[U-Boot-Users] [PATCH] sh: Update MS7750SE01 platform
Update MS7750SE01 platform. - Add support type-R mode - Add support sh7751
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- board/ms7750se/lowlevel_init.S | 63 +++++++++++++++++++------------- board/ms7750se/ms7750se.c | 2 +- include/configs/ms7750se.h | 79 ++++++++++++++++++++++++++++------------ 3 files changed, 94 insertions(+), 50 deletions(-)
diff --git a/board/ms7750se/lowlevel_init.S b/board/ms7750se/lowlevel_init.S index 056c691..360c9fa 100644 --- a/board/ms7750se/lowlevel_init.S +++ b/board/ms7750se/lowlevel_init.S @@ -1,7 +1,28 @@ /* - modified from SH-IPL+g - Renesaso SuperH Solution Enginge MS775x BSC setting - Coyright (c) 2007 Nobuhiro Iwamatsu + modified from SH-IPL+g + Renesaso SuperH / Solution Enginge MS775xSE01 BSC setting. + + Support CPU : SH7750/SH7750S/SH7750R/SH7751/SH7751R + + Coyright (c) 2007 Nobuhiro Iwamatsu iwmatsu@nigauri.org + + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA */
#include <config.h> @@ -9,38 +30,34 @@
#include <asm/processor.h>
-#ifdef CONFIG_CPU_SUBTYPE_SH7751 +#ifdef CONFIG_CPU_SH7751 #define BCR2_D_VALUE 0x2FFC /* Area 1-6 width: 32/32/32/32/32/16 */ #define WCR1_D_VALUE 0x02770771 /* DMA:0 A6:2 A3:0 A0:1 Others:15 */ -#ifdef CONFIG_MRSHPC +#ifdef CONFIG_MARUBUN_PCCARD #define WCR2_D_VALUE 0xFFFE4FE7 /* A6:15 A6B:7 A5:15 A5B:7 A4:15 A3:2 A2:15 A1:15 A0:6 A0B:7 */ -#else /* CONFIG_MRSHPC*/ +#else /* CONFIG_MARUBUN_PCCARD */ #define WCR2_D_VALUE 0x7FFE4FE7 /* A6:3 A6B:7 A5:15 A5B:7 A4:15 A3:2 A2:15 A1:15 A0:6 A0B:7 */ -#endif /* CONFIG_MRSHPC */ +#endif /* CONFIG_MARUBUN_PCCARD */ #define WCR3_D_VALUE 0x01777771 /* A6: 0-1 A5: 1-3 A4: 1-3 A3: 1-3 A2: 1-3 A1: 1-3 A0: 0-1 */ -#define LED_ADDRESS 0xBA000000 /* Address of LED register */ #define RTCOR_D_VALUE 0xA50D /* Write code A5, data 0D (~15us?) */ #define SDMR3_ADDRESS 0xFF940088 /* SDMR3 address on 32-bit bus */ #define MCR_D1_VALUE 0x100901B4 /* SDRAM 32-bit, CAS/RAS Refresh, ... */ #define MCR_D2_VALUE 0x500901B4 /* Same w/MRSET now 1 (mode reg cmd) */ -#define SWITCH_ADDR 0xB9000000 /* Address of DIP switches */ -#else /* CONFIG_CPU_SUBTYPE_SH7751 */ +#else /* CONFIG_CPU_SH7751 */ #define BCR2_D_VALUE 0x2E3C /* Area 1-6 width: 32/32/64/16/32/16 */ #define WCR1_D_VALUE 0x02720777 /* DMA:0 A6:2 A4:2 A3:0 Others:15 */ #define WCR2_D_VALUE 0xFFFE4FFF /* A6:15 A6B:7 A5:15 A5B:7 A4:15 A3:2 A2:15 A1:15 A0:15 A0B:7 */ #define WCR3_D_VALUE 0x01717771 /* A6: 0-1 A5: 1-3 A4: 0-1 A3: 1-3 A2: 1-3 A1: 1-3 A0: 0-1 */ -#define LED_ADDRESS 0xB0C00000 /* Address of LED register */ #define RTCOR_D_VALUE 0xA510 /* Write code A5, data 10 (~15us?) */ #define SDMR3_ADDRESS 0xFF940110 /* SDMR3 address on 64-bit bus */ #define MCR_D1_VALUE 0x8801001C /* SDRAM 64-bit, CAS/RAS Refresh, ... */ #define MCR_D2_VALUE 0xC801001C /* Same w/MRSET now 1 (mode reg cmd) */ -#define SWITCH_ADDR 0xb0800000 /* Address of DIP switches */ -#endif /* CONFIG_CPU_SUBTYPE_SH7751 */ +#endif /* CONFIG_CPU_SH7751 */
