[PATCH] arm64: zynqmp: Used fixed-partitions for QSPI in k26
Using fixed partitions is recommended way how to describe QSPI. Also add label for qspi flash memory to be able to reference it in future.
Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/dts/zynqmp-sm-k26-revA.dts | 163 +++++++++++++++------------- 1 file changed, 85 insertions(+), 78 deletions(-)
diff --git a/arch/arm/dts/zynqmp-sm-k26-revA.dts b/arch/arm/dts/zynqmp-sm-k26-revA.dts index 7c2bfa395da7..ac349a9dcc5d 100644 --- a/arch/arm/dts/zynqmp-sm-k26-revA.dts +++ b/arch/arm/dts/zynqmp-sm-k26-revA.dts @@ -130,7 +130,7 @@
&qspi { /* MIO 0-5 - U143 */ status = "okay"; - flash@0 { /* MT25QU512A */ + spi_flash: flash@0 { /* MT25QU512A */ compatible = "mt25qu512a", "jedec,spi-nor"; /* 64MB */ #address-cells = <1>; #size-cells = <1>; @@ -138,83 +138,90 @@ spi-tx-bus-width = <4>; spi-rx-bus-width = <4>; spi-max-frequency = <40000000>; /* 40MHz */ - partition@0 { - label = "Image Selector"; - reg = <0x0 0x80000>; /* 512KB */ - read-only; - lock; - }; - partition@80000 { - label = "Image Selector Golden"; - reg = <0x80000 0x80000>; /* 512KB */ - read-only; - lock; - }; - partition@100000 { - label = "Persistent Register"; - reg = <0x100000 0x20000>; /* 128KB */ - }; - partition@120000 { - label = "Persistent Register Backup"; - reg = <0x120000 0x20000>; /* 128KB */ - }; - partition@140000 { - label = "Open_1"; - reg = <0x140000 0xC0000>; /* 768KB */ - }; - partition@200000 { - label = "Image A (FSBL, PMU, ATF, U-Boot)"; - reg = <0x200000 0xD00000>; /* 13MB */ - }; - partition@f00000 { - label = "ImgSel Image A Catch"; - reg = <0xF00000 0x80000>; /* 512KB */ - read-only; - lock; - }; - partition@f80000 { - label = "Image B (FSBL, PMU, ATF, U-Boot)"; - reg = <0xF80000 0xD00000>; /* 13MB */ - }; - partition@1c80000 { - label = "ImgSel Image B Catch"; - reg = <0x1C80000 0x80000>; /* 512KB */ - read-only; - lock; - }; - partition@1d00000 { - label = "Open_2"; - reg = <0x1D00000 0x100000>; /* 1MB */ - }; - partition@1e00000 { - label = "Recovery Image"; - reg = <0x1E00000 0x200000>; /* 2MB */ - read-only; - lock; - }; - partition@2000000 { - label = "Recovery Image Backup"; - reg = <0x2000000 0x200000>; /* 2MB */ - read-only; - lock; - }; - partition@2200000 { - label = "U-Boot storage variables"; - reg = <0x2200000 0x20000>; /* 128KB */ - }; - partition@2220000 { - label = "U-Boot storage variables backup"; - reg = <0x2220000 0x20000>; /* 128KB */ - }; - partition@2240000 { - label = "SHA256"; - reg = <0x2240000 0x10000>; /* 256B but 64KB sector */ - read-only; - lock; - }; - partition@2250000 { - label = "User"; - reg = <0x2250000 0x1db0000>; /* 29.5 MB */ + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "Image Selector"; + reg = <0x0 0x80000>; /* 512KB */ + read-only; + lock; + }; + partition@80000 { + label = "Image Selector Golden"; + reg = <0x80000 0x80000>; /* 512KB */ + read-only; + lock; + }; + partition@100000 { + label = "Persistent Register"; + reg = <0x100000 0x20000>; /* 128KB */ + }; + partition@120000 { + label = "Persistent Register Backup"; + reg = <0x120000 0x20000>; /* 128KB */ + }; + partition@140000 { + label = "Open_1"; + reg = <0x140000 0xC0000>; /* 768KB */ + }; + partition@200000 { + label = "Image A (FSBL, PMU, ATF, U-Boot)"; + reg = <0x200000 0xD00000>; /* 13MB */ + }; + partition@f00000 { + label = "ImgSel Image A Catch"; + reg = <0xF00000 0x80000>; /* 512KB */ + read-only; + lock; + }; + partition@f80000 { + label = "Image B (FSBL, PMU, ATF, U-Boot)"; + reg = <0xF80000 0xD00000>; /* 13MB */ + }; + partition@1c80000 { + label = "ImgSel Image B Catch"; + reg = <0x1C80000 0x80000>; /* 512KB */ + read-only; + lock; + }; + partition@1d00000 { + label = "Open_2"; + reg = <0x1D00000 0x100000>; /* 1MB */ + }; + partition@1e00000 { + label = "Recovery Image"; + reg = <0x1E00000 0x200000>; /* 2MB */ + read-only; + lock; + }; + partition@2000000 { + label = "Recovery Image Backup"; + reg = <0x2000000 0x200000>; /* 2MB */ + read-only; + lock; + }; + partition@2200000 { + label = "U-Boot storage variables"; + reg = <0x2200000 0x20000>; /* 128KB */ + }; + partition@2220000 { + label = "U-Boot storage variables backup"; + reg = <0x2220000 0x20000>; /* 128KB */ + }; + partition@2240000 { + label = "SHA256"; + reg = <0x2240000 0x10000>; /* 256B but 64KB sector */ + read-only; + lock; + }; + partition@2250000 { + label = "User"; + reg = <0x2250000 0x1db0000>; /* 29.5 MB */ + }; }; }; };
po 20. 6. 2022 v 15:46 odesÃlatel Michal Simek monstr@monstr.eu napsal:
partition@0 {
read-only;
lock;
partition@80000 {
read-only;
lock;
partition@100000 {
partition@120000 {
partition@140000 {
label = "Open_1";
partition@200000 {
partition@f00000 {
read-only;
lock;
partition@f80000 {
partition@1c80000 {
read-only;
lock;
partition@1d00000 {
label = "Open_2";
partition@1e00000 {
read-only;
lock;
partition@2000000 {
read-only;
lock;
partition@2200000 {
partition@2220000 {
partition@2240000 {
label = "SHA256";
read-only;
lock;
partition@2250000 {
label = "User";
partitions {
#size-cells = <1>;
partition@0 {
read-only;
lock;
partition@80000 {
read-only;
lock;
partition@100000 {
partition@120000 {
partition@140000 {
label = "Open_1";
partition@200000 {
partition@f00000 {
read-only;
lock;
partition@f80000 {
partition@1c80000 {
read-only;
lock;
partition@1d00000 {
label = "Open_2";
partition@1e00000 {
read-only;
lock;
partition@2000000 {
read-only;
lock;
partition@2200000 {
partition@2220000 {
partition@2240000 {
label = "SHA256";
read-only;
lock;
partition@2250000 {
label = "User";
2.36.1
Applied. M
Michal Simek
