[v3] configs: ls1046aqds: support distro boot
Add support of distro boot for ls1046aqds
Signed-off-by: Biwen Li biwen.li@nxp.com --- Change in v3 - fix warning of checkpatch Change in v2: - correct subject
include/configs/ls1046a_common.h | 18 +++++++++++++++++- include/configs/ls1046aqds.h | 30 +++++++++++++++++++----------- 2 files changed, 36 insertions(+), 12 deletions(-)
diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index e80c2996ef..24db23b3c3 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -217,6 +217,10 @@ #define LS1046A_BOOT_SRC_AND_HDR\ "boot_scripts=ls1046afrwy_boot.scr\0" \ "boot_script_hdr=hdr_ls1046afrwy_bs.out\0" +#elif defined(CONFIG_TARGET_LS1046AQDS) +#define LS1046A_BOOT_SRC_AND_HDR\ + "boot_scripts=ls1046aqds_boot.scr\0" \ + "boot_script_hdr=hdr_ls1046aqds_bs.out\0" #else #define LS1046A_BOOT_SRC_AND_HDR\ "boot_scripts=ls1046ardb_boot.scr\0" \ @@ -230,7 +234,7 @@ "ramdisk_size=0x2000000\0" \ "bootm_size=0x10000000\0" \ "fdt_addr=0x64f00000\0" \ - "kernel_addr=0x65000000\0" \ + "kernel_addr=0x61000000\0" \ "scriptaddr=0x80000000\0" \ "scripthdraddr=0x80080000\0" \ "fdtheader_addr_r=0x80100000\0" \ @@ -277,6 +281,18 @@ "&& sf read $kernelheader_addr_r $kernelheader_start " \ "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; " \ "bootm $load_addr#$board\0" \ + "nand_bootcmd=echo Trying load from nand..;" \ + "nand info; nand read $load_addr " \ + "$kernel_start $kernel_size; env exists secureboot " \ + "&& nand read $kernelheader_addr_r $kernelheader_start " \ + "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; " \ + "bootm $load_addr#$board\0" \ + "nor_bootcmd=echo Trying load from nor..;" \ + "cp.b $kernel_addr $load_addr " \ + "$kernel_size; env exists secureboot " \ + "&& cp.b $kernelheader_addr $kernelheader_addr_r " \ + "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; " \ + "bootm $load_addr#$board\0" \ "sd_bootcmd=echo Trying load from SD ..;" \ "mmcinfo; mmc read $load_addr " \ "$kernel_addr_sd $kernel_size_sd && " \ diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 0b17b1e994..d04ad00e76 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -440,19 +440,27 @@ unsigned long get_board_ddr_clk(void);
#undef CONFIG_BOOTCOMMAND #ifdef CONFIG_TFABOOT -#define QSPI_NOR_BOOTCOMMAND "sf probe && sf read $kernel_load " \ - "e0000 f00000 && bootm $kernel_load" -#define IFC_NOR_BOOTCOMMAND "cp.b $kernel_start $kernel_load " \ - "$kernel_size && bootm $kernel_load" -#define SD_BOOTCOMMAND "mmc info; mmc read $kernel_load" \ - "$kernel_addr_sd $kernel_size_sd && bootm $kernel_load" +#define IFC_NAND_BOOTCOMMAND "run distro_bootcmd; run nand_bootcmd; " \ + "env exists secureboot && esbc_halt;;" +#define QSPI_NOR_BOOTCOMMAND "run distro_bootcmd; run nor_bootcmd" \ + "env exists secureboot && esbc_halt;;" +#define IFC_NOR_BOOTCOMMAND "run distro_bootcmd; run nor_bootcmd; " \ + "env exists secureboot && esbc_halt;;" +#define SD_BOOTCOMMAND "run distro_bootcmd; run sd_bootcmd; " \ + "env exists secureboot && esbc_halt;;" #else -#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) -#define CONFIG_BOOTCOMMAND "sf probe && sf read $kernel_load " \ - "e0000 f00000 && bootm $kernel_load" +#if defined(CONFIG_QSPI_BOOT) +#define CONFIG_BOOTCOMMAND "run distro_bootcmd; run nor_bootcmd; " \ + "env exists secureboot && esbc_halt;;" +#elif defined(CONFIG_NAND_BOOT) +#define CONFIG_BOOTCOMMAND "run distro_bootcmd; run nand_bootcmd; " \ + "env exists secureboot && esbc_halt;;" +#elif defined(CONFIG_SD_BOOT) +#define CONFIG_BOOTCOMMAND "run distro_bootcmd; run sd_bootcmd; " \ + "env exists secureboot && esbc_halt;;" #else -#define CONFIG_BOOTCOMMAND "cp.b $kernel_start $kernel_load " \ - "$kernel_size && bootm $kernel_load" +#define CONFIG_BOOTCOMMAND "run distro_bootcmd; run nor_bootcmd; " \ + "env exists secureboot && esbc_halt;;" #endif #endif
Biwen Li
