;
int j;
[snip]
Actually this is OK because it is not really in the middle of the code, due to the #ifdef.
We can currently set this but there is no API function to get it. Add one.
drivers/i2c/i2c-uclass.c | 7 +++++++ include/i2c.h | 9 ++++++++- 2 files changed, 15 insertions(+), 1 deletion(-)
diff --git a/drivers/i2c/i2c-uclass.c b/drivers/i2c/i2c-uclass.c index f2e95c0..2dfb435 100644 --- a/drivers/i2c/i2c-uclass.c +++ b/drivers/i2c/i2c-uclass.c @@ -396,6 +396,13 @@ int i2c_set_chip_offset_len(struct udevice *dev, uint offset_len) return 0; }
+int i2c_get_chip_offset_len(struct udevice *dev) +{ + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + + return chip->offset_len; +} + int i2c_deblock(struct udevice *bus) { struct dm_i2c_ops *ops = i2c_get_ops(bus); diff --git a/include/i2c.h b/include/i2c.h index 6fd73fa..9a9e4f7 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -171,8 +171,15 @@ int i2c_get_chip_flags(struct udevice *dev, uint *flagsp); * * @offset_len: New offset length value (typically 1 or 2) */ - int i2c_set_chip_offset_len(struct udevice *dev, uint offset_len); + +/** + * i2c_get_offset_len() - get the offset length for a chip + * + * @return: Current offset length value (typically 1 or 2) + */ +int i2c_get_chip_offset_len(struct udevice *dev); + /** * i2c_deblock() - recover a bus that is in an unknown state *
Hi Simon,
Hello Simon,
Thanks!
Acked-by: Heiko Schocherhs@denx.de
bye, Heiko
- struct dm_i2c_chip *chip = dev_get_parent_platdata(dev);
- return chip->offset_len;
- int i2c_deblock(struct udevice *bus) { struct dm_i2c_ops *ops = i2c_get_ops(bus);
- @offset_len: New offset length value (typically 1 or 2)
- i2c_get_offset_len() - get the offset length for a chip
- @return: Current offset length value (typically 1 or 2)
- i2c_deblock() - recover a bus that is in an unknown state
On 5 May 2015 at 23:37, Heiko Schocher hs@denx.de wrote:
Hello Simon,
Thanks!
As a first step towards converting the TPM system to driver model, allow it to work with CONFIG_DM_I2C.
drivers/tpm/tpm.c | 89 +++++++++++++++++++++++++----- drivers/tpm/tpm_private.h | 3 ++ drivers/tpm/tpm_tis_i2c.c | 134 +++++++++++++++++++++++++++++++--------------- 3 files changed, 170 insertions(+), 56 deletions(-)
diff --git a/drivers/tpm/tpm.c b/drivers/tpm/tpm.c index 31761ec..a650892 100644 --- a/drivers/tpm/tpm.c +++ b/drivers/tpm/tpm.c @@ -34,6 +34,7 @@
#include <config.h> #include <common.h> +#include <dm.h> #include <linux/compiler.h> #include <fdtdec.h> #include <i2c.h> @@ -48,10 +49,14 @@ DECLARE_GLOBAL_DATA_PTR;
/* TPM configuration */ struct tpm { +#ifdef CONFIG_DM_I2C + struct udevice *dev; +#else int i2c_bus; int slave_addr; - char inited; int old_bus; +#endif + char inited; } tpm;
/* Global structure for tpm chip data */ @@ -372,7 +377,7 @@ static unsigned long tpm_calc_ordinal_duration(struct tpm_chip *chip,
static ssize_t tpm_transmit(const unsigned char *buf, size_t bufsiz) { - ssize_t rc; + int rc; u32 count, ordinal; unsigned long start, stop;
@@ -391,9 +396,11 @@ static ssize_t tpm_transmit(const unsigned char *buf, size_t bufsiz) return -E2BIG; }
+ debug("Calling send\n"); rc = chip->vendor.send(chip, (u8 *)buf, count); + debug(" ... done calling send\n"); if (rc < 0) { - error("tpm_transmit: tpm_send: error %zd\n", rc); + error("tpm_transmit: tpm_send: error %d\n", rc); goto out; }
@@ -403,7 +410,7 @@ static ssize_t tpm_transmit(const unsigned char *buf, size_t bufsiz) start = get_timer(0); stop = tpm_calc_ordinal_duration(chip, ordinal); do { - debug("waiting for status...\n"); + debug("waiting for status... %ld %ld\n", start, stop); u8 status = chip->vendor.status(chip); if ((status & chip->vendor.req_complete_mask) == chip->vendor.req_complete_val) { @@ -428,15 +435,30 @@ out_recv: debug("out_recv: reading response...\n"); rc = chip->vendor.recv(chip, (u8 *)buf, TPM_BUFSIZE); if (rc < 0) - error("tpm_transmit: tpm_recv: error %zd\n", rc); + error("tpm_transmit: tpm_recv: error %d\n", rc);
out: return rc; }
+#ifdef CONFIG_DM_I2C +static int tpm_open_dev(struct udevice *dev) +{ + int rc; + + debug("%s: start\n", __func__); + if (g_chip.is_open) + return -EBUSY; + rc = tpm_vendor_init_dev(dev); + if (rc < 0) + g_chip.is_open = 0; + return rc; +} +#else static int tpm_open(uint32_t dev_addr) { int rc; + if (g_chip.is_open) return -EBUSY; rc = tpm_vendor_init(dev_addr); @@ -444,7 +466,7 @@ static int tpm_open(uint32_t dev_addr) g_chip.is_open = 0; return rc; } - +#endif static void tpm_close(void) { if (g_chip.is_open) { @@ -455,6 +477,7 @@ static void tpm_close(void)
static int tpm_select(void) { +#ifndef CONFIG_DM_I2C int ret;
tpm.old_bus = i2c_get_bus_num(); @@ -466,11 +489,13 @@ static int tpm_select(void) return -1; } } +#endif return 0; }
static int tpm_deselect(void) { +#ifndef CONFIG_DM_I2C int ret;
if (tpm.old_bus != i2c_get_bus_num()) { @@ -482,6 +507,7 @@ static int tpm_deselect(void) } } tpm.old_bus = -1; +#endif return 0; }
@@ -493,10 +519,9 @@ static int tpm_deselect(void) */ static int tpm_decode_config(struct tpm *dev) { -#ifdef CONFIG_OF_CONTROL const void *blob = gd->fdt_blob; - int node, parent; - int i2c_bus; + int parent; + int node;
