[U-Boot] [PATCH] mips: bmips: increment SYS_MALLOC_F_LEN
This prevents the following ENOMEM: Error binding driver 'bmips_cpu': -12
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com --- arch/mips/mach-bmips/Kconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/mips/mach-bmips/Kconfig b/arch/mips/mach-bmips/Kconfig index e3e1da3c28..db8b40523a 100644 --- a/arch/mips/mach-bmips/Kconfig +++ b/arch/mips/mach-bmips/Kconfig @@ -1,6 +1,9 @@ menu "Broadcom MIPS platforms" depends on ARCH_BMIPS
+config SYS_MALLOC_F_LEN + default 0x1000 + config SYS_SOC default "bcm3380" if SOC_BMIPS_BCM3380 default "bcm6328" if SOC_BMIPS_BCM6328
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
Applied to u-boot-mips/next, thanks.
Daniel Schwierzeck
