[RESEND PATCH 1/1] clk: ti: k3-pll: Add calibration support for non fractional mode
PLL calibration needs to be enabled when operating in non fractional mode. Add the sequence to do a fast calibration when using PLL in this mode.
Signed-off-by: Vishal Mahaveer vishalm@ti.com --- drivers/clk/ti/clk-k3-pll.c | 81 ++++++++++++++++++++++++++++++++++--- 1 file changed, 75 insertions(+), 6 deletions(-)
diff --git a/drivers/clk/ti/clk-k3-pll.c b/drivers/clk/ti/clk-k3-pll.c index bf762c558ef..c1158c13290 100644 --- a/drivers/clk/ti/clk-k3-pll.c +++ b/drivers/clk/ti/clk-k3-pll.c @@ -25,6 +25,23 @@ #define PLL_16FFT_FREQ_CTRL0 0x30 #define PLL_16FFT_FREQ_CTRL1 0x34 #define PLL_16FFT_DIV_CTRL 0x38 +#define PLL_16FFT_CAL_CTRL 0x60 +#define PLL_16FFT_CAL_STAT 0x64 + +/* CAL STAT register bits */ +#define PLL_16FFT_CAL_STAT_CAL_LOCK BIT(31) + +/* CFG register bits */ +#define PLL_16FFT_CFG_PLL_TYPE_SHIFT (0) +#define PLL_16FFT_CFG_PLL_TYPE_MASK (0x3 << 0) +#define PLL_16FFT_CFG_PLL_TYPE_FRACF 1 + +/* CAL CTRL register bits */ +#define PLL_16FFT_CAL_CTRL_CAL_EN BIT(31) +#define PLL_16FFT_CAL_CTRL_FAST_CAL BIT(20) +#define PLL_16FFT_CAL_CTRL_CAL_BYP BIT(15) +#define PLL_16FFT_CAL_CTRL_CAL_CNT_SHIFT 16 +#define PLL_16FFT_CAL_CTRL_CAL_CNT_MASK (0x7 << 16)
/* CTRL register bits */ #define PLL_16FFT_CTRL_BYPASS_EN BIT(31) @@ -40,9 +57,14 @@ /* DIV CTRL register bits */ #define PLL_16FFT_DIV_CTRL_REF_DIV_MASK 0x3f
-#define PLL_16FFT_FREQ_CTRL1_FB_DIV_FRAC_BITS 24 +/* HSDIV register bits*/ #define PLL_16FFT_HSDIV_CTRL_CLKOUT_EN BIT(15)
+/* FREQ_CTRL1 bits */ +#define PLL_16FFT_FREQ_CTRL1_FB_DIV_FRAC_BITS 24 +#define PLL_16FFT_FREQ_CTRL1_FB_DIV_FRAC_MASK 0xffffff +#define PLL_16FFT_FREQ_CTRL1_FB_DIV_FRAC_SHIFT 0 + /* KICK register magic values */ #define PLL_KICK0_VALUE 0x68ef3490 #define PLL_KICK1_VALUE 0xd172bc5a @@ -63,18 +85,65 @@ static int ti_pll_wait_for_lock(struct clk *clk) { struct ti_pll_clk *pll = to_clk_pll(clk); u32 stat; + u32 cfg; + u32 cal; + u32 freq_ctrl1; int i; + u32 pllfm; + u32 pll_type; + int success;
for (i = 0; i < 100000; i++) { stat = readl(pll->reg + PLL_16FFT_STAT); - if (stat & PLL_16FFT_STAT_LOCK) - return 0; + if (stat & PLL_16FFT_STAT_LOCK) { + success = 1; + break; + } }
- printf("%s: pll (%s) failed to lock\n", __func__, - clk->dev->name); + /* Enable calibration if not in fractional mode of the FRACF PLL */ + freq_ctrl1 = readl(pll->reg + PLL_16FFT_FREQ_CTRL1); + pllfm = freq_ctrl1 & PLL_16FFT_FREQ_CTRL1_FB_DIV_FRAC_MASK; + pllfm >>= PLL_16FFT_FREQ_CTRL1_FB_DIV_FRAC_SHIFT; + cfg = readl(pll->reg + PLL_16FFT_CFG); + pll_type = (cfg & PLL_16FFT_CFG_PLL_TYPE_MASK) >> PLL_16FFT_CFG_PLL_TYPE_SHIFT; + + if (success && pll_type == PLL_16FFT_CFG_PLL_TYPE_FRACF && pllfm == 0) { + cal = readl(pll->reg + PLL_16FFT_CAL_CTRL);
- return -EBUSY; + /* Enable calibration for FRACF */ + cal |= PLL_16FFT_CAL_CTRL_CAL_EN; + + /* Enable fast cal mode */ + cal |= PLL_16FFT_CAL_CTRL_FAST_CAL; + + /* Disable calibration bypass */ + cal &= ~PLL_16FFT_CAL_CTRL_CAL_BYP; + + /* Set CALCNT to 2 */ + cal &= ~PLL_16FFT_CAL_CTRL_CAL_CNT_MASK; + cal |= 2 << PLL_16FFT_CAL_CTRL_CAL_CNT_SHIFT; + + /* Note this register does not readback the written value. */ + writel(cal, pll->reg + PLL_16FFT_CAL_CTRL); + + success = 0; + for (i = 0; i < 100000; i++) { + stat = readl(pll->reg + PLL_16FFT_CAL_STAT); + if (stat & PLL_16FFT_CAL_STAT_CAL_LOCK) { + success = 1; + break; + } + } + } + + if (success == 0) { + printf("%s: pll (%s) failed to lock\n", __func__, + clk->dev->name); + return -EBUSY; + } else { + return 0; + } }
static ulong ti_pll_clk_get_rate(struct clk *clk)
Hi Vishal!
+Tom
On October 23, 2023 thus sayeth Vishal Mahaveer:
Reviewed-by: Bryan Brattlof bb@ti.com
Thanks for fixing this! I've tested the am62x and the j721e and this appears to properly setup the PLLs without firmware's help after :)
~Bryan
Bryan Brattlof
Vishal Mahaveer