node = fdtdec_next_compatible(blob, 0, COMPAT_INFINEON_SLB9635_TPM); if (node < 0) { @@ -512,15 +537,48 @@ static int tpm_decode_config(struct tpm *dev) debug("%s: Cannot find node parent\n", __func__); return -1; } +#ifdef CONFIG_DM_I2C + struct udevice *bus; + int chip_addr; + int ret; + + /* + * TODO(sjg@chromium.org): Remove this when driver model supports + * TPMs + */ + ret = uclass_get_device_by_of_offset(UCLASS_I2C, parent, &bus); + if (ret) { + debug("Cannot find bus for node '%s: ret=%d'\n", + fdt_get_name(blob, parent, NULL), ret); + return ret; + } + + chip_addr = fdtdec_get_int(blob, node, "reg", -1); + if (chip_addr == -1) { + debug("Cannot find reg property for node '%s: ret=%d'\n", + fdt_get_name(blob, node, NULL), ret); + return ret; + } + /* + * TODO(sjg@chromium.org): Older TPMs will need to use the older method + * in iic_tpm_read() so the offset length needs to be 0 here. + */ + ret = i2c_get_chip(bus, chip_addr, 1, &dev->dev); + if (ret) { + debug("Cannot find device for node '%s: ret=%d'\n", + fdt_get_name(blob, node, NULL), ret); + return ret; + } +#else + int i2c_bus; + i2c_bus = i2c_get_bus_num_fdt(parent); if (i2c_bus < 0) return -1; dev->i2c_bus = i2c_bus; dev->slave_addr = fdtdec_get_addr(blob, node, "reg"); -#else - dev->i2c_bus = CONFIG_TPM_TIS_I2C_BUS_NUMBER; - dev->slave_addr = CONFIG_TPM_TIS_I2C_SLAVE_ADDRESS; #endif + return 0; }
@@ -547,6 +605,7 @@ int tis_init(void) if (tpm_select()) return -1;
+#ifndef CONFIG_DM_I2C /* * Probe TPM twice; the first probing might fail because TPM is asleep, * and the probing can wake up TPM. @@ -556,8 +615,10 @@ int tis_init(void) tpm.slave_addr); return -1; } +#endif
tpm_deselect(); + debug("%s: done\n", __func__);
tpm.inited = 1;
@@ -574,7 +635,11 @@ int tis_open(void) if (tpm_select()) return -1;
+#ifdef CONFIG_DM_I2C + rc = tpm_open_dev(tpm.dev); +#else rc = tpm_open(tpm.slave_addr); +#endif
tpm_deselect();
diff --git a/drivers/tpm/tpm_private.h b/drivers/tpm/tpm_private.h index 888a074..8894c98 100644 --- a/drivers/tpm/tpm_private.h +++ b/drivers/tpm/tpm_private.h @@ -131,6 +131,9 @@ struct tpm_chip *tpm_register_hardware(const struct tpm_vendor_specific *);
int tpm_vendor_init(uint32_t dev_addr);
+struct udevice; +int tpm_vendor_init_dev(struct udevice *dev); + void tpm_vendor_cleanup(struct tpm_chip *chip);
diff --git a/drivers/tpm/tpm_tis_i2c.c b/drivers/tpm/tpm_tis_i2c.c index c1bbed4..ee4dfea 100644 --- a/drivers/tpm/tpm_tis_i2c.c +++ b/drivers/tpm/tpm_tis_i2c.c @@ -37,6 +37,7 @@ */
#include <common.h> +#include <dm.h> #include <fdtdec.h> #include <linux/compiler.h> #include <i2c.h> @@ -122,13 +123,19 @@ static const char * const chip_name[] = {
/* Structure to store I2C TPM specific stuff */ struct tpm_dev { +#ifdef CONFIG_DM_I2C + struct udevice *dev; +#else uint addr; +#endif u8 buf[TPM_DEV_BUFSIZE + sizeof(u8)]; /* Max buffer size + addr */ enum i2c_chip_type chip_type; };
static struct tpm_dev tpm_dev = { +#ifndef CONFIG_DM_I2C .addr = TPM_I2C_ADDR +#endif };
static struct tpm_dev tpm_dev; @@ -156,8 +163,12 @@ static int iic_tpm_read(u8 addr, u8 *buffer, size_t len) if ((tpm_dev.chip_type == SLB9635) || (tpm_dev.chip_type == UNKNOWN)) { /* slb9635 protocol should work in both cases */ for (count = 0; count < MAX_COUNT; count++) { +#ifdef CONFIG_DM_I2C + rc = dm_i2c_write(tpm_dev.dev, 0, (uchar *)&addrbuf, 1); +#else rc = i2c_write(tpm_dev.addr, 0, 0, (uchar *)&addrbuf, 1); +#endif if (rc == 0) break; /* Success, break to skip sleep */ udelay(SLEEP_DURATION); @@ -171,7 +182,11 @@ static int iic_tpm_read(u8 addr, u8 *buffer, size_t len) */ for (count = 0; count < MAX_COUNT; count++) { udelay(SLEEP_DURATION); +#ifdef CONFIG_DM_I2C + rc = dm_i2c_read(tpm_dev.dev, 0, buffer, len); +#else rc = i2c_read(tpm_dev.addr, 0, 0, buffer, len); +#endif if (rc == 0) break; /* success, break to skip sleep */ } @@ -184,7 +199,11 @@ static int iic_tpm_read(u8 addr, u8 *buffer, size_t len) * be safe on the safe side. */ for (count = 0; count < MAX_COUNT; count++) { +#ifdef CONFIG_DM_I2C + rc = dm_i2c_read(tpm_dev.dev, addr, buffer, len); +#else rc = i2c_read(tpm_dev.addr, addr, 1, buffer, len); +#endif if (rc == 0) break; /* break here to skip sleep */ udelay(SLEEP_DURATION); @@ -206,18 +225,26 @@ static int iic_tpm_write_generic(u8 addr, u8 *buffer, size_t len, int count;
/* Prepare send buffer */ +#ifndef CONFIG_DM_I2C tpm_dev.buf[0] = addr; memcpy(&(tpm_dev.buf[1]), buffer, len); + buffer = tpm_dev.buf; + len++; +#endif
for (count = 0; count < max_count; count++) { - rc = i2c_write(tpm_dev.addr, 0, 0, tpm_dev.buf, len + 1); +#ifdef CONFIG_DM_I2C + rc = dm_i2c_write(tpm_dev.dev, addr, buffer, len); +#else + rc = i2c_write(tpm_dev.addr, 0, 0, buffer, len); +#endif if (rc == 0) break; /* Success, break to skip sleep */ udelay(sleep_time); }
/* take care of 'guard time' */ - udelay(SLEEP_DURATION); + udelay(sleep_time); if (rc) return -rc;
