[U-Boot] [PATCH v2] sun8i: h3: Add support for the Beelink-x2 STB
The Beelink X2 is an STB based on the Allwinner H3 SoC with a uSD slot, 2 USB ports( 1 * USB-2 Host, 1 USB OTG), a 10/100M ethernet port using the SoC's integrated PHY, Wifi via an sdio wifi chip, HDMI, an IR receiver, a dual colour LED and an optical S/PDIF connector.
Signed-off-by: Marcus Cooper codekipper@gmail.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun8i-h3-beelink-x2.dts | 179 +++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 + configs/beelink_x2_defconfig | 19 +++ 4 files changed, 204 insertions(+) create mode 100644 arch/arm/dts/sun8i-h3-beelink-x2.dts create mode 100644 configs/beelink_x2_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 1cbb45d679..cc217d4f98 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -370,6 +370,7 @@ dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h2-plus-orangepi-r1.dtb \ sun8i-h2-plus-orangepi-zero.dtb \ sun8i-h3-bananapi-m2-plus.dtb \ + sun8i-h3-beelink-x2.dtb \ sun8i-h3-libretech-all-h3-cc.dtb \ sun8i-h3-nanopi-m1.dtb \ sun8i-h3-nanopi-m1-plus.dtb \ diff --git a/arch/arm/dts/sun8i-h3-beelink-x2.dts b/arch/arm/dts/sun8i-h3-beelink-x2.dts new file mode 100644 index 0000000000..683c5c31a9 --- /dev/null +++ b/arch/arm/dts/sun8i-h3-beelink-x2.dts @@ -0,0 +1,179 @@ +// SPDX-License-Identifier: GPL-2.0+ +// +// Device Tree Source for Beelink X2 +// +// Copyright (C) 2018 Marcus Cooper codekipper@gmail.com +/dts-v1/; +#include "sun8i-h3.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> + +/ { + model = "Beelink X2"; + compatible = "roofull,beelink-x2", "allwinner,sun8i-h3"; + + aliases { + serial0 = &uart0; + /* ethernet0 is the H3 emac, defined in sun8i-h3.dtsi */ + ethernet1 = &sdiowifi; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + blue { + label = "beelink-x2:blue:pwr"; + gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; /* PL10 */ + default-state = "on"; + }; + + red { + label = "beelink-x2:red:standby"; + gpios = <&pio 0 15 GPIO_ACTIVE_HIGH>; /* PA15 */ + }; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&r_pio 0 7 GPIO_ACTIVE_LOW>; /* PL7 */ + }; + + sound_spdif { + compatible = "simple-audio-card"; + simple-audio-card,name = "On-board SPDIF"; + + simple-audio-card,cpu { + sound-dai = <&spdif>; + }; + + simple-audio-card,codec { + sound-dai = <&spdif_out>; + }; + }; + + spdif_out: spdif-out { + #sound-dai-cells = <0>; + compatible = "linux,spdif-dit"; + }; +}; + +&de { + status = "okay"; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&emac { + phy-handle = <&int_mii_phy>; + phy-mode = "mii"; + allwinner,leds-active-low; + status = "okay"; +}; + +&hdmi { + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&ir { + pinctrl-names = "default"; + pinctrl-0 = <&ir_pins_a>; + status = "okay"; +}; + +&mmc0 { + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ + status = "okay"; +}; + +&mmc1 { + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + non-removable; + status = "okay"; + + /* + * Explicitly define the sdio device, so that we can add an ethernet + * alias for it (which e.g. makes u-boot set a mac-address). + */ + sdiowifi: sdio_wifi@1 { + reg = <1>; + }; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_8bit_pins>; + vmmc-supply = <®_vcc3v3>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +®_usb0_vbus { + gpio = <&r_pio 0 2 GPIO_ACTIVE_HIGH>; /* PL2 */ + status = "okay"; +}; + +&spdif { + pinctrl-names = "default"; + pinctrl-0 = <&spdif_tx_pins_a>; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usbphy { + /* USB VBUS is always on except for the OTG port */ + status = "okay"; + usb0_id_det-gpios = <&pio 0 7 GPIO_ACTIVE_HIGH>; /* PA07 */ + usb0_vbus-supply = <®_usb0_vbus>; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 478e37285f..6417158fd1 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -159,6 +159,11 @@ M: Jagan Teki jagan@amarulasolutions.com S: Maintained F: configs/bananapi_m64_defconfig
+BEELINK X2 BOARD +M: Marcus Cooper codekipper@gmail.com +S: Maintained +F: configs/beelink_x2_defconfig + COLOMBUS BOARD M: Maxime Ripard maxime.ripard@bootlin.com S: Maintained diff --git a/configs/beelink_x2_defconfig b/configs/beelink_x2_defconfig new file mode 100644 index 0000000000..6508e470a0 --- /dev/null +++ b/configs/beelink_x2_defconfig @@ -0,0 +1,19 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL=y +CONFIG_MACH_SUN8I_H3=y +CONFIG_DRAM_CLK=624 +CONFIG_DRAM_ZQ=3881979 +CONFIG_DRAM_ODT_EN=y +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-beelink-x2" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SPL_I2C_SUPPORT=y +# CONFIG_CMD_FLASH is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN8I_EMAC=y +CONFIG_SY8106A_POWER=y +CONFIG_USB_EHCI_HCD=y +CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y
need space, but this doesn't look like Linux sync. better sync it directly w/o any changes, if you need updated license do first in Linux.
otherwise,
Reviewed-by: Jagan Teki jagan@openedev.com
Jagan Teki
