[U-Boot] [PATCH v2] build: imx: Fix 'u-boot.imx' build without full OBJTREE reference
When calling 'make u-boot.imx' the build were failing as it were expecting the full path for the file; this regression has been included by commit 71a988a (imximage.cfg: run files through C preprocessor).
The direct references for u-boot.imx were replaced by $(obj) as config.mk handles the proper setting of it making it set to $(OBJTREE) when required.
The build has been test using:
- ./MAKEALL -s mx5 -s mx6 - make u-boot.imx - make O=/tmp/build
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v2: - Improve commit log - Fix out of tree build
Makefile | 4 ++-- arch/arm/cpu/arm926ejs/config.mk | 2 +- arch/arm/cpu/armv7/config.mk | 2 +- 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/Makefile b/Makefile index f4a9b33..a8c7b7b 100644 --- a/Makefile +++ b/Makefile @@ -467,8 +467,8 @@ $(obj)u-boot.img: $(obj)u-boot.bin sed -e 's/"[ ]*$$/ for $(BOARD) board"/') \ -d $< $@
-$(OBJTREE)/u-boot.imx : $(obj)u-boot.bin $(SUBDIR_TOOLS) depend - $(MAKE) -C $(SRCTREE)/arch/arm/imx-common $@ +$(obj)u-boot.imx: $(obj)u-boot.bin depend + $(MAKE) -C $(SRCTREE)/arch/arm/imx-common $(OBJTREE)/u-boot.imx
$(obj)u-boot.kwb: $(obj)u-boot.bin $(obj)tools/mkimage -n $(CONFIG_SYS_KWD_CONFIG) -T kwbimage \ diff --git a/arch/arm/cpu/arm926ejs/config.mk b/arch/arm/cpu/arm926ejs/config.mk index 47f24f5..6a3a1bb 100644 --- a/arch/arm/cpu/arm926ejs/config.mk +++ b/arch/arm/cpu/arm926ejs/config.mk @@ -34,6 +34,6 @@ PLATFORM_RELFLAGS += $(PF_RELFLAGS_SLB_AT)
ifneq ($(CONFIG_IMX_CONFIG),)
-ALL-y += $(OBJTREE)/u-boot.imx +ALL-y += $(obj)u-boot.imx
endif diff --git a/arch/arm/cpu/armv7/config.mk b/arch/arm/cpu/armv7/config.mk index 350e946..9c3e2f3 100644 --- a/arch/arm/cpu/armv7/config.mk +++ b/arch/arm/cpu/armv7/config.mk @@ -40,5 +40,5 @@ PF_NO_UNALIGNED := $(call cc-option, -mno-unaligned-access,) PLATFORM_NO_UNALIGNED := $(PF_NO_UNALIGNED)
ifneq ($(CONFIG_IMX_CONFIG),) -ALL-y += $(OBJTREE)/u-boot.imx +ALL-y += $(obj)u-boot.imx endif
Dear Otavio Salvador,
- make u-boot.imx
- make O=/tmp/build
BUILD_DIR=/tmp/xyz MAKEALL please.
Best regards, Marek Vasut
Dear Otavio, Marek,
- make u-boot.imx
- make O=/tmp/build
Once you're confident with this patch, do you mind if I integrate it as is in my MXC NAND + SPL series in order to avoid merge conflicts (unless it is applied before)?
Best regards, Benoît
On Tue, Feb 12, 2013 at 12:01 PM, Benoît Thébaudeau benoit.thebaudeau@advansee.com wrote:
Dear Otavio, Marek,
- make u-boot.imx
- make O=/tmp/build
Alright; It did the test Marek has requested and it works fine. I think this should go to imx/master as it fixes a regression.
Hi Otavio,
Dear Otavio, Marek,
- make u-boot.imx
- make O=/tmp/build
OK. I include it into my series so that patches apply fine whether Stefano applies it alone first or from my series.
On 12/02/2013 18:55, Benoît Thébaudeau wrote:
Hi Otavio,
Hi Benoît,
I merged it - you do not need to bother about it.
Best regards, Stefano
Hi Stefano,
Hi Otavio,
Hi Benoît,
Great, thanks.
Benoît Thébaudeau
Otavio Salvador
Stefano Babic