@@ -292,11 +319,14 @@ static int request_locality(struct tpm_chip *chip, int loc) { unsigned long start, stop; u8 buf = TPM_ACCESS_REQUEST_USE; + int rc;
if (check_locality(chip, loc) >= 0) return loc; /* We already have the locality */
- iic_tpm_write(TPM_ACCESS(loc), &buf, 1); + rc = iic_tpm_write(TPM_ACCESS(loc), &buf, 1); + if (rc) + return rc;
/* Wait for burstcount */ start = get_timer(0); @@ -323,10 +353,15 @@ static u8 tpm_tis_i2c_status(struct tpm_chip *chip)
static void tpm_tis_i2c_ready(struct tpm_chip *chip) { + int rc; + /* This causes the current command to be aborted */ u8 buf = TPM_STS_COMMAND_READY;
- iic_tpm_write_long(TPM_STS(chip->vendor.locality), &buf, 1); + debug("%s\n", __func__); + rc = iic_tpm_write_long(TPM_STS(chip->vendor.locality), &buf, 1); + if (rc) + debug("%s: rc=%d\n", __func__, rc); }
static ssize_t get_burstcount(struct tpm_chip *chip) @@ -422,6 +457,8 @@ static int tpm_tis_i2c_recv(struct tpm_chip *chip, u8 *buf, size_t count)
expected = get_unaligned_be32(buf + TPM_RSP_SIZE_BYTE); if ((size_t)expected > count) { + error("Error size=%x, expected=%x, count=%x\n", size, expected, + count); size = -EIO; goto out; } @@ -456,11 +493,12 @@ out: static int tpm_tis_i2c_send(struct tpm_chip *chip, u8 *buf, size_t len) { int rc, status; - ssize_t burstcnt; + size_t burstcnt; size_t count = 0; int retry = 0; u8 sts = TPM_STS_GO;
+ debug("%s: len=%d\n", __func__, len); if (len > TPM_DEV_BUFSIZE) return -E2BIG; /* Command is too long for our tpm, sorry */
@@ -483,9 +521,10 @@ static int tpm_tis_i2c_send(struct tpm_chip *chip, u8 *buf, size_t len) if (burstcnt < 0) return burstcnt;
- while (count < len - 1) { - if (burstcnt > len - 1 - count) - burstcnt = len - 1 - count; + while (count < len) { + udelay(300); + if (burstcnt > len - count) + burstcnt = len - count;
#ifdef CONFIG_TPM_TIS_I2C_BURST_LIMITATION if (retry && burstcnt > CONFIG_TPM_TIS_I2C_BURST_LIMITATION) @@ -497,9 +536,15 @@ static int tpm_tis_i2c_send(struct tpm_chip *chip, u8 *buf, size_t len) if (rc == 0) count += burstcnt; else { - retry++; - wait_for_stat(chip, TPM_STS_VALID, - chip->vendor.timeout_c, &status); + debug("%s: error\n", __func__); + if (retry++ > 10) { + rc = -EIO; + goto out_err; + } + rc = wait_for_stat(chip, TPM_STS_VALID, + chip->vendor.timeout_c, &status); + if (rc) + goto out_err;
if ((status & TPM_STS_DATA_EXPECT) == 0) { rc = -EIO; @@ -508,20 +553,14 @@ static int tpm_tis_i2c_send(struct tpm_chip *chip, u8 *buf, size_t len) } }
- /* Write last byte */ - iic_tpm_write(TPM_DATA_FIFO(chip->vendor.locality), &(buf[count]), 1); - wait_for_stat(chip, TPM_STS_VALID, chip->vendor.timeout_c, &status); - if ((status & TPM_STS_DATA_EXPECT) != 0) { - rc = -EIO; - goto out_err; - } - /* Go and do it */ iic_tpm_write(TPM_STS(chip->vendor.locality), &sts, 1); + debug("done\n");
return len;
out_err: + debug("%s: out_err\n", __func__); tpm_tis_i2c_ready(chip); /* * The TPM needs some time to clean up here, @@ -558,26 +597,17 @@ static enum i2c_chip_type tpm_vendor_chip_type(void) return UNKNOWN; }
-/* Initialisation of i2c tpm */ -int tpm_vendor_init(uint32_t dev_addr) +static int tpm_vendor_init_common(void) { + struct tpm_chip *chip; u32 vendor; u32 expected_did_vid; - uint old_addr; - int rc = 0; - struct tpm_chip *chip; - - old_addr = tpm_dev.addr; - if (dev_addr != 0) - tpm_dev.addr = dev_addr;
tpm_dev.chip_type = tpm_vendor_chip_type();
chip = tpm_register_hardware(&tpm_tis_i2c); - if (chip < 0) { - rc = -ENODEV; - goto out_err; - } + if (chip < 0) + return -ENODEV;
/* Disable interrupts (not supported) */ chip->vendor.irq = 0; @@ -588,15 +618,13 @@ int tpm_vendor_init(uint32_t dev_addr) chip->vendor.timeout_c = TIS_SHORT_TIMEOUT; chip->vendor.timeout_d = TIS_SHORT_TIMEOUT;
- if (request_locality(chip, 0) < 0) { - rc = -ENODEV; - goto out_err; - } + if (request_locality(chip, 0) < 0) + return -ENODEV;
/* Read four bytes from DID_VID register */ if (iic_tpm_read(TPM_DID_VID(0), (uchar *)&vendor, 4) < 0) { - rc = -EIO; - goto out_release; + release_locality(chip, 0, 1); + return -EIO; }
if (tpm_dev.chip_type == SLB9635) { @@ -609,8 +637,7 @@ int tpm_vendor_init(uint32_t dev_addr)
if (tpm_dev.chip_type != UNKNOWN && vendor != expected_did_vid) { error("Vendor id did not match! ID was %08x\n", vendor); - rc = -ENODEV; - goto out_release; + return -ENODEV; }
debug("1.2 TPM (chip type %s device-id 0x%X)\n", @@ -622,14 +649,33 @@ int tpm_vendor_init(uint32_t dev_addr) */
return 0; +} + +#ifdef CONFIG_DM_I2C +/* Initialisation of i2c tpm */ +int tpm_vendor_init_dev(struct udevice *dev) +{ + tpm_dev.dev = dev; + return tpm_vendor_init_common(); +} +#else +/* Initialisation of i2c tpm */ +int tpm_vendor_init(uint32_t dev_addr) +{ + uint old_addr; + int rc = 0;
-out_release: - release_locality(chip, 0, 1); + old_addr = tpm_dev.addr; + if (dev_addr != 0) + tpm_dev.addr = dev_addr; + + rc = tpm_vendor_init_common(); + if (rc) + tpm_dev.addr = old_addr;
-out_err: - tpm_dev.addr = old_addr; return rc; } +#endif
void tpm_vendor_cleanup(struct tpm_chip *chip) {
This name is used in Linux, so use it in U-Boot.