.global lowlevel_init .text @@ -48,8 +65,8 @@
lowlevel_init:
- mov.l L_CCR, r1 ! CCR Address - mov.l L_CCR_DISABLE, r0 ! CCR Data + mov.l CCR_A, r1 ! CCR Address + mov.l CCR_D_DISABLE, r0 ! CCR Data mov.l r0, @r1
init_bsc: @@ -77,11 +94,6 @@ init_bsc: mov.l WCR3_D,r0 /* WCR3 Data */ mov.l r0,@r1
- mov.l LED_A,r1 /* LED Address */ - mov #0xff,r0 /* LED ALL 'on' */ - shll8 r0 - mov.w r0,@r1 - mov.l MCR_A,r1 /* MCR Address */ mov.l MCR_D1,r0 /* MCR Data1 */ mov.l r0,@r1 @@ -129,19 +141,19 @@ init_bsc:
.align 2
-L_CCR: .long CCR -L_CCR_DISABLE: .long 0x0808 +CCR_A: .long CCR +CCR_D_DISABLE: .long 0x0808 FRQCR_A: .long FRQCR FRQCR_D: -#ifdef CONFIG_CPU_SUBTYPE_SH_R +#ifdef CONFIG_CPU_TYPE_R .long 0x00000e1a /* 12:3:3 */ -#else +#else /* CONFIG_CPU_TYPE_R */ #ifdef CONFIG_GOOD_SESH4 .long 0x00000e13 /* 6:2:1 */ #else .long 0x00000e23 /* 6:1:1 */ #endif -#endif /* CONFIG_CPU_SUBTYPE_SH_R */ +#endif /* CONFIG_CPU_TYPE_R */
BCR1_A: .long BCR1 BCR1_D: .long 0x00000008 /* Area 3 SDRAM */ @@ -153,7 +165,6 @@ WCR2_A: .long WCR2 WCR2_D: .long WCR2_D_VALUE /* Per-area access and burst wait states */ WCR3_A: .long WCR3 WCR3_D: .long WCR3_D_VALUE /* Address setup and data hold cycles */ -LED_A: .long LED_ADDRESS /* LED Address */ RTCSR_A: .long RTCSR RTCSR_D: .long 0xA518 /* RTCSR Write Code A5h Data 18h */ RTCNT_A: .long RTCNT diff --git a/board/ms7750se/ms7750se.c b/board/ms7750se/ms7750se.c index 4b4697b..1ae9dd1 100644 --- a/board/ms7750se/ms7750se.c +++ b/board/ms7750se/ms7750se.c @@ -26,7 +26,7 @@
int checkboard(void) { - puts("BOARD: SH7750 Solution Engine\n"); + puts("BOARD: SH7750/SH7750S/SH7750R Solution Engine\n"); return 0; }
diff --git a/include/configs/ms7750se.h b/include/configs/ms7750se.h index 0467a5e..7925f20 100644 --- a/include/configs/ms7750se.h +++ b/include/configs/ms7750se.h @@ -1,50 +1,89 @@ -#ifndef __CONFIG_H -#define __CONFIG_H +/* + * Configuation settings for the Hitachi Solution Engine 7750 + * + * Copyright (C) 2007 Nobuhiro Iwamatsu iwamatsu@nigauri.org + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __MS7750SE_H +#define __MS7750SE_H
#undef DEBUG - #define CONFIG_SH 1 #define CONFIG_SH4 1 #define CONFIG_CPU_SH7750 1 +/* #define CONFIG_CPU_SH7751 1 */ +/* #define CONFIG_CPU_TYPE_R 1 */ #define CONFIG_MS7750SE 1 #define __LITTLE_ENDIAN__ 1
