[v2] zlib: Fix big performance regression
Commit 340fdf1303dc ("zlib: Port fix for CVE-2016-9841 to U-Boot") brings a big performance regression in inflate_fast(), which leads to watchdog timer reset on powerpc 8xx.
It looks like that commit does more than what it describe, it especially removed an important optimisation that was doing copies using halfwords instead of bytes. That unexpected change multiplied by almost 4 the time spent in inflate_fast() and increased by 40% the overall time needed to uncompress linux kernel image.
So partially revert that commit but keep post incrementation as it is the initial purpose of said commit.
Fixes: 340fdf1303dc ("zlib: Port fix for CVE-2016-9841 to U-Boot") [trini: Combine assorted patches in to this one, just restoring the performance commit] Signed-off-by: Tom Rini trini@konsulko.com Signed-off-by: Christophe Leroy christophe.leroy@csgroup.eu --- Given that in master we now have Michal's series un-reverted, I have collapsed Christophe's series down to a patch that is just fixing the performance issues, while not regressing other platforms.
Cc: Michal Simek michal.simek@amd.com --- lib/zlib/inffast.c | 51 ++++++++++++++++++++++++++++++++++++---------- lib/zlib/zlib.h | 1 - 2 files changed, 40 insertions(+), 12 deletions(-)
diff --git a/lib/zlib/inffast.c b/lib/zlib/inffast.c index 5e2a65ad4d27..b5a0adcce69f 100644 --- a/lib/zlib/inffast.c +++ b/lib/zlib/inffast.c @@ -236,18 +236,47 @@ unsigned start; /* inflate()'s starting value for strm->avail_out */ } } else { + unsigned short *sout; + unsigned long loops; + from = out - dist; /* copy direct from output */ - do { /* minimum length is three */ - *out++ = *from++; - *out++ = *from++; - *out++ = *from++; - len -= 3; - } while (len > 2); - if (len) { - *out++ = *from++; - if (len > 1) - *out++ = *from++; - } + /* minimum length is three */ + /* Align out addr */ + if (!((long)(out - 1) & 1)) { + *out++ = *from++; + len--; + } + sout = (unsigned short *)out; + if (dist > 2 ) { + unsigned short *sfrom; + + sfrom = (unsigned short *)from; + loops = len >> 1; + do + *sout++ = get_unaligned(sfrom++); + while (--loops); + out = (unsigned char *)sout; + from = (unsigned char *)sfrom; + } else { /* dist == 1 or dist == 2 */ + unsigned short pat16; + + pat16 = *(sout - 1); + if (dist == 1) +#if defined(__BIG_ENDIAN) + pat16 = (pat16 & 0xff) | ((pat16 & 0xff ) << 8); +#elif defined(__LITTLE_ENDIAN) + pat16 = (pat16 & 0xff00) | ((pat16 & 0xff00 ) >> 8); +#else +#error __BIG_ENDIAN nor __LITTLE_ENDIAN is defined +#endif + loops = len >> 1; + do + *sout++ = pat16; + while (--loops); + out = (unsigned char *)sout; + } + if (len & 1) + *out++ = *from++; } } else if ((op & 64) == 0) { /* 2nd level distance code */ diff --git a/lib/zlib/zlib.h b/lib/zlib/zlib.h index 560e7be97d3a..f9b2f69ac027 100644 --- a/lib/zlib/zlib.h +++ b/lib/zlib/zlib.h @@ -10,7 +10,6 @@ /* avoid conflicts */ #undef OFF #undef ASMINF -#undef POSTINC #undef NO_GZIP #define GUNZIP #undef STDC
*out++ = *from++;
*out++ = *from++;
*out++ = *from++;
len -= 3;
} while (len > 2);
if (len) {
*out++ = *from++;
if (len > 1)
*out++ = *from++;
*out++ = *from++;
len--;
if (dist > 2 ) {
loops = len >> 1;
do
while (--loops);
if (dist == 1)
loops = len >> 1;
do
*sout++ = pat16;
while (--loops);
if (len & 1)
I am fine with whatever change which doesn't break functionality and address CVE. I took that code from upstream zlib version but I forget details why I removed this part of code.
Acked-by: Michal Simek michal.simek@amd.com
Thanks, Michal
Michal Simek
