[U-Boot] [PATCH v2 0/2] README.arm-relocation: debugging options update
As Wolfgang pointed out, bdinfo can be used to get the relocation address so update the README to indicate that this can be done instead of suggesting that u-boot get rebuilt with debugging enabled.
Since it can also be useful to script the operation, describe also a method whereby the relocation address is obtained from a register in a breakpoint.
Ben Gardiner (2): README.arm-relocation: get relocated address from bdinfo README.arm-relocation: get relocated address in gdb
doc/README.arm-relocation | 104 +++++++++++++++++++++++++++++++------------- 1 files changed, 73 insertions(+), 31 deletions(-)
The bdinfo command prints the relocaddr on ARM as it does on PPC.
Update the debugging instructions for arm relocation to reflect this fact rather than requiring that the user rebuild the u-boot image using -DDEBUG.
Signed-off-by: Ben Gardiner bengardiner@nanometrics.ca CC: Wolfgang Denk wd@denx.de
No changes since V1 / introduced in this version
--- doc/README.arm-relocation | 53 ++++++++++++++++++-------------------------- 1 files changed, 22 insertions(+), 31 deletions(-)
diff --git a/doc/README.arm-relocation b/doc/README.arm-relocation index c0957c2..8bfb500 100644 --- a/doc/README.arm-relocation +++ b/doc/README.arm-relocation @@ -106,13 +106,9 @@ TBC Debugging u-boot in RAM: (example on the qong board)
-a) add in config.mk: - -PLATFORM_CPPFLAGS += -DDEBUG - -----------------
-b) start debugger +a) start debugger
arm-linux-gdb u-boot
@@ -130,7 +126,7 @@ The target architecture is set automatically (currently arm)
-c) connect to target +b) connect to target
target remote bdi10:2001
@@ -141,7 +137,7 @@ Remote debugging using bdi10:2001
-d) discard symbol-file +c) discard symbol-file
(gdb) symbol-file Discard symbol table from `/home/hs/celf/u-boot/u-boot'? (y or n) y @@ -150,7 +146,7 @@ No symbol file now.
-e) load new symbol table: +d) load new symbol table:
(gdb) add-symbol-file u-boot 0x8ff08000 add symbol table from file "u-boot" at @@ -167,28 +163,23 @@ Program received signal SIGSTOP, Stopped (signal).
add-symbol-file u-boot 0x8ff08000 ^^^^^^^^^^ - get this address from u-boot debug printfs - -U-Boot 2010.06-rc2-00009-gf77b8b8-dirty (Jun 22 2010 - 09:43:46) - -U-Boot code: A0000000 -> A0058BAC BSS: -> A0061F10 -CPU: Freescale i.MX31 at 398 MHz -Board: DAVE/DENX Qong -mon: FFFFFFFF gd->monLen: 00061F10 -Top of RAM usable for U-Boot at: 90000000 -LCD panel info: 640 x 480, 16 bit/pix -Reserving 600k for LCD Framebuffer at: 8ff6a000 -Reserving 391k for U-Boot at: 8ff08000 - ^^^^^^^^ -Reserving 1280k for malloc() at: 8fdc8000 -Reserving 24 Bytes for Board Info at: 8fdc7fe8 -Reserving 52 Bytes for Global Data at: 8fdc7fb4 -New Stack Pointer is: 8fdc7fb0 -RAM Configuration: -Bank #0: 80000000 256 MiB -relocation Offset is: eff08000 -mon: 00058BAC gd->monLen: 00061F10 -Now running in RAM - U-Boot at: 8ff08000 - ^^^^^^^^ + get this address from u-boot bdinfo command + + => bdinfo +rch_number = XXXXXXXXXX +boot_params = XXXXXXXXXX +DRAM bank = XXXXXXXXXX +-> start = XXXXXXXXXX +-> size = XXXXXXXXXX +ethaddr = XXXXXXXXXX +ip_addr = XXXXXXXXXX +baudrate = XXXXXXXXXX +TLB addr = XXXXXXXXXX +relocaddr = 0x8ff08000 + ^^^^^^^^^^ +reloc off = XXXXXXXXXX +irq_sp = XXXXXXXXXX +sp start = XXXXXXXXXX +FB base = XXXXXXXXXX
Now you can use gdb as usual :-)
Dear Ben Gardiner,
In message 787a04417ee0eb01c6eb3a7a1edff7ee9a8f825e.1304008866.git.bengardiner@nanometrics.ca you wrote:
Applied, thanks.
When your emulator is connected at reset (or is used to load u-boot) it is possible to get the relocation address from the parameter passed to relocate_code() instead of building with -DDEBUG and extracting from the console messages.
Document this alternate method following the style of the original method written by Heiko Schocher.
Signed-off-by: Ben Gardiner bengardiner@nanometrics.ca CC: Heiko Schocher hs@denx.de CC: Wolfgang Denk wd@denx.de
Changes since V1: * update to reflect proposed changes to existing debug instructions: renumber seteps, remove note about -DDEBUG
--- doc/README.arm-relocation | 51 +++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 51 insertions(+), 0 deletions(-)
diff --git a/doc/README.arm-relocation b/doc/README.arm-relocation index 8bfb500..c5aef55 100644 --- a/doc/README.arm-relocation +++ b/doc/README.arm-relocation @@ -183,3 +183,54 @@ sp start = XXXXXXXXXX FB base = XXXXXXXXXX
Now you can use gdb as usual :-) + +An alternative to retrieving the relocated base address from the bdinfo command +is to evaluate the 'addr' parameter of relocate_code() and use its value as the +argument to add-symbol-file. This method is only available when your emulator +is connected to the target on reset. + +----------------- +a) [same as above] start debugger +b) [same as above] connect to target +[remainder is different than above] +----------------- + +c) set breakpoint on relocate_code + +(gdb) b relocate_code +Breakpoint 1 at 0xc1080078: file start.S, line 196. + +----------------- + +d) run target until relocate_code + +(gdb) c +Breakpoint 2, relocate_code () at start.S:197 +197 mov r5, r1 /* save addr of gd */ +(gdb) d +Delete all breakpoints? (y or n) y + +----------------- + +e) discard symbol file + +(gdb) symbol-file +Discard symbol table from `/home/bengardiner/src/u-boot/u-boot'? (y or n) y +No symbol file now. +(gdb) + +----------------- + +f) load new symbol table using the addr parameter (aka $r2) + +(gdb) add-symbol-file u-boot $r2 +add symbol table from file "u-boot" at + .text_addr = 0xc7f53000 +(y or n) y +Reading symbols from /home/bengardiner/src/u-boot/u-boot...done. + +----------------- + +g) set breakpoints for any function after (and including) board_init_r. +"Now you can use gdb as usual :-)" +
Hello Ben,
Changes since V1:
- update to reflect proposed changes to existing debug instructions: renumber seteps, remove note about -DDEBUG
Thanks!
Maybe we can add here also the info, that we can get this address through the bdinfo command?
- .text_addr = 0xc7f53000
bye, Heiko
Dear Ben Gardiner,
In message 713eaea232693cd6775d409b17c2e187328d1598.1304008866.git.bengardiner@nanometrics.ca you wrote:
Changes since V1:
Applied, thanks.
Ben Gardiner
Heiko Schocher