arch/arm/dts/exynos5420-peach-pit.dts | 2 +- arch/arm/dts/exynos5800-peach-pi.dts | 2 +- lib/fdtdec.c | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/exynos5420-peach-pit.dts b/arch/arm/dts/exynos5420-peach-pit.dts index 7d8fa28..6fe762d 100644 --- a/arch/arm/dts/exynos5420-peach-pit.dts +++ b/arch/arm/dts/exynos5420-peach-pit.dts @@ -79,7 +79,7 @@ i2c@12e10000 { /* i2c9 */ clock-frequency = <400000>; tpm@20 { - compatible = "infineon,slb9645-tpm"; + compatible = "infineon,slb9645tt"; reg = <0x20>; }; }; diff --git a/arch/arm/dts/exynos5800-peach-pi.dts b/arch/arm/dts/exynos5800-peach-pi.dts index 8c1f616..176ce55 100644 --- a/arch/arm/dts/exynos5800-peach-pi.dts +++ b/arch/arm/dts/exynos5800-peach-pi.dts @@ -72,7 +72,7 @@ i2c@12e10000 { /* i2c9 */ clock-frequency = <400000>; tpm@20 { - compatible = "infineon,slb9645-tpm"; + compatible = "infineon,slb9645tt"; reg = <0x20>; }; }; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 14984b7..30573c2 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -65,7 +65,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(GENERIC_SPI_FLASH, "spi-flash"), COMPAT(MAXIM_98095_CODEC, "maxim,max98095-codec"), COMPAT(INFINEON_SLB9635_TPM, "infineon,slb9635-tpm"), - COMPAT(INFINEON_SLB9645_TPM, "infineon,slb9645-tpm"), + COMPAT(INFINEON_SLB9645_TPM, "infineon,slb9645tt"), COMPAT(SAMSUNG_EXYNOS5_I2C, "samsung,exynos5-hsi2c"), COMPAT(SANDBOX_LCD_SDL, "sandbox,lcd-sdl"), COMPAT(TI_TPS65090, "ti,tps65090"),
This should say 'in', not 'out'.
include/asm-generic/gpio.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/asm-generic/gpio.h b/include/asm-generic/gpio.h index 4752ea4..519bb0b 100644 --- a/include/asm-generic/gpio.h +++ b/include/asm-generic/gpio.h @@ -115,7 +115,7 @@ struct gpio_desc { unsigned long flags; #define GPIOD_REQUESTED (1 << 0) /* Requested/claimed */ #define GPIOD_IS_OUT (1 << 1) /* GPIO is an output */ -#define GPIOD_IS_IN (1 << 2) /* GPIO is an output */ +#define GPIOD_IS_IN (1 << 2) /* GPIO is an input */ #define GPIOD_ACTIVE_LOW (1 << 3) /* value has active low */ #define GPIOD_IS_OUT_ACTIVE (1 << 4) /* set output active */
Commit 47ed5dd0 dropped the .got section from U-Boot binaries. This is needed for some relocations, and causes failures if missing. Add it back.
arch/arm/config.mk | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/config.mk b/arch/arm/config.mk index c005ce4..0550225 100644 --- a/arch/arm/config.mk +++ b/arch/arm/config.mk @@ -112,7 +112,8 @@ endif ifdef CONFIG_ARM64 OBJCOPYFLAGS += -j .text -j .rodata -j .data -j .u_boot_list -j .rela.dyn else -OBJCOPYFLAGS += -j .text -j .secure_text -j .rodata -j .hash -j .data -j .got.plt -j .u_boot_list -j .rel.dyn +OBJCOPYFLAGS += -j .text -j .secure_text -j .rodata -j .hash -j .data -j \ + .got -j .got.plt -j .u_boot_list -j .rel.dyn endif
ifdef CONFIG_OF_EMBED
It is convenient for some boards to implement save_boot_params() in C rather than assembler. Provide a way to return in this case.
arch/arm/include/asm/system.h | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/arch/arm/include/asm/system.h b/arch/arm/include/asm/system.h index 2a5bed2..e584c3b 100644 --- a/arch/arm/include/asm/system.h +++ b/arch/arm/include/asm/system.h @@ -158,6 +158,22 @@ void flush_l3_cache(void); * void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3); */
+/** + * save_boot_params_ret() - Return from save_boot_params() + * + * If you provide save_boot_params(), then you should jump back to this + * function when done. Try to preserve all registers. + * + * If your implementation of save_boot_params() is in C then it is acceptable + * to simply call save_boot_params_ret() at the end of your function. Since + * there is no link register set up, you cannot just exit the function. U-Boot + * will return to the (initialised) value of lr, and likely crash/hang. + * + * If your implementation of save_boot_params() is in assembler then you + * should use 'b' or 'bx' to return to save_boot_params_ret. + */ +void save_boot_params_ret(void); + #define isb() __asm__ __volatile__ ("" : : : "memory")
#define nop() __asm__ __volatile__("mov\tr0,r0\t@ nop\n\t");
Hi Simon,
On 4 May 2015 at 15:09, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Simon,
For secure boot systems it is common to have a read-only U-Boot which starts the machine and jumps to a read-write U-Boot for actual booting the OS. This allows the read-write U-Boot to be upgraded without risk of permanently bricking the machine. In the event that the read-write U-Boot is corrupted, the read-only U-Boot can detect this with a checksum and boot into a recovery flow.
To support this, add a way to detect when U-Boot is run from SPL as opposed to some other method, such as booted directly (no SPL) or started from another source (e.g. a primary U-Boot). This works by putting a special value in r0.
For now we rely on board-specific code to actually check the register and set a flag. At some point this could be generalised, perhaps by using a spare register and passing a flag to _main and/or board_init_f().
include/spl.h | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/include/spl.h b/include/spl.h index b2e5bf7..cdd63a7 100644 --- a/include/spl.h +++ b/include/spl.h @@ -11,6 +11,8 @@ #include <linux/compiler.h> #include <asm/spl.h>
+/* Value in r0 indicates we booted from U-Boot */ +#define SPL_RUNNING_FROM_UBOOT 0x13578642
/* Boot type */ #define MMCSD_MODE_UNDEFINED 0 @@ -82,4 +84,15 @@ int spl_load_image_ext_os(block_dev_desc_t *block_dev, int partition); #ifdef CONFIG_SPL_BOARD_INIT void spl_board_init(void); #endif + +/** + * spl_was_boot_source() - check if U-Boot booted from SPL + * + * This will normally be true, but if U-Boot jumps to second U-Boot, it will + * be false. This should be implemented by board-specific code. + * + * @return true if U-Boot booted from SPL, else false + */ +bool spl_was_boot_source(void); + #endif
Hi Simon,
Part of this patch seems to be missing. I don't see how these changes can accomplish what is described in the commit log.
- spl_was_boot_source() - check if U-Boot booted from SPL
- This will normally be true, but if U-Boot jumps to second U-Boot, it will
- be false. This should be implemented by board-specific code.
- @return true if U-Boot booted from SPL, else false
#endif
Thanks, -Joe
This function is used before jumping to U-Boot, but in that case we don't always want to disable caches.
