[U-Boot-Users] [PATCH 7/8] SPARC: Added GRETH Ethernet 10/100/1000 support for LEON3
GRETH is an Ethernet 10/100 or 10/100/1000 MAC with out without a debug link (EDCL). The GRETH core is documented in GRIP.pdf available at www.gaisler.com.
If the GRETH has GigaBit support (GBIT, Scatter gather, checksum offloading etc.) can be determined by a bit in the control register. The GBIT MAC is supported by operating in GRTEH 10/100 legacy mode.
Best Regards, Daniel Hellstrom
drivers/net/Makefile | 1 + drivers/net/greth.c | 644 ++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/greth.h | 97 ++++++++ net/eth.c | 4 + 4 files changed, 746 insertions(+), 0 deletions(-)
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index b9723fa..be3a232 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -57,6 +57,7 @@ COBJS-y += tigon3.o COBJS-y += tsec.o COBJS-y += tsi108_eth.o COBJS-y += uli526x.o +COBJS-y += greth.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/net/greth.c b/drivers/net/greth.c new file mode 100644 index 0000000..3084771 --- /dev/null +++ b/drivers/net/greth.c @@ -0,0 +1,644 @@ +/* Gaisler.com GRETH 10/100/1000 Ethernet MAC driver + * + * Driver use polling mode (no Interrupt) + * + * (C) Copyright 2007 + * Daniel Hellstrom, Gaisler Research, daniel@gaisler.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <net.h> + +#ifdef CONFIG_GRETH + +#include <malloc.h> +#include <asm/processor.h> +#include <ambapp.h> +#include <asm/leon.h> + +/* #define DEBUG */ + +#include "greth.h" + +/* Default to 3s timeout on autonegotiation */ +#ifndef GRETH_PHY_TIMEOUT_MS + #define GRETH_PHY_TIMEOUT_MS 3000 +#endif + +/* ByPass Cache when reading regs */ +#define GRETH_REGLOAD(addr) SPARC_NOCACHE_READ(addr) +/* Write-through cache ==> no bypassing needed on writes */ +#define GRETH_REGSAVE(addr,data) (*(unsigned int *)(addr) = (data)) +#define GRETH_REGORIN(addr,data) GRETH_REGSAVE(addr,GRETH_REGLOAD(addr)|data) +#define GRETH_REGANDIN(addr,data) GRETH_REGSAVE(addr,GRETH_REGLOAD(addr)&data) + +#define GRETH_RXBD_CNT 4 +#define GRETH_TXBD_CNT 1 + +#define GRETH_RXBUF_SIZE 1540 +#define GRETH_BUF_ALIGN 4 +#define GRETH_RXBUF_EFF_SIZE \ + ( (GRETH_RXBUF_SIZE&~(GRETH_BUF_ALIGN-1))+GRETH_BUF_ALIGN ) + +typedef struct { + greth_regs *regs; + int irq; + struct eth_device *dev; + + /* Hardware info */ + unsigned char phyaddr; + int gbit_mac; + + /* Current operating Mode */ + int gb; /* GigaBit */ + int fd; /* Full Duplex */ + int sp; /* 10/100Mbps speed (1=100,0=10) */ + int auto_neg; /* Auto negotiate done */ + + unsigned char hwaddr[6]; /* MAC Address */ + + /* Descriptors */ + greth_bd *rxbd_base, *rxbd_max; + greth_bd *txbd_base, *txbd_max; + + greth_bd *rxbd_curr; + + /* rx buffers in rx descriptors */ + void *rxbuf_base; /* (GRETH_RXBUF_SIZE+ALIGNBYTES) * GRETH_RXBD_CNT */ + + /* unused for gbit_mac, temp buffer for sending packets with unligned + * start. + * Pointer to packet allocated with malloc. + */ + void *txbuf; + + struct { + /* rx status */ + unsigned int rx_packets, + rx_crc_errors, + rx_frame_errors, + rx_length_errors, + rx_errors; + + /* tx stats*/ + unsigned int tx_packets, + tx_latecol_errors, + tx_underrun_errors, + tx_limit_errors, + tx_errors; + } stats; +} greth_priv; + +/* Read MII register 'addr' from core 'regs' */ +static int read_mii(int addr, volatile greth_regs *regs) +{ + while (GRETH_REGLOAD(®s->mdio) & GRETH_MII_BUSY) {} + + GRETH_REGSAVE(®s->mdio, (0 << 11) | ((addr&0x1F) << 6) | 2); + + while (GRETH_REGLOAD(®s->mdio) & GRETH_MII_BUSY) {} + + if (!(GRETH_REGLOAD(®s->mdio) & GRETH_MII_NVALID)) { + return (GRETH_REGLOAD(®s->mdio)>>16)&0xFFFF; + } + else { + return -1; + } +} + +static void write_mii(int addr, int data, volatile greth_regs *regs) +{ + while (GRETH_REGLOAD(®s->mdio) & GRETH_MII_BUSY) {} + + GRETH_REGSAVE(®s->mdio, + ((data&0xFFFF)<<16) | (0 << 11) | ((addr&0x1F) << 6) | 1); + + while (GRETH_REGLOAD(®s->mdio) & GRETH_MII_BUSY) {} + +} + +/* init/start hardware and allocate descriptor buffers for rx side + * + */ +int greth_init(struct eth_device *dev, bd_t * bis) +{ + int i; + + greth_priv *greth = dev->priv; + greth_regs *regs = greth->regs; +#ifdef DEBUG + printf("greth_init\n"); +#endif + + GRETH_REGSAVE(®s->control,0); + + if ( !greth->rxbd_base ){ + + /* allocate descriptors */ + greth->rxbd_base = (greth_bd *) + memalign(0x1000,GRETH_RXBD_CNT*sizeof(greth_bd)); + greth->txbd_base = (greth_bd *) + memalign(0x1000,GRETH_RXBD_CNT*sizeof(greth_bd)); + + /* allocate buffers to all descriptors */ + greth->rxbuf_base = + malloc(GRETH_RXBUF_EFF_SIZE * GRETH_RXBD_CNT); + } + + /* initate rx decriptors */ + for(i=0; i<GRETH_RXBD_CNT; i++){ + greth->rxbd_base[i].addr = (unsigned int) + greth->rxbuf_base + (GRETH_RXBUF_EFF_SIZE*i); + /* enable desciptor & set wrap bit if last descriptor */ + if ( i >= (GRETH_RXBD_CNT-1) ){ + greth->rxbd_base[i].stat = GRETH_BD_EN | GRETH_BD_WR; + }else{ + greth->rxbd_base[i].stat = GRETH_BD_EN; + } + } + + /* initiate indexes */ + greth->rxbd_curr = greth->rxbd_base; + greth->rxbd_max = greth->rxbd_base+(GRETH_RXBD_CNT-1); + greth->txbd_max = greth->txbd_base+(GRETH_TXBD_CNT-1); + /* + * greth->txbd_base->addr = 0; + * greth->txbd_base->stat = GRETH_BD_WR; + */ + + /* initate tx decriptors */ + for(i=0; i<GRETH_TXBD_CNT; i++){ + greth->txbd_base[i].addr = 0; + /* enable desciptor & set wrap bit if last descriptor */ + if ( i >= (GRETH_RXBD_CNT-1) ){ + greth->txbd_base[i].stat = GRETH_BD_WR; + }else{ + greth->txbd_base[i].stat = 0; + } + } + + /**** SET HARDWARE REGS ****/ + + /* Set pointer to tx/rx descriptor areas */ + GRETH_REGSAVE(®s->rx_desc_p,(unsigned int)&greth->rxbd_base[0]); + GRETH_REGSAVE(®s->tx_desc_p,(unsigned int)&greth->txbd_base[0]); + + /* Enable Transmitter, GRETH will now scan descriptors for packets + * to transmitt */ +#ifdef DEBUG + printf("greth_init: enabling receiver\n"); +#endif + GRETH_REGORIN(®s->control, GRETH_RXEN); + + return 0; +} + +/* Initiate PHY