-//#define CONFIG_COMMANDS (CONFIG_CMD_DFL | CFG_CMD_NET |CFG_CMD_PING) -#define CONFIG_COMMANDS CONFIG_CMD_DFL & ~CFG_CMD_NET +/* + * Command line configuration. + */ +//#include <config_cmd_default.h> + +#define CONFIG_CMD_DFL +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_ENV
#define CFG_SCIF_CONSOLE 1 #define CONFIG_BAUDRATE 38400 #define CONFIG_CONS_SCIF1 1 #define BOARD_LATE_INIT 1
-#include <cmd_confdefs.h> - #define CONFIG_BOOTDELAY -1 -#define CONFIG_BOOTARGS "console=ttySC0,115200" +#define CONFIG_BOOTARGS "console=ttySC0,38400" #define CONFIG_ENV_OVERWRITE 1
+/* SDRAM */ #define CFG_SDRAM_BASE (0x8C000000) #define CFG_SDRAM_SIZE (64 * 1024 * 1024)
#define CFG_LONGHELP -#define CFG_PROMPT "=> " -#define CFG_CBSIZE 256 -#define CFG_PBSIZE 256 +#define CFG_PROMPT "=> " +#define CFG_CBSIZE 256 +#define CFG_PBSIZE 256 #define CFG_MAXARGS 16 -#define CFG_BARGSIZE 512 -#define CFG_BAUDRATE_TABLE { 115200, 57600, 38400, 19200, 9600 } /* List of legal baudrate settings for this board */ +#define CFG_BARGSIZE 512 +/* List of legal baudrate settings for this board */ +#define CFG_BAUDRATE_TABLE { 115200, 57600, 38400, 19200, 9600 }
#define CFG_MEMTEST_START (CFG_SDRAM_BASE) #define CFG_MEMTEST_END (TEXT_BASE - 0x100000)
+/* NOR Flash */ +/* #define CFG_FLASH_BASE (0xA1000000)*/ +#define CFG_FLASH_BASE (0xA0000000) +#define CFG_MAX_FLASH_BANKS (1) /* Max number of + * Flash memory banks + */ +#define CFG_MAX_FLASH_SECT 142 +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE }
#define CFG_LOAD_ADDR (CFG_SDRAM_BASE + 4 * 1024 * 1024) #define CFG_MONITOR_BASE (CFG_FLASH_BASE) /* Address of u-boot image in Flash */ -#define CFG_MONITOR_LEN (128 * 1024) +#define CFG_MONITOR_LEN (128 * 1024) #define CFG_MALLOC_LEN (256 * 1024) /* Size of DRAM reserved for malloc() use */
#define CFG_GBL_DATA_SIZE (256) /* size in bytes reserved for initial data */ -#define CFG_BOOTMAPSZ (8 * 1024 * 1024) +#define CFG_BOOTMAPSZ (8 * 1024 * 1024) #define CFG_RX_ETH_BUFFER (8)
#define CFG_FLASH_CFI @@ -53,12 +92,6 @@ #undef CFG_FLASH_QUIET_TEST #define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */
-#define CFG_FLASH_BASE (0xA1000000) -#define CFG_MAX_FLASH_BANKS (1) /* Max number of - * Flash memory banks - */ -#define CFG_MAX_FLASH_SECT 142 -#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE }
#define CFG_ENV_IS_IN_FLASH #define CFG_ENV_SECT_SIZE 0x20000 @@ -67,9 +100,9 @@ #define CFG_FLASH_ERASE_TOUT 120000 #define CFG_FLASH_WRITE_TOUT 500
+/* Board Clock */ #define CONFIG_SYS_CLK_FREQ 33333333 #define TMU_CLK_DIVIDER 4 #define CFG_HZ (CONFIG_SYS_CLK_FREQ / TMU_CLK_DIVIDER) -#define CFG_PLL_SETTLING_TIME 100 /* in us */
-#endif /* __CONFIG_H */ +#endif /* __MS7750SE_H */
Nobuhiro Iwamatsu