Signed-off-by: Simon Glass sjg@chromium.org Signed-off-by: Vadim Bendebury vbendeb@chromium.org ---
arch/arm/cpu/armv7/cpu.c | 47 +++++++++++++++++++++++++++++------------------ include/common.h | 15 +++++++++++++++ 2 files changed, 44 insertions(+), 18 deletions(-)
diff --git a/arch/arm/cpu/armv7/cpu.c b/arch/arm/cpu/armv7/cpu.c index c56417d..0b0e500 100644 --- a/arch/arm/cpu/armv7/cpu.c +++ b/arch/arm/cpu/armv7/cpu.c @@ -24,7 +24,7 @@
void __weak cpu_cache_initialization(void){}
-int cleanup_before_linux(void) +int cleanup_before_linux_select(int flags) { /* * this function is called just before we call linux @@ -42,24 +42,30 @@ int cleanup_before_linux(void) icache_disable(); invalidate_icache_all();
- /* - * turn off D-cache - * dcache_disable() in turn flushes the d-cache and disables MMU - */ - dcache_disable(); - v7_outer_cache_disable(); + if (flags & CBL_DISABLE_CACHES) { + /* + * turn off D-cache + * dcache_disable() in turn flushes the d-cache and disables MMU + */ + dcache_disable(); + v7_outer_cache_disable();
- /* - * After D-cache is flushed and before it is disabled there may - * be some new valid entries brought into the cache. We are sure - * that these lines are not dirty and will not affect our execution. - * (because unwinding the call-stack and setting a bit in CP15 SCTLR - * is all we did during this. We have not pushed anything on to the - * stack. Neither have we affected any static data) - * So just invalidate the entire d-cache again to avoid coherency - * problems for kernel - */ - invalidate_dcache_all(); + /* + * After D-cache is flushed and before it is disabled there may + * be some new valid entries brought into the cache. We are + * sure that these lines are not dirty and will not affect our + * execution. (because unwinding the call-stack and setting a + * bit in CP15 SCTRL is all we did during this. We have not + * pushed anything on to the stack. Neither have we affected + * any static data) So just invalidate the entire d-cache again + * to avoid coherency problems for kernel + */ + invalidate_dcache_all(); + } else { + flush_dcache_all(); + invalidate_icache_all(); + icache_enable(); + }
/* * Some CPU need more cache attention before starting the kernel. @@ -68,3 +74,8 @@ int cleanup_before_linux(void)
return 0; } + +int cleanup_before_linux(void) +{ + return cleanup_before_linux_select(CBL_ALL); +} diff --git a/include/common.h b/include/common.h index cde3474..0b21599 100644 --- a/include/common.h +++ b/include/common.h @@ -728,6 +728,21 @@ void invalidate_dcache_range(unsigned long start, unsigned long stop); void invalidate_dcache_all(void); void invalidate_icache_all(void);
+enum { + /* Disable caches (else flush caches but leave them active) */ + CBL_DISABLE_CACHES = 1 << 0, + CBL_SHOW_BOOTSTAGE_REPORT = 1 << 1, + + CBL_ALL = 3, +}; + +/** + * Clean up ready for linux + * + * @param flags Flags to control what is done + */ +int cleanup_before_linux_select(int flags); + /* arch/$(ARCH)/lib/ticks.S */ uint64_t get_ticks(void); void wait_ticks (unsigned long);
In which usecase exactly is this applicable please ? :)
Best regards, Marek Vasut
Hi Marek,
This is sort-of related to "Enable detecting when U-Boot is started from SPL" so there are some details there.
I was able to get SPL to enable the cache and leave it on all the way through the verified boot flow (read-only and read-write U-Boot) and it saved about 600ms. So in short this refactor allows you to jump into U-Boot with the cache still enabled.
On Monday, May 04, 2015 at 07:49:16 PM, Simon Glass wrote:
Hi Marek,
Hi Simon,
Sounds good, thanks for clarifying !
Support this function so we can use Chrome OS verified boot with sandbox.
arch/sandbox/cpu/cpu.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/sandbox/cpu/cpu.c b/arch/sandbox/cpu/cpu.c index 168f2ef..4646f07 100644 --- a/arch/sandbox/cpu/cpu.c +++ b/arch/sandbox/cpu/cpu.c @@ -55,6 +55,11 @@ int cleanup_before_linux(void) return 0; }
+int cleanup_before_linux_select(int flags) +{ + return 0; +} + void *map_physmem(phys_addr_t paddr, unsigned long len, unsigned long flags) { #ifdef CONFIG_PCI
This function should return a useful error for U-Boot, rather than -1.
arch/sandbox/cpu/state.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/sandbox/cpu/state.c b/arch/sandbox/cpu/state.c index 033958c..cae731c 100644 --- a/arch/sandbox/cpu/state.c +++ b/arch/sandbox/cpu/state.c @@ -51,7 +51,7 @@ static int state_read_file(struct sandbox_state *state, const char *fname) ret = os_get_filesize(fname, &size); if (ret < 0) { printf("Cannot find sandbox state file '%s'\n", fname); - return ret; + return -ENOENT; } state->state_fdt = os_malloc(size); if (!state->state_fdt) {
Hi Simon,
On 4 May 2015 at 15:12, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Simon,
These files use error numbering, so add the include.
arch/sandbox/cpu/start.c | 1 + drivers/misc/i2c_eeprom_emul.c | 1 + drivers/misc/swap_case.c | 1 + 3 files changed, 3 insertions(+)
diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index ec01040..0707256 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <errno.h> #include <os.h> #include <cli.h> #include <malloc.h> diff --git a/drivers/misc/i2c_eeprom_emul.c b/drivers/misc/i2c_eeprom_emul.c index 7343445..4410d03 100644 --- a/drivers/misc/i2c_eeprom_emul.c +++ b/drivers/misc/i2c_eeprom_emul.c @@ -8,6 +8,7 @@
#include <common.h> #include <dm.h> +#include <errno.h> #include <fdtdec.h> #include <i2c.h> #include <malloc.h> diff --git a/drivers/misc/swap_case.c b/drivers/misc/swap_case.c index f6028ba..3b8aa48 100644 --- a/drivers/misc/swap_case.c +++ b/drivers/misc/swap_case.c @@ -9,6 +9,7 @@
#include <common.h> #include <dm.h> +#include <errno.h> #include <pci.h> #include <asm/test.h> #include <linux/ctype.h>
Emualate this function which is used with Chrome OS verified boot.
drivers/misc/cros_ec_sandbox.c | 2 ++ include/ec_commands.h | 15 +++++++++++++++ 2 files changed, 17 insertions(+)
diff --git a/drivers/misc/cros_ec_sandbox.c b/drivers/misc/cros_ec_sandbox.c index df41e82..7509612 100644 --- a/drivers/misc/cros_ec_sandbox.c +++ b/drivers/misc/cros_ec_sandbox.c @@ -459,6 +459,8 @@ static int process_cmd(struct ec_state *ec, case EC_CMD_MKBP_STATE: len = cros_ec_keyscan(ec, resp_data); break; + case EC_CMD_ENTERING_MODE: + break; default: printf(" ** Unknown EC command %#02x\n", req_hdr->command); return -1; diff --git a/include/ec_commands.h b/include/ec_commands.h index 78baab1..7605066 100644 --- a/include/ec_commands.h +++ b/include/ec_commands.h @@ -1555,6 +1555,21 @@ struct ec_params_sb_wr_block { uint16_t data[32]; } __packed;
+/* + * Entering Verified Boot Mode Command + * Default mode is VBOOT_MODE_NORMAL if EC did not receive this command. + * Valid Modes are: normal, developer, and recovery. + */ +#define EC_CMD_ENTERING_MODE 0xb6 + +struct ec_params_entering_mode { + int vboot_mode; +} __packed; + +#define VBOOT_MODE_NORMAL 0 +#define VBOOT_MODE_DEVELOPER 1 +#define VBOOT_MODE_RECOVERY 2 + /*****************************************************************************/ /* System commands */
This printf() should have a newline at the end. Add it.