to a relevant speed + * return: + * - 0 = success + * - 1 = timeout/fail + */ +int greth_init_phy(greth_priv *dev, bd_t * bis) +{ + greth_regs *regs = dev->regs; + int tmp,tmp1,tmp2,i; + unsigned int start, timeout; + + /* X msecs to ticks */ + timeout = usec2ticks(GRETH_PHY_TIMEOUT_MS*1000); + + /* Get system timer0 current value + * Total timeout is 5s + */ + start = get_timer(0); + + /* get phy control register default values */ + + while ((tmp = read_mii(0, regs)) & 0x8000) { + if ( get_timer(start) > timeout ) + return 1; /* Fail */ + } + + /* reset PHY and wait for completion */ + write_mii(0, 0x8000 | tmp, regs); + + while (((tmp = read_mii(0, regs))) & 0x8000) { + if ( get_timer(start) > timeout ) + return 1; /* Fail */ + } + + /* Check if PHY is autoneg capable and then determine operating + * mode, otherwise force it to 10 Mbit halfduplex + */ + dev->gb = 0; + dev->fd = 0; + dev->sp = 0; + dev->auto_neg = 0; + if (!((tmp >> 12) & 1)) { + write_mii(0, 0, regs); + } else { + /* wait for auto negotiation to complete and then check operating mode */ + dev->auto_neg = 1; + i = 0; + while (!(((tmp = read_mii(1, regs)) >> 5) & 1)) { + if ( get_timer(start) > timeout ) { + printf("Auto negotiation timed out. " + "Selecting default config\n"); + tmp = read_mii(0, regs); + dev->gb = ((tmp >> 6) & 1) && !((tmp >> 13) & 1); + dev->sp = !((tmp >> 6) & 1) && ((tmp >> 13) & 1); + dev->fd = (tmp >> 8) & 1; + goto auto_neg_done; + } + } + if ((tmp >> 8) & 1) { + tmp1 = read_mii(9, regs); + tmp2 = read_mii(10, regs); + if ( (tmp1 & GRETH_MII_EXTADV_1000FD) && + (tmp2 & GRETH_MII_EXTPRT_1000FD)) { + dev->gb = 1; + dev->fd = 1; + } + if ( (tmp1 & GRETH_MII_EXTADV_1000HD) && + (tmp2 & GRETH_MII_EXTPRT_1000HD)) { + dev->gb = 1; + dev->fd = 0; + } + } + if ((dev->gb == 0) || ((dev->gb == 1) && (dev->gbit_mac == 0))) { + tmp1 = read_mii(4, regs); + tmp2 = read_mii(5, regs); + if ( (tmp1 & GRETH_MII_100TXFD) && + (tmp2 & GRETH_MII_100TXFD)) { + dev->sp = 1; + dev->fd = 1; + } + if ( (tmp1 & GRETH_MII_100TXHD) && + (tmp2 & GRETH_MII_100TXHD)) { + dev->sp = 1; + dev->fd = 0; + } + if ( (tmp1 & GRETH_MII_10FD) && + (tmp2 & GRETH_MII_10FD)) { + dev->fd = 1; + } + if ((dev->gb == 1) && (dev->gbit_mac == 0)) { + dev->gb = 0; + dev->fd = 0; + write_mii(0, dev->sp << 13, regs); + } + } + + } +auto_neg_done: +#ifdef DEBUG + printf("%s GRETH Ethermac at [0x%x] irq %d. Running \ + %d Mbps %s duplex\n", dev->gbit_mac ? "10/100/1000":"10/100", + (unsigned int)(regs), (unsigned int)(dev->irq), + dev->gb ? 1000:(dev->sp ? 