[PATCH 0/2] odroid-go2: two small config changes
Hello,
The following series contain two config changes for odroid go2 board.
Roger Pau Monné (2): odroid-go2: do not disable EFI odroid-go2: fix default FDT file path
configs/odroid-go2_defconfig | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
Remove the unset of the EFI loader, it's possible for U-Boot to provide a EFI environment on this board, and it's also required by the FreeBSD loader which mandated EFI on Aarch64.
Signed-off-by: Roger Pau Monné royger@FreeBSD.org --- configs/odroid-go2_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/odroid-go2_defconfig b/configs/odroid-go2_defconfig index 5632b15611..be7ba09334 100644 --- a/configs/odroid-go2_defconfig +++ b/configs/odroid-go2_defconfig @@ -109,4 +109,3 @@ CONFIG_SPL_TINY_MEMSET=y CONFIG_TPL_TINY_MEMSET=y CONFIG_LZO=y CONFIG_ERRNO_STR=y -# CONFIG_EFI_LOADER is not set
Forgot to add maintainer, doing it now, sorry for the spam.
2.30.1
The path in the Linux kernel dts directory is rockchip/rk3326-odroid-go2.dtb.
That also seems to match the FDT path set on other boards (ie: rock64-rk3328 for example).
Signed-off-by: Roger Pau Monne royger@FreeBSD.org --- configs/odroid-go2_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/odroid-go2_defconfig b/configs/odroid-go2_defconfig index be7ba09334..6aa41e3755 100644 --- a/configs/odroid-go2_defconfig +++ b/configs/odroid-go2_defconfig @@ -24,7 +24,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_BEST_MATCH=y CONFIG_SPL_LOAD_FIT=y -CONFIG_DEFAULT_FDT_FILE="rk3326-odroidgo2.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3326-odroid-go2.dtb" # CONFIG_CONSOLE_MUX is not set # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y
Forgot to Cc the maintainer, doing it now, sorry for the spam.
diff --git a/configs/odroid-go2_defconfig b/configs/odroid-go2_defconfig index be7ba09334..6aa41e3755 100644 --- a/configs/odroid-go2_defconfig +++ b/configs/odroid-go2_defconfig @@ -24,7 +24,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_BEST_MATCH=y CONFIG_SPL_LOAD_FIT=y -CONFIG_DEFAULT_FDT_FILE="rk3326-odroidgo2.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3326-odroid-go2.dtb" # CONFIG_CONSOLE_MUX is not set # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -- 2.30.1
Roger Pau Monné