drivers/mtd/spi/sandbox.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/sandbox.c b/drivers/mtd/spi/sandbox.c index d576d31..895604d 100644 --- a/drivers/mtd/spi/sandbox.c +++ b/drivers/mtd/spi/sandbox.c @@ -129,7 +129,7 @@ static int sandbox_sf_probe(struct udevice *dev) } } if (cs == -1) { - printf("Error: Unknown chip select for device '%s'", + printf("Error: Unknown chip select for device '%s'\n", dev->name); return -EINVAL; }
Hi Simon,
On 5 May 2015 at 02:36, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Simon,
thanks!
Hi Simon,
thanks!
Jagan Teki, Openedev.
This fixes a warning in the print_buffer() function with some toolchains.
lib/display_options.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/display_options.c b/lib/display_options.c index d5d17b2..495a547 100644 --- a/lib/display_options.c +++ b/lib/display_options.c @@ -123,7 +123,7 @@ int print_buffer(ulong addr, const void *data, uint width, uint count, else x = lb.uc[i] = *(volatile uint8_t *)data; #ifdef CONFIG_SYS_SUPPORT_64BIT_DATA - printf(" %0*" PRIx64, width * 2, x); + printf(" %0*llx", width * 2, (long long)x); #else printf(" %0*x", width * 2, x); #endif
Hi Simon,
On 4 May 2015 at 15:45, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Simon,
Increase the LCD size to 1366x768.
arch/sandbox/dts/sandbox.dts | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/sandbox/dts/sandbox.dts b/arch/sandbox/dts/sandbox.dts index efa2097..6bfa735 100644 --- a/arch/sandbox/dts/sandbox.dts +++ b/arch/sandbox/dts/sandbox.dts @@ -70,8 +70,8 @@
lcd { compatible = "sandbox,lcd-sdl"; - xres = <800>; - yres = <600>; + xres = <1366>; + yres = <768>; };
gpio_a: gpios@0 {
Hi Simon,
Is this actually emulated somehow? Maybe I just don't see it since I'm SSH'ed into my build machine?
Thanks, -Joe
Hi Joe,
On 4 May 2015 at 15:27, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Simon,
Yes, plus you need the -l option.
On 4 May 2015 at 15:36, Simon Glass sjg@chromium.org wrote:
Hi Joe,
Hi Simon,
For 16-bit-per-pixel displays it is useful to support 8 bit-per-pixel images to reduce image size. Add support for this when drawing BMP images.
common/lcd.c | 23 ++++++++++++++++++++--- include/bmp_layout.h | 4 ++-- 2 files changed, 22 insertions(+), 5 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index 055c366..2d11578 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -578,6 +578,8 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) unsigned long width, height, byte_width; unsigned long pwidth = panel_info.vl_col; unsigned colors, bpix, bmp_bpix; + int hdr_size; + bmp_color_table_entry_t *palette = bmp->color_table;
if (!bmp || !(bmp->header.signature[0] == 'B' && bmp->header.signature[1] == 'M')) { @@ -589,6 +591,8 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) width = get_unaligned_le32(&bmp->header.width); height = get_unaligned_le32(&bmp->header.height); bmp_bpix = get_unaligned_le16(&bmp->header.bit_count); + hdr_size = get_unaligned_le16(&bmp->header.size); + debug("hdr_size=%d, bmp_bpix=%d\n", hdr_size, bmp_bpix);
colors = 1 << bmp_bpix;
@@ -613,8 +617,8 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) return 1; }
- debug("Display-bmp: %d x %d with %d colors\n", - (int)width, (int)height, (int)colors); + debug("Display-bmp: %d x %d with %d colors, display %d\n", + (int)width, (int)height, (int)colors, 1 << bpix);
if (bmp_bpix == 8) lcd_set_cmap(bmp, colors); @@ -641,6 +645,7 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) cmap_base = configuration_get_cmap(); #ifdef CONFIG_LCD_BMP_RLE8 u32 compression = get_unaligned_le32(&bmp->header.compression); + debug("compressed %d %d\n", compression, BMP_BI_RLE8); if (compression == BMP_BI_RLE8) { if (bpix != 16) { /* TODO implement render code for bpix != 16 */ @@ -663,7 +668,19 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) if (bpix != 16) { fb_put_byte(&fb, &bmap); } else { - *(uint16_t *)fb = cmap_base[*(bmap++)]; + struct bmp_color_table_entry *entry; + uint val; + + if (cmap_base) { + val = cmap_base[*bmap]; + } else { + entry = &palette[*bmap]; + val = entry->blue >> 3 | + entry->green >> 2 << 5 | + entry->red >> 3 << 11; + } + *(uint16_t *)fb = val; + bmap++; fb += sizeof(uint16_t) / sizeof(*fb); } } diff --git a/include/bmp_layout.h b/include/bmp_layout.h index 22b1fbc..47f505c 100644 --- a/include/bmp_layout.h +++ b/include/bmp_layout.h @@ -11,12 +11,12 @@ #ifndef _BMP_H_ #define _BMP_H_
-typedef struct bmp_color_table_entry { +typedef struct __packed bmp_color_table_entry { __u8 blue; __u8 green; __u8 red; __u8 reserved; -} __attribute__ ((packed)) bmp_color_table_entry_t; +} bmp_color_table_entry_t;
/* When accessing these fields, remember that they are stored in little endian format, so use linux macros, e.g. le32_to_cpu(width) */
Hi Simon,
int hdr_size;
bmp_color_table_entry_t *palette = bmp->color_table; if (!bmp || !(bmp->header.signature[0] == 'B' && bmp->header.signature[1] == 'M')) {
debug("hdr_size=%d, bmp_bpix=%d\n", hdr_size, bmp_bpix); colors = 1 << bmp_bpix;
(int)width, (int)height, (int)colors, 1 << bpix); if (bmp_bpix == 8) lcd_set_cmap(bmp, colors);
uint val;
if (cmap_base) {
} else {
It would be great to drop the typedef here.