100:10), dev->fd ? "full":"half"); +#endif + /* Read out PHY info if extended registers are available */ + if (tmp & 1) { + tmp1 = read_mii(2, regs); + tmp2 = read_mii(3, regs); + tmp1 = (tmp1 << 6) | ((tmp2 >> 10) & 0x3F); + tmp = tmp2 & 0xF; + + tmp2 = (tmp2 >> 4) & 0x3F; +#ifdef DEBUG + printf("PHY: Vendor %x Device %x Revision %d\n", tmp1, tmp2, tmp); +#endif + } else { + printf("PHY info not available\n"); + } + + /* set speed and duplex bits in control register */ + GRETH_REGORIN(®s->control, (dev->gb << 8) | (dev->sp << 7) | (dev->fd << 4)); + + return 0; +} + +void greth_halt(struct eth_device *dev) +{ + greth_priv *greth; + greth_regs *regs; + int i; +#ifdef DEBUG + printf("greth_halt\n"); +#endif + if ( !dev || !dev->priv) + return; + + greth = dev->priv; + regs = greth->regs; + + if ( !regs ) + return; + + /* disable receiver/transmitter by clearing the enable bits */ + GRETH_REGANDIN(®s->control,~(GRETH_RXEN|GRETH_TXEN)); + + /* reset rx/tx descriptors */ + if ( greth->rxbd_base ){ + for(i=0; i<GRETH_RXBD_CNT; i++){ + greth->rxbd_base[i].stat = (i >= (GRETH_RXBD_CNT-1)) ? GRETH_BD_WR : 0; + } + } + + if ( greth->txbd_base ){ + for(i=0; i<GRETH_TXBD_CNT; i++){ + greth->txbd_base[i].stat = (i >= (GRETH_TXBD_CNT-1)) ? GRETH_BD_WR : 0; + } + } +} + +int greth_send(struct eth_device *dev, volatile void *eth_data, + int data_length) +{ + greth_priv *greth = dev->priv; + greth_regs *regs = greth->regs; + greth_bd *txbd; + void *txbuf; + unsigned int status; +#ifdef DEBUG + printf("greth_send\n"); +#endif + /* send data, wait for data to be sent, then return */ + if ( ((unsigned int)eth_data&(GRETH_BUF_ALIGN-1)) && !greth->gbit_mac ){ + /* data not aligned as needed by GRETH 10/100, solve this by allocating 4 byte aligned buffer + * and copy data to before giving it to GRETH. + */ + if ( !greth->txbuf ){ + greth->txbuf = malloc(GRETH_RXBUF_SIZE); +#ifdef DEBUG + printf("GRETH: allocated aligned tx-buf\n"); +#endif + } + + txbuf = greth->txbuf; + + /* copy data info buffer */ + memcpy((char *)txbuf,(char *)eth_data,data_length); + + /* keep buffer to next time */ + }else{ + txbuf = (void *)eth_data; + } + /* get descriptor to use, only 1 supported... hehe easy */ + txbd = greth->txbd_base; + + /* setup descriptor to wrap around to it self */ + txbd->addr = (unsigned int)txbuf; + txbd->stat = GRETH_BD_EN | GRETH_BD_WR | data_length; + + /* Remind Core which descriptor to use when sending */ + GRETH_REGSAVE(®s->tx_desc_p,(unsigned int)txbd); + + /* initate send by enabling transmitter */ + GRETH_REGORIN(®s->control,GRETH_TXEN); + + /* Wait for data to be sent */ + while( (status=GRETH_REGLOAD(&txbd->stat)) & GRETH_BD_EN ){ + ; + } + + /* was the packet transmitted succesfully? */ + if ( status & GRETH_TXBD_ERR_AL ){ + greth->stats.tx_limit_errors++; + } + + if ( status & GRETH_TXBD_ERR_UE ){ + greth->stats.tx_underrun_errors++; + } + + if ( status & GRETH_TXBD_ERR_LC ){ + greth->stats.tx_latecol_errors++; + } + + if ( status & (GRETH_TXBD_ERR_LC|GRETH_TXBD_ERR_UE|GRETH_TXBD_ERR_AL) ){ + /* any error */ + greth->stats.tx_errors++; + return -1; + } + + /* bump tx packet counter */ + greth->stats.tx_packets++; + + /* return succefully */ + return 0; +} + +int greth_recv(struct eth_device *dev) +{ + greth_priv *greth = dev->priv; + greth_regs *regs = greth->regs; + greth_bd *rxbd; + unsigned int status, len = 0, bad; + unsigned char *d; + int enable = 0; + int