/* When accessing these fields, remember that they are stored in little endian format, so use linux macros, e.g. le32_to_cpu(width) */ --
Cheers, -Joe
Add an implementation of this function for Tegra.
arch/arm/mach-tegra/board.c | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/arch/arm/mach-tegra/board.c b/arch/arm/mach-tegra/board.c index 222de6a..77be211 100644 --- a/arch/arm/mach-tegra/board.c +++ b/arch/arm/mach-tegra/board.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <spl.h> #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/funcmux.h> @@ -29,6 +30,21 @@ enum { UART_COUNT = 5, };
+static bool from_spl __attribute__ ((section(".data"))); + +#ifndef CONFIG_SPL_BUILD +void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) +{ + from_spl = r0 != SPL_RUNNING_FROM_UBOOT; + save_boot_params_ret(); +} +#endif + +bool spl_was_boot_source(void) +{ + return from_spl; +} + #if defined(CONFIG_TEGRA_SUPPORT_NON_SECURE) #if !defined(CONFIG_TEGRA124) #error tegra_cpu_is_non_secure has only been validated on Tegra124
- from_spl = r0 != SPL_RUNNING_FROM_UBOOT;
- save_boot_params_ret();
+} +#endif
(Using terminology from: https://patchwork.ozlabs.org/patch/467771/ arm: spl: Enable detecting when U-Boot is started from SPL )
That doesn't look right. Surely (at least on Tegra), if the r/o U-Boot chain-loads to the r/w U-Boot, then the chain-loaded U-Boot has no SPL and is just the main CPU build of U-Boot.
Hence, "SPL_RUNNING_FROM_UBOOT" seems incorrectly named, since the r/o U-Boot doesn't chain to SPL but rather to U-Boot.
This approach sounds a little brittle; what happens if r0 just happens to have that value. Won't the code get confused?
Why does U-Boot care whether it's been chain-loaded? Shouldn't it always behave identically in all cases, so it's independent of what caused it to run?
Hi Stephen,
+} +#endif
What name do you suggest? I was trying to add a prefix indicating that it relates to non-SPL start-up of U-Boot.
Yes, but SPL does not set that value in r0, and we have control over this.
In the case of read-only U-Boot it must find the read-write one to jump to. In the case of read-write U-Boot it must boot a kernel.
On 05/05/2015 10:02 AM, Simon Glass wrote:
Hi Stephen,
+} +#endif
Well, that name specifically states that it's SPL that's running, whereas the exact opposite is true.
Perhaps UBOOT_CHAIN_LOADED_FROM_UBOOT?
Surely that should be taken care of by placing the correct boot scripts into the U-Boot environment, rather than hard-coding specific boot behaviour into the U-Boot binary?
This feature seems really use-case-specific; I wonder if it's useful/generic-enough to upstream even?
Hi Stephen,
Hi Stephen,
+} +#endif
I really want to say that it is not chain-loaded from SPL. Maybe UBOOT_NOT_LOADED_FROM_SPL?
Two problems here:
1. The two U-Boot will use the same environment (as they are identical after all)
2. Loading the environment is a security risk (since anyone can change it in Linux, for example) so cannot be loaded.
I am keen to upstream this use case (upgrading U-Boot in a secure way) as I think it has wide application.
On 05/05/2015 10:19 AM, Simon Glass wrote:
Hi Stephen,
Hi Stephen,
+} +#endif
OK, that highlights that better.
Two problems here:
- The two U-Boot will use the same environment (as they are identical
after all)
That's a design decision. There's absolutely no need for that to be true.
- Loading the environment is a security risk (since anyone can change
Well, the environment could be the default/built-in environment and hence validated as part of the validation of the U-Boot binary. Or, even if loaded separately, could also be validated in the same way (but perhaps there's not much point in that, since a fall-back to the built-in environment would be required in case the external environment validation failed).
OK. I worry that there are many many possible ways of doing that, and the selection of the best option depends on the system use-cases, security model, and environments. We might not want to lock people into a specific method. So long as the existence of this code doesn't prevent doing things some other way if they need, or upstreaming support for other methods, nor make the code too complex, then it's probably fine.
Hi Stephen,
Hi Stephen,
Hi Stephen,
+} +#endif
Two problems here:
after all)
At present U-Boot has a single CONFIG for the environment type/position. Therefore we can't have the same U-Boot behave differently.
That's why we have the load-env device tree option, which uses the default environment. But since the RO and RW U-Boot then have the same environment, this doesn't really help.
Yes we could validate it, although it's a pain since it is one more thing to sign and hash and it's not in the FIT.
This seems pretty simple to me.
Enable the I2C3 pins so that the TPM can be used.
board/nvidia/nyan-big/pinmux-config-nyan-big.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/nvidia/nyan-big/pinmux-config-nyan-big.h b/board/nvidia/nyan-big/pinmux-config-nyan-big.h index 9c5fbaa..ddf572f 100644 --- a/board/nvidia/nyan-big/pinmux-config-nyan-big.h +++ b/board/nvidia/nyan-big/pinmux-config-nyan-big.h @@ -234,8 +234,8 @@ static const struct pmux_pingrp_config nyan_big_pingrps[] = { PINCFG(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), PINCFG(PBB0, VGP6, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), - PINCFG(CAM_I2C_SCL_PBB1, RSVD3, DOWN, TRISTATE, OUTPUT, DISABLE, DEFAULT), - PINCFG(CAM_I2C_SDA_PBB2, RSVD3, DOWN, TRISTATE, OUTPUT, DISABLE, DEFAULT), + PINCFG(CAM_I2C_SCL_PBB1, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(CAM_I2C_SDA_PBB2, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), PINCFG(PBB3, VGP3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), PINCFG(PBB4, VGP4, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), PINCFG(PBB5, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT),
If the mmc device is non-removable (as indicated by the device tree), set the flag so that users of the device know.
drivers/mmc/tegra_mmc.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/tegra_mmc.c b/drivers/mmc/tegra_mmc.c index 2cd8cf1..5c9c54a 100644 --- a/drivers/mmc/tegra_mmc.c +++ b/drivers/mmc/tegra_mmc.c @@ -528,7 +528,7 @@ static const struct mmc_ops tegra_mmc_ops = { .getcd = tegra_mmc_getcd, };
-static int do_mmc_init(int dev_index) +static int do_mmc_init(int dev_index, bool removable) { struct mmc_host *host; struct mmc *mmc; @@ -573,6 +573,7 @@ static int do_mmc_init(int dev_index) host->cfg.b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
mmc = mmc_create(&host->cfg, host); + mmc->block_dev.removable = removable; if (mmc == NULL) return -1;
@@ -586,7 +587,8 @@ static int do_mmc_init(int dev_index) * @param node Device index (0-3) * @param host Structure to fill in (reg, width, mmc_id) */ -static int mmc_get_config(const void *blob, int node, struct mmc_host *host) +static int mmc_get_config(const void *blob, int node, struct mmc_host *host, + bool *removablep) { debug("%s: node = %d\n", __func__, node);
@@ -619,6 +621,7 @@ static int mmc_get_config(const void *blob, int node, struct mmc_host *host) GPIOD_IS_IN); gpio_request_by_name_nodev(blob, node, "power-gpios", 0, &host->pwr_gpio, GPIOD_IS_OUT); + *removablep = !fdtdec_get_bool(blob, node, "non-removable");
debug("%s: found controller at %p, width = %d, periph_id = %d\n", __func__, host->reg, host->width, host->mmc_id); @@ -636,6 +639,7 @@ static int mmc_get_config(const void *blob, int node, struct mmc_host *host) static int process_nodes(const void *blob, int node_list[], int count) { struct mmc_host *host; + bool removable; int i, node;
debug("%s: count = %d\n", __func__, count); @@ -649,11 +653,11 @@ static int process_nodes(const void *blob, int node_list[], int count) host = &mmc_host[i]; host->id = i;
- if (mmc_get_config(blob, node, host)) { + if (mmc_get_config(blob, node, host, &removable)) { printf("%s: failed to decode dev %d\n", __func__, i); return -1; } - do_mmc_init(i); + do_mmc_init(i, removable); } return 0; }
Hi Simon,
Hi Simon,
- mmc->block_dev.removable = removable; if (mmc == NULL) return -1;
- @param node Device index (0-3)
- @param host Structure to fill in (reg, width, mmc_id)
bool *removablep)
}if (mmc_get_config(blob, node, host, &removable)) { printf("%s: failed to decode dev %d\n", __func__, i); return -1;
do_mmc_init(i);
} return 0;do_mmc_init(i, removable);
Applied, thanks.