i; +#ifdef DEBUG +/* printf("greth_recv\n"); */ +#endif + /* Receive One packet only, but clear as many error packets as there are + * available. + */ + { + /* current receive descriptor */ + rxbd = greth->rxbd_curr; + + /* get status of next received packet */ + status = GRETH_REGLOAD(&rxbd->stat); + + bad = 0; + + /* stop if no more packets received */ + if (status & GRETH_BD_EN){ + goto done; + } + +#ifdef DEBUG + printf("greth_recv: packet 0x%lx, 0x%lx, len: %d\n",(unsigned int)rxbd,status, status&GRETH_BD_LEN); +#endif + + /* Check status for errors. + */ + if (status & GRETH_RXBD_ERR_FT) { + greth->stats.rx_length_errors++; + bad = 1; + } + if (status & (GRETH_RXBD_ERR_AE | GRETH_RXBD_ERR_OE)) { + greth->stats.rx_frame_errors++; + bad = 1; + } + if (status & GRETH_RXBD_ERR_CRC) { + greth->stats.rx_crc_errors++; + bad = 1; + } + if (bad) { + greth->stats.rx_errors++; + printf("greth_recv: Bad packet (%d, %d, %d, 0x%08x, %d)\n",greth->stats.rx_length_errors,greth->stats.rx_frame_errors,greth->stats.rx_crc_errors,status,greth->stats.rx_packets); + /* print all rx descriptors */ + for(i=0; i<GRETH_RXBD_CNT ; i++){ + printf("[%d]: Stat=0x%lx, Addr=0x%lx\n",i,GRETH_REGLOAD(&greth->rxbd_base[i].stat),GRETH_REGLOAD(&greth->rxbd_base[i].addr)); + } + }else{ + /* Process the incoming packet. */ + len = status & GRETH_BD_LEN; + d = (char *)rxbd->addr; +#ifdef DEBUG + printf("greth_recv: new packet, length: %d. data: %x %x %x %x %x %x %x %x\n",len,d[0],d[1],d[2],d[3],d[4],d[5],d[6],d[7]); +#endif + /* flush all data cache to make sure we're not reading old packet data */ + sparc_dcache_flush_all(); + + /* pass packet on to network subsystem */ + NetReceive((void *)d,len); + + /* bump stats counters */ + greth->stats.rx_packets++; + + /* bad is now 0 ==> will stop loop */ + } + + /* reenable descriptor to receive more packet with this descriptor, wrap around if needed */ + rxbd->stat = GRETH_BD_EN | (((unsigned int)greth->rxbd_curr >= (unsigned int)greth->rxbd_max) ? GRETH_BD_WR : 0); + enable = 1; + + /* increase index */ + greth->rxbd_curr = ((unsigned int)greth->rxbd_curr >= (unsigned int)greth->rxbd_max) ? greth->rxbd_base : (greth->rxbd_curr+1); + + }; + + if ( enable ){ + GRETH_REGORIN(®s->control, GRETH_RXEN); + } +done: + /* return positive length of packet or 0 if non recieved */ + return len; +} + +void greth_set_hwaddr(greth_priv *greth, unsigned char *mac) +{ + /* save new MAC address */ + greth->dev->enetaddr[0] = greth->hwaddr[0] = mac[0]; + greth->dev->enetaddr[1] = greth->hwaddr[1] = mac[1]; + greth->dev->enetaddr[2] = greth->hwaddr[2] = mac[2]; + greth->dev->enetaddr[3] = greth->hwaddr[3] = mac[3]; + greth->dev->enetaddr[4] = greth->hwaddr[4] = mac[4]; + greth->dev->enetaddr[5] = greth->hwaddr[5] = mac[5]; + greth->regs->esa_msb = (mac[0]<<8) | mac[1]; + greth->regs->esa_lsb = (mac[2]<<24) | (mac[3]<<16) | (mac[4]<<8) | mac[5]; +#ifdef DEBUG + printf("GRETH: New MAC address: %02x:%02x:%02x:%02x:%02x:%02x\n",mac[0],mac[1],mac[2],mac[3],mac[4],mac[5]); +#endif +} + +int greth_initialize(bd_t * bis) +{ + greth_priv *greth; + ambapp_apbdev apbdev; + struct eth_device *dev; + int i; + char *addr_str, *end; + unsigned char addr[6]; +#ifdef DEBUG + printf("Scanning for GRETH\n"); +#endif + /* Find Device & IRQ via AMBA Plug&Play information */ + if ( ambapp_apb_first(VENDOR_GAISLER,GAISLER_ETHMAC,&apbdev) != 1 ){ + return -1; /* GRETH not found */ + } + + greth = (greth_priv *)malloc(sizeof(greth_priv)); + dev = (struct eth_device *)malloc(sizeof(struct eth_device)); + memset(dev, 0, sizeof(struct eth_device)); + memset(greth, 0, sizeof(greth_priv)); + + greth->regs = (greth_regs *)apbdev.address; + greth->irq = apbdev.irq; +#ifdef DEBUG + printf("Found GRETH at 0x%lx, irq %d\n",greth->regs,greth->irq); +#endif + dev->priv = (void *)greth; + dev->iobase = (unsigned int)greth->regs; + dev->init = greth_init; + dev->halt = greth_halt; + dev->send = greth_send; + dev->recv = greth_recv; + greth->dev = dev; + + /* Reset Core */ + GRETH_REGSAVE(&greth->regs->control, GRETH_RESET); + + /* Wait for core to finish reset cycle */ + while (GRETH_REGLOAD(&greth->regs->control) & GRETH_RESET) + ; + + /* Get the phy address which assumed to have been set + correctly with the reset value in hardware */ + greth->phyaddr = (GRETH_REGLOAD(&greth->regs->mdio) >> 11) & 0x1F; + + /* Check if mac is gigabit capable */ + greth->gbit_mac = (GRETH_REGLOAD(&greth->regs->control) >> 27) & 1; + + /* Make descriptor string */ + if ( greth->gbit_mac ){ + sprintf(dev->name, "GRETH 10/100/GB"); + }else{ + sprintf(dev->name, "GRETH 10/100"); + } + + /* initiate PHY, select speed/duplex depending on connected PHY */ + if ( greth_init_phy(greth, bis) ){ + /* Failed to init PHY (timedout) */ + return -1; + } + + /* Register Device to EtherNet subsystem */ + eth_register(dev); + + /* Get MAC address */ + if ( (addr_str=getenv("ethaddr")) != NULL ) { + for (i=0; i<6; i++) { + addr[i] = addr_str ? simple_strtoul(addr_str, &end, 16) : 0; + if (addr_str){ + addr_str = (*end) ? end+1 : end; + } + } + }else{ + /* HW Address not found in environment, Set default HW address */ + addr[0] = GRETH_HWADDR_0; /* MSB */ + addr[1] = GRETH_HWADDR_1; + addr[2] = GRETH_HWADDR_2; + addr[3] = GRETH_HWADDR_3; + addr[4] = GRETH_HWADDR_4; + addr[5] = GRETH_HWADDR_5; /* LSB */ + } + + /* set and remember MAC address */ + greth_set_hwaddr(greth,addr); + + return 1; +} + +#endif diff --git a/drivers/net/greth.h b/drivers/net/greth.h new file mode 100644 index 0000000..7f75b74 --- /dev/null +++ b/drivers/net/greth.h @@ -0,0 +1,97 @@ +/* Gaisler.com GRETH 10/100/1000 Ethernet MAC driver + * + * (C) Copyright 2007 + * Daniel Hellstrom, Gaisler Research, daniel@gaisler.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define GRETH_FD 0x10 +#define GRETH_RESET 0x40 +#define GRETH_MII_BUSY 0x8 +#define GRETH_MII_NVALID 0x10 + +/* MII registers */ +#define GRETH_MII_EXTADV_1000FD 0x00000200 +#define GRETH_MII_EXTADV_1000HD 0x00000100 +#define GRETH_MII_EXTPRT_1000FD 0x00000800 +#define GRETH_MII_EXTPRT_1000HD 0x00000400 + +#define GRETH_MII_100T4 0x00000200 +#define GRETH_MII_100TXFD 0x00000100 +#define GRETH_MII_100TXHD 0x00000080 +#define GRETH_MII_10FD 0x00000040 +#define GRETH_MII_10HD 0x00000020 + +#define GRETH_BD_EN 0x800 +#define GRETH_BD_WR 0x1000 +#define GRETH_BD_IE 0x2000 +#define GRETH_BD_LEN 0x7FF + +#define GRETH_TXEN 0x1 +#define GRETH_INT_TX 0x8 +#define GRETH_TXI 0x4 +#define GRETH_TXBD_STATUS 0x0001C000 +#define GRETH_TXBD_MORE 0x20000 +#define GRETH_TXBD_IPCS 0x40000 +#define GRETH_TXBD_TCPCS 0x80000 +#define GRETH_TXBD_UDPCS 0x100000 +#define GRETH_TXBD_ERR_LC 0x10000 +#define GRETH_TXBD_ERR_UE 0x4000 +#define GRETH_TXBD_ERR_AL 0x8000 +#define GRETH_TXBD_NUM 128 +#define GRETH_TXBD_NUM_MASK (GRETH_TXBD_NUM-1) +#define GRETH_TX_BUF_SIZE 2048 + +#define GRETH_INT_RX 0x4 +#define GRETH_RXEN 0x2 +#define GRETH_RXI 0x8 +#define GRETH_RXBD_STATUS 0xFFFFC000 +#define GRETH_RXBD_ERR_AE 0x4000 +#define GRETH_RXBD_ERR_FT 0x8000 +#define GRETH_RXBD_ERR_CRC 0x10000 +#define GRETH_RXBD_ERR_OE 0x20000 +#define GRETH_RXBD_ERR_LE 0x40000 +#define GRETH_RXBD_IP_DEC 0x80000 +#define GRETH_RXBD_IP_CSERR 0x100000 +#define GRETH_RXBD_UDP_DEC 0x200000 +#define GRETH_RXBD_UDP_CSERR 0x400000 +#define GRETH_RXBD_TCP_DEC 0x800000 +#define GRETH_RXBD_TCP_CSERR 0x1000000 + +#define GRETH_RXBD_NUM 128 +#define GRETH_RXBD_NUM_MASK (GRETH_RXBD_NUM-1) +#define GRETH_RX_BUF_SIZE 2048 + +/* Ethernet configuration registers */ +typedef struct _greth_regs { + volatile unsigned int control; + volatile unsigned int status; + volatile unsigned int esa_msb; + volatile unsigned int esa_lsb; + volatile unsigned int mdio; + volatile unsigned int tx_desc_p; + volatile unsigned int rx_desc_p; +} greth_regs; + +/* Ethernet buffer descriptor */ +typedef struct _greth_bd { + volatile unsigned int stat; + unsigned int addr; /* Buffer address not changed by HW */ +} greth_bd; diff --git a/net/eth.c b/net/eth.c index 16a6dcb..3b86f87 100644 --- a/net/eth.c +++ b/net/eth.c @@ -60,6 +60,7 @@ extern int npe_initialize(bd_t *); extern int uec_initialize(int); extern int bfin_EMAC_initialize(bd_t *); extern int atstk1000_eth_initialize(bd_t *); +extern int greth_initialize(bd_t *); extern int atngw100_eth_initialize(bd_t *); extern int mcffec_initialize(bd_t*); extern int mcdmafec_initialize(bd_t*); @@ -275,6 +276,9 @@ int eth_initialize(bd_t *bis) #if defined(CONFIG_ATSTK1000) atstk1000_eth_initialize(bis); #endif +#if defined(CONFIG_GRETH) + greth_initialize(bis); +#endif #if defined(CONFIG_ATNGW100) atngw100_eth_initialize(bis); #endif
Line-wrapped, coding style.
- Driver use polling mode (no Interrupt)
- (C) Copyright 2007
- Daniel Hellstrom, Gaisler Research, daniel@gaisler.com
- project.
- MA 02111-1307 USA
Please move this to the Makefile
+#include "greth.h"
Please remove the whitespace too.
Best Regards, J.
Daniel Hellstrom
Jean-Christophe PLAGNIOL-VILLARD