— Pantelis
We are getting very close to running out of space in SPL, and with the currently Chrome OS gcc 4.9 we exceed the limit. Add a litle more space.
include/configs/tegra124-common.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/tegra124-common.h b/include/configs/tegra124-common.h index f2b3774..0347132 100644 --- a/include/configs/tegra124-common.h +++ b/include/configs/tegra124-common.h @@ -30,7 +30,7 @@ /*----------------------------------------------------------------------- * Physical Memory Map */ -#define CONFIG_SYS_TEXT_BASE 0x8010E000 +#define CONFIG_SYS_TEXT_BASE 0x80110000
/* * Memory layout for where various images get loaded by boot scripts:
8K is quite a bump given we only had 24K allocated before. Why is gcc-4.9 less efficient that earlier compilers I wonder? Were we extremely close to the limit ebfore? Still, I guess this is fine.
Did you validate whether tegra-uboot-flasher still works with this change? I think it will since it only cares about the SPL TEXT_BASE and not the main U-Boot TEXT_BASE, but double-checking would be nice.
You forgot to CC Tom Warren on this Tegra patch.
Hi Stephen,
I tested this with USB A-A (tegrarcm). Is that what you mean?
Ooops, I should have used a 'tegra' tag.
On 05/05/2015 10:03 AM, Simon Glass wrote:
Hi Stephen,
Did you just use tegrarcm, or tegra-uboot-flasher? The latter is a wrapper on top of tegrarcm, and is a bit more involved. See the various READMEs at https://github.com/NVIDIA/tegra-uboot-flasher-scripts. This doesn't support any nyan-derived boards yet, but does support Jetson TK1 which I think you have?
Hi Stephen,
Hi Stephen,
We were about 1KB away, mostly due to the gcc garbage collection bug I think. The cros compiler seems even worse, not sure why.
Ah, OK. The script at:
https://github.com/NVIDIA/tegra-uboot-flasher-scripts/blob/master/tegra-uboo...
looks OK to me. It does not have anything hard-coded that I can see. But I have not used it myself. It's kind-of painful that we have all this out-of-tree Tegra stuff (pin mux also) that might break when we change U-Boot. Is there any way to improve this?
On 05/05/2015 10:26 AM, Simon Glass wrote:
Hi Stephen,
Hi Stephen,
I don't think there's anything to improve; nothing is wrong.
If something changes about the way U-Boot works or must be used, then that requires changes elsewhere no matter what. Whether the externals changes are:
* Updates to documentation of how to build/use/... U-Boot. * Updates to the command-lines/techniques people know and use. * Updates to code/tools that interface with U-Boot.
... then in all cases, a change to U-Boot requires a change to something else. I would argue that updating an external tool is actually the easiest of the cases, since it's entirely clear what that tool does, what change to make to it, and how. Conversely, updating the command-lines/techniques that people use is much harder to propagate to all people. The update-a-document case may also be about as easy, presuming you know which documents to update (there are probably more docs than tools at least at present).
In the pinmux case, please consider the system-level implications of a change to the pinmux. There is a single correct pinmux configuration for a given HW configuration, and that's driven purely by the HW design[1]. If the pinmux that U-Boot programs is wrong and needs to be changed, the same change should be propagated to all SW to fix the bug everywhere. The existence of the external Tegra pinmux tools makes that easier; update the pinmux tool, regenerate derived files for all SW stacks, and apply the changes everywhere. Sure it's more work to do that than just updating only U-Boot. However, the tool doesn't add that extra work, rather the change to the desired pinmux makes the work. The only alternative (which does indeed reduce overall work) is to update e.g. only U-Boot's pinmux programming, and leave everything else buggy. That's certainly not a desirable situation. I introduced tegra-pinmux-scripts specifically to avoid that kind of situation.
[1] For boards with expansion headers where the end-user/... can use different pins for different things, I consider the HW configuration to include the definition of whatever the user has plugged into the expansion header.
Hi Stephen,
Hi Stephen,
Hi Stephen,
- Updates to documentation of how to build/use/... U-Boot.
- Updates to the command-lines/techniques people know and use.
- Updates to code/tools that interface with U-Boot.
Here I am enabling the TPM in U-Boot. There may or may not be a kernel TPM driver. Presumably if there is, then something is wrong, because it has the wrong pinmux and won't work, or someone did update it in the kernel and not in U-Boot? Actually I'm not sure that I care about it running in Linux any more than someone working in Linux cares that the TPM is working in U-Boot.
Why can't this stuff go in the device tree, which is already shared between U-Boot and Linux?
+Tom Warren
- Physical Memory Map
- Memory layout for where various images get loaded by boot scripts:
LGTM, but it s/b 'Add a _little_ more space' in the commit msg.
Should we change the TEXT_BASE for the CPU portion in all Tegra builds?
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Tuesday, May 05, 2015 9:04 AM To: U-Boot Mailing List Cc: Simon Glass; Heiko Schocher; Tom Rini; Tom Warren Subject: Re: [PATCH 24/24] tegra124: Expand SPL space by 8KB
+Tom Warren
----------------------------------------------------------------------------------- This email message is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message. -----------------------------------------------------------------------------------
Provide a function to detect USB device insertion/removal in order to avoid having to do USB enumeration in a tight loop when trying to detect peripheral hotplugging.
Signed-off-by: Vincent Palatin vpalatin@chromium.org
Reviewed-by: Stefan Reinauer reinauer@chromium.org Tested-by: Stefan Reinauer reinauer@chromium.org Signed-off-by: Simon Glass sjg@chromium.org
common/usb.c | 26 ++++++++++++++++++++++++++ common/usb_hub.c | 2 +- include/usb.h | 2 ++ 3 files changed, 29 insertions(+), 1 deletion(-)
Applied to u-boot-dm, thanks Vincent.
participants (8)
Heiko Schocher
Jagan Teki
Joe Hershberger
Pantelis Antoniou
Stephen Warren
Tom Warren
